查看: 3586|回復(fù): 2
ADE7758 SPI讀寫問(wèn)題
ID:266943 發(fā)表于 2018-4-4 16:27 | 只看該作者 回帖獎(jiǎng)勵(lì) |正序?yàn)g覽 |閱讀模式
想做一個(gè)ADE7758的SPI通信驅(qū)動(dòng)程序,用的STVD軟件庫(kù)函數(shù),模擬SPi讀寫ADE7758寄存器,程序如下:
void SPI_Write(unsigned char type,unsigned long int wdata,unsigned char databit)
    unsigned char loop = 0;
    type = type & 0x7F;
    type = type | 0x80;
                GPIO_WriteLow(SCLK); //時(shí)鐘
                GPIO_WriteLow(NCS); //片選信號(hào)
    for(loop = 0; loop < 8; loop++)
                  GPIO_WriteHigh(SCLK);
                        nop();
                        if(type&0x80)
                    GPIO_WriteHigh(DIN);
                    GPIO_WriteLow(DIN);
                  nop();
                        nop();
                        type = (type << 1);
                         nop();
    }//end of for()
    delayus(10);
    for(loop = 0; loop < databit; loop++)
                        nop();
                        if(wdata&0x800000)//24位
                    GPIO_WriteLow(DIN);
                        nop();
                        nop();
                        wdata = (wdata << 1);
                         nop();
    }//end of for()
     GPIO_WriteHigh(NCS);
}//end of write7758()
unsigned long SPI_Read(unsigned char type,unsigned char databit)
    unsigned char loop;
    unsigned long  rtdata = 0;
    type = type & 0x7F;
    type = type | 0x00;
                  GPIO_WriteLow(NCS);
    for(loop = 0;loop < 8;loop ++)
      nop();
      if(type&0x80)
                  GPIO_WriteLow(DIN);
      nop();
      nop();
      type = (type << 1);
                         nop();
                delayus(10);
    for(loop = 0;loop < databit;loop ++)
    {                   rtdata = (rtdata << 1);
      nop();
      if(GPIO_ReadInputPin(DOUT))
                          rtdata |=0x01;
      nop();
      nop();
    return(rtdata);
}//end of read7758()
同時(shí)讀寫3個(gè)電壓增益寄存器,寄存器為有符號(hào)12位
    SPI_Write(0x24,0x055500,16);   //寫相位A的電壓增益寄存器
    SPI_Write(0x25,0x055500,16);   //寫相位B的電壓增益寄存器
    SPI_Write(0x26,0x055500,16);   //寫相位C的電壓增益寄存器
    DATA[0]= SPI_Read(0x24,16);
    DATA[1]= SPI_Read(0x25,16);
    DATA[2]= SPI_Read(0x26,16);
仿真了一下得的結(jié)果不一樣
DATA[0]=1365
DATA[1]=1195
DATA[2]=1365
A、C相數(shù)是對(duì)的,B相不對(duì),讀電流增益寄存器正好相反B相是對(duì)的,AC錯(cuò)了,是時(shí)序有問(wèn)題還是其他原因,求幫助。
ID:266943 發(fā)表于 2018-4-7 08:50 | 只看該作者
寄存器有8位、12位,16位,24位四種電壓增益寄存器是12位,按照16位寫,高位開始寫,SPI_Write(0x24,0x055500,16)是向12位寄存器寫入數(shù)值0x555,我對(duì)三個(gè)同類型寄存器進(jìn)行寫入讀取操作,讀出來(lái)結(jié)果不一樣,就是想問(wèn)問(wèn)可能是什么原因
ID:287575 發(fā)表于 2018-4-4 18:09 | 只看該作者
你到底是16位還是24位,ADE7758我沒(méi)用,但類似的芯片都是24位,三個(gè)字節(jié)
應(yīng)該是SPI_Write(0x24,0x055500,24);既然讀寫都是三字節(jié),就沒(méi)必要帶形參了,直接SPI_Write(ADDR, DATA)
