查看: 2452|回復: 0
12864的STC89C52 漢字顯示
ID:308393 發(fā)表于 2018-4-15 10:17 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg52.h>
#include<stdlib.h>
sbit wr=P2^5;
sbit rs=P2^6;
sbit e=P2^7;
sbit psb=P3^2;
sbit key1=P3^1;
sbit key2=P3^0;
uchar k,flag;
uchar code table[]="在破敗中崛起 ,在寂滅中復蘇 ,滄海成塵 ,雷電枯竭 ,那一縷幽霧又一次臨近大地 ,世間的枷鎖被打開了 ,一個全新的世界就此揭開            ";
void delayms(uint x)
uchar y;
for(;x>0;x--)
for(y=110;y>0;y--);
void timeinit()
TMOD=0X01;
TH0=(65536-50000)/256;
TL0=(65536-50000)%256;
EA=1;
ET0=1;
TR0=1;
void write_com(uchar com)
wr=0;
rs=0;
e=0;
P0=com;
delayms(1);
e=1;
delayms(1);
e=0;
void write_date(uchar date)
wr=0;
rs=1;
e=0;
P0=date;
delayms(1);
e=1;
delayms(1);
e=0;
void init()
psb=1;
write_com(0x30);
delayms(2);
write_com(0x0c);
delayms(2);
write_com(0x01);
delayms(2);
void keyscan()
if(key1==0)
  delayms(10);
  if(key1==0)
   write_com(0x01);
   k=k+64;
   if(k>64) k=0;
while(!key1);
if(key2==0)
  delayms(10);
  if(key2==0)
   if(k>0)
   k=k-16;
while(!key2);
uchar i;
init();
timeinit();
delayms(5);
write_com(0x80);
delayms(2);
for(i=0;i<16;i++)
  write_date(table[i+k]);
  delayms(2);
write_com(0x90);
delayms(2);
for(i=0;i<16;i++)
  write_date(table[i+16+k]);
  delayms(2);
write_com(0x88);
delayms(2);
  for(i=0;i<16;i++)
  write_date(table[i+32+k]);
  delayms(2);
  write_com(0x98);
  delayms(2);
  for(i=0;i<16;i++)
  write_date(table[i+48+k]);
  delayms(2);
void time0() interrupt 1
     keyscan();
Powered by 單片機教程網
