adc0809芯片測(cè)量0到5v仿真原理圖如下(proteus仿真工程文件可到本帖附件中下載)
- #include <reg52.h> //頭文件
- #define uchar unsigned char //宏定義無(wú)符號(hào)字符型
- #define uint unsigned int //宏定義無(wú)符號(hào)整型
- code uchar seg7code[10]={ 0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90}; //顯示段碼 數(shù)碼管字跟
- uchar wei[4]={0XEf,0XDf,0XBf,0X7f}; //位的控制端 //位控制碼
- sbit ST=P3^0; //A/D啟動(dòng)轉(zhuǎn)換信號(hào)
- sbit OE=P3^1; //數(shù)據(jù)輸出允許信號(hào)
- sbit EOC=P3^2; //A/D轉(zhuǎn)換結(jié)束信號(hào)
- sbit CLK=P3^3; //時(shí)鐘脈沖
- uint z,x,c,v,AD0809, date; //定義數(shù)據(jù)類型
- 延時(shí)函數(shù)
- void delay(uint t)
- uint i,j;
- for(i=0;i<t;i++)
- for(j=110;j>0;j--);
- 數(shù)碼管動(dòng)態(tài)掃描
- void xianshi() //顯示函數(shù)
- uint z,x,c,v;
- z=date/1000; //求千位
- x=date%1000/100; //求百位
- c=date%100/10; //求十位
- v=date%10; //求個(gè)位
- P2=0XFF;
- P0=seg7code[z]&0x7f;
- P2=wei[0];
- delay(1);
- P2=0XFF;
- P0=seg7code[x];
- P2=wei[1];
- delay(1);
- P2=0XFF;
- P0=seg7code[c];
- P2=wei[2];
- delay(1);
- P2=0XFF;
- P0=seg7code[v];
- P2=wei[3];
- delay(1);
- P2=0XFF;
- CLK振蕩信號(hào)
- void timer0( ) interrupt 1 //定時(shí)器0工作方式1
- TH0=(65536-2)/256; //重裝計(jì)數(shù)初值
- TL0=(65536-2)%256; //重裝計(jì)數(shù)初值
- CLK=!CLK; //取反
- 主函數(shù)
- void main()
- TMOD=0X01; //定時(shí)器中斷0
- CLK=0; //脈沖信號(hào)初始值為0
- TH0=(65536-2)/256; //定時(shí)時(shí)間高八位初值
- TL0=(65536-2)%256; //定時(shí)時(shí)間低八位初值
- EA=1; //開(kāi)CPU中斷
- ET0=1; //開(kāi)T/C0中斷
- TR0=1;
- while(1) //無(wú)限循環(huán)
- ST=0; //使采集信號(hào)為低
- ST=1; //開(kāi)始數(shù)據(jù)轉(zhuǎn)換
- ST=0; //停止數(shù)據(jù)轉(zhuǎn)換
- while(!EOC); //等待數(shù)據(jù)轉(zhuǎn)換完畢
- OE=1; //允許數(shù)據(jù)輸出信號(hào)
- delay(1);
- AD0809=P1; //讀取數(shù)據(jù)
- OE=0; //關(guān)閉數(shù)據(jù)輸出允許信號(hào)
- if(AD0809>=251) //電壓顯示不能超過(guò)5V
- AD0809=250;
- date=AD0809*20; //數(shù)碼管顯示的數(shù)據(jù)值,其中20為采集數(shù)據(jù)的毫安值
- xianshi(); //數(shù)碼管顯示函數(shù)
ad0809.zip
(305.89 KB, 下載次數(shù): 52)
2018-4-22 16:32 上傳
點(diǎn)擊文件名下載附件
