查看: 3302|回復(fù): 8
跪求大神給看看1602不顯示是怎么回事啊
ID:306099 發(fā)表于 2018-4-23 21:38 | 顯示全部樓層 |閱讀模式
//包含頭文件
#include <REG52.h>
#include<intrins.h>
//宏定義
#define LCM_Data  P0    //將P0口定義為LCM_Data
#define uint  unsigned int
//1602的控制腳
sbit lcd1602_rs=P2^7;
sbit lcd1602_rw=P2^6;
sbit lcd1602_en=P2^5;
sbit Scl=P3^4;   //24C02串行時(shí)鐘
sbit Sda=P3^5;   //24C02串行數(shù)據(jù)
sbit ALAM = P2^3;  //報(bào)警
sbit KEY = P3^6;  //開鎖
bit  pass=0;   //密碼正確標(biāo)志
bit  ReInputEn=0;  //重置輸入允許標(biāo)志
bit  s3_keydown=0;  //3秒按鍵標(biāo)志位
bit  key_disable=0;  //鎖定鍵盤標(biāo)志
unsigned char countt0,second; //t0中斷計(jì)數(shù)器,秒計(jì)數(shù)器
void Delay5Ms(void);  //聲明延時(shí)函數(shù)
unsigned char code a[]={0xFE,0xFD,0xFB,0xF7};     //控盤掃描控制表
//液晶顯示數(shù)據(jù)數(shù)組
unsigned char code start_line[] = {"password:       "};
unsigned char code name[]    = {"===Coded Lock==="}; //顯示名稱
unsigned char code Correct[]  = {"     correct    "};  //輸入正確
unsigned char code Error[]    = {"      error     "};   //輸入錯(cuò)誤
unsigned char code codepass[] = {"      pass      "};
unsigned char code LockOpen[] = {"      open      "};  //OPEN
unsigned char code SetNew[]  = {"SetNewWordEnable"};
unsigned char code Input[]    = {"input:          "};  //INPUT
unsigned char code ResetOK[]  = {"ResetPasswordOK "};
unsigned char code initword[] = {"Init password..."};
unsigned char code Er_try[]  = {"error,try again!"};
unsigned char code again[]  = {"input again     "};
unsigned char InputData[6];         //輸入密碼暫存區(qū)
unsigned char CurrentPassword[6]={1,3,1,4,2,0};    //管理員密碼(只可在程序中修改)
unsigned char TempPassword[6];
unsigned char N=0;    //密碼輸入位數(shù)記數(shù)
unsigned char ErrorCont;   //錯(cuò)誤次數(shù)計(jì)數(shù)
unsigned char CorrectCont;   //正確輸入計(jì)數(shù)
unsigned char ReInputCont;    //重新輸入計(jì)數(shù)
unsigned char code initpassword[6]={0,0,0,0,0,0};   //輸入管理員密碼后將密碼初始為000000
//=====================5ms延時(shí)==============================
void Delay5Ms(void)
unsigned int TempCyc = 5552;
while(TempCyc--);
//===================400ms延時(shí)==============================
void Delay400Ms(void)
unsigned char TempCycA = 5;
unsigned int TempCycB;
while(TempCycA--)
  TempCycB=7269;
  while(TempCycB--);
//================================24C02========================================================
void mDelay(uint t) //延時(shí)
uchar i;
    while(t--)
     for(i=0;i<125;i++)
void Nop(void)    //空操作
  _nop_();    //僅作延時(shí)用一條語句大約1us
  _nop_();
  _nop_();
  _nop_();
/*****24c02程序參照24c02時(shí)序圖*****/
/*起始條件*/
void Start(void)
  Sda=1;
  Scl=1;
  Nop();
  Sda=0;
  Nop();
/*停止條件*/
void Stop(void)
  Sda=0;
  Scl=1;
  Nop();
  Sda=1;
  Nop();
/*應(yīng)答位*/
void Ack(void)
Sda=0;
Nop();
Scl=1;
Nop();
Scl=0;
/*反向應(yīng)答位*/
void NoAck(void)
  Sda=1;
  Nop();
  Scl=1;
  Nop();
  Scl=0;
/*發(fā)送數(shù)據(jù)子程序,Data為要求發(fā)送的數(shù)據(jù)*/
void Send(uchar Data)
    uchar BitCounter=8;
    uchar temp;
    do
     temp=Data;        //將待發(fā)送數(shù)據(jù)暫存temp
     Scl=0;
     Nop();
     if((temp&0x80)==0x80)     //將讀到的數(shù)據(jù)&0x80
     Sda=1;
     Sda=0;
     Scl=1;
     temp=Data<<1;       //數(shù)據(jù)左移
     Data=temp;        //數(shù)據(jù)左移后重新賦值Data
     BitCounter--;       //該變量減到0時(shí),數(shù)據(jù)也就傳送完成了
    while(BitCounter);       //判斷是否傳送完成
    Scl=0;
/*讀一字節(jié)的數(shù)據(jù),并返回該字節(jié)值*/
uchar Read(void)
    uchar temp=0;
uchar temp1=0;
uchar BitCounter=8;
Sda=1;
do
  Scl=0;
  Nop();
  Scl=1;
  Nop();
  if(Sda)       //數(shù)據(jù)位是否為1
   temp=temp|0x01;    //為1 temp的最低位為1(|0x01,就是將最低位變?yōu)?)
  else       //如果為0
   temp=temp&0xfe;    //temp最低位為0(&0xfe(11111110)最低位就是0)
  if(BitCounter-1)    //BitCounter減1后是否為真
   temp1=temp<<1;    //temp左移
   temp=temp1;
  BitCounter--;     //BitCounter減到0時(shí),數(shù)據(jù)就接收完了
while(BitCounter);     //判斷是否接收完成
return(temp);
void WrToROM(uchar Data[],uchar Address,uchar Num)
  uchar i;
  uchar *PData;
  PData=Data;
  for(i=0;i<Num;i++)
  Start();
  Send(0xa0);
  Ack();
  Send(Address+i);
  Ack();
  Send(*(PData+i));
  Ack();
  Stop();
  mDelay(20);
void RdFromROM(uchar Data[],uchar Address,uchar Num)
  uchar i;
  uchar *PData;
  PData=Data;
  for(i=0;i<Num;i++)
  Start();
  Send(0xa0);
  Ack();
  Send(Address+i);
  Ack();
  Start();
  Send(0xa1);
  Ack();
  *(PData+i)=Read();
  Scl=0;
  NoAck();
  Stop();
//=======================================LCD1602====================================================
#define yi 0x80 //LCD第一行的初始位置,因?yàn)長CD1602字符地址首位D7恒定為1(100000000=80)
#define er 0x80+0x40 //LCD第二行初始位置(因?yàn)榈诙械谝粋(gè)字符位置地址是0x40)
//----------------延時(shí)函數(shù),后面經(jīng)常調(diào)用----------------------
void delay(uint xms)//延時(shí)函數(shù),有參函數(shù)
uint x,y;
for(x=xms;x>0;x--)
  for(y=110;y>0;y--);
//--------------------------寫指令---------------------------
void write_1602com(uchar com)//****液晶寫入指令函數(shù)****
lcd1602_rs=0;//數(shù)據(jù)/指令選擇置為指令
lcd1602_rw=0; //讀寫選擇置為寫
P0=com;//送入數(shù)據(jù)
delay(1);
lcd1602_en=1;//拉高使能端,為制造有效的下降沿做準(zhǔn)備
delay(1);
lcd1602_en=0;//en由高變低,產(chǎn)生下降沿,液晶執(zhí)行命令
//-------------------------寫數(shù)據(jù)-----------------------------
void write_1602dat(uchar dat)//***液晶寫入數(shù)據(jù)函數(shù)****
lcd1602_rs=1;//數(shù)據(jù)/指令選擇置為數(shù)據(jù)
P0=dat;//送入數(shù)據(jù)
delay(1);
lcd1602_en=1; //en置高電平,為制造下降沿做準(zhǔn)備
delay(1);
lcd1602_en=0; //en由高變低,產(chǎn)生下降沿,液晶執(zhí)行命令
//-------------------------初始化-------------------------
void lcd_init(void)
write_1602com(0x38);//設(shè)置液晶工作模式,意思:16*2行顯示,5*7點(diǎn)陣,8位數(shù)據(jù)
write_1602com(0x0c);//開顯示不顯示光標(biāo)
write_1602com(0x06);//整屏不移動(dòng),光標(biāo)自動(dòng)右移
write_1602com(0x01);//清顯示
//==============將按鍵值編碼為數(shù)值=========================
unsigned char coding(unsigned char m)
unsigned char k;
switch(m)
  case (0x11): k=1;break;
  case (0x21): k=2;break;
  case (0x41): k=3;break;
  case (0x81): k='A';break;
  case (0x12): k=4;break;
  case (0x22): k=5;break;
  case (0x42): k=6;break;
  case (0x82): k='B';break;
  case (0x14): k=7;break;
  case (0x24): k=8;break;
  case (0x44): k=9;break;
  case (0x84): k='C';break;
  case (0x18): k='*';break;
  case (0x28): k=0;break;
  case (0x48): k='#';break;
  case (0x88): k='D';break;
return(k);
//=====================按鍵檢測并返回按鍵值===============================
unsigned char keynum(void)
  unsigned char row,col,i;
  P1=0xf0;
  if((P1&0xf0)!=0xf0)
     Delay5Ms();
        Delay5Ms();
     if((P1&0xf0)!=0xf0)
      row=P1^0xf0;          //確定行線
   i=0;
   P1=a[i];           //精確定位
   while(i<4)
     if((P1&0xf0)!=0xf0)
        col=~(P1&0xff);   //確定列線
        break;            //已定位后提前退出
        i++;
        P1=a[i];
   return 0;
  while((P1&0xf0)!=0xf0);
  return (row|col);    //行線與列線組合后返回
  else return 0;            //無鍵按下時(shí)返回0
//=======================一聲提示音,表示有效輸入========================
void OneAlam(void)
ALAM=0;
Delay5Ms();
    ALAM=1;
//========================二聲提示音,表示操作成功========================
void TwoAlam(void)
ALAM=0;
Delay5Ms();
    ALAM=1;
    Delay5Ms();
ALAM=0;
Delay5Ms();
    ALAM=1;
//========================三聲提示音,表示錯(cuò)誤========================
void ThreeAlam(void)
ALAM=0;
Delay5Ms();
    ALAM=1;
    Delay5Ms();
ALAM=0;
Delay5Ms();
    ALAM=1;
    Delay5Ms();
ALAM=0;
Delay5Ms();
    ALAM=1;
//=======================顯示提示輸入=========================
void DisplayChar(void)
unsigned char i;
if(pass==1)
  //DisplayListChar(0,1,LockOpen);
  write_1602com(er);       //在二行開始顯示
  for(i=0;i<16;i++)
   write_1602dat(LockOpen[i]);    //顯示open 開鎖成功
  if(N==0)
   //DisplayListChar(0,1,Error);
   write_1602com(er);
   for(i=0;i<16;i++)
    write_1602dat(Error[i]); //顯示錯(cuò)誤
   //DisplayListChar(0,1,start_line);
   write_1602com(er);
   for(i=0;i<16;i++)
    write_1602dat(start_line[i]);//顯示開始輸入
//========================重置密碼==================================================
void ResetPassword(void)
unsigned char i;
unsigned char j;
if(pass==0)
  pass=0;
  DisplayChar();    //顯示錯(cuò)誤
  ThreeAlam();    //沒開鎖時(shí)按下重置密碼報(bào)警3聲
else       //開鎖狀態(tài)下才能進(jìn)行密碼重置程序
     if(ReInputEn==1)   //開鎖狀態(tài)下,ReInputEn置1,重置密碼允許
   if(N==6)    //輸入6位密碼
    ReInputCont++;   //密碼次數(shù)計(jì)數(shù)
    if(ReInputCont==2)  //輸入兩次密碼
     for(i=0;i<6;)
      if(TempPassword[i]==InputData[i]) //將兩次輸入的新密碼作對比
       i++;
      else        //如果兩次的密碼不同
       write_1602com(er);
       for(j=0;j<16;j++)
        write_1602dat(Error[j]); //顯示錯(cuò)誤Error
       ThreeAlam();   //錯(cuò)誤提示
       pass=0;     //關(guān)鎖
       ReInputEn=0;   //關(guān)閉重置功能,
       ReInputCont=0;
       DisplayChar();
       break;
     if(i==6)
      //DisplayListChar(0,1,ResetOK);
      write_1602com(er);
      for(j=0;j<16;j++)
       write_1602dat(ResetOK[j]);   //密碼修改成功,顯示
      TwoAlam();    //操作成功提示
       WrToROM(TempPassword,0,6);  //將新密碼寫入24C02存儲(chǔ)
      ReInputEn=0;
     ReInputCont=0;
     CorrectCont=0;
    else       //輸入一次密碼時(shí)
     OneAlam();
     //DisplayListChar(0, 1, again);   //顯示再次輸入一次
     write_1602com(er);
     for(j=0;j<16;j++)
      write_1602dat(again[j]);   //顯示再輸入一次
     for(i=0;i<6;i++)
      TempPassword[i]=InputData[i];  //將第一次輸入的數(shù)據(jù)暫存起來
   N=0;      //輸入數(shù)據(jù)位數(shù)計(jì)數(shù)器清零
//=======================輸入密碼錯(cuò)誤超過三過,報(bào)警并鎖死鍵盤======================
void Alam_KeyUnable(void)
P1=0x00;
  ALAM=~ALAM;     //蜂鳴器一直閃爍鳴響
  Delay5Ms();
//=======================取消所有操作============================================
void Cancel(void)
unsigned char i;
unsigned char j;
//DisplayListChar(0, 1, start_line);
write_1602com(er);
for(j=0;j<16;j++)
  write_1602dat(start_line[j]);   //顯示開機(jī)輸入密碼界面
TwoAlam();    //提示音
for(i=0;i<6;i++)
  InputData[i]=0;  //將輸入密碼清零
KEY=1;     //關(guān)閉鎖
ALAM=1;     //報(bào)警關(guān)
pass=0;     //密碼正確標(biāo)志清零
ReInputEn=0;   //重置輸入充許標(biāo)志清零
ErrorCont=0;   //密碼錯(cuò)誤輸入次數(shù)清零
CorrectCont=0;   //密碼正確輸入次數(shù)清零
ReInputCont=0;   //重置密碼輸入次數(shù)清零
s3_keydown=0;
key_disable=0;   //鎖定鍵盤標(biāo)志清零
N=0;     //輸入位數(shù)計(jì)數(shù)器清零
//==========================確認(rèn)鍵,并通過相應(yīng)標(biāo)志位執(zhí)行相應(yīng)功能===============================
void Ensure(void)
unsigned char i,j;
RdFromROM(CurrentPassword,0,6);      //從24C02里讀出存儲(chǔ)密碼
    if(N==6)
     if(ReInputEn==0)       //重置密碼功能未開啟
   for(i=0;i<6;)
    if(CurrentPassword[i]==InputData[i]) //判斷輸入密碼和24c02中的密碼是否相同
     i++;        //相同一位 i就+1
    else          //如果有密碼不同
     ErrorCont++;      //錯(cuò)誤次數(shù)++
     if(ErrorCont==3)   //錯(cuò)誤輸入計(jì)數(shù)達(dá)三次時(shí),報(bào)警并鎖定鍵盤
      write_1602com(er);
      for(i=0;i<16;i++)
      do
      Alam_KeyUnable();
      while(1);
     else      //錯(cuò)誤次數(shù)小于3次時(shí),鎖死鍵盤3秒,然后重新可以輸入
      TR0=1;    //開啟定時(shí)
      key_disable=1;   //鎖定鍵盤
      pass=0;     //pass位清零
      break;     //跳出
   if(i==6)      //密碼輸入對時(shí)
    CorrectCont++;     //輸入正確變量++
    if(CorrectCont==1)    //正確輸入計(jì)數(shù),當(dāng)只有一次正確輸入時(shí),開鎖
     write_1602com(er);
     for(j=0;j<16;j++)
      write_1602dat(LockOpen[j]);    //顯示open開鎖畫面
     TwoAlam();   //操作成功提示音
     KEY=0;           //開鎖
     pass=1;           //置正確標(biāo)志位
     TR0=1;           //開啟定時(shí)
     for(j=0;j<6;j++)        //將輸入清除
      InputData[i]=0;        //開鎖后將輸入位清零
    else            //當(dāng)兩次正確輸入時(shí),開啟重置密碼功能
     //DisplayListChar(0,1,SetNew);
     write_1602com(er);
     for(j=0;j<16;j++)
      write_1602dat(SetNew[j]);     //顯示重置密碼界面
     TwoAlam();             //操作成功提示
     ReInputEn=1;         //允許重置密碼輸入
     CorrectCont=0;         //正確計(jì)數(shù)器清零
   else   //=========================當(dāng)?shù)谝淮问褂没蛲浢艽a時(shí)可以用131420對其密碼初始化============
    if((InputData[0]==1)&&(InputData[1]==3)&&(InputData[2]==1)&&(InputData[3]==4)&&(InputData[4]==2)&&(InputData[5]==0))
     WrToROM(initpassword,0,6);     //強(qiáng)制將初始密碼寫入24C02存儲(chǔ)
     //DisplayListChar(0,1,initword);   //顯示初始化密碼
     write_1602com(er);
     for(j=0;j<16;j++)
      write_1602dat(initword[j]);    //顯示初始化密碼
     TwoAlam();         //成功提示音
     Delay400Ms();        //延時(shí)400ms
     TwoAlam();         //成功提示音
    else           //密碼輸入錯(cuò)誤
     write_1602com(er);
     for(j=0;j<16;j++)
      write_1602dat(Error[j]);     //顯示錯(cuò)誤信息
      ThreeAlam();          //錯(cuò)誤提示音
     pass=0;
  else           //當(dāng)已經(jīng)開啟重置密碼功能時(shí),而按下開鎖鍵,
   //DisplayListChar(0,1,Er_try);
   write_1602com(er);
   for(j=0;j<16;j++)
    write_1602dat(Er_try[j]);     //錯(cuò)誤,請重新輸入
else       //密碼沒有輸入到6位時(shí),按下確認(rèn)鍵時(shí)
  write_1602com(er);
  for(j=0;j<16;j++)
  pass=0;
N=0;             //將輸入數(shù)據(jù)計(jì)數(shù)器清零,為下一次輸入作準(zhǔn)備
//==============================主函數(shù)===============================
void main(void)
  unsigned char KEY,NUM;
unsigned char i,j;
  P1=0xFF;        //P1口復(fù)位
TMOD=0x11;       //定義工作方式
  TL0=0xB0;
  TH0=0x3C;       //定時(shí)器賦初值
  EA=1;        //打開中斷總開關(guān)
  ET0=1;        //打開中斷允許開關(guān)
  TR0=0;        //打開定時(shí)器開關(guān)
  Delay400Ms();  //啟動(dòng)等待,等LCM講入工作狀態(tài)
  lcd_init();  //LCD初始化
write_1602com(yi);//日歷顯示固定符號從第一行第0個(gè)位置之后開始顯示
for(i=0;i<16;i++)
  write_1602dat(name[i]);//向液晶屏寫開機(jī)畫面
write_1602com(er);
for(i=0;i<16;i++)
  write_1602dat(start_line[i]);//寫輸入密碼等待界面
write_1602com(er+9); //設(shè)置光標(biāo)位置
write_1602com(0x0f); //設(shè)置光標(biāo)為閃爍
  Delay5Ms(); //延時(shí)片刻(可不要)
  N=0;              //初始化數(shù)據(jù)輸入位數(shù)
  while(1)   //進(jìn)入循環(huán)
  if(key_disable==1)      //鎖定鍵盤標(biāo)志為1時(shí)
   Alam_KeyUnable();     //報(bào)警鍵盤鎖
   ALAM=1;        //關(guān)報(bào)警
  KEY=keynum();       //讀按鍵的位置碼
  if(KEY!=0)        //當(dāng)有按鍵按下時(shí)
    second=0;      //秒清零
   else        //沒有鎖定鍵盤時(shí)
    NUM=coding(KEY);    //根據(jù)按鍵的位置將其編碼,編碼值賦值給NUM
     switch(NUM)     //判斷按鍵值
      case ('A'):  ;      break;
      case ('B'):  ;         break;
      case ('C'):
         for(i=0;i<16;i++)
         if(N>=1) N--; OneAlam();        //按鍵提示音
         //DisplayOneChar(6+N,1,'*');
         for(j=N;j<16;j++)
          write_1602com(er+6+j);
          write_1602dat(' ');
         for(j=0;j<N;j++)
          write_1602com(er+6+j);    //顯示位數(shù)隨輸入增加而增加
          write_1602dat('*');     //但不顯示實(shí)際數(shù)字,用*代替
         InputData[N]=N+4;
         break;  //ABC是無定義按鍵
      case ('D'): ResetPassword();  break;      //重新設(shè)置密碼
      case ('*'): Cancel();    break;      //取消當(dāng)前輸入
      case ('#'): Ensure();     break;    //確認(rèn)鍵,
      default:           //如果不是功能鍵按下時(shí),就是數(shù)字鍵按下
       //DisplayListChar(0,1,Input);
       if(N<6)                        //當(dāng)輸入的密碼少于6位時(shí),接受輸入并保存,大于6位時(shí)則無效。
        write_1602com(er);
        for(i=0;i<16;i++)
         write_1602dat(Input[i]);    //顯示輸入畫面
        OneAlam();        //按鍵提示音
         for(j=0;j<=N;j++)
        InputData[N]=NUM;      //將數(shù)字鍵的碼賦值給InputData[]數(shù)組暫存
        N++;         //密碼位數(shù)加
       else          //輸入數(shù)據(jù)位數(shù)大于6后,忽略輸入
        N=6;         //密碼輸入大于6位時(shí),不接受輸入
         break;
//*********************************中斷服務(wù)函數(shù)**************************************
void  time0_int(void) interrupt 1      //定時(shí)器T0
  TL0=0xB0;
  TH0=0x3C;    //定時(shí)器重新賦初值
  //TR0=1;
  countt0++;      //計(jì)時(shí)變量加,加1次時(shí)50ms
   if(countt0==20)     //加到20次就是1s
  countt0=0;     //變量清零
  second++;     //秒加
  if(pass==1)     //開鎖狀態(tài)時(shí)
   if(second==1)   //秒加到1s時(shí)
    TR0=0;    //關(guān)定時(shí)器
    TL0=0xB0;
     TH0=0x3C;   //再次賦初值
    second=0;   //秒清零
  else      //不在開鎖狀態(tài)時(shí)
   if(second==3)   //秒加到3時(shí)
    TR0=0;    //關(guān)閉定時(shí)器
    second=0;   //秒清零
    key_disable=0;  //鎖定鍵盤清零
    s3_keydown=0;
    TL0=0xB0;
    TH0=0x3C;   //重新賦初值
       TR0=1;    //打開定時(shí)器
ID:306099 發(fā)表于 2018-4-23 22:34 | 顯示全部樓層
只顯示一排黑框 硬件沒問題 應(yīng)該就是軟件的事  但是根本搞不懂啊 求大神指點(diǎn)一下
ID:111634 發(fā)表于 2018-4-24 08:30 | 顯示全部樓層
本帖最后由 zl2168 于 2018-4-24 08:32 編輯
給你一個(gè)正確有效案例,自己去對照鉆研吧!
實(shí)例67  LCD1602顯示屏顯示
實(shí)例61 LCD1602顯示屏顯示.rar (49.26 KB, 下載次數(shù): 9)
Proteus仿真一下,確認(rèn)有效以上摘自張志良編著《80C51單片機(jī)仿真設(shè)計(jì)實(shí)例教程——基于Keil CProteus》清華大學(xué)出版社ISBN 978-7-302-41682-1。書中電路和程序設(shè)計(jì)有詳細(xì)說明,程序語句條條有注解。
ID:315067 發(fā)表于 2018-4-24 09:15 | 顯示全部樓層
有個(gè)調(diào)整亮度的RV1  你調(diào)整亮度看看
ID:314246 發(fā)表于 2018-4-24 09:31 | 顯示全部樓層
只顯示黑框,應(yīng)該是液晶沒有正常初始化
ID:213173 發(fā)表于 2018-4-24 11:12 | 顯示全部樓層
只顯示一排黑塊說明1602初始化失敗,你把與顯示無關(guān)的所有代碼屏蔽,單獨(dú)調(diào)試1602,顯示正常后再逐步加入其它功能,我這樣試的可以正常顯示。 無標(biāo)題.jpg
//包含頭文件
#include <REG52.h>
#include<intrins.h>
//宏定義
//#define LCM_Data  P0    //將P0口定義為LCM_Data
//1602的控制腳
//sbit Scl=P3^4;   //24C02串行時(shí)鐘
//sbit Sda=P3^5;   //24C02串行數(shù)據(jù)
//sbit ALAM = P2^3;  //報(bào)警
//sbit KEY = P3^6;  //開鎖
//bit  pass=0;   //密碼正確標(biāo)志
//bit  ReInputEn=0;  //重置輸入允許標(biāo)志
//bit  s3_keydown=0;  //3秒按鍵標(biāo)志位
//bit  key_disable=0;  //鎖定鍵盤標(biāo)志
//unsigned char countt0,second; //t0中斷計(jì)數(shù)器,秒計(jì)數(shù)器
//void Delay5Ms(void);  //聲明延時(shí)函數(shù)
//unsigned char code a[]={0xFE,0xFD,0xFB,0xF7};     //控盤掃描控制表
//unsigned char code Correct[]  = {"     correct    "};  //輸入正確
//unsigned char code Error[]    = {"      error     "};   //輸入錯(cuò)誤
//unsigned char code codepass[] = {"      pass      "};
//unsigned char code LockOpen[] = {"      open      "};  //OPEN
//unsigned char code SetNew[]  = {"SetNewWordEnable"};
//unsigned char code Input[]    = {"input:          "};  //INPUT
//unsigned char code ResetOK[]  = {"ResetPasswordOK "};
//unsigned char code initword[] = {"Init password..."};
//unsigned char code Er_try[]  = {"error,try again!"};
//unsigned char code again[]  = {"input again     "};
//unsigned char InputData[6];         //輸入密碼暫存區(qū)
//unsigned char CurrentPassword[6]={1,3,1,4,2,0};    //管理員密碼(只可在程序中修改)
//unsigned char TempPassword[6];
//unsigned char N=0;    //密碼輸入位數(shù)記數(shù)
//unsigned char ErrorCont;   //錯(cuò)誤次數(shù)計(jì)數(shù)
//unsigned char CorrectCont;   //正確輸入計(jì)數(shù)
//unsigned char ReInputCont;    //重新輸入計(jì)數(shù)
//unsigned char code initpassword[6]={0,0,0,0,0,0};   //輸入管理員密碼后將密碼初始為000000
void Delay5Ms(void)
while(TempCyc--);
while(TempCycA--)
  TempCycB=7269;
  while(TempCycB--);
uchar i;
    while(t--)
     for(i=0;i<125;i++)
  _nop_();
  _nop_();
  _nop_();
/*起始條件*/
void Start(void)
  Sda=1;
  Scl=1;
  Nop();
  Sda=0;
  Nop();
/*停止條件*/
void Stop(void)
  Sda=0;
  Scl=1;
  Nop();
  Sda=1;
  Nop();
/*應(yīng)答位*/
void Ack(void)
Sda=0;
Nop();
Scl=1;
Nop();
Scl=0;
/*反向應(yīng)答位*/
void NoAck(void)
  Sda=1;
  Nop();
  Scl=1;
  Nop();
  Scl=0;
    uchar BitCounter=8;
    uchar temp;
    do
     Scl=0;
     Nop();
     Sda=1;
     Sda=0;
     Scl=1;
    Scl=0;
uchar Read(void)
    uchar temp=0;
uchar temp1=0;
uchar BitCounter=8;
Sda=1;
do
  Scl=0;
  Nop();
  Scl=1;
  Nop();
  else       //如果為0
   temp=temp1;
return(temp);
  uchar i;
  uchar *PData;
  PData=Data;
  for(i=0;i<Num;i++)
  Start();
  Send(0xa0);
  Ack();
  Send(Address+i);
  Ack();
  Send(*(PData+i));
  Ack();
  Stop();
  mDelay(20);
  uchar i;
  uchar *PData;
  PData=Data;
  for(i=0;i<Num;i++)
  Start();
  Send(0xa0);
  Ack();
  Send(Address+i);
  Ack();
  Start();
  Send(0xa1);
  Ack();
  *(PData+i)=Read();
  Scl=0;
  NoAck();
  Stop();
        uint x,y;
        for(x=xms;x>0;x--)
                for(y=110;y>0;y--);
        delay(1);
        delay(1);
        delay(1);
        delay(1);
void lcd_init(void)
unsigned char k;
switch(m)
return(k);
  P1=0xf0;
  if((P1&0xf0)!=0xf0)
     Delay5Ms();
        Delay5Ms();
     if((P1&0xf0)!=0xf0)
      row=P1^0xf0;          //確定行線
   i=0;
   P1=a;           //精確定位
   while(i<4)
     if((P1&0xf0)!=0xf0)
        break;            //已定位后提前退出
        i++;
        P1=a;
   return 0;
void OneAlam(void)
        ALAM=0;
        Delay5Ms();
        ALAM=1;
void TwoAlam(void)
        ALAM=0;
        Delay5Ms();
        ALAM=1;
        Delay5Ms();
        ALAM=0;
        Delay5Ms();
        ALAM=1;
        ALAM=0;
        Delay5Ms();
        ALAM=1;
        Delay5Ms();
        ALAM=0;
        Delay5Ms();
        ALAM=1;
        Delay5Ms();
        ALAM=0;
        Delay5Ms();
        ALAM=1;
        unsigned char i;
        if(pass==1)
                for(i=0;i<16;i++)
                        write_1602dat(LockOpen);    //顯示open 開鎖成功
        if(N==0)
        write_1602com(er);
        for(i=0;i<16;i++)
        write_1602dat(Error); //顯示錯(cuò)誤
        write_1602com(er);
        for(i=0;i<16;i++)
        write_1602dat(start_line);//顯示開始輸入
unsigned char i;
unsigned char j;
if(pass==0)
  pass=0;
   if(N==6)    //輸入6位密碼
     for(i=0;i<6;)
      if(TempPassword==InputData) //將兩次輸入的新密碼作對比
       i++;
      else        //如果兩次的密碼不同
       write_1602com(er);
       for(j=0;j<16;j++)
       pass=0;     //關(guān)鎖
       ReInputCont=0;
       DisplayChar();
       break;
     if(i==6)
      write_1602com(er);
      for(j=0;j<16;j++)
      TwoAlam();    //操作成功提示
      ReInputEn=0;
     ReInputCont=0;
     CorrectCont=0;
    else       //輸入一次密碼時(shí)
     OneAlam();
     write_1602com(er);
     for(j=0;j<16;j++)
     for(i=0;i<6;i++)
      TempPassword=InputData;  //將第一次輸入的數(shù)據(jù)暫存起來
P1=0x00;
  Delay5Ms();
void Cancel(void)
unsigned char i;
unsigned char j;
write_1602com(er);
for(j=0;j<16;j++)
TwoAlam();    //提示音
for(i=0;i<6;i++)
  InputData=0;  //將輸入密碼清零
KEY=1;     //關(guān)閉鎖
s3_keydown=0;
void Ensure(void)
unsigned char i,j;
    if(N==6)
   for(i=0;i<6;)
    if(CurrentPassword==InputData) //判斷輸入密碼和24c02中的密碼是否相同
     i++;        //相同一位 i就+1
    else          //如果有密碼不同
      write_1602com(er);
      for(i=0;i<16;i++)
      do
      Alam_KeyUnable();
      while(1);
      TR0=1;    //開啟定時(shí)
      pass=0;     //pass位清零
      break;     //跳出
     write_1602com(er);
     for(j=0;j<16;j++)
     KEY=0;           //開鎖
     TR0=1;           //開啟定時(shí)
      InputData=0;        //開鎖后將輸入位清零
     write_1602com(er);
     for(j=0;j<16;j++)
     TwoAlam();             //操作成功提示
     write_1602com(er);
     for(j=0;j<16;j++)
     TwoAlam();         //成功提示音
     TwoAlam();         //成功提示音
    else           //密碼輸入錯(cuò)誤
     write_1602com(er);
     for(j=0;j<16;j++)
     pass=0;
   write_1602com(er);
   for(j=0;j<16;j++)
  write_1602com(er);
  for(j=0;j<16;j++)
  pass=0;
//        unsigned char KEY,NUM;
        unsigned char i;//j;
//        P1=0xFF;        //P1口復(fù)位
//        TMOD=0x11;       //定義工作方式
//        TL0=0xB0;
//        TH0=0x3C;       //定時(shí)器賦初值
//        EA=1;        //打開中斷總開關(guān)
//        ET0=1;        //打開中斷允許開關(guān)
//        TR0=0;        //打開定時(shí)器開關(guān)
//        Delay400Ms();  //啟動(dòng)等待,等LCM講入工作狀態(tài)
        for(i=0;i<16;i++)
                write_1602dat(name);//向液晶屏寫開機(jī)畫面
        write_1602com(er);
        for(i=0;i<16;i++)
                write_1602dat(start_line);//寫輸入密碼等待界面
//        Delay5Ms(); //延時(shí)片刻(可不要)
//        N=0;              //初始化數(shù)據(jù)輸入位數(shù)
/*  if(key_disable==1)      //鎖定鍵盤標(biāo)志為1時(shí)
    second=0;      //秒清零
   else        //沒有鎖定鍵盤時(shí)
     switch(NUM)     //判斷按鍵值
      case ('C'):
         for(i=0;i<16;i++)
         for(j=N;j<16;j++)
          write_1602dat(' ');
         for(j=0;j<N;j++)
         InputData[N]=N+4;
         break;  //ABC是無定義按鍵
        write_1602com(er);
        for(i=0;i<16;i++)
         write_1602dat(Input);    //顯示輸入畫面
        OneAlam();        //按鍵提示音
         for(j=0;j<=N;j++)
        N++;         //密碼位數(shù)加
         break;
  TL0=0xB0;
  //TR0=1;
  countt0=0;     //變量清零
  second++;     //秒加
    TL0=0xB0;
     TH0=0x3C;   //再次賦初值
    second=0;   //秒清零
    second=0;   //秒清零
    s3_keydown=0;
    TL0=0xB0;
    TH0=0x3C;   //重新賦初值
       TR0=1;    //打開定時(shí)器
ID:306099 發(fā)表于 2018-4-26 22:49 | 顯示全部樓層
wulin 發(fā)表于 2018-4-24 11:12
只顯示一排黑塊說明1602初始化失敗,你把與顯示無關(guān)的所有代碼屏蔽,單獨(dú)調(diào)試1602,顯示正常后再逐步加入其 ...
大神  你用的 什么牌子的開發(fā)板
ID:306099 發(fā)表于 2018-4-26 22:51 | 顯示全部樓層
zl2168 發(fā)表于 2018-4-24 08:30
先Proteus仿真一下,確認(rèn)有效以上 ...
請問   自己怎么焊接1602外部電路  求指點(diǎn)
ID:213173 發(fā)表于 2018-4-27 06:22 | 顯示全部樓層
燒友分分分 發(fā)表于 2018-4-26 22:49
大神  你用的 什么牌子的開發(fā)板
是郭天祥的TX-1C開發(fā)板,除了rw固定接地,其他沒有差別。1602這部分與用什么開發(fā)板關(guān)系不大,關(guān)鍵是時(shí)序要正確,有的開發(fā)板使用了STC的1T單片機(jī),速度快許多,不能直接套用這個(gè)程序,需要修改Delay延時(shí)參數(shù)。
