2018-4-14 16:54 上傳
2018-4-14 16:54 上傳
操作方式
十字鍵 控制方向
A 鍵確認(rèn)
B 鍵返回
進(jìn)入詳細(xì)信息頁(yè)面可以通過左右鍵切換顯示內(nèi)容
2018-4-14 16:54 上傳
2018-4-14 16:54 上傳
電路圖
2018-4-14 16:56 上傳
- #include "U8glib.h"//引用U8G頭文件
- U8GLIB_SSD1306_128X64 u8g(U8G_I2C_OPT_NONE);//設(shè)置設(shè)備名稱:I2C-SSD1306-128*64(OLED)
- //如果屏幕不同請(qǐng)自行修改 如果第一次使用u8glib并且遇到顯示不正確,請(qǐng)自行修改u8g配置
- 位圖
- //HWT
- const uint8_t HWT[] PROGMEM = {0x18, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x66, 0x06, 0x33, 0x3c, 0x12, 0x8b, 0xe0, 0x89, 0x44, 0x42, 0x09, 0x49, 0x24, 0x12, 0x88, 0x80, 0x89, 0x44, 0x99, 0x02, 0x49, 0x3c, 0x1e, 0x88, 0x8c, 0x8f, 0x44, 0x99, 0x04, 0x49, 0x24, 0x12, 0xa8, 0x8c, 0x89, 0x54, 0x42, 0x08, 0x49, 0x24, 0x12, 0x50, 0x80, 0x89, 0x28, 0x66, 0x0f, 0x33, 0xbc, 0x12, 0x50, 0x80, 0xe9, 0x28, 0x18, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00};
- //title
- const uint8_t title[] PROGMEM = {0x00, 0x00, 0x00, 0x08, 0x00, 0x3f, 0xff, 0x02, 0x30, 0x00, 0x00, 0x80, 0x00, 0x3f, 0xfc, 0x03, 0xff, 0xf0, 0x3f, 0xff, 0x02, 0x33, 0xf8, 0x00, 0x80, 0x00, 0x00, 0x00, 0x00, 0x1c, 0x00, 0x30, 0x83, 0x0f, 0xfb, 0x18, 0x7f, 0xff, 0x00, 0x00, 0x00, 0x00, 0x1c, 0x00, 0x30, 0x83, 0x07, 0x33, 0x18, 0x00, 0x80, 0x00, 0x00, 0x00, 0x03, 0xff, 0xe0, 0x37, 0xf3, 0x02, 0x33, 0x18, 0x3f, 0xfe, 0x00, 0x00, 0x00, 0x00, 0x08, 0x00, 0x30, 0x83, 0x03, 0xf3, 0xf8, 0x3f, 0xfe, 0x00, 0x7f, 0xff, 0x0f, 0xff, 0xf8, 0x21, 0xc3, 0x02, 0x33, 0x18, 0x00, 0x80, 0x00, 0x06, 0x20, 0x00, 0x31, 0x80, 0x2f, 0xfb, 0x03, 0x33, 0x18, 0xff, 0xff, 0x80, 0x06, 0x20, 0x01, 0xff, 0x80, 0x20, 0x03, 0x03, 0xf3, 0x18, 0x03, 0x40, 0x00, 0x06, 0x20, 0x01, 0xfe, 0x40, 0x27, 0xf3, 0x02, 0x33, 0xf8, 0x06, 0xc2, 0x00, 0x06, 0x20, 0x00, 0x38, 0x60, 0x26, 0x33, 0x0f, 0xfb, 0x18, 0x0e, 0x46, 0x00, 0x04, 0x20, 0x03, 0xff, 0xf0, 0x66, 0x33, 0x0f, 0xfb, 0x18, 0x3e, 0x7c, 0x00, 0x0c, 0x20, 0x03, 0x0c, 0x00, 0x66, 0x33, 0x02, 0x23, 0x18, 0x76, 0x38, 0x00, 0x18, 0x21, 0x80, 0xcc, 0xc0, 0x67, 0xf3, 0x06, 0x36, 0x18, 0x46, 0xd8, 0x00, 0x38, 0x31, 0x87, 0x8c, 0x70, 0x40, 0x03, 0x0c, 0x1e, 0x18, 0x07, 0x8f, 0x80, 0xf0, 0x3f, 0x06, 0x3c, 0x30, 0xc0, 0x1f, 0x08, 0x0c, 0x38, 0x07, 0x03, 0x80, 0x40, 0x00, 0x00, 0x10, 0x00, 0x40, 0x0e, 0x00, 0x00, 0x20, 0x04, 0x00, 0x00};
- //放射性
- const uint8_t radiation[] PROGMEM = {0x00, 0x00, 0x0f, 0xf0, 0x1f, 0xe8, 0x27, 0xe4, 0x43, 0xc2, 0x43, 0x82, 0x03, 0x80, 0x02, 0x40, 0x7e, 0x7e, 0x7f, 0xfe, 0x7c, 0x7e, 0x7c, 0x3e, 0x38, 0x1c, 0x18, 0x18, 0x0c, 0x30, 0x00, 0x00};
- //金屬
- const uint8_t Bmrtal[] PROGMEM = {0x00, 0x00, 0x03, 0xfe, 0x04, 0x06, 0x08, 0x0a, 0x10, 0x12, 0x3f, 0xe2, 0x20, 0x22, 0x20, 0x22, 0x20, 0x22, 0x60, 0x22, 0xa0, 0x24, 0x60, 0x29, 0xa0, 0x3a, 0x7f, 0xf5, 0xaa, 0xaa, 0x55, 0x54};
- const uint8_t Element[] PROGMEM = {0x7f, 0xc0, 0x10, 0x01, 0x00, 0x1c, 0x80, 0x00, 0x00, 0x10, 0x03, 0xfc, 0x38, 0x80, 0x00, 0x01, 0xff, 0x02, 0x08, 0x09, 0x98, 0x00, 0x00, 0x10, 0x0d, 0x90, 0x3f, 0x18, 0xff, 0xc3, 0xff, 0x80, 0xe0, 0x18, 0x40, 0x1a, 0x00, 0xfe, 0x00, 0xc0, 0x18, 0x40, 0x12, 0x00, 0x33, 0x03, 0xfc, 0x1d, 0x50, 0x12, 0x01, 0xff, 0x8f, 0x04, 0x39, 0x48, 0x32, 0x00, 0x10, 0x01, 0x04, 0x2b, 0x48, 0x63, 0x21, 0x93, 0x01, 0xfc, 0x0a, 0x40, 0xc1, 0xe2, 0x30, 0x01, 0x04, 0x08, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00};
- //元素名稱
- const uint8_t Relative[] PROGMEM = {0x7f, 0xe1, 0xff, 0x04, 0x40, 0x0b, 0xf0, 0x42, 0x00, 0x06, 0x06, 0x4c, 0x10, 0x30, 0x5f, 0xc0, 0x08, 0x02, 0x58, 0x34, 0x20, 0x50, 0x40, 0x10, 0x00, 0x40, 0x0c, 0xe0, 0x5f, 0xc0, 0x10, 0x0f, 0xfe, 0x1b, 0x18, 0x50, 0x43, 0xff, 0x80, 0x40, 0x3a, 0x00, 0x5f, 0xc0, 0x10, 0x00, 0x40, 0x2b, 0xf8, 0x42, 0x00, 0x10, 0x0f, 0xfe, 0x08, 0x40, 0x4a, 0xc0, 0x10, 0x00, 0x40, 0x08, 0x40, 0x92, 0x60, 0x10, 0x00, 0x40, 0x08, 0x40, 0xa6, 0x00, 0x70, 0x00, 0x40, 0x1f, 0xf8};
- //相對(duì)質(zhì)量
- const uint8_t RM[] PROGMEM = {0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x13, 0xf0, 0x00, 0x81, 0xfe, 0x0f, 0xf8, 0x12, 0x11, 0xf0, 0x83, 0xb0, 0x0f, 0xf8, 0x7e, 0x10, 0x3f, 0xc3, 0xff, 0x0f, 0xf8, 0x33, 0xf0, 0x37, 0xc3, 0xfe, 0x18, 0x0c, 0x33, 0x11, 0xa0, 0x82, 0x30, 0x1f, 0xfc, 0x3e, 0x10, 0xec, 0x82, 0xfe, 0x0f, 0xf8, 0x77, 0xf0, 0x64, 0x82, 0x92, 0x0f, 0xf8, 0x52, 0x10, 0x64, 0x82, 0x92, 0x0f, 0xf8, 0x12, 0x10, 0xb0, 0x86, 0x3c, 0x00, 0x80, 0x13, 0xf1, 0x90, 0x86, 0x6e, 0x07, 0xf0, 0x13, 0x11, 0x03, 0x85, 0xc3, 0x1f, 0xfc};
- //價(jià)態(tài)
- const uint8_t VA[] PROGMEM = {0x00, 0x00, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1f, 0xc0, 0x08, 0x01, 0xfc, 0x04, 0x38, 0x11, 0x80, 0x18, 0x00, 0x1f, 0xc1, 0xff, 0xc1, 0xfc, 0x09, 0xa0, 0x11, 0x81, 0xff, 0xc0, 0x10, 0x40, 0x7f, 0x01, 0x04, 0x09, 0x20, 0x22, 0x40, 0x14, 0x00, 0x00, 0x00, 0x41, 0x00, 0x00, 0x19, 0x20, 0x26, 0x30, 0x22, 0x00, 0x7f, 0xf0, 0x7f, 0x07, 0xff, 0x19, 0xfc, 0x6c, 0x10, 0x73, 0x00, 0x24, 0x00, 0x00, 0x02, 0x40, 0x09, 0x20, 0x22, 0x41, 0x88, 0xc0, 0x3f, 0xe1, 0x00, 0x43, 0xfe, 0x09, 0x20, 0x22, 0x41, 0x00, 0x00, 0x3d, 0x41, 0x3e, 0x43, 0xd4, 0x09, 0x30, 0x22, 0x40, 0xac, 0x80, 0x26, 0xc1, 0x22, 0x42, 0x6c, 0x09, 0xd0, 0x22, 0x41, 0xa0, 0xc0, 0x7c, 0xc1, 0x3e, 0x47, 0xcc, 0x09, 0xdc, 0x24, 0x41, 0x21, 0x40, 0x05, 0x31, 0x00, 0xc0, 0x53, 0x08, 0x4c, 0x2c, 0x40, 0x3f, 0x00};
- 自定義按鍵
- #define UP 11//定義方向鍵上為Arduino上的11號(hào)引腳
- #define DOWN 10//定義方向鍵上為Arduino上的10號(hào)引腳
- #define LEFT 9//定義方向鍵上為Arduino上的9號(hào)引腳
- #define RIGHT 8//定義方向鍵上為Arduino上的8號(hào)引腳
- #define A 7//定義方向鍵上為Arduino上的7號(hào)引腳
- #define B 6//定義方向鍵上為Arduino上的6號(hào)引腳
- 變量
- boolean metal;
- boolean refresh = true;
- byte EX = 0;
- byte EY = 0; //當(dāng)前顯示位置
- int Nx, Ny;
- byte ZQ; //周期
- byte x, y;
- const byte AM[10][18] PROGMEM = { //排列方式
- {1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 2},
- {3, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 5, 6, 7, 8, 9, 10},
- {11, 12, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 13, 14, 15, 16, 17, 18},
- {19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36},
- {37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54},
- {55, 56, 0, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86},
- {87, 88, 0, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118},
- {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0},
- {0, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 0, 0},
- {0, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 0, 0}
- const byte non[24] PROGMEM = { //非金屬
- 1, 2,
- 5, 6, 7, 8, 9, 10,
- 14, 15, 16, 17, 18,
- 33, 34, 33, 36,
- 52, 53, 54,
- 85, 86,
- 117, 118,
- const byte Radius[107] PROGMEM = { //半徑
- 78, 100, 154, 113, 95, 86, 80, 66, 64, 100,
- 191, 160, 143, 134, 130, 104, 162, 100, 234, 197, 164,
- 145, 135, 127, 132, 127, 126, 124, 128, 139, 140, 140,
- 150, 160, 111, 114, 250, 215, 180, 160, 148, 140, 135,
- 132, 134, 137, 144, 157, 166, 158, 160, 170, 195, 133,
- 271, 224, 184, 182, 183, 182, 163, 180, 204, 180, 178,
- 177, 177, 176, 175, 194, 173, 159, 148, 141, 146, 134,
- 136, 139, 144, 162, 173, 175, 170, 170, 153, 153, 153,
- 153, 188, 180, 160, 155, 158, 164, 173, 142, 142, 142,
- 142, 142, 142, 142, 142, 142, 142, 142, 142,
- const byte mass[] PROGMEM = { //相對(duì)質(zhì)量
- 10, 8, 40, 3, 69, 41, 90, 12, 10, 81, 12, 1, 14, 1,
- 16, 0, 19, 00, 20, 18, 22, 99, 24, 31, 26, 98, 23, 9,
- 30, 97, 32, 6, 35, 45, 39, 95, 39, 10, 40, 8, 44, 96,
- 47, 87, 50, 94, 52, 0, 54, 94, 55, 85, 58, 93, 58, 69,
- 63, 55, 65, 38, 69, 72, 72, 63, 74, 92, 78, 96, 79, 90,
- 83, 80, 85, 47, 87, 62, 88, 91, 91, 22, 92, 91, 95, 96,
- 98, 0, 10, 11, 10, 29, 10, 64, 10, 79, 11, 24, 11, 48,
- 11, 87, 12, 18, 12, 76, 12, 69, 13, 13, 13, 29, 13, 73,
- 13, 89, 14, 1, 14, 9, 14, 42, 14, 50, 15, 4, 15, 20,
- 15, 73, 15, 89, 16, 25, 16, 49, 16, 73, 16, 89, 17, 31,
- 17, 50, 17, 85, 18, 9, 18, 38, 18, 62, 19, 2, 19, 22,
- 19, 51, 19, 70, 20, 6, 20, 44, 20, 72, 20, 90, 20, 90,
- 21, 0, 22, 20, 22, 30, 22, 60, 22, 70, 23, 20, 23, 10,
- 23, 80, 23, 70, 24, 40, 24, 30, 24, 70, 24, 70, 25, 10,
- 25, 20, 25, 70, 25, 80, 25, 90, 26, 20, 26, 50, 26, 80,
- 27, 10, 27, 00, 27, 70, 27, 60, 28, 10, 28, 00, 28, 50,
- 28, 40, 28, 90, 28, 80, 29, 30, 29, 40, 29, 40, 30,
- const byte AC[118][7] PROGMEM = { //結(jié)構(gòu)
- {1, 0, 0, 0, 0, 0, 0},
- {2, 0, 0, 0, 0, 0, 0},
- {2, 1, 0, 0, 0, 0, 0},
- {2, 2, 0, 0, 0, 0, 0},
- {2, 3, 0, 0, 0, 0, 0},
- {2, 4, 0, 0, 0, 0, 0},
- {2, 5, 0, 0, 0, 0, 0},
- {2, 6, 0, 0, 0, 0, 0},
- {2, 7, 0, 0, 0, 0, 0},
- {2, 8, 0, 0, 0, 0, 0},
- {2, 8, 1, 0, 0, 0, 0},
- {2, 8, 2, 0, 0, 0, 0},
- {2, 8, 3, 0, 0, 0, 0},
- {2, 8, 4, 0, 0, 0, 0},
- {2, 8, 5, 0, 0, 0, 0},
- {2, 8, 6, 0, 0, 0, 0},
- {2, 8, 7, 0, 0, 0, 0},
- {2, 8, 8, 0, 0, 0, 0}, //18
- {2 , 8 , 8 , 1, 0, 0, 0},
- {2 , 8 , 8 , 2, 0, 0, 0},
- {2 , 8 , 9 , 2, 0, 0, 0},
- {2 , 8 , 10 , 2, 0, 0, 0},
- {2 , 8 , 11 , 2, 0, 0, 0},
- {2 , 8 , 13 , 1, 0, 0, 0},
- {2 , 8 , 13 , 2, 0, 0, 0},
- {2 , 8 , 14 , 2, 0, 0, 0},
- {2 , 8 , 15 , 2, 0, 0, 0},
- {2 , 8 , 16 , 2, 0, 0, 0},
- {2 , 8 , 18 , 1, 0, 0, 0},
- {2 , 8 , 18 , 2, 0, 0, 0},
- {2 , 8 , 18 , 3, 0, 0, 0},
- {2 , 8 , 18 , 4, 0, 0, 0},
- {2 , 8 , 18 , 5, 0, 0, 0},
- {2 , 8 , 18 , 6, 0, 0, 0},
- {2 , 8 , 18 , 7, 0, 0, 0},
- {2 , 8 , 18 , 8, 0, 0, 0,},
- {2 , 8 , 18 , 8 , 1, 0, 0},
- {2 , 8 , 18 , 8 , 2, 0, 0},
- {2 , 8 , 18 , 9 , 2, 0, 0},
- {2 , 8 , 18 , 10, 2, 0, 0},
- {2 , 8 , 18 , 12, 1, 0, 0},
- {2 , 8 , 18 , 13, 1, 0, 0},
- {2 , 8 , 18 , 13, 2, 0, 0},
- {2 , 8 , 18 , 15, 1, 0, 0},
- {2 , 8 , 18 , 16, 1, 0, 0},
- {2 , 8 , 18 , 18 , 0, 0, 0},
- {2 , 8 , 18 , 18 , 1 , 0, 0},
- {2 , 8 , 18 , 18 , 2 , 0, 0},
- {2 , 8 , 18 , 18 , 3 , 0, 0},
- {2 , 8 , 18 , 18 , 4 , 0, 0},
- {2 , 8 , 18 , 18 , 5 , 0, 0},
- {2 , 8 , 18 , 18 , 6 , 0, 0},
- {2 , 8 , 18 , 18 , 7 , 0, 0},
- {2 , 8 , 18 , 18 , 8 , 0, 0},
- {2 , 8 , 18 , 18 , 8 , 1, 0},
- {2 , 8 , 18 , 18 , 8 , 2, 0},
- {2 , 8 , 18 , 18 , 9 , 2, 0},
- {2 , 8 , 18 , 19 , 9 , 2, 0},
- {2 , 8 , 18 , 21 , 8 , 2, 0},
- {2 , 8 , 18 , 22 , 8 , 2, 0},
- {2 , 8 , 18 , 23 , 8 , 2, 0},
- {2 , 8 , 18 , 24 , 8 , 2, 0},
- {2 , 8 , 18 , 25 , 8 , 2, 0},
- {2 , 8 , 18 , 25 , 9 , 2, 0},
- {2 , 8 , 18 , 27 , 8 , 2, 0},
- {2 , 8 , 18 , 28 , 8 , 2, 0},
- {2 , 8 , 18 , 29 , 8 , 2, 0},
- {2 , 8 , 18 , 30 , 8 , 2, 0},
- {2 , 8 , 18 , 31 , 8 , 2, 0},
- {2 , 8 , 18 , 32 , 8 , 2, 0},
- {2 , 8 , 18 , 32 , 9 , 2, 0},
- {2 , 8 , 18 , 32 , 10, 2, 0}, //72
- {2 , 8 , 18 , 32 , 11, 2 , 0},
- {2 , 8 , 18 , 32 , 12, 2 , 0},
- {2 , 8 , 18 , 32 , 13, 2 , 0},
- {2 , 8 , 18 , 32 , 14, 2 , 0},
- {2 , 8 , 18 , 32 , 15, 2 , 0},
- {2 , 8 , 18 , 32 , 17, 1 , 0},
- {2 , 8 , 18 , 32 , 18, 1 , 0},
- {2 , 8 , 18 , 32 , 18, 2 , 0},
- {2 , 8 , 18 , 32 , 18, 3 , 0},
- {2 , 8 , 18 , 32 , 18, 4 , 0},
- {2 , 8 , 18 , 32 , 18, 5 , 0},
- {2 , 8 , 18 , 32 , 18, 6 , 0},
- {2 , 8 , 18 , 32 , 18, 7 , 0},
- {2 , 8 , 18 , 32 , 18, 8 , 0},
- {2 , 8 , 18 , 32 , 18, 8 , 1},
- {2 , 8 , 18 , 32 , 18, 8 , 2},
- {2 , 8 , 18 , 32 , 18, 9 , 2},
- {2 , 8 , 18 , 32 , 18, 10, 2},
- {2 , 8 , 18 , 32 , 20, 9 , 2},
- {2 , 8 , 18 , 32 , 21, 9 , 2},
- {2 , 8 , 18 , 32 , 22, 9 , 2},
- {2 , 8 , 18 , 32 , 24, 8 , 2},
- {2 , 8 , 18 , 32 , 25, 8 , 2},
- {2 , 8 , 18 , 32 , 25, 9 , 2},
- {2 , 8 , 18 , 32 , 27, 8 , 2},
- {2 , 8 , 18 , 32 , 28, 8 , 2},
- {2 , 8 , 18 , 32 , 29, 8 , 2},
- {2 , 8 , 18 , 32 , 30, 8 , 2},
- {2 , 8 , 18 , 32 , 31, 8 , 2},
- {2 , 8 , 18 , 32 , 32, 8 , 2},
- {2 , 8 , 18 , 32 , 32, 9 , 2},
- {2 , 8 , 18 , 32 , 32, 10, 2},
- {2 , 8 , 18 , 32 , 32, 11, 2},
- {0, 0, 0, 0, 0, 0, 0,},
- //元素名稱
- const byte EN[354] PROGMEM = {72, 32, 32, 72, 101, 32, 76, 105, 32, 66, 101, 32, 66, 32, 32, 67, 32, 32, 78, 32, 32, 79, 32, 32, 70, 32, 32, 78, 101, 32, 78, 97, 32, 77, 103, 32, 65, 108, 32, 83, 105, 32, 80, 32, 32, 83, 32, 32, 67, 108, 32, 65, 114, 32, 75, 32, 32, 67, 97, 32, 83, 99, 32, 84, 105, 32, 86, 32, 32, 67, 114, 32, 77, 110, 32, 70, 101, 32, 67, 111, 32, 78, 105, 32, 67, 117, 32, 90, 110, 32, 71, 97, 32, 71, 101, 32, 65, 115, 32, 83, 101, 32, 66, 114, 32, 75, 114, 32, 82, 98, 32, 83, 114, 32, 89, 32, 32, 90, 114, 32, 78, 98, 32, 77, 111, 32, 84, 99, 42, 82, 117, 32, 82, 104, 32, 80, 100, 32, 65, 103, 32, 67, 100, 32, 73, 110, 32, 83, 110, 32, 83, 98, 32, 84, 101, 32, 73, 32, 32, 88, 101, 32, 67, 115, 32, 66, 97, 32, 76, 97, 32, 67, 101, 32, 80, 114, 32, 78, 100, 32, 80, 109, 32, 83, 109, 32, 69, 117, 32, 71, 100, 32, 84, 98, 32, 68, 121, 32, 72, 111, 32, 69, 114, 32, 84, 109, 32, 89, 98, 32, 76, 117, 32, 72, 102, 32, 84, 97, 32, 87, 32, 32, 82, 101, 32, 79, 115, 32, 73, 114, 32, 80, 116, 32, 65, 117, 32, 72, 103, 32, 84, 105, 32, 80, 98, 32, 66, 105, 32, 80, 111, 42, 65, 116, 42, 82, 110, 42, 70, 114, 42, 82, 97, 42, 65, 99, 42, 84, 104, 42, 80, 97, 42, 85, 32, 42, 78, 112, 42, 80, 117, 42, 65, 109, 42, 67, 109, 42, 66, 107, 42, 67, 102, 42, 69, 115, 42, 70, 109, 42, 77, 100, 42, 78, 111, 42, 76, 114, 42, 82, 102, 42, 68, 98, 42, 83, 103, 42, 66, 104, 42, 72, 115, 42, 77, 116, 42, 68, 115, 42, 82, 103, 42, 67, 110, 42, 78, 104, 42, 70, 108, 42, 77, 101, 42, 76, 118, 42, 84, 115, 42, 79, 103, 42,};
- 只循環(huán)一次
- void setup() {
- //串口通訊波特率設(shè)置
- //初始化按鈕
- pinMode(UP, INPUT);//定義方向UP引腳狀態(tài)
- pinMode(DOWN, INPUT);//定義方向DOWN引腳狀態(tài)
- pinMode(LEFT, INPUT);//定義方向LEFT引腳狀態(tài)
- pinMode(RIGHT, INPUT);//定義方向RIGHT引腳狀態(tài)
- pinMode(A, INPUT);//定義按鍵A引腳狀態(tài)
- pinMode(B, INPUT);//定義按鍵B引腳狀態(tài)
- //啟動(dòng)動(dòng)畫
- for (int i = 63; i >= 46; i--) {
- u8g.firstPage();
- do {
- u8g.drawBitmapP(26, i, 9, 8, HWT);
- if (i == 46) u8g.drawBitmapP(15, 9, 13, 17, title);
- } while ( u8g.nextPage() );
- delay(1000);
- 不停循環(huán)
- void loop() {
- 按鍵輸入
- if (digitalRead(UP) == HIGH) {
- if (EY > 0) {
- EY--;
- refresh = true;
- if (digitalRead(DOWN) == HIGH) {
- if (EY < 9) {
- EY++;
- refresh = true;
- if (digitalRead(LEFT) == HIGH) {
- if (EX > 0) {
- EX--;
- refresh = true;
- if (digitalRead(RIGHT) == HIGH) {
- if (EX < 17) {
- EX++;
- refresh = true;
- if (digitalRead(A) == HIGH) {
- if (pgm_read_byte_near(&AM[EY][EX]) != 0) {
- refresh = true;
- show();
- } else {
- if (EX == 2 && EY == 5) {
- EX = 1;
- EY = 8;
- refresh = true;
- if (EX == 2 && EY == 6) {
- EX = 1;
- EY = 9;
- refresh = true;
- delay(200); //防止按鍵短時(shí)間觸發(fā)兩遍
- 顯示
- if (refresh == true) {
- u8g.firstPage();
- do {
- DrawTable();
- refresh = false;
- 渲染表格
- void DrawTable() {
- Nx = EX - 3;
- Ny = EY - 1;
- for (int y = 1; y <= 3; y++) {
- for (int x = 1; x <= 7; x++) {
- if (x == 4 && y == 2) {
- //處于選擇位置 反色處理開始
- u8g.setColorIndex(1);
- u8g.drawBox(x * 16 - 1, y * 16 - 1, 17, 17); //白色背景
- u8g.setColorIndex(0);
- if (Nx >= 0 && Ny >= 0 && Nx <= 17 && Ny <= 9) {
- u8g.setFont(u8g_font_u8glib_4); //切換u8g_font_u8glib_4字體
- if (pgm_read_byte_near(&AM[Ny][Nx]) != 0) { //如果當(dāng)前位置存在元素
- if (x == 4 && y == 2) {} else {
- u8g.drawFrame(x * 16 - 1, y * 16 - 1, 17, 17); //畫格子
- u8g.setPrintPos(x * 16 + 1, y * 16 + 6); //在坐標(biāo)開始畫
- u8g.print(pgm_read_byte_near(&AM[Ny][Nx])); //原子序號(hào)
- //元素名稱
- u8g.setPrintPos(x * 16 + 1, y * 16 + 6 + 8); //在坐標(biāo)開始畫 第1個(gè)字符
- u8g.print((char)pgm_read_byte_near(&EN[(3 * pgm_read_byte_near(&AM[Ny][Nx])) - 3])); //元素名稱
- u8g.setPrintPos(x * 16 + 1 + 5, y * 16 + 6 + 8); //在坐標(biāo)開始畫 第2個(gè)字符
- u8g.print((char)pgm_read_byte_near(&EN[(3 * pgm_read_byte_near(&AM[Ny][Nx])) - 2])); //元素名稱
- u8g.setPrintPos(x * 16 + 1 + 5 + 5, y * 16 + 6 + 8); //在坐標(biāo)開始畫 第3個(gè)字符
- u8g.print((char)pgm_read_byte_near(&EN[(3 * pgm_read_byte_near(&AM[Ny][Nx])) - 1])); //元素名稱
- } else {
- //判斷是否為鑭系和錒系
- if (Nx == 2 && Ny == 5) {
- u8g.setPrintPos(x * 16 + 1, y * 16 + 10); //在坐標(biāo)開始畫
- u8g.print("La X");
- } else {
- if (Nx == 2 && Ny == 6) {
- u8g.print("Ac X");
- } else {
- //畫背景
- u8g.drawLine(x * 16 + 3, y * 16 + 3, x * 16 + 12, y * 16 + 12);
- u8g.drawLine(x * 16 + 12, y * 16 + 3, x * 16 + 3, y * 16 + 12);
- //處于選擇位置 反色處理結(jié)束
- Nx++;
- //畫周期
- if (Ny + 1 <= 7 && Ny + 1 > 0) {
- u8g.setFont(u8g_font_courB08); //切換u8g_font_courB08字體
- u8g.setPrintPos(3, y * 16 + 11); //在坐標(biāo)開始畫
- u8g.print(Ny + 1);
- Nx = EX - 3;
- Ny++;
- if (EY <= 7) { //在鑭系和錒系關(guān)閉族的顯示
- //畫族
- u8g.setPrintPos(69 - EX * 16, 6); //在坐標(biāo)開始畫
- u8g.print(F("IA IIA IIIB IVB VB VIB VIIB VIII VIII VIII IB IIB IIIA IVA VA"));
- if (EX >= 12) {
- //清除渲染錯(cuò)誤區(qū)域
- u8g.drawBox(64 - EX * 16, 0, 112, 14); //清空重繪區(qū)
- //繪后半部分
- u8g.setPrintPos(48 - EX * 16, 6); //在坐標(biāo)開始畫
- u8g.print(F(" VIA VIIA 0 "));
- if (EX <= 3) {
- u8g.drawBox(0, 0, 48 - EX * 16, 14); //清空重繪區(qū)
- 詳細(xì)資料
- void show() {
- byte p = 1;
- while (digitalRead(B) == LOW)
- if (p > 1) {
- p--;
- refresh = true;
- if (p < 3) {
- p++;
- refresh = true;
- refresh = false;
- u8g.firstPage();
- do {
- if (p == 1) {
- //資料頁(yè)
- u8g.setFont(u8g_font_10x20);
- u8g.setPrintPos(60, 14);
- u8g.print((char)pgm_read_byte_near(&EN[(3 * pgm_read_byte_near(&AM[EY][EX])) - 3])); //元素名稱
- u8g.setPrintPos(74, 14);
- u8g.print((char)pgm_read_byte_near(&EN[(3 * pgm_read_byte_near(&AM[EY][EX])) - 2])); //元素名稱
- u8g.setPrintPos(92, 14);
- //是否放射性
- if (pgm_read_byte_near(&EN[(3 * pgm_read_byte_near(&AM[EY][EX])) - 1]) == 42) u8g.drawBitmapP(112, 19, 2, 16, radiation); //放射性圖標(biāo)
- //是否金屬
- metal = true;
- for (int i = 0; i <= 23; i++) {
- if (pgm_read_byte_near(&non[i]) == pgm_read_byte_near(&AM[EY][EX])) {
- metal = false;
- if (metal == true) u8g.drawBitmapP(112, 36, 2, 16, Bmrtal); //金屬圖標(biāo)
- u8g.print(pgm_read_byte_near(&AM[EY][EX])); //原子序數(shù)
- u8g.setFont(u8g_font_tpssb);
- u8g.drawBitmapP(2, 1, 7, 11, Element);
- u8g.drawBitmapP(2, 21, 7, 11, Relative);
- u8g.drawBitmapP(1, 40, 7, 12, RM);
- u8g.setPrintPos(61, 30);
- if (pgm_read_byte_near(&AM[EY][EX]) < 108) {
- u8g.print(float(pgm_read_byte_near(&Radius[pgm_read_byte_near(&AM[EY][EX]) - 1])) / 100); //半徑
- } else {
- u8g.print("?.???");
- u8g.setPrintPos(61, 52);
- if (pgm_read_byte_near(&AM[EY][EX]) <= 4) {
- u8g.print(pgm_read_byte_near(&mass[2 * pgm_read_byte_near(&AM[EY][EX]) - 2]) / float(10) + pgm_read_byte_near(&mass[2 * pgm_read_byte_near(&AM[EY][EX]) - 1]) / float(1000), 3); //相對(duì)質(zhì)量
- } else {
- if (pgm_read_byte_near(&AM[EY][EX]) <= 43) {
- u8g.print(pgm_read_byte_near(&mass[2 * pgm_read_byte_near(&AM[EY][EX]) - 2]) + pgm_read_byte_near(&mass[2 * pgm_read_byte_near(&AM[EY][EX]) - 1]) / float(100), 2); //相對(duì)質(zhì)量
- } else {
- u8g.print(pgm_read_byte_near(&mass[2 * pgm_read_byte_near(&AM[EY][EX]) - 2]) * 10 + pgm_read_byte_near(&mass[2 * pgm_read_byte_near(&AM[EY][EX]) - 1]) / float(10), 1); //相對(duì)質(zhì)量
- u8g.drawLine(0, 35, 128, 35);
- u8g.drawLine(0, 17, 128, 17);
- } else {
- if (p == 2) {
- //結(jié)構(gòu)頁(yè)
- //計(jì)算原子層數(shù)
- if (EY <= 7) {
- ZQ = EY;
- } else {
- if (EY == 8) {
- ZQ = 5;
- } else {
- if (EY == 9) {
- ZQ = 6;
- //46號(hào)不規(guī)則
- if (pgm_read_byte_near(&AM[EY][EX]) == 46) ZQ = 3;
- u8g.drawDisc(11, 30, 16); //畫實(shí)心圓
- for (int i = 1; i <= ZQ + 1; i++) {
- u8g.drawCircle(11, 30, 12 + i * 15); //渲染運(yùn)行軌道
- //原子序數(shù)
- u8g.setPrintPos(-2, 35);
- u8g.print("+");
- u8g.setPrintPos(6, 35);
- u8g.drawBox(29, 26, 95, 13); //清理軌道
- //標(biāo)上電子數(shù)
- u8g.setFont(u8g_font_blipfest_07);
- for (int i = 0; i <= ZQ; i++) {
- u8g.setPrintPos(39 + i * 14, 34);
- if (pgm_read_byte_near(&AM[EY][EX]) < 105) {
- u8g.print(pgm_read_byte_near(&AC[pgm_read_byte_near(&AM[EY][EX]) - 1][i]));
- } else {
- u8g.print("?");
- } else {
- if (p == 3) {
- u8g.drawBitmapP(22, 1, 11, 12, VA);
- u8g.drawBox(0, 16, 128, 1);
- u8g.drawBox(64, 16, 1, 128);
- u8g.setPrintPos(16, 34);
- u8g.print("Max");
- u8g.setPrintPos(85, 34);
- u8g.print("Min");
- u8g.setPrintPos(27, 51);
- u8g.print(pgm_read_byte_near(&AC[pgm_read_byte_near(&AM[EY][EX]) - 1][ZQ])); //打印最外層電子
- u8g.setPrintPos(95, 51);
- if (metal == true) {
- //金屬?zèng)]有負(fù)假
- u8g.print("0");
- } else {
- if (pgm_read_byte_near(&AC[pgm_read_byte_near(&AM[EY][EX]) - 1][ZQ]) >= 4 && (pgm_read_byte_near(&AC[pgm_read_byte_near(&AM[EY][EX]) - 1][ZQ]) != 8)) {
- u8g.print(8 - pgm_read_byte_near(&AC[pgm_read_byte_near(&AM[EY][EX]) - 1][ZQ]));
- u8g.setPrintPos(80, 51);
- u8g.print("-");
- } else {
- u8g.print("0");
- refresh = true; //返回后進(jìn)行畫面刷新
2018-4-15 05:24 上傳
