該程序可以完成一個按鍵控制音樂播放,但是暫停功能我不知道怎么弄,求助一下各位!
#include "reg52.h" //此文件中定義了單片機的一些特殊功能寄存器
typedef unsigned int u16; //對數(shù)據(jù)類型進行聲明定義
typedef unsigned char u8;
sbit beepIO=P1^5;
sbit LSA=P2^2;
sbit LSB=P2^3;
sbit LSC=P2^4;
sbit IRIN=P3^2;
sbit LED1=P2^0;
sbit LED2=P2^5;
sbit LED3=P2^6;
u8 IrValue[6];
u8 Time;
u8 n;
u8 m;
u8 code T[49][2]={{0,0},
{0xF8,0x8B},{0xF8,0xF2},{0xF9,0x5B},{0xF9,0xB7},{0xFA,0x14},{0xFA,0x66},{0xFA,0xB9},{0xFB,0x03},{0xFB,0x4A},{0xFB,0x8F},{0xFB,0xCF},{0xFC,0x0B},
{0xFC,0x43},{0xFC,0x78},{0xFC,0xAB},{0xFC,0xDB},{0xFD,0x08},{0xFD,0x33},{0xFD,0x5B},{0xFD,0x81},{0xFD,0xA5},{0xFD,0xC7},{0xFD,0xE7},{0xFE,0x05},
{0xFE,0x21},{0xFE,0x3C},{0xFE,0x55},{0xFE,0x6D},{0xFE,0x84},{0xFE,0x99},{0xFE,0xAD},{0xFE,0xC0},{0xFE,0x02},{0xFE,0xE3},{0xFE,0xF3},{0xFF,0x02},
{0xFF,0x10},{0xFF,0x1D},{0xFF,0x2A},{0xFF,0x36},{0xFF,0x42},{0xFF,0x4C},{0xFF,0x56},{0xFF,0x60},{0xFF,0x69},{0xFF,0x71},{0xFF,0x79},{0xFF,0x81}
u8 code music[][2]={{0,4},
{0,8},{0,8},{13,8},{15,8},{17,4},{13,4},{15,4},{17,4},{0,4},{13,4},{20,4},{20,4},{20,8},{20,4},{17,8},{15,4},{13,8},{13,4},{10,4},{12,4},{13,4},{0,4},{10,4},{17,4},{17,4},{17,8},{17,4},{12,8},{10,4},{8,8},{13,4},{10,4},{12,4},{13,4},{0,4},{8,4},{22,4},{20,4},{20,4},{20,4},{17,4},{13,4},{0,4},{15,4},{17,4},{10,4},{17,4},{17,4},{17,4},{17,4},{17,4},{15,4},{13,4},{17,4},
{0xFF,0xFF}};
u8 DisplayData[8];
u8 code smgduan[17]={
0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71,0X76};
//0、1、2、3、4、5、6、7、8、9、A、b、C、d、E、F、H的顯示碼
void delay11(u8 p)
u8 i,j;
for(;p>0;p--)
for(i=181;i>0;i--)
for(j=181;j>0;j--);
void pause()
u8 i,j;
for(i=150;i>0;i--)
for(j=150;j>0;j--);
* 函 數(shù) 名 : delay
* 函數(shù)功能 : 延時函數(shù),i=1時,大約延時10us
void delay(u16 i)
while(i--);
* 函數(shù)名 :DigDisplay()
* 函數(shù)功能 :數(shù)碼管顯示函數(shù)
* 輸入 : 無
* 輸出 : 無
void DigDisplay()
u8 i;
for(i=0;i<3;i++)
switch(i) //位選,選擇點亮的數(shù)碼管,
case(0):
LSA=0;LSB=0;LSC=0; break;//顯示第0位
case(1):
LSA=1;LSB=0;LSC=0; break;//顯示第1位
case(2):
LSA=0;LSB=1;LSC=0; break;//顯示第2位
P0=DisplayData[2-i];//發(fā)送數(shù)據(jù)
delay(100); //間隔一段時間掃描
P0=0x00;//消隱
* 函數(shù)名 : IrInit()
* 函數(shù)功能 : 初始化紅外線接收
* 輸入 : 無
* 輸出 : 無
void IrInit()
IT0=1;//下降沿觸發(fā)
EX0=1;//打開中斷0允許
EA=1; //打開總中斷
IRIN=1;//初始化端口
void hehe()//設(shè)置播放的音樂
u8 i=0;
TMOD=0x01; EA=1; ET0=1;
m=music[i][0];n=music[i][1];
if(m==0x00)
{TR0=0;delay11(n);i++;}
else if(m==0xFF)
{TR0=0;delay11(30);i=0;}
else if(m==music[i+1][0])
{TR0=1;delay11(n);TR0=0;pause();i++;}
{TR0=1;delay11(n);i++;}
* 函 數(shù) 名 : main
* 函數(shù)功能 : 主函數(shù)
* 輸 入 : 無
* 輸 出 : 無
IrInit();
DisplayData[0] = smgduan[IrValue[2]/16];
DisplayData[1] = smgduan[IrValue[2]%16];
DisplayData[2] = smgduan[16];
DigDisplay();
if( IrValue[2] == 0x45 )
hehe();//播放音樂
* 函數(shù)名 : ReadIr()
* 函數(shù)功能 : 讀取紅外數(shù)值的中斷函數(shù)
* 輸入 : 無
* 輸出 : 無
void ReadIr() interrupt 0 //外部中斷
u8 j,k;
u16 err;
Time=0;
delay(700); //7ms
if(IRIN==0) //確認是否真的接收到正確的信號
err=1000; //1000*10us=10ms,超過說明接收到錯誤的信號
/*當兩個條件都為真是循環(huán),如果有一個條件為假的時候跳出循環(huán),免得程序出錯的時
侯,程序死在這里*/
while((IRIN==0)&&(err>0)) //等待前面9ms的低電平過去
delay(1);
err--;
if(IRIN==1) //如果正確等到9ms低電平
err=500;
while((IRIN==1)&&(err>0)) //等待4.5ms的起始高電平過去
delay(1);
err--;
for(k=0;k<4;k++) //共有4組數(shù)據(jù)
for(j=0;j<8;j++) //接收一組數(shù)據(jù)
err=60;
while((IRIN==0)&&(err>0))//等待信號前面的560us低電平過去
delay(1);
err--;
err=500;
while((IRIN==1)&&(err>0)) //計算高電平的時間長度。
delay(10); //0.1ms
Time++;
err--;
if(Time>30)
return;
IrValue[k]>>=1; //k表示第幾組數(shù)據(jù)
if(Time>=8) //如果高電平出現(xiàn)大于565us,那么是1
IrValue[k]|=0x80;
Time=0; //用完時間要重新賦值
if(IrValue[2]!=~IrValue[3])
return;
void T0_int() interrupt 1 //定時中斷
beepIO=!beepIO;
TH0=T[m][0]; TL0=T[m][1];
