查看: 3070|回復(fù): 6
為什么該程序運(yùn)行一點(diǎn)都沒(méi)反應(yīng)求大佬詳細(xì)解答,感覺(jué)自己寫(xiě)的是超簡(jiǎn)簡(jiǎn)化版求大佬指....
5黑幣
#include<reg52.h>
#include<intrins.h>
#define Lcd1602_DB  P0
sbit Lcd1602_RS = P2^6;
sbit Lcd1602_RW = P2^5;
sbit Lcd1602_EN = P2^7;
sbit Trig = P2^1;
sbit Echo = P2^0;
static unsigned char DisNum = 0;
unsigned int  time=0;
unsigned long S=0;
bit      flag =0;
unsigned char disdat[4] ={ 0,0,0,0,};
void delayms(unsigned int ms)
        unsigned char i=100,j;
        for(;ms;ms--)
                while(--i)
                        j=10;
                        while(--j);
void Lcd1602_Write_com(unsigned char cmd)
        Lcd1602_RS=0;
        P0=cmd;
        delayms(1);
        Lcd1602_EN =1;
    delayms(1);
        Lcd1602_EN =0;
    delayms(1);
void Lcd1602_Write_Data(unsigned char shu)
        Lcd1602_RS=1;
        P0=shu;
        delayms(1);
        Lcd1602_EN =1;
    delayms(1);
        Lcd1602_EN =0;
        delayms(1);
void write_1602(uchar add,uchar sj)
        Lcd1602_Write_com(0*80+0*40+add);
        Lcd1602_Write_Data(sj) ;
void zifuchuan(uchar *ch)
    while(*ch!=0)
    Lcd1602_Write_Data(*ch++);
        delayms(1);
}        //仔細(xì)看一下那個(gè)程序
void LcdInit()
         Lcd1602_Write_Data(0x38);
         Lcd1602_Write_Data(0x0c);
         Lcd1602_Write_Data(0x06);
         Lcd1602_Write_Data(0x01);
         Lcd1602_Write_Data(0x80);
         zifuchuan("TFB") ;
  void Conut(void)
         time=TH0*256+TL0;
         TH0=0;
         TL0=0;
         S=time/58;
         disdat[0]=S%1000/100;
         disdat[1]=S%1000%100/10;
         disdat[2]=S%1000%10 %10;
         write_1602(1,disdat[1]+0*30);
         write_1602(2,disdat[2]+0*30);
         write_1602(3,disdat[3]+0*30);
         write_1602(5,'c');
     write_1602(6,'m');
void zd0() interrupt 1
    flag=1;
void  StartModule()
          Trig=1;
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          Trig=0;
void main(void)
         delayms(1);
     LcdInit();
         TMOD=0x01;
         TH0=0;
         TL0=0;
         ET0=1;
         EA=1;
         StartModule();
     while(!Echo);
         TR0=1;
     while(Echo);
         TR0=0;
     Conut();
     delayms(1);
最佳答案
查看完整內(nèi)容
LCD初始化程序?qū)戝e(cuò)了!改這樣試試 void LcdInit() { Lcd1602_Write_com(0x38); Lcd1602_Write_com(0x0c); Lcd1602_Write_com(0x06); Lcd1602_Write_com(0x01); Lcd1602_Write_com(0x80); zifuchuan("TFB") ; }
ID:213173 發(fā)表于 2018-4-16 15:13 | 只看該作者
523633035 發(fā)表于 2018-4-16 21:14
求指點(diǎn)謝謝,謝謝 謝謝。
void LcdInit()
        zifuchuan("TFB") ;
ID:301339 發(fā)表于 2018-4-16 21:09 | 只看該作者
大佬們這是單片機(jī)超聲波測(cè)距的程序
ID:301339 發(fā)表于 2018-4-16 21:14 | 只看該作者
RE: 為什么該單片機(jī)超聲波測(cè)距程序運(yùn)行沒(méi)反應(yīng)求大佬詳細(xì)解答求指點(diǎn)急
求指點(diǎn)謝謝,謝謝 謝謝。
ID:301339 發(fā)表于 2018-4-17 14:52 | 只看該作者
wulin 發(fā)表于 2018-4-17 10:40
void LcdInit()
對(duì)確實(shí)是這樣COM設(shè)置的是地址這個(gè)地方粘貼時(shí)出錯(cuò)了,謝謝�?墒沁€是顯示不出來(lái)求大佬于百忙中再指點(diǎn)一下謝謝
ID:213173 發(fā)表于 2018-4-17 16:24 | 只看該作者
523633035 發(fā)表于 2018-4-17 14:52
對(duì)確實(shí)是這樣COM設(shè)置的是地址這個(gè)地方粘貼時(shí)出錯(cuò)了,謝謝。可是還是顯示不出來(lái)求大佬于百忙中再指點(diǎn)一下 ...
我沒(méi)有超聲波傳感器用來(lái)測(cè)試,只是把LCD1602驅(qū)動(dòng)程序修改后驗(yàn)證了一下,可以正常顯示字符。你如果還有問(wèn)題可以按模塊逐一調(diào)試,分別調(diào)通了再統(tǒng)一調(diào)試,否則你搞不清問(wèn)題在哪里。
ID:213173 發(fā)表于 2018-4-17 17:50 | 只看該作者
對(duì)確實(shí)是這樣COM設(shè)置的是地址這個(gè)地方粘貼時(shí)出錯(cuò)了,謝謝�?墒沁€是顯示不出來(lái)求大佬于百忙中再指點(diǎn)一下 ...
下面兩個(gè)函數(shù)都寫(xiě)錯(cuò)了,改后的效果是不是你想要的?
        Lcd1602_Write_com(0x80+0x40+add);
        Lcd1602_Write_Data(sj);
void Conut(void)
        time=TH0*256+TL0;
        TH0=0;
        TL0=0;
//        S=time/58;
        S=125;//這是隨便寫(xiě)的數(shù),用以驗(yàn)證此程序
        write_1602(1,disdat[0]+0x30);
        write_1602(2,disdat[1]+0x30);
        write_1602(3,disdat[2]+0x30);
        write_1602(5,'c');
        write_1602(6,'m');
