查看: 5016|回復(fù): 7
關(guān)于基于74HC595和138的16*16點(diǎn)陣左移單片機(jī)程序的問(wèn)題
ID:236686 發(fā)表于 2018-4-12 20:50 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
10黑幣
我是最近學(xué)單片機(jī)的萌新  我用的  兩塊74HC138級(jí)聯(lián)加三極管  作為行驅(qū)動(dòng)    兩塊74HC595級(jí)聯(lián)作為列驅(qū)動(dòng)   連接如圖片所示
字符取碼逐行式  低位在前   高位在后     我已經(jīng)完成了  拉幕顯示   從下往上移顯示      現(xiàn)在問(wèn)題是由于我是只能是逐行式掃描   我要怎么進(jìn)行從右往左移顯示啊  有點(diǎn)想不通 希望各位大神能給一點(diǎn)指點(diǎn)    編程的思路  萬(wàn)分感謝  我不想更改595和138的驅(qū)動(dòng)程序
下面是我發(fā)送數(shù)據(jù)的595和138的驅(qū)動(dòng)代碼
void HC595_Data_Send(uchar daH,daL,hang) //¸高八位在點(diǎn)陣屏幕的右八位     因此我先移如高八位再移入第八位
uchar i;
Latch_port = 0;//關(guān)閉鎖存器的存儲(chǔ)寄存器  不輸出數(shù)據(jù)
CLK_port = 0;//鎖存器移位寄存器的時(shí)鐘輸入口置0
for(i=0;i<8;i++){
  if((daH&0x80)!=0) DA_in_port = 1;
  else DA_in_port = 0;
  CLK_port = 1;
  CLK_port = 0;
  daH <<= 1;
for(i=0;i<8;i++){
  if((daL&0x80)!=0) DA_in_port = 1;
  CLK_port = 1;
  CLK_port = 0;
  daL <<= 1;
EN_port = 1; /關(guān)閉顯示   使138輸出全為1  點(diǎn)陣不顯示
switch (hang){
  case 0:
   A_port = 0; B_port = 0; C_port = 0; D_port = 0; //D為0時(shí)   對(duì)應(yīng)上八行有可能不顯示
   break;
  case 1:
   A_port = 1; B_port = 0; C_port = 0; D_port = 0;
   break;
  case 2:
   A_port = 0; B_port = 1; C_port = 0; D_port = 0;
   break;
  case 3:
   A_port = 1; B_port = 1; C_port = 0; D_port = 0;
   break;
  case 4:
   A_port = 0; B_port = 0; C_port = 1; D_port = 0;
   break;
  case 5:
   A_port = 1; B_port = 0; C_port = 1; D_port = 0;
   break;
  case 6:
   A_port = 0; B_port = 1; C_port = 1; D_port = 0;
   break;
  case 7:
   A_port = 1; B_port = 1; C_port = 1; D_port = 0;
   break;
  case 8:
   A_port = 0; B_port = 0; C_port = 0; D_port = 1;     //D為1時(shí)  下有可能八行顯示
   break;
  case 9:
   A_port = 1; B_port = 0; C_port = 0; D_port = 1;
   break;
  case 10:
   A_port = 0; B_port = 1; C_port = 0; D_port = 1;
   break;
  case 11:
   A_port = 1; B_port = 1; C_port = 0; D_port = 1;
   break;
  case 12:
   A_port = 0; B_port = 0; C_port = 1; D_port = 1;
   break;
  case 13:
   A_port = 1; B_port = 0; C_port = 1; D_port = 1;
   break;
  case 14:
   A_port = 0; B_port = 1; C_port = 1; D_port = 1;
   break;
  case 15:
   A_port = 1; B_port = 1; C_port = 1; D_port = 1;
   break;
Latch_port = 1; //595數(shù)據(jù)輸出到Q1---Q8端
EN_port = 0; /*138輸出有效打開(kāi)顯示*/
Latch_port = 0; /*595輸出鎖定*/
ID:123289 發(fā)表于 2018-4-13 02:45 | 只看該作者
要點(diǎn):
1、顯示不要直接取字庫(kù)顯示,這樣不靈活。
2、建立兩個(gè)與LED點(diǎn)陣的對(duì)應(yīng)緩沖區(qū),區(qū)內(nèi)的每個(gè)字節(jié)對(duì)應(yīng)每個(gè)LED的一個(gè)行,字節(jié)的8個(gè)位剛好對(duì)應(yīng)8個(gè)點(diǎn)。一個(gè)8*8的點(diǎn)陣,用8個(gè)字節(jié)做緩沖區(qū)。
3、給這兩個(gè)緩沖區(qū)取名:一個(gè)叫RAMX1-RAMX8,另一個(gè)叫RAMY1-RAMY8
4、顯示的內(nèi)容:顯示的內(nèi)容不要直接送到LED,而是送入RAMX1-RAMX8�。。∵@是要點(diǎn)一!��!
5、顯示(掃描輸出):每次送到LED中內(nèi)容從RAMY1-RAMY8取數(shù)�。�!這是要點(diǎn)二!�。呙璧姆绞�,樓主已會(huì)了,不再重復(fù)。
6、正常顯示、上下滾行、左右滾行:多久滾一行呢?做個(gè)時(shí)間中斷就解決了,假設(shè)中斷時(shí)間=滾行時(shí)間。
7、正常顯示:每次中斷、將RAMX1-RAMX8的內(nèi)容依序送到RAMY1-RAMY8。就是樓主已會(huì)的方式。
8、上下滾行:每次中斷將從RAMx起至RAM(x+8)結(jié)束,依序送到RAMY1-RAMY8。比如將RAMX2送入RAMY1,或RAMX3送入RAMY1,就是錯(cuò)開(kāi)送,形成滾動(dòng)效果!
9、如何時(shí)做到呢:做一個(gè)指針RXP(一個(gè)寄存器)x取RXP的末三位,高出的位不要,屏蔽掉。每次中斷先將RXP+1,以RXP的末三位為索引,做第8步。這樣上下滾行就做完成了。
10、左右滾列:每次中斷、每當(dāng)將RAMX1-RAMX8的內(nèi)容取一個(gè)字節(jié)后,先循環(huán)左移(也可右移)一位[記得要回送],而后再送到RAMY1-RAMY8。這樣左右滾行就做完成了。
對(duì)于樓主的16*16點(diǎn)陣:先理解一下我構(gòu)思方案,再自己去以葫蘆畫(huà)瓢。
這個(gè)方案的好處時(shí):更換顯示內(nèi)容與滾不滾行無(wú)關(guān),都是向RAMX1-RAMX8中送入字庫(kù)。
滾不滾?上滾、下滾、左滾、右滾,只要做個(gè)選標(biāo)記,在中斷時(shí)讓RXP=0、RXP+1、RXP-1、字節(jié)左移、右移。即可實(shí)現(xiàn)!�。�
ID:123289 發(fā)表于 2018-4-13 02:47 | 只看該作者
我在自己所做的產(chǎn)品中就是這樣處理的,效果很好。也出個(gè)題目給樓主想想,也是個(gè)提示:
我的屏只能顯示4個(gè)漢字,超過(guò)4個(gè)漢字顯示時(shí),就需要左滾顯示。不超過(guò)4個(gè)就不滾。約定最多一次顯示8個(gè)漢字(需滾),但是我的RAMX的數(shù)量卻是按9個(gè)漢字做的,而RAMY是按4個(gè)漢字做的。這是為什么呢?
ID:140489 發(fā)表于 2018-4-13 15:07 | 只看該作者
yzwzfyz 發(fā)表于 2018-4-13 02:47
我的屏只能顯示4個(gè)漢 ...
請(qǐng)問(wèn)點(diǎn)陣左移、右移漢字正常,數(shù)字左移、右移就顯示亂碼,改怎么處理呢?
ID:7485 發(fā)表于 2018-4-13 16:02 | 只看該作者
做左右滾動(dòng),使用逐列取模方便。例如:第一次掃描從字模的第一列開(kāi)始,延時(shí)后從第二列開(kāi)始......,就會(huì)向左滾動(dòng)了。
逐行取模不好處理。
ID:282370 發(fā)表于 2018-4-18 15:03 | 只看該作者
樓主可以加扣嗎:532560194,我做了16*16的點(diǎn)陣屏設(shè)計(jì),但是想改成16*32的,不知道怎么改了
