現(xiàn)象是這樣的旋轉(zhuǎn)編碼器時(shí)轉(zhuǎn)的慢沒有事!轉(zhuǎn)的快單片機(jī)就死機(jī)了!大家?guī)臀铱纯词鞘裁磫栴}!
- #include <STC12C5A60S2.H>
- typedef unsigned int uint;
- typedef unsigned char uchar;
- sbit wela = P1^1;
- sbit dula = P1^2;
- sbit LED=P1^0;
- sbit AA=P3^7; //編碼加
- sbit BB=P3^6; //編碼減
- uint flage,status,current_bmb,counter = 0,
- p,dataa;
- float PA;
- static uint m,tm;
- unsigned char code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,
- 0x07,0x7f,0x6f};
- void delay(unsigned char i)
- unsigned char j,k;
- for(j=i;j>0;j--)
- for(k=110;k>0;k--);
- void datakae()
- status=BB; //一直賦值!
- while(0==AA)//當(dāng)AA條件允許進(jìn)入主循環(huán)!并且BB上次的值保持為臨近狀態(tài)!
- current_bmb=BB;
- flage=1;
- if(1==flage)
- flage=0;
- if((0==current_bmb)&&(1==status))
- tm++;
- if(tm>=1000)
- tm=1000;
- if((0==status)&&(1==current_bmb))
- tm--;
- if(tm<=10)
- tm=10;
- void display()
- P0=table[dataa%10];//個(gè)
- dula=1;
- dula=0;
- P2=0xfe;
- wela=1;
- wela=0;
- delay(2);
- P0=table[dataa%100/10]; //十
- dula=1;
- dula=0;
- P2=0xfd;
- wela=1;
- wela=0;
- delay(2);
- P0=table[dataa%1000/100];
- dula=1;
- dula=0;
- P2=0xfb; // 百
- wela=1;
- wela=0;
- delay(2);
- P0=table[dataa%10000/1000];
- dula=1;
- dula=0;
- P2=0xf7;//千
- wela=1;
- wela=0;
- delay(2);
- void huansuan()
- m=10000/tm;
- dataa=tm;
- //定時(shí)器T1初始化
- void initial()
- LED=0;
- P1M1 = 0x00;
- P1M0 = 0xFF;
- counter=0;
- EA = 1;
- TR0 = 1;
- TMOD = 0x01;
- TH0 = (65535-1000)/256; //1ms
- TL0 = (65535-1000)%256;
- ET0 = 1;
- //主程序
- void main()
- tm=250;
- initial();
- while(1)
- huansuan();
- datakae();
- display();
- LED=0;
- void timer0_int()interrupt 1 using 0
- TH0 = (65535-1000)/256;//1ms產(chǎn)生一次中斷
- counter++;
- if(counter==m)
- LED=1;
- for(p=0;p<150;p++);
- counter=0;
- } else LED=0;
