查看: 2745|回復(fù): 1
VL53L0X如何用arduino顯示距離
ID:307818 發(fā)表于 2018-4-24 17:17 | 顯示全部樓層 |閱讀模式
各位大佬好,我是arduino萌新,想請(qǐng)問一下如何給以下測距程序加一個(gè)1602顯示距離的程序呢?
測距程序是在google論壇找的...
#include "Adafruit_VL53L0X.h"
#include <LiquidCrystal.h>
Adafruit_VL53L0X lox = Adafruit_VL53L0X();
void setup() {
  Serial.begin(9600);
  // wait until serial port opens for native USB devices
  while (! Serial) {
    delay(1);
  Serial.println("Adafruit VL53L0X test");
  if (!lox.begin()) {
    Serial.println(F("Failed to boot VL53L0X"));
    while(1);
  // power
  Serial.println(F("VL53L0X API Simple Ranging example\n\n"));
void loop() {
  VL53L0X_RangingMeasurementData_t measure;
  Serial.print("Reading a measurement... ");
  lox.rangingTest(&measure, false); // pass in 'true' to get debug data printout!
  if (measure.RangeStatus != 4) {  // phase failures have incorrect data
    Serial.print("Distance (mm): "); Serial.println(measure.RangeMilliMeter);
  } else {
    Serial.println(" out of range ");
  delay(100);
ID:306178 發(fā)表于 2018-4-26 09:53 | 顯示全部樓層
自己寫液晶屏驅(qū)動(dòng)庫吧,,我覺得arduino提供的LCD1602庫不好用,自己寫一個(gè)好了。
PS:耐心點(diǎn)看資料,然后參考一下其他人的代碼,很容易寫庫
LCD1602液晶完整中文資料.pdf
344.19 KB, 下載次數(shù): 11
