查看: 2008|回復(fù): 0
IIC通信程序
ID:300027 發(fā)表于 2018-4-3 10:03 | 顯示全部樓層 |閱讀模式
#include "Global.h"
#define SDA                                P3_1
#define SCL                                P3_0
#define SET_SDA                        (SDA        = 1)
#define CLR_SDA                        (SDA        = 0)
#define SET_SCL                        (SCL        = 1)
#define CLR_SCL                        (SCL        = 0)
#define SDA_INPUT                {P3M1 &= ~(BIT1);SET_SDA;}
#define SDA_OUTPUT                {P3M1 |= (BIT1);}
#define SCL_INPUT                {P3M1 &= ~(BIT0);SET_SCL;}
#define SCL_OUTPUT                {P3M1 |= (BIT0);}
#define Device_Addr                0xA0
#define DELAN_TIM                30
void DelanNop(u8 Count)
        do
                Count--;
        } while (Count != 0);
//I2C start signal
void i2cStart(void)
        SDA_OUTPUT;                                        //set SDA as output
        SCL_OUTPUT;                                        //set SCL as output
        SET_SDA; DelanNop(DELAN_TIM);                //SDA=1
        SET_SCL; DelanNop(DELAN_TIM);                //SCL=1
        CLR_SDA; DelanNop(DELAN_TIM);                //SDA=0
        CLR_SCL; DelanNop(DELAN_TIM);                //SCL=0
//I2C stop signal
void i2cStop(void)
        CLR_SDA; DelanNop(DELAN_TIM);//SDA=0
        SET_SCL; DelanNop(DELAN_TIM);//SCL=1
        SET_SDA; DelanNop(DELAN_TIM);//SDA=1
        CLR_SCL; DelanNop(DELAN_TIM);//SCL=0
//ACK(0) signal
void Ack(void)
        SDA_OUTPUT;//set SDA as output
        SCL_OUTPUT;//set SCL as output
//NoAck(1) signal
void NoAck(void)
//master check ack signal
//0:ACK complete1 no complete
bl TestAck(void)
        bl Ack_Bit;                //define ack bit
        SDA_INPUT;                //set SDA as input
        //SDA=1;_delay(30);//SDA=1
        Ack_Bit = SDA; DelanNop(DELAN_TIM);//read back ACK
        SDA_OUTPUT;
        Ack_Bit = 1;
        if (!Ack_Bit)
                Ack_Bit = 1;
        return Ack_Bit;
//master write data
void i2cWrite(u8 Data)
        u8 count = 8;
        while (count--)
                SDA = (bl)(Data & 0x80);        //bit7 sent to SDA pin
                SET_SCL; DelanNop(DELAN_TIM);        //sent clock
                Data = Data << 1;                //Data shift left 1 bit
//master read data
u8 i2cRead(void)
        u8 count = 8, Data;
        SDA_INPUT;//set SDA as input
        do
                if (SDA){ Data |= BIT0; }
                CLR_SCL;
                count--;
        } while (count);
        return(Data);
//---------------------------------------------------------------------------------IIC 發(fā)送數(shù)據(jù)
void SendI2cData(void)
        u8 I;
        i2cStart();
        i2cWrite(Device_Addr);
        TestAck();
        for (I = 0; I < sizeof(SendBuf); I++)
                i2cWrite(SendBuf[I]);
                TestAck();
        i2cStop();
//---------------------------------------------------------------------------------IIC 接收數(shù)據(jù)
bl FlagBuzOk;
void ReceveI2cData(void)
        u8 I, CKM;
        i2cStart();
        i2cWrite(Device_Addr + 1);
        TestAck();
        for (I = 0; I < sizeof(ReadBuf); I++)
                ReadBuf[I] = i2cRead();
                Ack();
        NoAck();
        i2cStop();
