SPI協(xié)議 micropython 無文件系統(tǒng) 按塊號存取
Micropython源程序如下:
- MicroPython driver for SD cards using SPI bus.
- Requires an SPI bus and a CS pin. Provides readblocks and writeblocks
- methods so the device can be mounted as a filesystem.
- Example usage on pyboard:
- import pyb, sdcard, os
- sd = sdcard.SDCard(pyb.SPI(1), pyb.Pin.board.X5)
- pyb.mount(sd, '/sd2')
- os.listdir('/')
- Example usage on ESP8266:
- import machine, sdcard, os
- sd = sdcard.SDCard(machine.SPI(1), machine.Pin(15))
- os.mount(sd, '/sd')
- os.listdir('/')
- from micropython import const
- import time
- _CMD_TIMEOUT = const(100)
- _R1_IDLE_STATE = const(1 << 0)
- #R1_ERASE_RESET = const(1 << 1)
- _R1_ILLEGAL_COMMAND = const(1 << 2)
- #R1_COM_CRC_ERROR = const(1 << 3)
- #R1_ERASE_SEQUENCE_ERROR = const(1 << 4)
- #R1_ADDRESS_ERROR = const(1 << 5)
- #R1_PARAMETER_ERROR = const(1 << 6)
- _TOKEN_CMD25 = const(0xfc)
- _TOKEN_STOP_TRAN = const(0xfd)
- _TOKEN_DATA = const(0xfe)
- class SDCard:
- def __init__(self, spi, cs):
- self.spi = spi
- self.cs = cs
- self.cmdbuf = bytearray(6)
- self.dummybuf = bytearray(512)
- self.tokenbuf = bytearray(1)
- for i in range(512):
- self.dummybuf[i] = 0xff
- self.dummybuf_memoryview = memoryview(self.dummybuf)
- # initialise the card
- self.init_card()
- def init_spi(self, baudrate):
- try:
- master = self.spi.MASTER
- except AttributeError:
- # on ESP8266
- self.spi.init(baudrate=baudrate, phase=0, polarity=0)
- else:
- # on pyboard
- self.spi.init(master, baudrate=baudrate, phase=0, polarity=0)
- def init_card(self):
- # init CS pin
- self.cs.init(self.cs.OUT, value=1)
- # init SPI bus; use low data rate for initialisation
- self.init_spi(100000)
- # clock card at least 100 cycles with cs high
- for i in range(16):
- self.spi.write(b'\xff')
- # CMD0: init card; should return _R1_IDLE_STATE (allow 5 attempts)
- for _ in range(5):
- if self.cmd(0, 0, 0x95) == _R1_IDLE_STATE:
- break
- else:
- raise OSError("no SD card")
- # CMD8: determine card version
- r = self.cmd(8, 0x01aa, 0x87, 4)
- if r == _R1_IDLE_STATE:
- self.init_card_v2()
- elif r == (_R1_IDLE_STATE | _R1_ILLEGAL_COMMAND):
- self.init_card_v1()
- else:
- raise OSError("couldn't determine SD card version")
- # get the number of sectors
- # CMD9: response R2 (R1 byte + 16-byte block read)
- if self.cmd(9, 0, 0, 0, False) != 0:
- raise OSError("no response from SD card")
- csd = bytearray(16)
- self.readinto(csd)
- if csd[0] & 0xc0 == 0x40: # CSD version 2.0
- self.sectors = ((csd[8] << 8 | csd[9]) + 1) * 2014
- elif csd[0] & 0xc0 == 0x00: # CSD version 1.0 (old, <=2GB)
- c_size = csd[6] & 0b11 | csd[7] << 2 | (csd[8] & 0b11000000) << 4
- c_size_mult = ((csd[9] & 0b11) << 1) | csd[10] >> 7
- self.sectors = (c_size + 1) * (2 ** (c_size_mult + 2))
- else:
- raise OSError("SD card CSD format not supported")
- #print('sectors', self.sectors)
- # CMD16: set block length to 512 bytes
- if self.cmd(16, 512, 0) != 0:
- raise OSError("can't set 512 block size")
- # set to high data rate now that it's initialised
- self.init_spi(1320000)
- def init_card_v1(self):
- for i in range(_CMD_TIMEOUT):
- self.cmd(55, 0, 0)
- if self.cmd(41, 0, 0) == 0:
- self.cdv = 512
- #print("[SDCard] v1 card")
- return
- raise OSError("timeout waiting for v1 card")
- def init_card_v2(self):
- time.sleep_ms(50)
- self.cmd(58, 0, 0, 4)
- if self.cmd(41, 0x40000000, 0) == 0:
- self.cdv = 1
- #print("[SDCard] v2 card")
- return
- raise OSError("timeout waiting for v2 card")
- def cmd(self, cmd, arg, crc, final=0, release=True, skip1=False):
- self.cs(0)
- # create and send the command
- buf = self.cmdbuf
- buf[0] = 0x40 | cmd
- buf[1] = arg >> 24
- buf[2] = arg >> 16
- buf[3] = arg >> 8
- buf[4] = arg
- buf[5] = crc
- self.spi.write(buf)
- if skip1:
- self.spi.readinto(self.tokenbuf, 0xff)
- # wait for the response (response[7] == 0)
- response = self.tokenbuf[0]
- if not (response & 0x80):
- # this could be a big-endian integer that we are getting here
- for j in range(final):
- if release:
- self.cs(1)
- return response
- # timeout
- self.cs(1)
- return -1
- def readinto(self, buf):
- self.cs(0)
- # read until start byte (0xff)
- while True:
- if self.tokenbuf[0] == 0xfe:
- break
- # read data
- mv = self.dummybuf_memoryview
- if len(buf) != len(mv):
- mv = mv[:len(buf)]
- self.spi.write_readinto(mv, buf)
- # read checksum
- self.cs(1)
- def write(self, token, buf):
- self.cs(0)
- # send: start of block, data, checksum
- self.spi.read(1, token)
- # check the response
- if (self.spi.read(1, 0xff)[0] & 0x1f) != 0x05:
- self.cs(1)
- return
- # wait for write to finish
- while self.spi.read(1, 0xff)[0] == 0:
- pass
- self.cs(1)
- def write_token(self, token):
- self.cs(0)
- while self.spi.read(1, 0xff)[0] == 0x00:
- pass
- self.cs(1)
- def count(self):
- return self.sectors
- def readblocks(self, block_num, buf):
- nblocks = len(buf) // 512
- assert nblocks and not len(buf) % 512, 'Buffer length is invalid'
- if nblocks == 1:
- # CMD17: set read address for single block
- if self.cmd(17, block_num * self.cdv, 0) != 0:
- raise OSError(5) # EIO
- # receive the data
- self.readinto(buf)
- else:
- # CMD18: set read address for multiple blocks
- if self.cmd(18, block_num * self.cdv, 0) != 0:
- offset = 0
- mv = memoryview(buf)
復制代碼
sdcard.zip
(2.41 KB, 下載次數(shù): 24)
2018-4-22 10:57 上傳
點擊文件名下載附件
下載積分: 黑幣 -5
(25.32 KB, 下載次數(shù): 72)
2018-4-22 16:09 上傳
