摘要
在運(yùn)動控制系統(tǒng)中,電機(jī)轉(zhuǎn)速控制占有至關(guān)重要的作用,其控制算法和手段有很多,模擬PID控制是最早發(fā)展起來的控制策略之一,長期以來形成了典型的結(jié)構(gòu),并且參數(shù)整定方便,能夠滿足一般控制的要求,但由于在模擬PID控制系統(tǒng)中,參數(shù)一旦整定好后,在整個控制過程中都是固定不變的,而在實際中,由于現(xiàn)場的系統(tǒng)參數(shù)、溫度等條件發(fā)生變化,使系統(tǒng)很難達(dá)到最佳的控制效果,因此采用模擬PID控制器難以獲得滿意的控制效果。隨著計算機(jī)技術(shù)與智能控制理論的發(fā)展,數(shù)字PID技術(shù)漸漸發(fā)展起來,它不僅能夠?qū)崿F(xiàn)模擬PID所完成的控制任務(wù),而且具備控制算法靈活、可靠性高等優(yōu)點(diǎn),應(yīng)用面越來越廣。
本設(shè)計以上面提到的數(shù)字PID為基本控制算法,以AT89S51單片機(jī)為控制核心,產(chǎn)生占空比受數(shù)字PID算法控制的PWM脈沖實現(xiàn)對直流電機(jī)轉(zhuǎn)速的控制。同時利用光電傳感器將電機(jī)速度轉(zhuǎn)換成脈沖頻率反饋到單片機(jī)中,實現(xiàn)轉(zhuǎn)速閉環(huán)控制,達(dá)到轉(zhuǎn)速無靜差調(diào)節(jié)的目的。在系統(tǒng)中采數(shù)碼管顯示器作為顯示部件,通過2×2鍵盤設(shè)置P、I、D、V四個參數(shù),啟動后可以通過顯示部件了解電機(jī)當(dāng)前的轉(zhuǎn)速。該系統(tǒng)控制精度高,具有很強(qiáng)的抗干擾能力。
關(guān)鍵詞:數(shù)字PID;PWM脈沖;占空比;無靜差調(diào)節(jié)
Abstract
In the motion control system,the control of electromotor's rotate speed is of great importance,there are a lot of speed control arithmetics and methods ,the analog PID control is one of the earliest developed control policies which has formed typical structure ,its parametric setting is convenient and it's easy to meet normal control's demand,but as the whole control process is fixed once the parameter has been set while practically the changes of those conditions like the system parameters and temperature of the environment prohibit the system from reaching its best control effect,so the analog PID controller barely has satisfied effect.With the development of computer technology and intelligent control theory ,the digital PID technology is thriving which can achieve the analog PID's control tasks and consists of many advantages like flexible control arithmetics and high reliability,it is widely used now.
This design is based on the digital PID mentioned above as basic control arithmetic and AT89S51 SCM as control core,the system produces PWM impulse whose duty ratio is controlled by digital PID arithmetic to make sure the running of direct current machine's rotate speed.Meanwhile,the design uses photoelectric sensor to transduce the electromotor speed into impulse frequency and feed it back to SCM,this process implements rotate speed's closed loop control to attain the purpose of rotate speed's astatic modulation.In this system, the 128×64LCD is used as display unit , the 4×4 keyboard sets those four parameters P、I、D、V and obverse and reverse control,after starting up,the display unit shows the electromotor's current rotate speed and runtime.The system has great control precision and anti-jamming capability.
Keywords: digital PID;PWM impulse;dutyfactor;astatic modulation
前言
21世紀(jì),科學(xué)技術(shù)日新月異,科技的進(jìn)步帶動了控制技術(shù)的發(fā)展,現(xiàn)代控制設(shè)備的性能和結(jié)構(gòu)發(fā)生了翻天覆地的變化。我們已進(jìn)入高速發(fā)展的信息時代,控制技術(shù)成為當(dāng)今科技的主流之一,廣泛深入到研究和應(yīng)用工程等各個領(lǐng)域。
控制理論的發(fā)展經(jīng)歷了古典控制理論、現(xiàn)代控制理論和智能控制理論三個階段。其控制系統(tǒng)包括控制器﹑傳感器﹑變送器﹑執(zhí)行機(jī)構(gòu)﹑輸入輸出接口?刂破鞯妮敵鼋(jīng)過輸出接口﹑執(zhí)行機(jī)構(gòu)、加到被控系統(tǒng)上;控制系統(tǒng)的被控量、經(jīng)過傳感器、變送器、通過輸入接口送到控制器。不同的控制系統(tǒng)、傳感器﹑變送器﹑執(zhí)行機(jī)構(gòu)是不一樣的。比如壓力控制系統(tǒng)要采用壓力傳感器。電加熱控制系統(tǒng)的傳感器是溫度傳感器。目前,PID控制及其控制器或智能PID控制器已經(jīng)很多,產(chǎn)品已在工程實際中得到了廣泛的應(yīng)用。
受益于數(shù)十年來全球經(jīng)濟(jì)高速成長所獲得的PID控制成果,在中國市場,一大批機(jī)器設(shè)備制造商正處于蓬勃發(fā)展階段,除滿足本土市場龐大的機(jī)器設(shè)備需求外,走向國際市場,參與國際競爭也成為現(xiàn)實需求。在應(yīng)用方面,這種控制技術(shù)已經(jīng)滲透到了醫(yī)療、汽車制造、鐵道運(yùn)輸、航天航空、鋼鐵生產(chǎn)、物流配送、飲料生產(chǎn)等多個方面。但是由于中國科技落后,為此,我們需要更進(jìn)一步的學(xué)習(xí)、掌握與應(yīng)用先進(jìn)的控制技術(shù)與解決方案,以提升設(shè)備性能、檔次與市場競爭力。在國外,尤其在運(yùn)動控制及過程控制方面PID控制技術(shù)的應(yīng)用更是越來越廣泛和深入。隨著科技的進(jìn)步,人們對生活舒適性的追求將越來越高,PID控制技術(shù)作為一項具有發(fā)展前景和影響力的新技術(shù),正越來越受到國內(nèi)外各行業(yè)的高度重視。
PID控制器問世至今已有近70年歷史,它以其結(jié)構(gòu)簡單、穩(wěn)定性好、工作可靠、調(diào)整方便而成為工業(yè)控制的主要技術(shù)之一當(dāng)被控對象的結(jié)構(gòu)和參數(shù)不能完全掌握,或得不到精確的數(shù)學(xué)模型時,控制理論的其它技術(shù)難以采用時,系統(tǒng)控制器的結(jié)構(gòu)和參數(shù)必須依靠經(jīng)驗和現(xiàn)場調(diào)試來確定,這時應(yīng)用PID控制技術(shù)最為方便。即當(dāng)我們不完全了解一個系統(tǒng)和被控對象,或不能通過有效的測量手段來獲得系統(tǒng)參數(shù)時,最適合用PID控制技術(shù)。實際中也有PI和PD控制。PID控制器就是根據(jù)偏差的比例、積分、微分進(jìn)行控制的。比例控制是一種最簡單的控制方式。其控制器的輸出與輸入誤差信號成比例關(guān)系。當(dāng)僅有比例控制時系統(tǒng)輸出存在穩(wěn)態(tài)誤差(Steady-state error)。在積分控制中,控制器的輸出與輸入偏差信號的積分成正比關(guān)系。對一個自動控制系統(tǒng),如果在進(jìn)入穩(wěn)態(tài)后存在穩(wěn)態(tài)誤差,則稱這個控制系統(tǒng)是有穩(wěn)態(tài)誤差的或簡稱有差系統(tǒng)(System with Steady-state Error)。為了消除穩(wěn)態(tài)誤差,在控制器中必須引入“積分項”。積分項對誤差取決于時間的積分,隨著時間的增加,積分項會增大。這樣,即便誤差很小,積分項也會隨著時間的增加而加大,它推動控制器的輸出增大使穩(wěn)態(tài)誤差進(jìn)一步減小,直到等于零。因此,比例+積分(PI)控制器,可以使系統(tǒng)在進(jìn)入穩(wěn)態(tài)后無穩(wěn)態(tài)誤差。在微分控制中,控制器的輸出與輸入誤差信號的微分(即誤差的變化率)成正比關(guān)系。能反映偏差信號的變化趨勢(變化速率),并能在偏差信號的值變得太大之前,在系統(tǒng)中引入一個有效的早期修正信號,從而加快系統(tǒng)的動作速度,減少調(diào)節(jié)時間。因此在運(yùn)動控制系統(tǒng)中PID控制技術(shù)應(yīng)用更為廣泛,是機(jī)器人等高技術(shù)領(lǐng)域的技術(shù)基礎(chǔ),它可以對運(yùn)動部件的位置、速度等進(jìn)行實時控制管理,使其符合相應(yīng)的控制要求。被廣泛應(yīng)用于汽車制造、醫(yī)療、鐵道運(yùn)輸、航天航空、鋼鐵生產(chǎn)等領(lǐng)域,并受到各行各業(yè)地重視。其中電機(jī)速度的控制在運(yùn)動控制理論中占有至關(guān)重要的作用,本設(shè)計主要應(yīng)用數(shù)字PID算法,利用PWM調(diào)制技術(shù)實現(xiàn)電機(jī)轉(zhuǎn)速的控制。隨著社會的發(fā)展用戶對其性能提出了越來越高的要求,借助于數(shù)字和網(wǎng)絡(luò)技術(shù)的智能控制已經(jīng)深入到運(yùn)動控制系統(tǒng)的各個方面,各種新技術(shù)的應(yīng)用也大大提高了運(yùn)動控制系統(tǒng)的性能,高頻化、交流化和網(wǎng)絡(luò)化成為今后的發(fā)展方向。
本次設(shè)計主要研究的是PID控制技術(shù)在運(yùn)動控制領(lǐng)域中的應(yīng)用,縱所周知運(yùn)動控制系統(tǒng)最主要的控制對象是電機(jī),在不同的生產(chǎn)過程中,電機(jī)的運(yùn)行狀態(tài)要滿足生產(chǎn)要求,其中電機(jī)速度的控制在占有至關(guān)重要的作用,因此本次設(shè)計主要是利用PID控制技術(shù)對直流電機(jī)轉(zhuǎn)速的控制。其設(shè)計思路為:以AT89S51單片機(jī)為控制核心,產(chǎn)生占空比受PID算法控制的PWM脈沖實現(xiàn)對直流電機(jī)轉(zhuǎn)速的控制。同時利用光電傳感器將電機(jī)速度轉(zhuǎn)換成脈沖頻率反饋到單片機(jī)中,構(gòu)成轉(zhuǎn)速閉環(huán)控制系統(tǒng),達(dá)到轉(zhuǎn)速無靜差調(diào)節(jié)的目的。在系統(tǒng)中采128×64LCD顯示器作為顯示部件,通過4×4鍵盤設(shè)置P、I、D、V四個參數(shù)和正反轉(zhuǎn)控制,啟動后通過顯示部件了解電機(jī)當(dāng)前的轉(zhuǎn)速和運(yùn)行時間。因此該系統(tǒng)在硬件方面包括:電源模塊、電機(jī)驅(qū)動模塊、控制模塊、速度檢測模塊、人機(jī)交互模塊。軟件部分采用C語言進(jìn)行程序設(shè)計,其優(yōu)點(diǎn)為:可移植性強(qiáng)、算法容易實現(xiàn)、修改及調(diào)試方便、易讀等。
本次設(shè)計系統(tǒng)的主要特點(diǎn):
(1)優(yōu)化的軟件算法,智能化的自動控制,誤差補(bǔ)償;
(2)使用光電傳感器將電機(jī)轉(zhuǎn)速轉(zhuǎn)換為脈沖頻率,比較精確的反映出電機(jī)的轉(zhuǎn)速,從而與設(shè)定值進(jìn)行比較產(chǎn)生偏差,實現(xiàn)比例、積分、微分的控制,達(dá)到轉(zhuǎn)速無靜差調(diào)節(jié)的目的;
(3)使用光電耦合器將主電路和控制電路利用光隔開,使系統(tǒng)更加安全可靠;
(4)128×64LCD顯示模塊提供一個人機(jī)對話界面,并實時顯示電機(jī)運(yùn)行速度和運(yùn)行時間;
(5)利用Proteus軟件進(jìn)行系統(tǒng)整體仿真,從而進(jìn)一步驗證電路和程序的正確性,避免不必要的損失;
(6)采用數(shù)字PID算法,利用軟件實現(xiàn)控制,具有更改靈活,節(jié)約硬件等優(yōu)點(diǎn);
(7)系統(tǒng)性能指標(biāo):超調(diào)量 8%;
調(diào)節(jié)時間 4s;
轉(zhuǎn)速誤差 1r/min。
1 PID算法及PWM控制技術(shù)簡介
1.1 PID算法
控制算法是微機(jī)化控制系統(tǒng)的一個重要組成部分,整個系統(tǒng)的控制功能主要由控制算法來實現(xiàn)。目前提出的控制算法有很多。根據(jù)偏差的比例(P)、積分(I)、微分(D)進(jìn)行的控制,稱為PID控制。實際經(jīng)驗和理論分析都表明,PID控制能夠滿足相當(dāng)多工業(yè)對象的控制要求,至今仍是一種應(yīng)用最為廣泛的控制算法之一。下面分別介紹模擬PID、數(shù)字PID及其參數(shù)整定方法。
1.1.1 模擬PID
在模擬控制系統(tǒng)中,調(diào)節(jié)器最常用的控制規(guī)律是PID控制,常規(guī)PID控制系統(tǒng)原理框圖如圖1.1所示,系統(tǒng)由模擬PID調(diào)節(jié)器、執(zhí)行機(jī)構(gòu)及控制對象組成。
圖1.1 模擬PID控制系統(tǒng)原理框圖
PID調(diào)節(jié)器是一種線性調(diào)節(jié)器,它根據(jù)給定值 與實際輸出值 構(gòu)成的控制偏差: = - (1.1)
將偏差的比例、積分、微分通過線性組合構(gòu)成控制量,對控制對象進(jìn)行控制,故稱為PID調(diào)節(jié)器。在實際應(yīng)用中,常根據(jù)對象的特征和控制要求,將P、I、D基本控制規(guī)律進(jìn)行適當(dāng)組合,以達(dá)到對被控對象進(jìn)行有效控制的目的。例如,P調(diào)節(jié)器,PI調(diào)節(jié)器,PID調(diào)節(jié)器等。
模擬PID調(diào)節(jié)器的控制規(guī)律為
(1.2)
式中, 為比例系數(shù), 為積分時間常數(shù), 為微分時間常數(shù)。
簡單的說,PID調(diào)節(jié)器各校正環(huán)節(jié)的作用是:
(1)比例環(huán)節(jié):即時成比例地反應(yīng)控制系統(tǒng)的偏差信號 ,偏差一旦產(chǎn)生,調(diào)節(jié)器立即產(chǎn)生控制作用以減少偏差;
(2)積分環(huán)節(jié):主要用于消除靜差,提高系統(tǒng)的無差度。積分作用的強(qiáng)弱取決于積分時間常數(shù) , 越大,積分作用越弱,反之則越強(qiáng);
(3)微分環(huán)節(jié):能反映偏差信號的變化趨勢(變化速率),并能在偏差信號的值變得太大之前,在系統(tǒng)中引入一個有效的早期修正信號,從而加快系統(tǒng)的動作速度,減少調(diào)節(jié)時間。
由式1.2可得,模擬PID調(diào)節(jié)器的傳遞函數(shù)為
(1.3)
由于本設(shè)計主要采用數(shù)字PID算法,所以對于模擬PID只做此簡要介紹。
1.1.2 數(shù)字PID
在DDC系統(tǒng)中,用計算機(jī)取代了模擬器件,控制規(guī)律的實現(xiàn)是由計算機(jī)軟件來完成的。因此,系統(tǒng)中數(shù)字控制的設(shè)計,實際上是計算機(jī)算法的設(shè)計。
由于計算機(jī)只能識別數(shù)字量,不能對連續(xù)的控制算式直接進(jìn)行運(yùn)算,故在計算機(jī)控制系統(tǒng)中,首先必須對控制規(guī)律進(jìn)行離散化的算法設(shè)計。
為將模擬PID控制規(guī)律按式(1.2)離散化,我們把圖1.1中 、 、 、 在第n次采樣的數(shù)據(jù)分別用 、 、 、 表示,于是式(1.1)變?yōu)?:
= - (1.4)
當(dāng)采樣周期T很小時 可以用T近似代替, 可用 近似代替,“積分”用“求和”近似代替,即可作如下近似
(1.5)
(1.6)
這樣,式(1.2)便可離散化以下差分方程
(1.7)
上式中 是偏差為零時的初值,上式中的第一項起比例控制作用,稱為比例(P)項 ,即
(1.8)
第二項起積分控制作用,稱為積分(I)項 即
(1.9)
第三項起微分控制作用,稱為微分(D)項 即
(1.10)
這三種作用可單獨(dú)使用(微分作用一般不單獨(dú)使用)或合并使用,常用的組合有:
P控制: (1.11)
PI控制: (1.12)
PD控制: (1.13)
PID控制: (1.14)
式(1.7)的輸出量 為全量輸出,它對于被控對象的執(zhí)行機(jī)構(gòu)每次采樣時刻應(yīng)達(dá)到的位置。因此,式(1.7)又稱為位置型PID算式。
由(1.7)可看出,位置型控制算式不夠方便,這是因為要累加偏差 ,不僅要占用較多的存儲單元,而且不便于編寫程序,為此對式(1.7)進(jìn)行改進(jìn)。
根據(jù)式(1.7)不難看出u(n-1)的表達(dá)式,即
(1.15)
將式(1.7)和式(1.15)相減,即得數(shù)字PID增量型控制算式為
(1.16)
從上式可得數(shù)字PID位置型?控制算式為
(1.17)
式中: 稱為比例增益;
稱為積分系數(shù);
稱為微分系數(shù)[1]。
數(shù)字PID位置型示意圖和數(shù)字PID增量型示意圖分別如圖1.2和1.3所示:
圖1.2 數(shù)字PID位置型控制示意圖
圖1.3 數(shù)字PID增量型控制示意圖
1.1.3 數(shù)字PID參數(shù)整定方法
如何選擇控制算法的參數(shù),要根據(jù)具體過程的要求來考慮。一般來說,要求被控過程是穩(wěn)定的,能迅速和準(zhǔn)確地跟蹤給定值的變化,超調(diào)量小,在不同干擾下系統(tǒng)輸出應(yīng)能保持在給定值,操作變量不宜過大,在系統(tǒng)和環(huán)境參數(shù)發(fā)生變化時控制應(yīng)保持穩(wěn)定。顯然,要同時滿足上述各項要求是很困難的,必須根據(jù)具體過程的要求,滿足主要方面,并兼顧其它方面。
PID調(diào)節(jié)器的參數(shù)整定方法有很多,但可歸結(jié)為理論計算法和工程整定法兩種。用理論計算法設(shè)計調(diào)節(jié)器的前提是能獲得被控對象準(zhǔn)確的數(shù)學(xué)模型,這在工業(yè)過程中一般較難做到。因此,實際用得較多的還是工程整定法。這種方法最大優(yōu)點(diǎn)就是整定參數(shù)時不依賴對象的數(shù)學(xué)模型,簡單易行。當(dāng)然,這是一種近似的方法,有時可能略嫌粗糙,但相當(dāng)適用,可解決一般實際問題。下面介紹兩種常用的簡易工程整定法。
(1)擴(kuò)充臨界比例度法
這種方法適用于有自平衡特性的被控對象。使用這種方法整定數(shù)字調(diào)節(jié)器參數(shù)的步驟是:
①選擇一個足夠小的采樣周期,具體地說就是選擇采樣周期為被控對象純滯后時間的十分之一以下。
②用選定的采樣周期使系統(tǒng)工作:工作時,去掉積分作用和微分作用,使調(diào)節(jié)器成為純比例調(diào)節(jié)器,逐漸減小比例度 ( )直至系統(tǒng)對階躍輸入的響應(yīng)達(dá)到臨界振蕩狀態(tài),記下此時的臨界比例度 及系統(tǒng)的臨界振蕩周期 。
③選擇控制度:所謂控制度就是以模擬調(diào)節(jié)器為基準(zhǔn),將DDC的控制效果與模擬調(diào)節(jié)器的控制效果相比較。控制效果的評價函數(shù)通常用誤差平方面積 表示。
控制度= (1.18)
實際應(yīng)用中并不需要計算出兩個誤差平方面積,控制度僅表示控制效果的物理
概念。通常,當(dāng)控制度為1.05時,就可以認(rèn)為DDC與模擬控制效果相當(dāng);當(dāng)控制度為2.0時,DDC比模擬控制效果差。
④根據(jù)選定的控制度,查表1.1求得T、 、 、 的值[1]。
表1.1 擴(kuò)充臨界比例度法整定參數(shù)
控制度 控制規(guī)律 T
1.05 PI 0.03
0.53
0.88
1.05 PID 0.014
0.63
0.49
0.14
1.20 PI 0.05
0.49
0.91
1.20 PID 0.043
0.047
0.47
0.16
1.50 PI 0.14
0.42
0.99
1.50 PID 0.09
0.34
0.43
0.20
2.00 PI 0.22
0.36
1.05
2.00 PID 0.16
0.27
0.40
0.22
(2)經(jīng)驗法
經(jīng)驗法是靠工作人員的經(jīng)驗及對工藝的熟悉程度,參考測量值跟蹤與設(shè)定值曲
線,來調(diào)整P、I、D三者參數(shù)的大小的,具體操作可按以下口訣進(jìn)行:
參數(shù)整定找最佳,從小到大順序查;
先是比例后積分,最后再把微分加;
曲線振蕩很頻繁,比例度盤要放大;
曲線漂浮繞大灣,比例度盤往小扳;
曲線偏離回復(fù)慢,積分時間往下降;
曲線波動周期長,積分時間再加長;
曲線振蕩頻率快,先把微分降下來;
動差大來波動慢,微分時間應(yīng)加長。
下面以PID調(diào)節(jié)器為例,具體說明經(jīng)驗法的整定步驟:
①讓調(diào)節(jié)器參數(shù)積分系數(shù) =0,實際微分系數(shù) =0,控制系統(tǒng)投入閉環(huán)運(yùn)行,由小到大改變比例系數(shù) ,讓擾動信號作階躍變化,觀察控制過程,直到獲得滿意的控制過程為止。
②取比例系數(shù) 為當(dāng)前的值乘以0.83,由小到大增加積分系數(shù) ,同樣讓擾動信號作階躍變化,直至求得滿意的控制過程。
③積分系數(shù) 保持不變,改變比例系數(shù) ,觀察控制過程有無改善,如有改善則繼續(xù)調(diào)整,直到滿意為止。否則,將原比例系數(shù) 增大一些,再調(diào)整積分系數(shù) ,力求改善控制過程。如此反復(fù)試湊,直到找到滿意的比例系數(shù) 和積分系數(shù) 為止。
④引入適當(dāng)?shù)膶嶋H微分系數(shù) 和實際微分時間 ,此時可適當(dāng)增大比例系數(shù) 和積分系數(shù) 。和前述步驟相同,微分時間的整定也需反復(fù)調(diào)整,直到控制過程滿意為止。
PID參數(shù)是根據(jù)控制對象的慣量來確定的。大慣量如:大烘房的溫度控制,一般P可在10以上,I在(3、10)之間,D在1左右。小慣量如:一個小電機(jī)閉環(huán)控制,一般P在(1、10)之間,I在(0、5)之間,D在(0.1、1)之間,具體參數(shù)要在現(xiàn)場調(diào)試時進(jìn)行修正。
1.2 PWM脈沖控制技術(shù)
PWM(Pulse Width Modulation)控制就是對脈沖的寬度進(jìn)行調(diào)制的技術(shù)。即通過對一系列脈沖的寬度進(jìn)行調(diào)制,來等效地獲得所需要波形(含形狀和幅值)。
1.2.1 PWM控制的基本原理
在采樣控制理論中有一個重要的結(jié)論:沖量相等而形狀不同的窄脈沖加在具有慣性的環(huán)節(jié)上時,其效果基本相同。沖量即指窄脈沖的面積。這里所說的效果基本相同,是指環(huán)節(jié)的輸出響應(yīng)波形基本相同。如果把各輸出波形用傅立葉變換分析,則其低頻段非常接近,僅在高頻段略有差異。例如圖1.4中a、b、c所示的三個窄脈沖形狀不同,其中圖1.4的a為矩形脈沖,圖1.4的b為三角脈沖,圖1.4的c為正弦半波脈沖,但它們的面積(即沖量)都等于1,那么,當(dāng)它們分別加在具有慣性的同一環(huán)節(jié)上時,其輸出響應(yīng)基本相同。當(dāng)窄脈沖變?yōu)槿鐖D1.4的d所示的單位脈沖函數(shù) 時,環(huán)節(jié)的響應(yīng)即為該環(huán)節(jié)的脈沖過渡函數(shù)。
圖1.4 形狀不同而沖量相同的各種窄脈沖
圖1.5a的電路是一個具體的例子。圖中 為窄脈沖,其形狀和面積分別如圖1.4的a、b、c、d所示,為電路的輸入。該輸入加在可以看成慣性環(huán)節(jié)的R-L電路上,設(shè)其電流 為電路的輸出。圖1.5b給出了不同窄波時 的響應(yīng)波形。從波形可以看出,在 的上升段,脈沖形狀不同時 的形狀也略有不同,但其下降段幾乎完全相同。脈沖越窄,各 波形的差異也越小。如果周期性的施加上述脈沖,則響應(yīng) 也是周期性的。用傅立葉級數(shù)分解后將可看出,各 在低頻段的特性非常接近,僅在高頻段有所不同[2]。
圖1.5 沖量相同的各種窄脈沖的響應(yīng)波形
1.2.2 直流電機(jī)的PWM控制技術(shù)
直流電動機(jī)具有優(yōu)良的調(diào)速特性,調(diào)速平滑、方便,調(diào)速范圍廣,過載能力大,能承受頻繁的沖擊負(fù)載,可實現(xiàn)頻繁的無級快速起動、制動和反轉(zhuǎn);能滿足生產(chǎn)過程自動化系統(tǒng)各種不同的特殊運(yùn)行要求,在許多需要調(diào)速或快速正反向的電力拖動系統(tǒng)領(lǐng)域中得到了廣泛的應(yīng)用。
直流電動機(jī)的轉(zhuǎn)速調(diào)節(jié)主要有三種方法:調(diào)節(jié)電樞供電的電壓、減弱勵磁磁通和改變電樞回路電阻。針對三種調(diào)速方法,都有各自的特點(diǎn),也存在一定的缺陷。例如改變電樞回路電阻調(diào)速只能實現(xiàn)有級調(diào)速,減弱磁通雖然能夠平滑調(diào)速,但這種方法的調(diào)速范圍不大,一般都是配合變壓調(diào)速使用。所以在直流調(diào)速系統(tǒng)中,都是以變壓調(diào)速為主。其中,在變壓調(diào)速系統(tǒng)中,大體上又可分為可控整流式調(diào)速系統(tǒng)和直流PWM調(diào)速系統(tǒng)兩種。直流PWM調(diào)速系統(tǒng)與可控整流式調(diào)速系統(tǒng)相比有下列優(yōu)點(diǎn):由于PWM調(diào)速系統(tǒng)的開關(guān)頻率較高,僅靠電樞電感的濾波作用就可獲得平穩(wěn)的直流電流,低速特性好、穩(wěn)速精度高、調(diào)速范圍寬。同樣,由于開關(guān)頻率高,快速響應(yīng)特性好,動態(tài)抗干擾能力強(qiáng),可以獲得很寬的頻帶;開關(guān)器件只工作在開關(guān)狀態(tài),因此主電路損耗小、裝置效率高;直流電源采用不可控整流時,電網(wǎng)功率因數(shù)比相控整流器高。正因為直流PWM調(diào)速系統(tǒng)有以上優(yōu)點(diǎn),并且隨著電力電子器件開關(guān)性能的不斷提高,直流脈寬調(diào)制( PWM) 技術(shù)得到了飛速的發(fā)展。
隨著科學(xué)技術(shù)的迅猛發(fā)展傳統(tǒng)的模擬和數(shù)字電路已被大規(guī)模集成電路所取代,這就使得數(shù)字調(diào)制技術(shù)成為可能。目前,在該領(lǐng)域中大部分應(yīng)用的是數(shù)字脈寬調(diào)制技術(shù)。電動機(jī)調(diào)速系統(tǒng)采用微機(jī)實現(xiàn)數(shù)字化控制,是電氣傳動發(fā)展的主要方向之一。采用微機(jī)控制后,整個調(diào)速系統(tǒng)實現(xiàn)全數(shù)字化,并且結(jié)構(gòu)簡單、可靠性高、操作維護(hù)方便,電動機(jī)穩(wěn)態(tài)運(yùn)轉(zhuǎn)時轉(zhuǎn)速精度可達(dá)到較高水平,靜動態(tài)各項指標(biāo)均能較好地滿足工業(yè)生產(chǎn)中高性能電氣傳動的要求。下面主要介紹直流電機(jī)PWM調(diào)速系統(tǒng)的算法實現(xiàn)。
根據(jù)PWM控制的基本原理可知,一段時間內(nèi)加在慣性負(fù)載兩端的PWM脈沖與相等時間內(nèi)沖量相等的直流電加在負(fù)載上的電壓等效,那么如果在短時間T內(nèi)脈沖寬度為 ,幅值為U,由圖1.6可求得此時間內(nèi)脈沖的等效直流電壓為:
圖1.6 PWM脈沖
,若令 , 即為占空比,則上式可化為:
(U為脈沖幅值) (1.19)
若PWM脈沖為如圖1.7所示周期性矩形脈沖,那么與此脈沖等效的直流電壓的計算方法與上述相同,即
( 為矩形脈沖占空比) (1.20)
圖1.7 周期性PWM矩形脈沖
由式1.20可知,要改變等效直流電壓的大小,可以通過改變脈沖幅值U和占空比 來實現(xiàn),因為在實際系統(tǒng)設(shè)計中脈沖幅值一般是恒定的,所以通常通過控制占空比 的大小實現(xiàn)等效直流電壓在0~U之間任意調(diào)節(jié),從而達(dá)到利用PWM控制技術(shù)實現(xiàn)對直流電機(jī)轉(zhuǎn)速進(jìn)行調(diào)節(jié)的目的。
2 設(shè)計方案與論證
2.1 系統(tǒng)設(shè)計方案
根據(jù)系統(tǒng)設(shè)計的任務(wù)和要求,設(shè)計系統(tǒng)方框圖如圖2.1所示。圖中控制器模塊為系統(tǒng)的核心部件,鍵盤和顯示器用來實現(xiàn)人機(jī)交互功能,其中通過鍵盤將需要設(shè)置的參數(shù)和狀態(tài)輸入到單片機(jī)中,并且通過控制器顯示到顯示器上。在運(yùn)行過程中控制器產(chǎn)生PWM脈沖送到電機(jī)驅(qū)動電路中,經(jīng)過放大后控制直流電機(jī)轉(zhuǎn)速,同時利用速度檢測模塊將當(dāng)前轉(zhuǎn)速反饋到控制器中,控制器經(jīng)過數(shù)字PID運(yùn)算后改變PWM脈沖的占空比,實現(xiàn)電機(jī)轉(zhuǎn)速實時控制的目的。
圖2.1 系統(tǒng)方案框圖
2.2 控制器模塊設(shè)計方案
根據(jù)設(shè)計任務(wù),控制器主要用于產(chǎn)生占空比受數(shù)字PID算法控制的PWM脈沖,并對電機(jī)當(dāng)前速度進(jìn)行采集處理,根據(jù)算法得出當(dāng)前所需輸出的占空比脈沖。對于控制器的選擇有以下三種方案。
方案一:采用FPGA(現(xiàn)場可編輯門列陣)作為系統(tǒng)的控制器,F(xiàn)PGA可以實現(xiàn)各種復(fù)雜的邏輯功能[3],模塊大,密度高,它將所有器件集成在一塊芯片上,減少了體積,提高了穩(wěn)定性,并且可應(yīng)用EDA軟件仿真、調(diào)試,易于進(jìn)行功能控制。FPGA采用并行的輸入輸出方式,提高了系統(tǒng)的處理速度,適合作為大規(guī)模實時系統(tǒng)的控制核心。通過輸入模塊將參數(shù)輸入給FPGA,F(xiàn)PGA通過程序設(shè)計控制PWM脈沖的占空比,但是由于本次設(shè)計對數(shù)據(jù)處理的時間要求不高,F(xiàn)PGA的高速處理的優(yōu)勢得不到充分體現(xiàn),并且由于其集成度高,使其成本偏高,同時由于芯片的引腳較多,實物硬件電路板布線復(fù)雜,加重了電路設(shè)計和實際焊接的工作。
方案二:采用AT89S51作為系統(tǒng)控制的方案。AT89S51單片機(jī)算術(shù)運(yùn)算功能強(qiáng),軟件編程靈活、自由度大,可用軟件編程實現(xiàn)各種算法和邏輯控制[4]。相對于FPGA來說,它的芯片引腳少,在硬件很容易實現(xiàn)。并且它還具有功耗低、體積小、技術(shù)成熟和成本低等優(yōu)點(diǎn),在各個領(lǐng)域中應(yīng)用廣泛。
方案三:采用傳統(tǒng)的AT89C51單片機(jī)作為運(yùn)動物體的控制中心。它和AT89S51一樣都具有軟件編程靈活、體積小、成本低,使用簡單等特點(diǎn),但是它的頻率較低、運(yùn)算速度慢, RAM、ROM空間小等缺點(diǎn)。本題目在確定圓周坐標(biāo)值時?,需要進(jìn)行大量的運(yùn)算。若采用89C51需要做RAM,ROM來擴(kuò)展其內(nèi)存空間,其硬件工作量必然大大增多。
綜合上述三種方案比較,采用AT89S51作為控制器處理輸入的數(shù)據(jù)并控制電機(jī)運(yùn)動較為簡單,可以滿足設(shè)計要求。因此在本次設(shè)計選用方案二。
2.3 電機(jī)驅(qū)動模塊設(shè)計方案
本次設(shè)計的主要目的是控制電機(jī)的轉(zhuǎn)速,因此電機(jī)驅(qū)動模塊是必不可少,其方案有一下兩種。
方案一:采用大功率晶體管組合電路構(gòu)成驅(qū)動電路,這種方法結(jié)構(gòu)簡單,成本低、易實現(xiàn),但由于在驅(qū)動電路中采用了大量的晶體管相互連接,使得電路復(fù)雜、抗干擾能力差、可靠性下降,我們知道在實際的生產(chǎn)實踐過程中可靠性是一個非常重要的方面。因此此中方案不宜采用。
方案二:采用專用的電機(jī)驅(qū)動芯片,例如L298N、L297N等電機(jī)驅(qū)動芯片,由于它內(nèi)部已經(jīng)考慮到了電路的抗干擾能力,安全、可靠行,所以我們在應(yīng)用時只需考慮到芯片的硬件連接、驅(qū)動能力等問題就可以了,所以此種方案的電路設(shè)計簡單、抗干擾能力強(qiáng)、可靠性好。設(shè)計者不需要對硬件電路設(shè)計考慮很多,可將重點(diǎn)放在算法實現(xiàn)和軟件設(shè)計中,大大的提高了工作效率。
基于上述理論分析和實際情況,電機(jī)驅(qū)動模塊選用方案二。
2.4 速度采集模塊設(shè)計方案
本系統(tǒng)是一閉環(huán)控制系統(tǒng),在調(diào)節(jié)過程中需要將設(shè)定與當(dāng)前實際轉(zhuǎn)速進(jìn)行比較,速度采集模塊就是為完成這樣功能而設(shè)計的,其設(shè)計方案以下三種:
方案一:采用霍爾集成片。該器件內(nèi)部由三片霍爾金屬板組成。當(dāng)磁鐵正對金屬板時,由于霍爾效應(yīng),金屬板發(fā)生橫向?qū)╗5],因此可以在電機(jī)上安裝磁片,而將霍爾集成片安裝在固定軸上,通過對脈沖的計數(shù)進(jìn)行電機(jī)速度的檢測。
方案二:采用對射式光電傳感器。其檢測方式為:發(fā)射器和接受器相互對射安裝,發(fā)射器的光直接對準(zhǔn)接受器,當(dāng)測物擋住光束時,傳感器輸出產(chǎn)生變化以指示被測物被檢測到。通過脈沖計數(shù),對速度進(jìn)行測量。
方案三:采用測速發(fā)電機(jī)對直流電機(jī)轉(zhuǎn)速進(jìn)行測量。該方案的實現(xiàn)原理是將測速發(fā)電機(jī)固定在直流電機(jī)的軸上,當(dāng)直流電機(jī)轉(zhuǎn)動時,帶動測速電機(jī)的軸一起轉(zhuǎn)動,因此測速發(fā)電機(jī)會產(chǎn)生大小隨直流電機(jī)轉(zhuǎn)速大小變化的感應(yīng)電動勢,因此精度比較高,但由于該方案的安裝比較復(fù)雜、成本也比較高,在本次設(shè)計沒有采用此方案。
以上三種方案中,第三種方案不宜采用,第一種和第二種方案的測速原理基本相同都是將電機(jī)轉(zhuǎn)速轉(zhuǎn)換為電脈沖的頻率進(jìn)行測量,但考慮到市場中的霍爾元件比較難買,而且成本也比較高,所以綜合考慮在設(shè)計中選用第二種方案進(jìn)行設(shè)計。
2.5 顯示模塊設(shè)計方案
在電機(jī)轉(zhuǎn)速控制系統(tǒng)中,系統(tǒng)需要對參數(shù)、工作方式以及電機(jī)當(dāng)前運(yùn)行狀態(tài)的顯示,因此在整個系統(tǒng)中必須設(shè)計一個顯示模塊,考慮有三種方案:
方案一:使用七段數(shù)碼管(LED)顯示。數(shù)碼管具有亮度高、工作電壓低、功耗小、易于集成、驅(qū)動簡單、耐沖擊且性能穩(wěn)定等特點(diǎn),并且它可采用BCD編碼顯示數(shù)字,編程容易,硬件電路調(diào)試簡單。但由于在此次設(shè)計中需要設(shè)定的參數(shù)種類多,而且有些需要進(jìn)行漢字和字符的顯示,所以使用LED顯示器不能完成設(shè)計任務(wù),不宜采用。
方案二:采用1602LCD液晶顯示器,該顯示器控制方法簡單,功率低、硬件電路簡單、可對字符進(jìn)行顯示,但考慮到1602LCD液晶顯示器的屏幕小,不能顯示漢字,因此對于需要顯示大量參數(shù)的系統(tǒng)來說不宜采用。
方案三:采用128×64LCD液晶顯示器,該顯示器功率低,驅(qū)動方法和硬件連接電路較上面兩種方案復(fù)雜,顯示屏幕大、可對漢字和字符進(jìn)行顯示。
根據(jù)本次設(shè)計的設(shè)計要求,顯示模塊選用方案三。
2.6 鍵盤模塊設(shè)計方案
在電機(jī)轉(zhuǎn)速控制系統(tǒng)中,系統(tǒng)需要按鍵進(jìn)行參數(shù)的輸入、工作方式的設(shè)定以及電機(jī)起停的控制,因此鍵盤在整個系統(tǒng)中是不可缺少的一部分,考慮有二種方案:
方案一:采用獨(dú)立式鍵盤,這種鍵盤硬件連接和軟件實現(xiàn)簡單,并且各按鍵相互獨(dú)立,每個按鍵均有一端接地,另一端接到輸入線上。按鍵的工作狀態(tài)不會影響其它按鍵上的輸入狀態(tài)。但是由于獨(dú)立式鍵盤每個按鍵需要占用一根輸入口線,所以在按鍵數(shù)量較多時,I/O口浪費(fèi)大,故此鍵盤只適用于按鍵較少或操作速度較高的場合。
方案二:采用行列式鍵盤,這種鍵盤的特點(diǎn)是行線、列線分別接輸入線、輸出線。按鍵設(shè)置在行、列線的交叉點(diǎn)上,利用這種矩陣結(jié)構(gòu)只需m根行線和n根列線就可組成 個按鍵的鍵盤,因此矩陣式鍵盤適用于按鍵數(shù)量較多的場合。但此種鍵盤的軟件結(jié)構(gòu)較為復(fù)雜[6]。
根據(jù)上面兩種方案的論述,由于本次設(shè)計的系統(tǒng)硬件連接比較復(fù)雜,對軟件的運(yùn)行速度要求不高,所以采用方案二矩陣式鍵盤進(jìn)行設(shè)計。
2.7 電源模塊設(shè)計方案
電源是任何系統(tǒng)能否運(yùn)行的能量來源,無論那種電力系統(tǒng)電源模塊都是不可或缺的,對于該模塊考慮一下兩種方案。
方案一:通過電阻分壓的形式將整流后的電壓分別降為控制芯片和電機(jī)運(yùn)行所需的電壓,此種方案原理和硬件電路連接都比較簡單,但對能量的損耗大,在實際應(yīng)用系統(tǒng)同一般不宜采用。
方案二:通過固定芯片對整流后的電壓進(jìn)行降壓、穩(wěn)壓處理(如7812、7805等),此種方案可靠性、安全性高,對能源的利用率高,并且電路簡單容易實現(xiàn)。
根據(jù)系統(tǒng)的具體要求,采用方案二作為系統(tǒng)的供電模塊。
經(jīng)過上述的分析與論證,系統(tǒng)各模塊采用的方案如下:
(1)控制模塊: 采用AT89S51單片機(jī);
(2)電機(jī)驅(qū)動模塊:采用直流電機(jī)驅(qū)動芯片L298N實現(xiàn);
(3)速度采集模塊:采用光電傳感器;
(4)顯示模塊: 采用128×64LCD液晶顯示模塊;
(5)鍵盤模塊: 采用標(biāo)準(zhǔn)的4×4矩陣式鍵盤;
(6)電源模塊: 采用7805、7812芯片實現(xiàn)。
3 單元電路設(shè)計
3.1 硬件資源分配
本系統(tǒng)電路連接及硬件資源分配見圖3.1所示。采用AT89S51單片機(jī)作為核心器件,轉(zhuǎn)速檢測模塊作為電機(jī)轉(zhuǎn)速測量裝置,通過AT89S51的P3.3口將電脈沖信號送入單片機(jī)處理,L298作為直流電機(jī)的驅(qū)動模塊,利用128×64LCD顯示器和4×4鍵盤作為人機(jī)接口。
圖3.1 系統(tǒng)電路連接及硬件資源分配圖
3.2 電源電路設(shè)計
電源是整個系統(tǒng)的能量來源,它直接關(guān)系到系統(tǒng)能否運(yùn)行。在本系統(tǒng)中直流電機(jī)需要12V電源,而單片機(jī)、顯示模塊等其它電路需要5V的電源,因此電路中選用7805和7812兩種穩(wěn)壓芯片,其最大輸出電流為1.5A,能夠滿足系統(tǒng)的要求,其電路如圖3.2所示。
圖3.2 電源電路
3.3 電機(jī)驅(qū)動電路設(shè)計
驅(qū)動模塊是控制器與執(zhí)行器之間的橋梁,在本系統(tǒng)中單片機(jī)的I/O口不能直接驅(qū)動電機(jī),只有引入電機(jī)驅(qū)動模塊才能保證電機(jī)按照控制要求運(yùn)行,在這里選用L298N電機(jī)驅(qū)動芯片驅(qū)動電機(jī),該芯片是由四個大功率晶體管組成的H橋電路構(gòu)成,四個晶體管分為兩組,交替導(dǎo)通和截止,用單片機(jī)控制達(dá)林頓管使之工作在開關(guān)狀態(tài),通過調(diào)整輸入脈沖的占空比,調(diào)整電動機(jī)轉(zhuǎn)速。其中輸出腳(SENSEA和SENSEB?)用來連接電流檢測電阻,Vss接邏輯控制的電源。Vs為電機(jī)驅(qū)動電源。IN1-IN4輸入引腳為標(biāo)準(zhǔn)TTL 邏輯電平信號,用來控制H橋的開與關(guān)即實現(xiàn)電機(jī)的正反轉(zhuǎn),ENA、ENB引腳則為使能控制端,用來輸入PWM信號實現(xiàn)電機(jī)調(diào)速。其電路如圖3.3所示,利用兩個光電耦合器將單片機(jī)的I/O與驅(qū)動電路進(jìn)行隔離,保證電路安全可靠。這樣單片機(jī)產(chǎn)生的PWM脈沖控制L298N的選通端[7],使電機(jī)在PWM脈沖的控制下正常運(yùn)行,其中四個二極管對芯片起保護(hù)作用。
圖3.3 電機(jī)驅(qū)動電路
3.4 電機(jī)速度采集電路設(shè)計
在本系統(tǒng)中由于要將電機(jī)本次采樣的速度與上次采樣的速度進(jìn)行比較,通過偏差進(jìn)行PID運(yùn)算,因此速度采集電路是整個系統(tǒng)不可缺少的部分。本次設(shè)計中應(yīng)用了比較常見的光電測速方法來實現(xiàn),其具體做法是將電機(jī)軸上固定一圓盤,且其邊緣上有N個等分凹槽如圖3.5(a)所示,在圓盤的一側(cè)固定一個發(fā)光二極管,其位置對準(zhǔn)凹槽處,在另一側(cè)和發(fā)光二極光平行的位置上固定一光敏三極管,如果電動機(jī)轉(zhuǎn)到凹槽處時,發(fā)光二極管通過縫隙將光照射到光敏三極管上,三極管導(dǎo)通,反之三極管截止,電路如圖3.4(b)所示,從圖中可以得出電機(jī)每轉(zhuǎn)一圈在P3.3的輸出端就會產(chǎn)生N個低電平。這樣就可根據(jù)低電平的數(shù)量來計算電機(jī)此時轉(zhuǎn)速了。例如當(dāng)電機(jī)以一定的轉(zhuǎn)速運(yùn)行時,P3.3將輸出如圖3.5所示的脈沖,若知道一段時間t內(nèi)傳感器輸出的低脈沖數(shù)為n,則電機(jī)轉(zhuǎn)速v=r/s?。
(a) (b)
圖3.4 電機(jī)速度采集方案
圖3.5 傳感器輸出脈沖波形
3.5 顯示電路設(shè)計
根據(jù)設(shè)計要求要對系統(tǒng)各項參數(shù)和電機(jī)運(yùn)行狀態(tài)進(jìn)行顯示,因此在電路中加入顯示模塊是非常必要的。在系統(tǒng)運(yùn)行過程中需要顯示的數(shù)據(jù)比較多,而且需要漢字顯示,在這里選用128×64液晶顯示器比較適合,它是一種圖形點(diǎn)陣液晶顯示器,主要由行驅(qū)動器/列驅(qū)動器及128×64全點(diǎn)陣液晶顯示器組成,可完成漢字(16×16)顯示和
圖形顯示共有20個引腳[8],其引腳名稱及引腳編號的對應(yīng)關(guān)系如圖3.6,引腳功能如表3.1所示。
圖3.6 128×64LCD引腳分布
表3.1 12864液晶顯示模塊引腳功能
引腳 符 號 引 腳 功 能 引腳 符 號 引 腳 功 能
1 VSS 電源地 15 CS1 CS1=1芯片選擇左邊64*64點(diǎn)
2 VDD 電源正+5V 16 CS2 CS2=1芯片選擇右邊64*64點(diǎn)
3 VO 液晶顯示驅(qū)動電源 17 /RST 復(fù)位(低電平有效)
4 RS H:數(shù)據(jù)輸入;
L:指令碼輸入 18 VEE LCD驅(qū)動負(fù)電源
5 R/W H:數(shù)據(jù)讀;
L:數(shù)據(jù)寫入 19 A 背光電源(+)
6 E 使能信號。 20 K 背光電源(-)
7-14 DB0-DB7 數(shù)據(jù)線 有些型號的模塊19、20腳為空腳
128×64液晶顯示器與單片機(jī)的連接電路如圖3.7所示:
圖3.7 顯示模塊電路圖
3.6 鍵盤電路設(shè)計
根據(jù)設(shè)計需求,本系統(tǒng)中使用了4×4鍵盤用以實現(xiàn)對P、I、D三個參數(shù)和電機(jī)正反轉(zhuǎn)的設(shè)定,以及對電機(jī)啟動、停止、暫停、繼續(xù)的控制,其電路原理圖如圖4.8所示。圖中L0~L3為4×4鍵盤的列信號,H0~H3為4×4鍵盤的行信號。在本系統(tǒng)中,用P1.0~P1.3連接鍵盤的列信號L0~L3;用P0.4~P0.7連接鍵盤的行信號H0~H3[9]。按照要求設(shè)計操作面板如圖3.8所示:
圖3.8 鍵盤模塊
鍵盤操作說明:在系統(tǒng)開始運(yùn)行時,128×64LCD將顯示開機(jī)界面,若按下設(shè)置鍵顯示屏進(jìn)入?yún)?shù)設(shè)置界面,此時按1、2、3、4進(jìn)入相應(yīng)參數(shù)的設(shè)置的狀態(tài),輸入相應(yīng)的數(shù)字即可完成該參數(shù)的設(shè)置,待所有量設(shè)置完成后按正/反控制鍵設(shè)置正反轉(zhuǎn),最后按啟動鍵啟動系統(tǒng),在運(yùn)行過程中可按下相應(yīng)鍵對電機(jī)進(jìn)行暫停、繼續(xù)、停止運(yùn)行的控制。
4 軟件設(shè)計
4.1 算法實現(xiàn)
4.1.1 PID算法
本系統(tǒng)設(shè)計的核心算法為PID算法,它根據(jù)本次采樣的數(shù)據(jù)與設(shè)定值進(jìn)行比較得出偏差 ,對偏差進(jìn)行P、I、D運(yùn)算最終利用運(yùn)算結(jié)果控制PWM脈沖的占空比來實現(xiàn)對加在電機(jī)兩端電壓的調(diào)節(jié)[10],進(jìn)而控制電機(jī)轉(zhuǎn)速。其運(yùn)算公式為:
因此要想實現(xiàn)PID控制在單片機(jī)就必須存在上述算法,
其程序流程如圖4.1所示。
4.1.2 電機(jī)速度采集算法
本系統(tǒng)中電機(jī)速度采集是一個非常重要的部分,它的精度直接影響到整個控制的精度。在設(shè)計中采用了光電傳感器做為測速裝置,其計算公式為:
v= r/min
從這里可以看出速度v的誤差主要是由圓盤邊緣上的凹槽數(shù)的多少決定的,為了減少系統(tǒng)誤差應(yīng)盡量提高凹槽的數(shù)量,在本次設(shè)計中取凹槽數(shù)N為120,采樣時間t為0.5s,則速度計算具體程序流程如圖4.2所示。
圖4.2 測速程序流程
4.2 程序流程
4.2.1 主流程圖
在一個完整的系統(tǒng)中,只有硬件部分是不能完成相應(yīng)設(shè)計任務(wù)的,所以在該系統(tǒng)中軟件部分是非常重要的,按照要求和系統(tǒng)運(yùn)行過程設(shè)計出主程序流程如圖4.3所示。
圖4.3 主程序流程
4.2.2 鍵盤程序程序流程
鍵盤中斷程序是用來設(shè)在系統(tǒng)相應(yīng)參數(shù)和控制系統(tǒng)進(jìn)入相應(yīng)的運(yùn)行狀態(tài),其程序流程圖如圖4.4所示。
圖4.4 鍵盤程序流程
4.2.3 定時程序流程
在本系統(tǒng)中定時器T0中斷子程序是用來控制電機(jī)運(yùn)行時間和進(jìn)行速度計算和PID 運(yùn)算,其程序流程如圖4.5所示。
圖4.5 定時程序流程
4.2.4 顯示程序流程
顯示模塊是實現(xiàn)人機(jī)對話的重要部分,在這里選用128×64LCD顯示器可實現(xiàn)對漢字和字符的顯示,該顯示器的引腳功能在上面已經(jīng)做了說明,下面介紹128×64LCD的相關(guān)指令。
(1)讀取狀態(tài)字
D/I R/W DB7 DB6 DB5 DB4 DB3 DB2 DB1 DB0
0 1 BUSY 0 ON/OFF RST 0 0 0 0
當(dāng)R/W=1,D/I=0時,在E信號為高的作用下,狀態(tài)分別輸出到數(shù)據(jù)總線上。狀態(tài)字是了解模塊當(dāng)前工作狀態(tài)的唯一的信息渠道,在每次對模塊操作之前,都要讀出狀態(tài)字判斷BUSY是否為“0”。若不為“0”,則計算機(jī)需要等待,直至BUSY =0為止。
(2)顯示開關(guān)設(shè)置
0 0 0 0 1 1 1 1 1 D
D=1:開顯示;D=0關(guān)顯示。
(3)顯示起始行設(shè)置
0 0 1 1 顯示起始行(0~63)
指令表中DB5~DB0為顯示起始行的地址,取值在0~3FH(1~64行)范圍內(nèi),它規(guī)定了顯示屏上最頂一行所對應(yīng)的顯示存儲器的行地址。
(4)頁面地址設(shè)置
0 0 1 0 1 1 1 Page(0~7)
頁面地址是DDRAM的行地址。8行為一頁,DDRAM共64行即8頁,DB2-DB0表示0-7頁。
(5)列地址設(shè)置
0 0 0 1 Yaddress(0~63)
列地址是DDRAM的列地址。共64列,DB5-DB0取不同值得到0-3FH(1-64),代表某一頁面上的某一單元地址,列地址計數(shù)器在每一次讀/寫數(shù)據(jù)后它將自動加一。
(6)寫顯示數(shù)據(jù)
1 0 顯 示 數(shù) 據(jù)
該操作將8位數(shù)據(jù)寫入先前已確定的顯示存儲器的單元內(nèi)。操作完成后列地址計數(shù)器自動加一。
(7)讀顯示數(shù)據(jù)
1 1 顯 示 數(shù) 據(jù)
該操作將12864模塊中的DDRAM存儲器對應(yīng)單位中的內(nèi)容讀出,然后列地址計數(shù)器自動加一。
根據(jù)上面指令結(jié)合系統(tǒng)要實行的功能,其顯示子程序流程如圖4.6所示。
圖4.6 顯示程序流程
4.3 系統(tǒng)Proteus仿真
4.3.1 Proteus軟件簡介
Proteus是英國Labcenter electronics公司研發(fā)的EDA設(shè)計軟件, 是一個基于ProSPICE混合模型仿真器的,完整的嵌入式系統(tǒng)軟、硬件設(shè)計仿真平臺。 Proteus不僅可以做數(shù)字電路、模擬電路、數(shù);旌想娐返姆抡,還可進(jìn)行多種CPU的仿真,涵蓋了51、PIC、AVR、HC11、ARM等處理器,真正實現(xiàn)了在計算機(jī)從原理設(shè)計、電路分析、系統(tǒng)仿真、測試到PCB板完整的電子設(shè)計,實現(xiàn)了從 概念到產(chǎn)品的全過程。以下為本系統(tǒng)在Protues中的仿真流程:
(1)新建文件:打開Protues點(diǎn)File,在彈出的下拉菜單中選擇New Design,在彈出的圖幅選擇對話框中選Default。
(2)設(shè)置編輯環(huán)境:按上述的方法對Protues的設(shè)計環(huán)境進(jìn)行設(shè)置。
(3)元器件選。喊丛O(shè)計要求,在對象選擇窗口中點(diǎn)P,彈出Pickdevices對
話框,在Keywords中填寫要選擇的元器件,然后在右邊對話框中選中要選的元器件,則元器件列在對象選擇的窗口中如圖4.7所示。
本設(shè)計所需選用的元器件如下:
①AT89C51:單片機(jī)
②RES、RX8、RESPACK-8:電阻、排阻、上拉電阻 圖4.7 Proteus元器件選取界面
③CRYSTAL:晶振
④CAP、CAP-ELEC:電容、電解電容
⑤7805、7812:5V、12V三端穩(wěn)壓塊
⑥IN4007:二極管
⑦AMPIRE128 64:液晶顯示器
⑧OPTOCUPLER-NPN:光電耦合器
⑨BOUTTON:按鍵
⑩MOTOR-ENCODER:直流電機(jī)
放置元器件、放置電源和地、連線,得到附錄Ⅱ所示的系統(tǒng)整體電路,最后進(jìn)行電氣檢測。
(4)程序編譯
點(diǎn)菜單Source→Add/Remove sou rce Files”在出現(xiàn)的對話框如圖4.8中,選擇ASEM51編輯器,將上面的匯編源程序SEKED.ASM添加。再點(diǎn)菜單Source→Build ALL編譯匯編源程序,生成目標(biāo)代碼文件SWLED.HEX。
(5)程序加載 圖4.8 程序添加界面
在編輯環(huán)境左擊單片機(jī)然后右擊,在彈出的對話框中將編譯生成的HEX文件加載到芯片中,設(shè)單片機(jī)的時鐘工作頻率為12MHZ。
(6)電路仿真
點(diǎn)仿真按鍵,按照前面介紹的系統(tǒng)使用方法進(jìn)行仿真。
5 系統(tǒng)測試與分析
為了確定系統(tǒng)與設(shè)計要求的符合程度,需要進(jìn)行系統(tǒng)測試與分析,但是由于試驗調(diào)節(jié)的制約和時間的限制,不能完成此次制作,只能通過軟件仿真進(jìn)行驗證,在這里使用的是英國的Proteus軟件進(jìn)行測試,有關(guān)改軟件的使用在前面的章節(jié)已經(jīng)介紹,在這里不再重復(fù)。
根據(jù)第1章PID參數(shù)整定方法的介紹與分析,對于本系統(tǒng)采用經(jīng)驗法進(jìn)行參數(shù)整定,該方法調(diào)試的原則為:
先是比例后積分,最后再把微分加;
曲線振蕩很頻繁,比例度盤要放大;
曲線漂浮繞大灣,比例度盤往小扳;
曲線波動周期長,積分時間再加長;
曲線振蕩頻率快,先把微分降下來;
根據(jù)上訴方法,通過軟件仿真系統(tǒng)得出數(shù)據(jù)如表5.1所示,通過觀察得出該系統(tǒng)比較合適的P、I、D三者的參數(shù)值為: =2, =2.2, =0.2。并且可以反映
表5.1 測試數(shù)據(jù)表
次數(shù) 設(shè)定
設(shè)定
設(shè)定
設(shè)定(r/min) 超調(diào)量 調(diào)節(jié)時間(s) 誤差
1 2 2.2 0.2 100 8% 4
2 3 2.2 0.2 100 15% 5
3 4 2.2 0.2 100 22% 11
4 1 2.2 0.2 100 5% 6
5 0 2.2 0.2 100 1% 12
6 2 1.1 0.2 100 6% 8
7 2 0 0.2 100 2% 15
8 2 3.3 0.2 100 8% 5
9 2 4.4 0.2 100 9% 7
10 2 2.2 0.1 100 8% 6
11 2 2.2 0 100 6% 5
12 2 2.2 0.3 100 7% 5
13 2 2.2 0.4 100 6% 7
出PID調(diào)節(jié)器各校正環(huán)節(jié)的作用是:
(1)比例環(huán)節(jié): 值的選取決定于系統(tǒng)的響應(yīng)速度。增大 能提高響應(yīng)速度,減小穩(wěn)態(tài)誤差;但是, 值過大會產(chǎn)生較大的超調(diào),甚至使系統(tǒng)不穩(wěn)定減小 可以減小超調(diào),提高穩(wěn)定性,但 過小會減慢響應(yīng)速度,延長調(diào)節(jié)時間;
通過上訴的數(shù)據(jù)分析可知,該系統(tǒng)完成了設(shè)計的任務(wù)及要求,證實了設(shè)計方案的可行性和設(shè)計方法的正確性。
結(jié)論
本課題的目的在于利用單片機(jī)實現(xiàn)PID算法產(chǎn)生PWM脈沖來控制電機(jī)轉(zhuǎn)速。到目前為止通過對控制器模塊、電機(jī)驅(qū)動模塊、LCD顯示模塊、鍵盤模塊、數(shù)字PID算法等進(jìn)行深入的研究。完成了硬件電路的系統(tǒng)設(shè)計,并且利用Protel99se軟件繪制出PCB圖紙(見附錄Ⅳ),但由于實驗條件不足沒能做出PCB板。軟件方面利用C語言進(jìn)行編程,增強(qiáng)了程序的可移植性和靈活性,并且利用Proteus軟件進(jìn)行仿真更加保證了程序的準(zhǔn)確性。
歸納起來主要做了如下幾方面的工作:1、PID算法與PWM控制技術(shù)有機(jī)的結(jié)合;2、設(shè)計了速度檢測電路;3、利用C語言進(jìn)行程序設(shè)計,并通過仿真(部分源程序見附錄Ⅱ);4、利用Protel99se對PCB板進(jìn)行繪制。根據(jù)上面論述結(jié)合測試數(shù)據(jù)可以看出本次設(shè)計基本完成了設(shè)計任務(wù)和要求。
通過此次設(shè)計,掌握了數(shù)字PID算法的使用及編程方法,學(xué)習(xí)了如何進(jìn)行系統(tǒng)設(shè)計及相關(guān)技巧,為今后的工作和學(xué)習(xí)奠定了堅實的基礎(chǔ)。
完整的Word格式文檔51黑下載地址(附帶完整圖片):
[畢業(yè)設(shè)計]基于單片機(jī)和PID算法的直流電機(jī)調(diào)速設(shè)計(原創(chuàng)).doc
(1.98 MB, 下載次數(shù): 60)
2018-4-2 20:18 上傳
點(diǎn)擊文件名下載附件
電路圖,程序代碼 下載積分: 黑幣 -5
