1602 IICC模塊
2018-4-23 17:44 上傳
2018-4-23 17:44 上傳
- //YWROBOT
- //last updated on 21/12/2011
- //Tim Starling Fix the reset bug (Thanks Tim)
- //Compatible with the Arduino IDE 1.0
- //Library version:1.1
- #include "LiquidCrystal_I2C.h"
- #include <inttypes.h>
- #if defined(ARDUINO) && ARDUINO >= 100
- #include "Arduino.h"
- #define printIIC(args) Wire.write(args)
- inline size_t LiquidCrystal_I2C::write(uint8_t value) {
- send(value, Rs);
- return 0;
- #else
- #include "WProgram.h"
- #define printIIC(args) Wire.send(args)
- inline void LiquidCrystal_I2C::write(uint8_t value) {
- send(value, Rs);
- #endif
- #include "Wire.h"
- // When the display powers up, it is configured as follows:
- // 1. Display clear
- // 2. Function set:
- // DL = 1; 8-bit interface data
- // N = 0; 1-line display
- // F = 0; 5x8 dot character font
- // 3. Display on/off control:
- // D = 0; Display off
- // C = 0; Cursor off
- // B = 0; Blinking off
- // 4. Entry mode set:
- // I/D = 1; Increment by 1
- // S = 0; No shift
- // Note, however, that resetting the Arduino doesn't reset the LCD, so we
- // can't assume that its in that state when a sketch starts (and the
- // LiquidCrystal constructor is called).
- LiquidCrystal_I2C::LiquidCrystal_I2C(uint8_t lcd_Addr,uint8_t lcd_cols,uint8_t lcd_rows)
- _Addr = lcd_Addr;
- _cols = lcd_cols;
- _rows = lcd_rows;
- _backlightval = LCD_NOBACKLIGHT;
- void LiquidCrystal_I2C::init(){
- init_priv();
- void LiquidCrystal_I2C::init_priv()
- Wire.begin();
- _displayfunction = LCD_4BITMODE | LCD_1LINE | LCD_5x8DOTS;
- begin(_cols, _rows);
- void LiquidCrystal_I2C::begin(uint8_t cols, uint8_t lines, uint8_t dotsize) {
- if (lines > 1) {
- _displayfunction |= LCD_2LINE;
- _numlines = lines;
- // for some 1 line displays you can select a 10 pixel high font
- if ((dotsize != 0) && (lines == 1)) {
- _displayfunction |= LCD_5x10DOTS;
- // SEE PAGE 45/46 FOR INITIALIZATION SPECIFICATION!
- // according to datasheet, we need at least 40ms after power rises above 2.7V
- // before sending commands. Arduino can turn on way befer 4.5V so we'll wait 50
- delay(50);
- // Now we pull both RS and R/W low to begin commands
- expanderWrite(_backlightval); // reset expanderand turn backlight off (Bit 8 =1)
- delay(1000);
- //put the LCD into 4 bit mode
- // this is according to the hitachi HD44780 datasheet
- // figure 24, pg 46
- // we start in 8bit mode, try to set 4 bit mode
- write4bits(0x03 << 4);
- delayMicroseconds(4500); // wait min 4.1ms
- // second try
- // third go!
- delayMicroseconds(150);
- // finally, set to 4-bit interface
- write4bits(0x02 << 4);
- // set # lines, font size, etc.
- command(LCD_FUNCTIONSET | _displayfunction);
- // turn the display on with no cursor or blinking default
- _displaycontrol = LCD_DISPLAYON | LCD_CURSOROFF | LCD_BLINKOFF;
- display();
- // clear it off
- clear();
- // Initialize to default text direction (for roman languages)
- _displaymode = LCD_ENTRYLEFT | LCD_ENTRYSHIFTDECREMENT;
- // set the entry mode
- command(LCD_ENTRYMODESET | _displaymode);
- home();
- /********** high level commands, for the user! */
- void LiquidCrystal_I2C::clear(){
- command(LCD_CLEARDISPLAY);// clear display, set cursor position to zero
- delayMicroseconds(2000); // this command takes a long time!
- void LiquidCrystal_I2C::home(){
- command(LCD_RETURNHOME); // set cursor position to zero
- void LiquidCrystal_I2C::setCursor(uint8_t col, uint8_t row){
- int row_offsets[] = { 0x00, 0x40, 0x14, 0x54 };
- if ( row > _numlines ) {
- row = _numlines-1; // we count rows starting w/0
- command(LCD_SETDDRAMADDR | (col + row_offsets[row]));
- // Turn the display on/off (quickly)
- void LiquidCrystal_I2C::noDisplay() {
- _displaycontrol &= ~LCD_DISPLAYON;
- command(LCD_DISPLAYCONTROL | _displaycontrol);
- void LiquidCrystal_I2C::display() {
- _displaycontrol |= LCD_DISPLAYON;
- // Turns the underline cursor on/off
- void LiquidCrystal_I2C::noCursor() {
- _displaycontrol &= ~LCD_CURSORON;
- void LiquidCrystal_I2C::cursor() {
- _displaycontrol |= LCD_CURSORON;
- // Turn on and off the blinking cursor
- void LiquidCrystal_I2C::noBlink() {
- _displaycontrol &= ~LCD_BLINKON;
- void LiquidCrystal_I2C::blink() {
- _displaycontrol |= LCD_BLINKON;
- // These commands scroll the display without changing the RAM
- void LiquidCrystal_I2C::scrollDisplayLeft(void) {
- command(LCD_CURSORSHIFT | LCD_DISPLAYMOVE | LCD_MOVELEFT);
- void LiquidCrystal_I2C::scrollDisplayRight(void) {
- command(LCD_CURSORSHIFT | LCD_DISPLAYMOVE | LCD_MOVERIGHT);
- // This is for text that flows Left to Right
- void LiquidCrystal_I2C::leftToRight(void) {
- _displaymode |= LCD_ENTRYLEFT;
- // This is for text that flows Right to Left
- void LiquidCrystal_I2C::rightToLeft(void) {
- _displaymode &= ~LCD_ENTRYLEFT;
- // This will 'right justify' text from the cursor
- void LiquidCrystal_I2C::autoscroll(void) {
- _displaymode |= LCD_ENTRYSHIFTINCREMENT;
- // This will 'left justify' text from the cursor
- void LiquidCrystal_I2C::noAutoscroll(void) {
- _displaymode &= ~LCD_ENTRYSHIFTINCREMENT;
- // Allows us to fill the first 8 CGRAM locations
- // with custom characters
- void LiquidCrystal_I2C::createChar(uint8_t location, uint8_t charmap[]) {
- location &= 0x7; // we only have 8 locations 0-7
- command(LCD_SETCGRAMADDR | (location << 3));
- for (int i=0; i<8; i++) {
- write(charmap[i]);
- // Turn the (optional) backlight off/on
- void LiquidCrystal_I2C::noBacklight(void) {
- _backlightval=LCD_NOBACKLIGHT;
- expanderWrite(0);
- void LiquidCrystal_I2C::backlight(void) {
- _backlightval=LCD_BACKLIGHT;
- expanderWrite(0);
- /*********** mid level commands, for sending data/cmds */
- inline void LiquidCrystal_I2C::command(uint8_t value) {
- send(value, 0);
- /************ low level data pushing commands **********/
- // write either command or data
- void LiquidCrystal_I2C::send(uint8_t value, uint8_t mode) {
- uint8_t highnib=value&0xf0;
- uint8_t lownib=(value<<4)&0xf0;
- write4bits((highnib)|mode);
- write4bits((lownib)|mode);
- void LiquidCrystal_I2C::write4bits(uint8_t value) {
- expanderWrite(value);
- pulseEnable(value);
- void LiquidCrystal_I2C::expanderWrite(uint8_t _data){
- Wire.beginTransmission(_Addr);
- printIIC((int)(_data) | _backlightval);
- Wire.endTransmission();
- void LiquidCrystal_I2C::pulseEnable(uint8_t _data){
- expanderWrite(_data | En); // En high
- delayMicroseconds(1); // enable pulse must be >450ns
- expanderWrite(_data & ~En); // En low
- delayMicroseconds(50); // commands need > 37us to settle
- // Alias functions
- void LiquidCrystal_I2C::cursor_on(){
- cursor();
- void LiquidCrystal_I2C::cursor_off(){
- noCursor();
- void LiquidCrystal_I2C::blink_on(){
- blink();
- void LiquidCrystal_I2C::blink_off(){
- noBlink();
- void LiquidCrystal_I2C::load_custom_character(uint8_t char_num, uint8_t *rows){
- createChar(char_num, rows);
- void LiquidCrystal_I2C::setBacklight(uint8_t new_val){
- if(new_val){
- backlight(); // turn backlight on
- }else{
- noBacklight(); // turn backlight off
- void LiquidCrystal_I2C::printstr(const char c[]){
- //This function is not identical to the function used for "real" I2C displays
- //it's here so the user sketch doesn't have to be changed
- print(c);
- // unsupported API functions
- void LiquidCrystal_I2C::off(){}
- void LiquidCrystal_I2C::on(){}
- void LiquidCrystal_I2C::setDelay (int cmdDelay,int charDelay) {}
- uint8_t LiquidCrystal_I2C::status(){return 0;}
- uint8_t LiquidCrystal_I2C::keypad (){return 0;}
- uint8_t LiquidCrystal_I2C::init_bargraph(uint8_t graphtype){return 0;}
- void LiquidCrystal_I2C::draw_horizontal_graph(uint8_t row, uint8_t column, uint8_t len, uint8_t pixel_col_end){}
- void LiquidCrystal_I2C::draw_vertical_graph(uint8_t row, uint8_t column, uint8_t len, uint8_t pixel_row_end){}
- void LiquidCrystal_I2C::setContrast(uint8_t new_val){}
1602 IIC模塊資料.rar
(1.15 MB, 下載次數(shù): 13)
2018-4-23 16:25 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
