查看: 1467|回復(fù): 0
遙控器接收溫濕度的單片機(jī)源碼
ID:314426 發(fā)表于 2018-4-23 13:57 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
  1. #include <reg51.h>
  2. #include <intrins.h>
  3. #include "nrf24l01.h"
  4. #include "12864.h"
  5. /***************************************************
  6. *This file is distributed in the hope that it will be useful, but WITHOUT ANY WARRANT;
  7. *
  8. *UART:9600BPS
  9. /***************************************************/
  10. #define uchar unsigned char
  11. #define uint  unsigned int
  12. #define TX_ADR_WIDTH    5   // 5 bytes TX(RX) address width
  13. #define TX_PLOAD_WIDTH  20  // 20 bytes TX payload         發(fā)送的字節(jié)數(shù)
  14. uchar quanshu=0; //用來記錄圈數(shù)
  15. uchar xian=0; //用來記錄經(jīng)過了幾條線
  16. uchar const TX_ADDRESS[TX_ADR_WIDTH]  = {0x34,0x43,0x10,0x10,0x86}; // Define a static TX address 靜態(tài)地址
  17. uchar code dis1[] = {0xc8,0xa6,0xca,0xfd};          //圈數(shù)
  18. uchar code dis2[] = {"濕度  初始化中"};
  19. //uchar code dis3[] = {"無障礙物"};
  20. uchar code dis4[10]={0xb0,0xb1,0xb2,0xb3,0xb4,0xb5,0xb6,0xb7,0xb8,0xb9};
  21. uchar code dis5[] = {"黑線"};
  22. uchar code dis6[]={"溫度  初始化中"};
  23. uchar code digit[10]={"0123456789"};
  24. uchar code dis7[]={"傳感器異常"};
  25. uchar rx_buf[TX_PLOAD_WIDTH];
  26. uchar tx_buf[TX_PLOAD_WIDTH];
  27. uchar flag;
  28. /**************************************************/
  29. sbit CE =  P1^0;
  30. sbit CSN=  P1^4;
  31. sbit SCK=  P1^7;
  32. sbit MOSI= P1^5;
  33. sbit MISO= P1^6;
  34. sbit IRQ = P3^2;
  35. /**************************************************/
  36. uchar         bdata   sta;
  37. sbit        RX_DR        =sta^6;
  38. sbit        TX_DS        =sta^5;
  39. sbit        MAX_RT        =sta^4;
  40. /**************************************************/
  41. sbit LED1=P2^5;
  42. sbit LED2=P2^6;
  43. /**************************************************
  44. Function: Init_IO();
  45. Description:
  46.   flash led one time,chip enable(ready to TX or RX Mode),
  47.   Spi disable,Spi clock line init high
  48. 描述:
  49.   閃光燈一次,芯片使能(準(zhǔn)備進(jìn)入TX或RX模式)
  50.   Spi禁用,Spi時(shí)鐘線初始化高
  51. /**************************************************/
  52. #define KEY 0x60  // 0x60 0110 0000
  53. void dislap(uchar q);
  54. void Init_IO(void)
  55. {
  56.         P0=KEY;                    // led light
  57.         CE=0;                        // chip enable
  58.         CSN=1;                        // Spi disable
  59.         SCK=0;                        // Spi clock line init high
  60.         P0=0xff;                // led close
  61. }
  62. /**************************************************
  63. Function: Init_uart();
  64. Description:
  65.   set uart working mode
  66. 描述:
  67.   設(shè)置定時(shí)計(jì)數(shù)器工作模式
  68. /**************************************************/
  69. void Init_uart(void)
  70. {
  71.         TMOD = 0x20;                                //timer1 working mode 1
  72.         TL1 = 0xfd;                                        //f7=9600 for 16mhz Fosc,and ...
  73.         TH1 = 0xfd;                                        //...fd=19200 for 11.0592mhz Fosc
  74.         SCON = 0xd8;                                //uart mode 3,ren==1
  75.         PCON = 0x80;                                //smod=0
  76.         TR1 = 1;                                        //start timer1
  77. }
  78. /**************************************************
  79. Function: Init_int0();
  80. Description:
  81.   enable int0 interrupt;
  82.   中斷0使能
  83. /**************************************************
  84. void Init_int0(void)
  85. {
  86.         EA=1;
  87.         EX0=1;                                                // Enable int0 interrupt.
  88. }
  89. /**************************************************/
  90. /**************************************************
  91. Function: delay100();
  92. Description:
  93.   delay 100ms
  94.   延時(shí)100毫秒
  95. /**************************************************
  96. void delay100(void)
  97. {
  98.         uchar  x;
  99.         uchar  y;
  100.         for(x=0;x<100;x++)
  101.         {
  102.                 for(y=0;y<100;y++)
  103.                 _nop_();
  104.         }
  105. }
  106. /**************************************************/
  107. /**************************************************
  108. Function: delay_ms();
  109. Description:
  110.   delay x ms
  111.   延時(shí)X毫秒
  112. /**************************************************/
  113. void delay_ms(unsigned int x)
  114. {
  115.     unsigned int i,j;
  116.     i=0;
  117.     for(i=0;i<x;i++)
  118.     {
  119.        j=108;
  120.            ;
  121.        while(j--);
  122.     }
  123. }
  124. /**************************************************
  125. Function: SPI_RW();
  126. Description:
  127.   Writes one byte to nRF24L01, and return the byte read
  128.   from nRF24L01 during write, according to SPI protocol
  129.   根據(jù)SPI協(xié)議寫一個(gè)字節(jié)到nRF24L01,
  130.   并在寫期間返回從nRF24L01讀取的字節(jié)
  131. /**************************************************/
  132. uchar SPI_RW(uchar byte)
  133. {
  134.         uchar bit_ctr;
  135.            for(bit_ctr=0;bit_ctr<8;bit_ctr++)   // output 8-bit  輸出8位
  136.            {
  137.                    MOSI = (byte & 0x80);            // output 'byte', MSB to MOSI  最高位寫入主輸出從輸入
  138.                    byte = (byte << 1);              // shift next bit into MSB..        將下一位移到最高位
  139.                    SCK = 1;                         // Set SCK high..           同步時(shí)鐘置高位
  140.                    byte |= MISO;                            // capture current MISO bit         捕獲主輸入從輸出位
  141.                    SCK = 0;                                 // ..then set SCK low again         同步時(shí)鐘置0
  142.            }
  143.     return(byte);                                // return read byte
  144. }
  145. /**************************************************
  146. Function: SPI_RW_Reg();
  147. Description:
  148.   Writes value 'value' to register 'reg'
  149. /**************************************************/
  150. uchar SPI_RW_Reg(uchar reg, uchar value)
  151. {
  152.         uchar status;
  153.           CSN = 0;                   // CSN low, init SPI transaction                   SPI片選
  154.           status = SPI_RW(reg);      // select register
  155.           SPI_RW(value);             // ..and write value to it..
  156.           CSN = 1;                   // CSN high again
  157.           return(status);            // return nRF24L01 status byte
  158. }
  159. /**************************************************
  160. Function: SPI_Read();
  161. Description:
  162.   Read one byte from nRF24L01 register, 'reg'
  163. /**************************************************/
  164. uchar SPI_Read(uchar reg)
  165. {
  166.         uchar reg_val;
  167.           CSN = 0;                // CSN low, initialize SPI communication...
  168.           SPI_RW(reg);            // Select register to read from..
  169.           reg_val = SPI_RW(0);    // ..then read registervalue
  170.           CSN = 1;                // CSN high, terminate SPI communication
  171.           return(reg_val);        // return register value
  172. }
  173. /**************************************************
  174. Function: SPI_Read_Buf();
  175. Description:
  176.   Reads 'bytes' #of bytes from register 'reg'
  177.   Typically used to read RX payload, Rx/Tx address
  178. /**************************************************/
  179. uchar SPI_Read_Buf(uchar reg, uchar *pBuf, uchar bytes)
  180. {
  181.         uchar status,byte_ctr;
  182.           CSN = 0;                                    // Set CSN low, init SPI tranaction                SPI片選
  183.           status = SPI_RW(reg);                       // Select register to write to and read status byte
  184.           for(byte_ctr=0;byte_ctr<bytes;byte_ctr++)
  185.             pBuf[byte_ctr] = SPI_RW(0);     // Perform SPI_RW to read byte from nRF24L01         從nRF24L01讀取字節(jié)
  186.           CSN = 1;                            // Set CSN high again
  187.           return(status);                     // return nRF24L01 status byte
  188. }
  189. /**************************************************
  190. Function: SPI_Write_Buf();
  191. Description:
  192.   Writes contents of buffer '*pBuf' to nRF24L01         將緩沖區(qū)'* pBuf'的內(nèi)容寫入nRF24L01
  193.   Typically used to write TX payload, Rx/Tx address
  194. /**************************************************/
  195. uchar SPI_Write_Buf(uchar reg, uchar *pBuf, uchar bytes)
  196. {
  197.         uchar status,byte_ctr;
  198.           CSN = 0;                   // Set CSN low, init SPI tranaction           SPI片選
  199.           status = SPI_RW(reg);      // Select register to write to and read status byte
  200.
  201.         for(byte_ctr=0; byte_ctr<bytes; byte_ctr++) // then write all byte in buffer(*pBuf)                將所有字節(jié)寫入緩沖區(qū)
  202.             SPI_RW(*pBuf++);
  203.
  204.         CSN = 1;                   // Set CSN high again
  205.
  206.         return(status);            // return nRF24L01 status byte
  207. }
  208. /**************************************************
  209. Function: RX_Mode();
  210. Description:
  211.   This function initializes one nRF24L01 device to
  212.   RX Mode, set RX address, writes RX payload width,
  213.   select RF channel, datarate & LNA HCURR.
  214.   After init, CE is toggled high, which means that
  215.   this device is now ready to receive a datapacket.
  216.   該函數(shù)將一個(gè)nRF24L01器件初始化為RX模式,設(shè)置RX地址,
  217.   寫入RX有效負(fù)載寬度,選擇RF通道,數(shù)據(jù)速率和LNA HCURR。
  218.   在init之后,CE被切換為高電平,這意味著該設(shè)備現(xiàn)在準(zhǔn)備好
  219.   接收數(shù)據(jù)包
  220. /**************************************************/
  221. void RX_Mode(void)
  222. {
  223.         CE=0;
  224.           SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, TX_ADDRESS, TX_ADR_WIDTH); // Use the same address on the RX device as the TX device 在RX設(shè)備上使用與TX設(shè)備相同的地址
  225.           SPI_RW_Reg(WRITE_REG + EN_AA, 0x01);      // Enable Auto.Ack:Pipe0
  226.           SPI_RW_Reg(WRITE_REG + EN_RXADDR, 0x01);  // Enable Pipe0
  227.           SPI_RW_Reg(WRITE_REG + RF_CH, 40);        // Select RF channel 40
  228.           SPI_RW_Reg(WRITE_REG + RX_PW_P0, TX_PLOAD_WIDTH); // Select same RX payload width as TX Payload width 數(shù)據(jù)寬度相同
  229.           SPI_RW_Reg(WRITE_REG + RF_SETUP, 0x07);   // TX_PWR:0dBm, Datarate:2Mbps, LNA:HCURR          發(fā)射功率,數(shù)據(jù)率
  230.           SPI_RW_Reg(WRITE_REG + CONFIG, 0x0f);     // Set PWR_UP bit, enable CRC(2 bytes) & Prim:RX. RX_DR enabled..
  231.           CE = 1; // Set CE pin high to enable RX device         使能接受
  232.   //  This device is now ready to receive one packet of 16 bytes payload from a TX device sending to address
  233.   //  '3443101001', with auto acknowledgment, retransmit count of 10, RF channel 40 and datarate = 2Mbps.
  234.   //此設(shè)備現(xiàn)在準(zhǔn)備好從發(fā)送到地址'3443101001'的TX設(shè)備接收一個(gè)16字節(jié)有效載荷的包,其具有自動(dòng)確認(rèn),重傳計(jì)數(shù)為10,RF信道40和數(shù)據(jù)速率= 2Mbps。
  235. }
  236. /**************************************************
  237. Function: TX_Mode();
  238. Description:
  239.   This function initializes one nRF24L01 device to
  240.   TX mode, set TX address, set RX address for auto.ack,
  241.   fill TX payload, select RF channel, datarate & TX pwr.
  242.   PWR_UP is set, CRC(2 bytes) is enabled, & PRIM:TX.
  243.   ToDo: One high pulse(>10us) on CE will now send this
  244.   packet and expext an acknowledgment from the RX device.
  245.   該函數(shù)將一個(gè)nRF24L01器件初始化為TX模式,設(shè)置TX地址,
  246.   為auto.ack設(shè)置RX地址,填充TX有效負(fù)載,選擇RF通道,
  247.   數(shù)據(jù)和TX pwr。 PWR_UP置1,CRC(2字節(jié))使能,&PRIM:TX。
  248.   ToDo:CE上的一個(gè)高脈沖(> 10us)現(xiàn)在將發(fā)送此數(shù)據(jù)包,并從RX設(shè)備展開確認(rèn)。
  249. /**************************************************/
  250. void TX_Mode(void)
  251. {
  252.         CE=0;
  253.
  254.           SPI_Write_Buf(WRITE_REG + TX_ADDR, TX_ADDRESS, TX_ADR_WIDTH);    // Writes TX_Address to nRF24L01  將發(fā)送地址寫入nRF24L01
  255.           SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, TX_ADDRESS, TX_ADR_WIDTH); // RX_Addr0 same as TX_Adr for Auto.Ack
  256.           SPI_Write_Buf(WR_TX_PLOAD, tx_buf, TX_PLOAD_WIDTH); // Writes data to TX payload  將數(shù)據(jù)寫到發(fā)送區(qū)
  257.           SPI_RW_Reg(WRITE_REG + EN_AA, 0x01);      // Enable Auto.Ack:Pipe0
  258.           SPI_RW_Reg(WRITE_REG + EN_RXADDR, 0x01);  // Enable Pipe0
  259.           SPI_RW_Reg(WRITE_REG + SETUP_RETR, 0x1a); // 500us + 86us, 10 retrans...
  260.           SPI_RW_Reg(WRITE_REG + RF_CH, 40);        // Select RF channel 40
  261.           SPI_RW_Reg(WRITE_REG + RF_SETUP, 0x07);   // TX_PWR:0dBm, Datarate:2Mbps, LNA:HCURR
  262.           SPI_RW_Reg(WRITE_REG + CONFIG, 0x0e);     // Set PWR_UP bit, enable CRC(2 bytes) & Prim:TX. MAX_RT & TX_DS enabled..
  263.         CE=1;
  264.         xian=0;
  265. }
  266. /**************************************************
  267. Function: check_ACK();
  268. Description:
  269.   check if have "Data sent TX FIFO interrupt",if TX_DS=1,
  270.   all led light and after delay 100ms all led close
  271.   檢查是否有“數(shù)據(jù)發(fā)送TX FIFO中斷”,如果TX_DS = 1,
  272.   所有LED指示燈和延時(shí)100ms后全部LED關(guān)閉
  273. /**************************************************
  274. void check_ACK()
  275. {
  276.         uchar test;
  277.         test=SPI_Read(READ_REG+STATUS);        // read register STATUS's
  278.         test=test&0x20;                                        // check if have Data sent TX FIFO interrupt (TX_DS=1)
  279.         if(test==0x20)                                        // TX_DS =1
  280.         {
  281.                 P0=0x00;                                        // turn on all led
  282.             delay100();                                        // delay 100ms
  283.                 P0=0xff;
  284.         }
  285. }
  286. /**************************************************/
  287. /**************************************************
  288. Function: TxData();
  289. Description:
  290.   write data x to SBUF
  291. /**************************************************
  292. void TxData (uchar x)
  293. {
  294.         SBUF=x;                        // write data x to SBUF
  295.         while(TI==0);
  296.                 TI=0;
  297. }
  298. /**************************************************/
  299. /**************************************************
  300. Function: CheckButtons();
  301. Description:
  302.   check buttons ,if have press,read the key values,
  303.   turn on led and transmit it;  after transmition,
  304.   if received ACK, clear TX_DS interrupt and enter RX Mode;
  305.   turn off the led
  306.   檢查按鈕,如果有按下,讀取鍵值,打開led并發(fā)送;
  307.   發(fā)送后,如果收到ACK,清除TX_DS中斷并進(jìn)入RX模式;關(guān)閉led
  308. /**************************************************/
  309. void CheckButtons()
  310. {
  311.         uchar Temp,Tempi;
  312.         Temp=P3&KEY;                                 //讀鍵值
  313.         if (Temp!=KEY)
  314.         {
  315.                 delay_ms(10);
  316.                 Temp=P3&KEY;                                // 讀鍵值
  317.                 if (Temp!=KEY)
  318.                 {
  319.                         switch(Temp)
  320.                         {
  321.                                 case 0x20:Tempi=0x01;
  322.                                                   break;
  323.                                 case 0x40:Tempi=0x02;dislap(++quanshu);
  324.                                             break;
  325.                                 default:Tempi=0xff;
  326.                         }
  327.                         tx_buf[0]=Tempi;
  328.                         TX_Mode();                        // 置發(fā)射模式并開始發(fā)射數(shù)據(jù)
  329.                         delay_ms(10);
  330.                         SPI_RW_Reg(WRITE_REG+STATUS,SPI_Read(READ_REG+STATUS));        // 清除(TX_DS)中斷標(biāo)志
  331.                         delay_ms(500);
  332.                         RX_Mode();                        // 置位接收模式
  333.                         while((P3&KEY)!=KEY);
  334.                 }
  335.         }
  336. }
  337. /**************************************************
  338. Function: main();
  339. Description:
  340.   control all subprogrammes;
  341. /**************************************************/
  342. void displayInist()
  343. {
  344.         uchar i;
  345.         lcd_pos(0,0);             //設(shè)置顯示位置為第一行的第1個(gè)字符
  346.         i = 0;
  347.         while(i<5)
  348.         {                                                         //顯示圈數(shù)
  349.                 lcd_wdat(dis1[i]);
  350.                 i++;
  351.         }
  352.         lcd_pos(1,0);             //設(shè)置顯示位置為第二行的第1個(gè)字符
  353.         i = 0;
  354.         while(dis5[i] != '\0')
  355.         {
  356.                 lcd_wdat(dis5[i]);      //顯示經(jīng)過了幾條線
  357.                 i++;
  358.         }
  359.         lcd_wdat('0');
  360.         lcd_pos(2,0);             //設(shè)置顯示位置為第三行的第1個(gè)字符
  361.         i = 0;
  362.         while(dis2[i] != '\0')
  363.         {
  364.                 lcd_wdat(dis2[i]);      //顯示濕度初始化
  365.                 i++;
  366.     }
  367.         lcd_pos(3,0);             //設(shè)置顯示位置為第四行的第1個(gè)字符
  368.         i = 0;
  369.         while(dis6[i] != '\0')
  370.         {
  371.                    lcd_wdat(dis6[i]);      //顯示溫度初始化
  372.                 i++;
  373.     }
  374. }
  375. //顯示圈數(shù)的數(shù)字
  376. void dislap(uchar q)
  377. {
  378.         uchar tq;
  379.         if(q<10)
  380.         {
  381.                 lcd_pos(0,2);
  382.                 lcd_wdat(0xa3);
  383.                 lcd_wdat(dis4[q]);
  384.         }
  385.         else
  386.         {
  387.                 tq=q/10;
  388.                 lcd_pos(0,2);
  389.                 lcd_wdat(0xa3);
  390.                 lcd_wdat(dis4[tq]);
  391.                 tq=q%10;
  392.                 lcd_pos(0,3);
  393.                 lcd_wdat(0xa3);
  394.                 lcd_wdat(dis4[tq]);
  395.         }
  396. }
  397. //判斷接收的數(shù)據(jù)給出反應(yīng)
  398. void display(uchar xx,uchar yy)
  399. {
  400.         uchar i,T,H;
  401.         uchar t=0;
  402.         if(xx==0xff)
  403.                 return;
  404.         if(xx==0x01)
  405.         {
  406.                 lcd_pos(1,2);
  407.                 lcd_wdat(0xa3);
  408.                 lcd_wdat(dis4[++xian]);
  409.         }
  410.         if(xx==0x02)
  411.         {
  412.                 lcd_pos(2,0);             //設(shè)置顯示位置為第三行的第1個(gè)字符
  413.                 i = 0;
  414.                 while(dis2[i] != '\0')
  415.                 {
  416.                         lcd_wdat(dis2[i]);      //顯示有擋板
  417.                         i++;
  418.              }
  419.         }
  420.         if(xx==0x03)
  421.         {
  422.                 lcd_pos(3,2);
  423.                 for(i=0;i<12;i++)
  424.                 {
  425.                         lcd_wdat(' ');      //清除“初始化中”
  426.                 }
  427.                 lcd_pos(3,3);             //設(shè)置顯示位置為第三行的第1個(gè)字符
  428.                 i = 0;
  429.                 while(dis7[i] != '\0')
  430.                 {
  431.                         lcd_wdat(dis7[i]);      //顯示傳感器異常
  432.                         i++;
  433.              }
  434.         }
  435.         if(xx!=0x01&&xx!=0x02&&xx!=0x03)                //顯示溫度情況
  436.         {
  437.             T=xx%100;
  438.                  H=yy%100;
  439.                 lcd_pos(2,2);
  440.                 for(i=0;i<12;i++)
  441.                 {
  442.                         lcd_wdat(' ');      //清除內(nèi)容以便顯示濕度
  443.                 }
  444.                 lcd_pos(3,2);
  445.                 for(i=0;i<12;i++)
  446.                 {
  447.                         lcd_wdat(' ');      //清除內(nèi)容以便顯示溫度
  448.                 }
  449.                 lcd_pos(2,2);
  450.                 lcd_wdat(digit[H/10]);
  451.                 lcd_wdat(digit[H%10]);
  452.                 lcd_wdat(0xa3);
  453.                 lcd_wdat(0xa5);
  454.                 lcd_pos(3,2);
  455.                 lcd_wdat(digit[T/10]);
  456.                 lcd_wdat(digit[T%10]);
  457.                 lcd_wdat(0xa1);
  458.                 lcd_wdat(0xe6);
  459.         }
  460. }
  461. void main(void)
  462. {
  463.         uchar xx,yy;
  464.         Init_IO();                    // Initialize IO port  初始化IO端口
  465.         Init_uart();                // Initialize 232 uart
  466.         //Init_int0();            // enable int0 interrupt
  467.         RX_Mode();                    // set RX mode
  468.         delay_ms(20);                 //延時(shí)
  469.         lcd_init();                //初始化LCD
  470.         displayInist();                                //初始化顯示界面。
  471.         while(1)
  472.         {
  473.                 CheckButtons();         // scan key value and transmit 掃描鍵值和發(fā)送
  474.                 sta=SPI_Read(STATUS);        // read register STATUS's value          讀寄存器STATUS的值
  475. //---------------------------------- 余下見附件-----------------------//
遙控器接收溫濕度.rar (53.99 KB, 下載次數(shù): 6)
