查看: 1859|回復(fù): 1
串口和計算機通信
ID:300215 發(fā)表于 2018-4-14 20:53 | 顯示全部樓層 |閱讀模式
   #include <reg51.h>
   #include <string.h>
   #define INBUF_LEN 4 //數(shù)據(jù)長度
   unsigned char ch;
//   unsigned char checksum,count3;
   bit read_flag= 0 ;
   void init_serialcom( void )
       SCON = 0x50 ;  //SCON: serail mode 1, 8-bit UART, enable ucvr
           TMOD |= 0x20 ; //TMOD: timer 1, mode 2, 8-bit reload
           PCON |= 0x80 ; //SMOD=1;
           TH1 = 0xFA ;   //Baud:9600 fosc=11.0592MHz
           IE |= 0x90 ;   //Enable Serial Interrupt
           TR1 = 1 ;     // timer 1 run
           TI=1;
//向串口發(fā)送一個字符
          void send_char_com( unsigned char ch)
             SBUF=ch;
             while (TI== 0);
                 TI= 0 ;
//向串口發(fā)送一個字符串,strlen為該字符串長度
void send_string_com( unsigned char *str, unsigned int strlen)
     unsigned int k= 0 ;
         do { send_char_com(*(str + k)); k++; }
         while (k < strlen);
//串口接收中斷函數(shù)
void serial () interrupt 4 using 3
    if (RI)
                   RI = 0 ;
                   ch=SBUF;
                   read_flag= 1 ; //就置位取數(shù)標志
main()
            init_serialcom(); //初始化串口
                    while ( 1 )
                               if (read_flag) //如果取數(shù)標志已置位,就將讀到的數(shù)從串口發(fā)出
                                                    read_flag= 0 ; //取數(shù)標志清0
                                                        send_char_com(ch);
ID:277550 發(fā)表于 2018-4-14 23:01 | 顯示全部樓層
這已經(jīng)可以通訊了,只是接收一個字符
