本帖最后由 sdwfmt 于 2018-4-26 13:29 編輯
目前已經(jīng)有了利用單片機(jī)控制步進(jìn)電機(jī)的延時(shí)(按秒)、轉(zhuǎn)動(dòng)角度、等,需要在這個(gè)基礎(chǔ)上加上 一天三次啟動(dòng)的定時(shí)系統(tǒng)。有沒(méi)有碼農(nóng)知道怎么搞定的?
2018-4-26 13:27 上傳
源程序如下:
#include<reg52.h>
#include<stdio.h>
#include "lcd1602.h"
#include "eeprom.h"
#define N_ADDRESS 3
#define DIR_ADDRESS 7
#define SPEED_ADDRESS 12
#define SET_ANGLE_ADDRESS 5
#define SET_TIME_ADDRESS 12
#define MAX_PAGE 10 // 最大節(jié)點(diǎn)數(shù)
#define T0_INIT_DATA_10 100
#define T0_INIT_DATA_50ms 50000
#define Two_XiFen_Clk 400
unsigned char T0_NUM;
unsigned char T0_NUM_2;
unsigned char END_FLAG = 0;
unsigned char END_FLAG_2 = 0;
unsigned char S_FLAG = 0;
sbit SW1=P3^0; //四個(gè)獨(dú)立按鍵定義
sbit SW2=P3^1;
sbit SW5=P3^2;
sbit SW4=P3^3; // 暫調(diào)試
sbit SW3=P3^4;
sbit SW1=P1^3; //四個(gè)獨(dú)立按鍵定義
sbit SW2=P1^4;
sbit SW4=P1^2;
sbit SW5=P1^5;
sbit SW3=P1^6;
sbit MotorEn = P2^1; // 使能
sbit FX = P2^0; // 方向
sbit CLK = P2^2; // 脈沖
unsigned char g_MotorSt = 0; // 啟停
unsigned char g_MotorDir = 0; // 正反
unsigned int CLK_OUT_NUM = 0; // 脈沖計(jì)數(shù)
signed int MotorSpedNum = 0; // 速度檔
//float CUR_MotorAngle = 0.0; // 當(dāng)前角度
unsigned int CUR_MotorSpedQuan = 0; // 當(dāng)前圈數(shù)
//unsigned int SET_MotorQuan = 0; //
//unsigned int SET_MotorPulse = 0;
unsigned int CUR_Miao = 0;
unsigned int T0_INIT_DATA = 10;
unsigned char cMode = 0;
unsigned char s1_num;
unsigned int iSetData;
//signed char RL = 0; // 方向
//signed char iSet[3];
unsigned int SYS_NUM = 0;
unsigned char MotorTab[10] = {63, 42, 27, 18, 12, 8, 5, 3, 2};
//unsigned char MotorTab[10] = {25, 20, 16, 13, 9, 6, 4, 2, 1};
//unsigned int MotorSpedTab[6] = {400, 800, 1600, 3200, 6400, 12800};
//unsigned char MotorTab[10] = {63, 42, 27, 18, 12, 8, 5, 3, 2};
//unsigned int MotorSeparateTab[5] = {1, 2, 8, 16, 64}; // 細(xì)分
signed char EEPROM_Tab[8] = {0, 0, 0, 0, 0, 0, 0, 0};
unsigned char cur_page;
signed char page_num;
signed char set_page_num[2];
signed char set_jd_bai, set_jd_shi, set_jd_ge;
signed char set_sj_bai, set_sj_shi, set_sj_ge;
/********數(shù)據(jù)定義***********************************************************/
struct DataNum
signed char set_fx; // 方向
signed char set_sd; // 速度
signed int set_jd; // 角度
signed int set_time; // 間隔
struct DataNum StepData[7]; // 注意: 因?yàn)镾TC89C52芯片容量有限,這里采用最大7組連貫動(dòng)作
void delayms(xms);
void mDelay(unsigned int DelayTime); //延時(shí)函數(shù)
void EEPROM_Init();
void SYS_Init();
void T0_Init();
void LCD_Init();
void PageProcess(unsigned char ac_page);
void EEPROM_DATA(unsigned char ac_page);
void EEPROM_READ(unsigned char ac_page);
void KeyScan(void);
void Stop_Key();
void KeyProcess();
void SecondPro();
void SecondPro_2();
// 主程序 main()
void main(void)
SYS_Init(); // 參數(shù)初始化
EEPROM_Init(); // 讀取數(shù)據(jù)
T0_Init(); // 定時(shí)器0 初始化
LCD_Init(); // 顯示初始化
if (!cMode) // 空閑模式下
KeyScan(); // 按鍵
KeyProcess(); // 處理進(jìn)程
// 參數(shù)初始化
void SYS_Init()
MotorEn = 0; // 使能
page_num = 0; // 節(jié)點(diǎn)數(shù)
cur_page = 0; //當(dāng)前頁(yè)面數(shù)
set_page_num[0] = set_page_num[1] = 0; // 節(jié)點(diǎn)2位小數(shù)
/********定時(shí)器初始化***********************************************************/
void T0_Init()
TMOD = 0x01;
TH0 = (65535-100)/256; // 0.1ms
TL0 = (65535-100)%256;
EA = 1;
ET0 = 1;
// 液晶顯示初始化
void LCD_Init()
init_1602(); //lcd1602初始化
write_string(1, 1, "Enter Step Num");
write_string(2,3,"Step:");
write_sf(2,9,page_num);
/************存儲(chǔ)初始化*****************/
void EEPROM_Init()
EEPROM_READ(cur_page);
/********定時(shí)器中斷*****************/
void T0_time() interrupt 1
TR0 = 0;
// TH0 = (65535-T0_INIT_DATA)/256; // 0.1ms
// TL0 = (65535-T0_INIT_DATA)%256;
/* TH0 = (65535-100)/256; // 0.1ms
T0_NUM++;
// SYS_NUM++;
if (cMode == 6) // 間隔模式
TH0 = (65535-50000)/256; // 50ms
TL0 = (65535-50000)%256;
if (StepData[cur_page-1].set_time > 0)
T0_NUM_2++;
if (T0_NUM_2 >= 20)
T0_NUM_2 = 0;
CUR_Miao++;
if (CUR_Miao >= StepData[cur_page-1].set_time) // 達(dá)到目標(biāo)
CUR_Miao = 0;
TR0 = 0; // 關(guān)閉定時(shí)器
END_FLAG_2 = 1; // 時(shí)間目標(biāo)達(dá)到標(biāo)志
CUR_Miao = 0;
else if (cMode == 4) // 電機(jī)運(yùn)行模式
T0_NUM++;
if (StepData[cur_page-1].set_jd > 0)
// if(T0_NUM >= MotorTab[StepData[cur_page-1].set_sd]) MotorSpedTab
// if(T0_NUM >= MotorTab[9])
T0_NUM = 0;
CLK=CLK^0x01; // 輸出脈沖
CLK_OUT_NUM++;
if (S_FLAG)
if(CLK_OUT_NUM > 30) // 高速時(shí)給個(gè)加速過(guò)程
StepData[cur_page-1].set_sd = StepData[cur_page-1].set_sd + 1;
S_FLAG = 0;
if(CLK_OUT_NUM >= Two_XiFen_Clk) // 一圈 2細(xì)分
CLK_OUT_NUM = 0;
CUR_MotorSpedQuan++;
if(CUR_MotorSpedQuan >= StepData[cur_page-1].set_jd) // 達(dá)到圈數(shù)
CLK_OUT_NUM = 0; // 脈沖清空
END_FLAG = 1; // 目標(biāo)達(dá)到標(biāo)志
SYS_NUM = 0; // 清空
// if(CLK_OUT_NUM >= SET_MotorPulse) // 達(dá)到角度目標(biāo)
SYS_NUM = 0; // 清空
TR0 = 1;
/********保持當(dāng)前頁(yè)數(shù)據(jù)*****************/
if (ac_page == 0)
set_page_num[0] = page_num / 10;
set_page_num[1] = page_num % 10;
write_eeprom(SECTION_ADDRESS1,set_page_num,2); // 保存總節(jié)點(diǎn)數(shù)
else if (ac_page > 0)
EEPROM_Tab[0] = StepData[ac_page-1].set_fx;
EEPROM_Tab[1] = StepData[ac_page-1].set_sd;
EEPROM_Tab[2] = StepData[ac_page-1].set_jd / 100;
EEPROM_Tab[3] = StepData[ac_page-1].set_jd % 100 / 10;
EEPROM_Tab[4] = StepData[ac_page-1].set_jd % 10;
EEPROM_Tab[5] = StepData[ac_page-1].set_time / 100;
EEPROM_Tab[6] = StepData[ac_page-1].set_time % 100 / 10;
EEPROM_Tab[7] = StepData[ac_page-1].set_time % 10;
switch (ac_page-1)
case 0:
write_eeprom(SECTION_ADDRESS2,EEPROM_Tab,8);
break;
case 1:
write_eeprom(SECTION_ADDRESS3,EEPROM_Tab,8);
break;
case 2:
write_eeprom(SECTION_ADDRESS4,EEPROM_Tab,8);
break;
case 3:
write_eeprom(SECTION_ADDRESS5,EEPROM_Tab,8);
break;
case 4:
write_eeprom(SECTION_ADDRESS6,EEPROM_Tab,8);
break;
case 5:
write_eeprom(SECTION_ADDRESS7,EEPROM_Tab,8);
break;
case 6:
write_eeprom(SECTION_ADDRESS8,EEPROM_Tab,8);
break;
default:
break;
/********讀取數(shù)據(jù)*****************/
if (ac_page == 0)
read_eeprom(SECTION_ADDRESS1,set_page_num,2); // 保存總節(jié)點(diǎn)數(shù)
if ((set_page_num[0] > 0) || (set_page_num[0] < 0))
set_page_num[0] = 0;
if ((set_page_num[1] > 9) || (set_page_num[1] < 0))
page_num = set_page_num[0]*10 + set_page_num[1];
// read_eeprom(SECTION_ADDRESS1,page_num,2); // 保存總節(jié)點(diǎn)數(shù)
switch (ac_page-1)
case 0:
read_eeprom(SECTION_ADDRESS2,EEPROM_Tab,8);
break;
case 1:
read_eeprom(SECTION_ADDRESS3,EEPROM_Tab,8);
break;
case 2:
read_eeprom(SECTION_ADDRESS4,EEPROM_Tab,8);
break;
case 3:
read_eeprom(SECTION_ADDRESS5,EEPROM_Tab,8);
break;
case 4:
read_eeprom(SECTION_ADDRESS6,EEPROM_Tab,8);
break;
case 5:
read_eeprom(SECTION_ADDRESS7,EEPROM_Tab,8);
break;
case 6:
read_eeprom(SECTION_ADDRESS8,EEPROM_Tab,8);
break;
default:
break;
if ((EEPROM_Tab[0] > 1) || (EEPROM_Tab[0] < 0))
EEPROM_Tab[0] = 0;
if ((EEPROM_Tab[1] > 9) || (EEPROM_Tab[1] < 0))
EEPROM_Tab[1] = 0;
if ((EEPROM_Tab[2] > 9) || (EEPROM_Tab[2] < 0))
EEPROM_Tab[2] = 0;
if ((EEPROM_Tab[3] > 9) || (EEPROM_Tab[3] < 0))
EEPROM_Tab[3] = 0;
if ((EEPROM_Tab[4] > 9) || (EEPROM_Tab[4] < 0))
EEPROM_Tab[4] = 0;
if ((EEPROM_Tab[5] > 9) || (EEPROM_Tab[5] < 0))
EEPROM_Tab[5] = 0;
if ((EEPROM_Tab[6] > 9) || (EEPROM_Tab[6] < 0))
EEPROM_Tab[6] = 0;
if ((EEPROM_Tab[7] > 9) || (EEPROM_Tab[7] < 0))
EEPROM_Tab[7] = 0;
StepData[ac_page-1].set_fx = EEPROM_Tab[0];
StepData[ac_page-1].set_sd = EEPROM_Tab[1];
StepData[ac_page-1].set_jd = EEPROM_Tab[2]*100 + EEPROM_Tab[3]*10 + EEPROM_Tab[4];
StepData[ac_page-1].set_time = EEPROM_Tab[5]*100 + EEPROM_Tab[6]*10 + EEPROM_Tab[7];
/********翻頁(yè)界面***********************************************************/
write_string(1,0," ");
write_string(2,0," ");
write_string(1,1,"N:"); // 顯示節(jié)點(diǎn)
write_sf(1,3, (unsigned int)ac_page);
if(StepData[ac_page-1].set_fx == 0) //顯示方向
write_string(1,DIR_ADDRESS,"R");
write_string(1,DIR_ADDRESS,"L");
write_string(1,10,"S:"); // 顯示速度
write_one_data(1,SPEED_ADDRESS, StepData[ac_page-1].set_sd);
write_string(2,1,"set:"); // 顯示圈數(shù)
write_sfm(2, SET_ANGLE_ADDRESS, StepData[ac_page-1].set_jd);
write_string(2,10,"t:"); // 顯示間隔
write_sfm(2, SET_TIME_ADDRESS, StepData[ac_page-1].set_time);
/********按鍵掃描函數(shù)***********************************************************/
void KeyScan()
if(SW1 == 0)
delayms(10);
if(SW1 == 0) // 功能鍵
while(!SW1); // 等待松開(kāi)
cMode = 1; // 功能模式
if(SW2 == 0)
delayms(10);
if(SW2 == 0) // 增加
while(!SW2); // 等待松開(kāi)
cMode = 2;
/* if(SW3 == 0)
delayms(10);
if(SW3 == 0) // 減小
while(!SW3); // 等待松開(kāi)
cMode = 3;
if(SW4 == 0)
delayms(10);
if(SW4 == 0) // 啟停
while(!SW4); // 等待松開(kāi)
cMode = 4;
if (StepData[cur_page-1].set_sd >= 9)
StepData[cur_page-1].set_sd = StepData[cur_page-1].set_sd - 1;
S_FLAG = 1;
g_MotorSt = 1;
MotorEn = 1;
cur_page = 1; // 電機(jī)從第1個(gè)節(jié)點(diǎn)運(yùn)行
EEPROM_READ(cur_page); // 讀取數(shù)據(jù)
PageProcess(cur_page); // 頁(yè)面更新
// CUR_MotorAngle = 0;
if(StepData[cur_page-1].set_fx == 0)
FX = 0;
FX = 1;
TR0 = 1; // 定時(shí)器開(kāi)啟
if(SW5 == 0)
delayms(10);
if(SW5 == 0) // 翻頁(yè)
while(!SW5); // 等待松開(kāi)
cMode = 5;
void Stop_Key()
if(SW4 == 0)
delayms(10);
if(SW4 == 0) // 啟停
cMode = 0;
g_MotorSt = 0;
MotorEn = 1; // 繼續(xù)保持扭矩
TR0 = 0;
/********按鍵處理函數(shù)***********************************************************/
void KeyProcess()
switch(cMode)
case 0: // 空閑模式
break;
case 1: // 功能模式
s1_num++;
cMode = 0; // 功能模式
if(cur_page > 0) // 各自界面中
if(s1_num ==1) // 第1次被按下
write_com(0x80+DIR_ADDRESS); // 方向
write_com(0x0f); // 光標(biāo)閃爍
if(s1_num ==2)
write_com(0x80+SPEED_ADDRESS);
if(s1_num ==3)
write_com(0x80+0x40+SET_ANGLE_ADDRESS);
if(s1_num ==4)
write_com(0x80+0x40+SET_ANGLE_ADDRESS+1);
if(s1_num ==5)
write_com(0x80+0x40+SET_ANGLE_ADDRESS+2);
if(s1_num ==6) // 間隔
write_com(0x80+0x40+SET_TIME_ADDRESS);
if(s1_num ==7)
write_com(0x80+0x40+SET_TIME_ADDRESS+1);
if(s1_num ==8)
write_com(0x80+0x40+SET_TIME_ADDRESS+2);
if(s1_num == 9) //第9次退出
s1_num = 0; // 記錄按鍵清零
cMode = 0; // 退出模式
write_com(0x0c); // 取消光標(biāo)閃爍
// SET_MotorPulse = (unsigned int)((StepData[cur_page-1].set_jd/0.9)*8.0); // 脈沖
EEPROM_DATA(cur_page); // 保存數(shù)據(jù)
else // 設(shè)定總節(jié)點(diǎn)界面
write_com(0x80+0x40+9); // 節(jié)點(diǎn)數(shù)目
if(s1_num ==2)
write_com(0x80+0x40+10);
if(s1_num == 3) //第3次退出
cMode = 0; // 退出模式
break;
case 2: // 增加
cMode = 0; // 功能模式
set_jd_bai = StepData[cur_page-1].set_jd / 100;
set_jd_shi = StepData[cur_page-1].set_jd % 100 / 10;
set_jd_ge = StepData[cur_page-1].set_jd % 10;
set_sj_bai = StepData[cur_page-1].set_time / 100;
set_sj_shi = StepData[cur_page-1].set_time % 100 / 10;
set_sj_ge = StepData[cur_page-1].set_time % 10;
if(s1_num == 1) // 方向
StepData[cur_page-1].set_fx++;
if(StepData[cur_page-1].set_fx > 1)
StepData[cur_page-1].set_fx = 0;
// FX = 0;
write_string(1, DIR_ADDRESS, "R");
// FX = 1;
write_string(1, DIR_ADDRESS, "L");
if(s1_num == 2) // 速度
StepData[cur_page-1].set_sd++;
if(StepData[cur_page-1].set_sd >= 10)
StepData[cur_page-1].set_sd = 0;
write_one_data(1, SPEED_ADDRESS, StepData[cur_page-1].set_sd);
if(s1_num == 3) // 角度 百
set_jd_bai++;
if(set_jd_bai >= 10)
set_jd_bai = 0;
StepData[cur_page-1].set_jd = set_jd_bai*100 + set_jd_shi*10 + set_jd_ge;
write_sfm(2, SET_ANGLE_ADDRESS, StepData[cur_page-1].set_jd);
if(s1_num == 4)
set_jd_shi++;
if(set_jd_shi >= 10)
set_jd_shi = 0;
if(s1_num == 5)
set_jd_ge++;
if(set_jd_ge >= 10)
set_jd_ge = 0;
if(s1_num == 6) // 時(shí)間間隔 百
set_sj_bai++;
if(set_sj_bai >= 10)
set_sj_bai = 0;
StepData[cur_page-1].set_time = set_sj_bai*100 + set_sj_shi*10 + set_sj_ge;
write_sfm(2, SET_TIME_ADDRESS, StepData[cur_page-1].set_time);
if(s1_num == 7)
set_sj_shi++;
if(set_sj_shi >= 10)
set_sj_shi = 0;
if(s1_num == 8)
set_sj_ge++;
if(set_sj_ge >= 10)
set_sj_ge = 0;
if(s1_num == 1) // 十
set_page_num[0]++;
if(set_page_num[0] >= 1)
write_sf(2, 9, page_num);
if(s1_num == 2) // 個(gè)
set_page_num[1]++;
if(set_page_num[1] >= 6)
break;
case 3: // 減小
cMode = 0; // 功能模式
if(cur_page > 0)
StepData[cur_page-1].set_fx--;
if(StepData[cur_page-1].set_fx < 0)
// FX = 0;
// FX = 1;
StepData[cur_page-1].set_sd--;
if(StepData[cur_page-1].set_sd < 0)
if(s1_num == 3) // 百
set_jd_bai--;
if(set_jd_bai < 0)
set_jd_bai = 9;
if(s1_num == 4)
set_jd_shi--;
if(set_jd_shi < 0)
set_jd_shi = 9;
if(s1_num == 5)
set_jd_ge--;
if(set_jd_ge < 0)
set_jd_ge = 9;
write_sfm(2, SPEED_ADDRESS, StepData[cur_page-1].set_jd);
write_com(0x80+0x40+SPEED_ADDRESS+2);
set_sj_bai--;
if(set_sj_bai < 0)
set_sj_bai = 9;
if(s1_num == 7)
set_sj_shi--;
if(set_sj_shi < 0)
set_sj_shi = 9;
if(s1_num == 8)
set_sj_ge--;
if(set_sj_ge < 0)
set_sj_ge = 9;
if(s1_num == 1) // -
set_page_num[0]--;
if(set_page_num[0] < 0)
set_page_num[1]--;
if(set_page_num[1] < 0)
break;
case 4: // 運(yùn)行
if (SYS_NUM >= 100) // 10ms
SYS_NUM = 0;
// CUR_MotorAngle = CLK_OUT_NUM *0.9/8.0; // 計(jì)算當(dāng)前角度
SecondPro(); //
// Stop_Key();
break;
case 5: // 翻頁(yè)
cMode = 0; // 功能模式
cur_page++; //翻頁(yè)增加
if((cur_page > page_num) || (cur_page > MAX_PAGE))
cur_page = 1;
init_1602();
PageProcess(cur_page); // 顯示節(jié)點(diǎn)數(shù)
break;
case 6: //時(shí)間
// cMode = 0; // 功能模式
SecondPro_2();
break;
default:
break;
void SecondPro()
if (END_FLAG) // 角度目標(biāo)達(dá)到
END_FLAG = 0; // 清
g_MotorSt = 0; // 電機(jī)關(guān)閉關(guān)閉標(biāo)志
MotorEn = 1;
cMode = 6; // 進(jìn)入時(shí)間模式
// T0_INIT_DATA = 50000; // 定時(shí)器初始值
T0_INIT_DATA = T0_INIT_DATA_50ms; // 定時(shí)器初始值
TR0 = 1; //啟動(dòng)定時(shí)器
g_MotorSt = 1;
void SecondPro_2()
if (END_FLAG_2) // 時(shí)間目標(biāo)達(dá)到
END_FLAG_2 = 0; // 清
if (cur_page >= page_num) // 達(dá)到總節(jié)點(diǎn)數(shù)
cur_page = 0;
TR0 = 0; //關(guān)閉定時(shí)器
LCD_Init(); // 頁(yè)面更新
cMode = 0; // 待機(jī)模式
MotorEn = 1;
// T0_INIT_DATA = 10; // 定時(shí)器賦值
T0_INIT_DATA = T0_INIT_DATA_10; // 定時(shí)器賦值
cur_page = cur_page + 1; // 進(jìn)入下一個(gè)節(jié)點(diǎn)
cMode = 4; // 電機(jī)運(yùn)行模式
FX = 0;
FX = 1;
g_MotorSt = 1; // 電機(jī)
MotorEn = 1;
// 下一個(gè)動(dòng)作的角度冒充計(jì)算
TR0 = 1; // 啟動(dòng)定時(shí)器
/********延時(shí)函數(shù)***********************************************************/
void delayms(xms)
unsigned int x,y;
for(x=xms;x>0;x--)
for(y=110;y>0;y--)
原理圖1.pdf
2018-4-26 13:29 上傳
點(diǎn)擊文件名下載附件
42.37 KB, 下載次數(shù): 4
原理圖
