查看: 5238|回復(fù): 0
單片機(jī)計(jì)時(shí)器Keil源程序文件
ID:303185 發(fā)表于 2018-4-7 15:55 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
  1. #include <reg52.h>
  2. sbit ADDR0 = P1^0;
  3. sbit ADDR1 = P1^1;
  4. sbit ADDR2 = P1^2;
  5. sbit ADDR3 = P1^3;
  6. sbit ENLED = P1^4;
  7.         unsigned char code image[10][8] = {
  8.     {0xFF,0xE7,0xDB,0xDB,0xDB,0xDB,0xDB,0xE7},  //動(dòng)畫幀1
  9.     {0xFF,0xE7,0xE3,0xE7,0xE7,0xE7,0xE7,0xC3},  //動(dòng)畫幀2
  10.     {0xFF,0xC3,0xDF,0xDF,0xC3,0xFB,0xFB,0xC3},  //動(dòng)畫幀3
  11.     {0xFF,0xC3,0xDF,0xDF,0xC3,0xDF,0xDF,0xC3},  //動(dòng)畫幀4
  12.     {0xFF,0xDB,0xDB,0xDB,0xC3,0xDF,0xDF,0xDF},  //動(dòng)畫幀5
  13.     {0xFF,0xC3,0xFB,0xFB,0xC3,0xDF,0xDF,0xC3},  //動(dòng)畫幀6
  14.     {0xFF,0xC3,0xFB,0xFB,0xC3,0xDB,0xDB,0xC3},  //動(dòng)畫幀7
  15.     {0xFF,0xC3,0xDF,0xDF,0xDF,0xDF,0xDF,0xDF},  //動(dòng)畫幀8
  16.     {0xFF,0xC3,0xDB,0xDB,0xC3,0xDB,0xDB,0xC3},  //動(dòng)畫幀9
  17.     {0xFF,0xC3,0xDB,0xDB,0xC3,0xDF,0xDF,0xC3},  //動(dòng)畫幀10
  18. };
  19.    unsigned char led=0xff;
  20. unsigned char code LedChar[] = {  //數(shù)碼管顯示字符轉(zhuǎn)換表
  21.     0xC0, 0xF9, 0xA4, 0xB0, 0x99, 0x92, 0x82, 0xF8,
  22.     0x80, 0x90, 0x88, 0x83, 0xC6, 0xA1, 0x86, 0x8E
  23. };
  24. unsigned char LedBuff[6] = {  //數(shù)碼管顯示緩沖區(qū),初值0xFF確保啟動(dòng)時(shí)都不亮
  25.     0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF
  26. };
  27. unsigned int cnt = 0;  //記錄T1中斷次數(shù)
  28.          unsigned int cnt1=0;
  29. void main()
  30. {
  31.     char j;  //循環(huán)變量
  32.         unsigned char m=0;
  33.     unsigned long sec = 100000;  //記錄經(jīng)過的秒數(shù),倒計(jì)時(shí)初值為999999+1
  34.     unsigned char buf[6];   //中間轉(zhuǎn)換緩沖區(qū)
  35.         unsigned char dir = 0;   //定義移位方向變量dir,用于控制移位的方向
  36.     unsigned char shift = 0x01;
  37.     EA = 1;       //使能總中斷
  38.     ENLED = 0;    //使能U3
  39.
  40.     TMOD = 0x01;  //設(shè)置T1為模式1
  41.     TH0  = 0xFC;  //為T1賦初值0xFC67,定時(shí)1ms
  42.     TL0  = 0x67;
  43.     ET0  = 1;     //使能T1中斷
  44.     TR0  = 1;     //啟動(dòng)T1
  45.
  46.     while (1)
  47.     {
  48.         if(cnt1>=1000)
  49.         {           cnt1=0;
  50.         led=~shift;
  51.          if (dir == 0)             //移位方向變量為0時(shí),左移
  52.         {
  53.             shift = shift << 1;   //循環(huán)移位變量左移1位
  54.             if (shift == 0x80)    //左移到最左端后,改變移位方向
  55.             {
  56.                 dir = 1;
  57.             }
  58.         }
  59.         else                      //移位方向變量不為0時(shí),右移
  60.         {
  61.             shift = shift >> 1;   //循環(huán)移位變量右移1位
  62.             if (shift == 0x01)    //右移到最右端后,改變移位方向
  63.             {
  64.                 dir = 0;
  65.             }
  66.         }
  67.                 }
  68.         if (cnt >= 1000)  //判斷T1溢出是否達(dá)到1000次
  69.         {
  70.             cnt = 0;      //達(dá)到1000次后計(jì)數(shù)值清零
  71.             sec--;        //秒計(jì)數(shù)自減1
  72.             //將sec按十進(jìn)制位從低到高依次提取到buf數(shù)組中
  73.             buf[0] = sec%60%10;
  74.             buf[1] = sec%60/10;
  75.             buf[2] = sec%3600/60%10;
  76.             buf[3] = sec%3600/60/10;
  77.             buf[4] = sec/3600%24%10;
  78.             buf[5] = sec/3600%24/10;
  79.             //從最高為開始,遇到0不顯示,遇到非0退出循環(huán)
  80.             for (j=5; j>=1; j--)
  81.             {
  82.                 if (buf[j] == 0)
  83.                     LedBuff[j] = 0xFF;
  84.                 else
  85.                     break;
  86.             }
  87.             //將剩余的有效數(shù)字位如實(shí)轉(zhuǎn)換
  88.             for ( ; j>=0; j--)  //for()起始未對(duì)j操作,j即保持上個(gè)循環(huán)結(jié)束時(shí)的值
  89.             {
  90.                 LedBuff[j] = LedChar[buf[j]];
  91.             }
  92.         }
  93.     }
  94.
  95. }
  96. /* 定時(shí)器1中斷服務(wù)函數(shù) */
  97. void InterruptTimer1() interrupt 1
  98. {
  99.         static unsigned char i = 0;  //動(dòng)態(tài)掃描的索引
  100.     static unsigned int tmr = 0;  //1s軟件定時(shí)器
  101.     static unsigned char index = 0;  //圖片刷新索引
  102.     TH0 = 0xfe;  //重新加載初值
  103.     TL0 = 0x33;
  104.     cnt++;
  105.         cnt1++;       //中斷次數(shù)計(jì)數(shù)值加1
  106.     //以下代碼完成數(shù)碼管動(dòng)態(tài)掃描刷新
  107.     P0 = 0xFF;   //顯示消隱
  108.     switch (i)
  109.     {
  110.         case 0: ADDR3 = 1;ADDR2=0; ADDR1=0; ADDR0=0; i++; P0=LedBuff[0]; break;
  111.         case 1: ADDR3 = 1;ADDR2=0; ADDR1=0; ADDR0=1; i++; P0=LedBuff[1]; break;
  112.         case 2: ADDR3 = 1;ADDR2=0; ADDR1=1; ADDR0=0; i++; P0=LedBuff[2]&0x7f; break;
  113.         case 3: ADDR3 = 1;ADDR2=0; ADDR1=1; ADDR0=1; i++; P0=LedBuff[3]; break;
  114.         case 4: ADDR3 = 1;ADDR2=1; ADDR1=0; ADDR0=0; i++; P0=LedBuff[4]&0x7f; break;
  115.         case 5: ADDR3 = 1;ADDR2=1; ADDR1=0; ADDR0=1; i++; P0=LedBuff[5]; break;
  116.                 case 6: ADDR3 = 0;ADDR2=0; ADDR1=0; ADDR0=0; i++; P0=image[index][0]; break;
  117.         case 7: ADDR3 = 0;ADDR2=0; ADDR1=0; ADDR0=1; i++; P0=image[index][1]; break;
  118.         case 8: ADDR3 = 0;ADDR2=0; ADDR1=1; ADDR0=0; i++; P0=image[index][2]; break;
  119.         case 9: ADDR3 = 0;ADDR2=0; ADDR1=1; ADDR0=1; i++; P0=image[index][3]; break;
  120.         case 10:ADDR3 = 0;ADDR2=1; ADDR1=0; ADDR0=0; i++; P0=image[index][4]; break;
  121.         case 11:ADDR3 = 0;ADDR2=1; ADDR1=0; ADDR0=1; i++; P0=image[index][5]; break;
  122.         case 12:ADDR3 = 0;ADDR2=1; ADDR1=1; ADDR0=0; i++; P0=image[index][6]; break;
  123.         case 13:ADDR3 = 0;ADDR2=1; ADDR1=1; ADDR0=1; i++; P0=image[index][7]; break;
  124.                 case 14: ADDR3 = 1;ADDR2=1; ADDR1=1; ADDR0=0; i=0; P0=led; break;
  125.         default: break;
  126.     }
  127.         tmr++;
  128.     if (tmr >= 2000)  //達(dá)到1s時(shí)改變一次圖片索引
  129.     {
  130.         tmr = 0;
  131.         index++;
  132.         if (index >= 10)  //圖片索引達(dá)到10后歸零
  133.         {
  134.             index = 0;
  135.         }
  136.     }
  137. }
下載:
計(jì)時(shí)器.rar (22.59 KB, 下載次數(shù): 11)
