查看: 2181|回復(fù): 0
為什么數(shù)碼管沒反應(yīng)
ID:272089 發(fā)表于 2018-4-12 08:47 | 只看該作者 回帖獎勵 |倒序?yàn)g覽 |閱讀模式
30黑幣
#include<regx52.h>
#include<intrins.h>
#include<rtx51tny.h>
#include "string.h"
uchar gs=0,n,houdu=0;
bit flag=0;
uchar keynum;
void delay(uint i){while(i--);}
sbit in0=P1^0;sbit in1=P1^1;sbit in2=P1^2;sbit in3=P1^3;
sbit in4=P1^4;sbit in5=P1^5;sbit in6=P1^6;sbit in7=P1^7;
sbit k1=P2^0; sbit k2=P2^1; sbit k3=P2^2; sbit k4=P2^3;sbit k5=P2^4;
sbit col0=P3^0;sbit col1=P3^1;sbit col2=P3^2;
sbit row0=P3^4;sbit row1=P3^5;sbit col3=P3^3;
#define zuo        k1=0;k2=1
#define        you        k1=1;k2=0
#define stop       k2=k2=1
#define shang      k5=1
#define xia        k5=0
#define jia        k3=0;k4=1
#define song       k3=1;k4=0
extern uchar display(uchar *buf);
uchar key_get()
     uchar k=' ';
         col0=col1=col2=col3=1;
         row0=0;k=col0==0?'+':col1==0?'-':col2==0?'h':col3==0?'m':k;row0=1;
         row1=0;k=col0==0?'r':k;row1=1;
         return k;
void wuliao_task() _task_ 2                 //物料搬運(yùn)部分
           uchar n=0,i,houdu;
         switch(n)
              case 0:
                       if(in2){zuo;}
                           else stop;
                           n++;
                           break;
                  case 1:
                       if(in5==0)song;
                           n++;
                  case 2:
                       if(in7==0)
                              while(in0==1)you;
                                  break;
                           n++;
                  case 3:
                       if(in4)xia;
                           break;
                           n++;
                  case 4:
                       if(in5)jia;
                           break;
                           n++;
                  case 5:
                       if(in3)shang;
                           break;
                           n++;
                  case 6:
                       for(i=0;i<houdu;i++)
                               if(in2)zuo;
                                   if(in0)you;
                   os_switch_task();
void main1_task() _task_ 0
    os_create_task(1);
        os_create_task(2);
                 keynum=key_get();
                 if(' '!=key_get()&flag==0)
                      delay(150);
                          if(' '!=key_get())
                               flag=1;
                                   keynum=key_get();
                                   if(keynum=='+'&&gs==1)houdu++;
                                   if(keynum=='-'&&gs==1)houdu--;
                                   if(keynum=='s')
                                        if(gs==0)gs=1;
                                   if(keynum=='m')
                                        if(gs==0||gs==1)gs=2;
                                   if(keynum=='r')
                                        if(gs==1||gs==2)
                                                    gs=3;
                                                    n=0;
顯示部分
#include<regx52.h>
#include<intrins.h>
#include<string.h>
#define LED P0
sbit cs1=P2^5;sbit cs2=P2^6;sbit wr=P2^7;
extern delay(uint i);
uchar code tab_index[]="AB0123456789DLE ";
uchar code table[]={0x88,0x83,0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0xa1,0xc7,0x86,0xff};
extern  uchar gs,n,houdu;
extern  bit flag;
uchar  buf[8];
void str(uchar c,uchar *s)
    uchar i;
        for(i=0;s[i]!=0&&(c+i)<8;i++)
        buf[c+i]=strpos(tab_index,s[i]);
void display()                                  //顯示函數(shù)
    uchar i,j=0x7f;
        for(i=0;i<8;i++)
            cs1=0;cs2=1;
                LED=table[buf[i]];wr=1;wr=0;
                cs1=1;cs2=0;
                LED=j;wr=1;wr=0;
                j=_cror_(j,1);
                delay(100);
                cs1=cs2=0;
                LED=0xff;wr=1;wr=0;
void dis_task() _task_ 1
            switch(gs)
                    case 0:
                     str(0,"    1DLE");
                                 break;
                        case 1:
                             str(0,"       ");
                                 buf[6]=houdu;
                                 break;
                        case 2:
                             str(0,"       ");
                                 buf[6]=flag;
                                 break;
                        case 3:
                             str(0,"rUn   ");
                             buf[6]=houdu;
                                 buf[7]=flag;
                                 break;
                    display();
                        os_switch_task();
