查看: 2287|回復(fù): 0
upsd3234A實(shí)現(xiàn)led燈25HZ程序
ID:311210 發(fā)表于 2018-4-18 21:15 | 只看該作者 回帖獎(jiǎng)勵(lì) |正序?yàn)g覽 |閱讀模式
本帖最后由 378498084 于 2018-4-18 21:16 編輯
#include "upsd_hardware.h"                // 開(kāi)發(fā)板硬件定義
#include "upsd3200.h"                        // UPSD單片機(jī)特殊寄存器聲明頭文件
#include <stdio.h>
sbit L1=P4^5;
static unsigned int idata timer0_tick;
unsigned int timer0_count(void);
#define TIMER0_VALUE-(((FREQ_OSC * 10L) / 12L) - 17L)#define Watchdog_Off()  WDKEY=0x55
void UartInit();                    //串口初始化程序
void UartInit()
        T2MOD = 0;                     //timer2
        T2CON = 0x30;
        RCAP2L = 0x8B;            //計(jì)數(shù)器重裝值
        RCAP2H = 0xFF;
        TL2 = 0x8B;                        //baud rate = 9600
        TH2 = 0xFF;
        SCON |= 0x52;                //mode 1, REN = 1,TI=1
        PCON = 0x00;
        TI = 1;
        TR2 = 1;                        //enable timer2
void timer0_init(void)         //         chushihua
              EA = 0;
                  timer0_tick = 0;
                  TR0 = 0;
                  TMOD &= 0xF0;
                  TMOD |= 0x01;
                  TL0 = (TIMER0_VALUE & 0x00FF);
                  TH0 = (TIMER0_VALUE >> 8);
                  PT0 = 1;
                  ET0 = 1;
                  TR0 = 1;
                  EA = 1;
static void timer0_isr(void) interrupt TF0_VECTOR using 1
                  TR0 = OFF;
                  TL0= (TIMER0_VALUE & 0x00FF);
                  TR0 = ON;
                  timer0_tick++;
unsigned int timer0_count(void)         //
                  unsigned int t;
                  EA = 0;
                  t = timer0_tick;
                  EA = 1;
                  return(t);
void main(void){
         Watchdog_Off();
         UartInit();
         timer0_init();
          if(timer0_tick==2)
             L1=!L1;
                 timer0_tick=0;
