查看: 2647|回復(fù): 5
求助帖(基于C51的電子賀卡代碼問題)
ID:303454 發(fā)表于 2018-4-25 11:18 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
原理圖已連接完畢,代碼出現(xiàn)這些問題,求大神解答一下。
代碼問題
代碼問題
代碼問題1
代碼問題1
原理圖
原理圖
#include<reg52.h>
#define LCD P0
unsigned char a,i,j,k;
int b;
int key=0;
sbit EN=P2^0;
sbit RW=P2^1;
sbit RS=P2^2;
sbit CS1=P2^3;
sbit CS2=P2^4;
sbit BUSY=P0^0;
sbit speaker=P1^7;
unsigned char timer0h,timer0l,time;
void delay(unsigned char t)//延遲函數(shù)
  unsigned char t1;
  unsigned long t2;
  for(t1=0;t1<t;t1++)
   for(t2=0;t2<8000;t2++);
void t0int() interrupt 1                 //spk中斷
TR0=0;
speaker=!speaker;
TH0=timer0h;
TL0=timer0l;
TR0=1;
void song()                                          //音樂播放
TH0=timer0h;
TL0=timer0l;
TR0=1;
delay(time);
checkbusy()                 //LCD
{ EN=1;
  RW=1;
  RS=0;
  LCD=0XFF;
  if(BUSY);
writecode(unsigned char dat)  //寫命令
{ checkbusy();
  EN=1;
  RW=0;
  RS=0;
  LCD=dat;
  EN=1;
  EN=0;
writedata(unsigned char dat)  //寫數(shù)據(jù)
{ checkbusy();
  EN=1;
  RW=0;
  RS=1;
  LCD=dat;
  EN=1;
  EN=0;
//滿屏顯示圖片函數(shù)
void LCDDisplay(unsigned char page,unsigned char lineaddress, unsigned char table[8][128])
   for(i=0;i<8;i++)
      if(lineaddress<0X80)
            CS1=0;
            CS2=0;
       writecode(page+i);
       writecode(lineaddress);
     for(j=0;j<64;j++)
       writedata(table[i][j]);
     lineaddress+=1;
         if(lineaddress>=0X80)
          CS1=0;
            CS2=1;
            lineaddress=lineaddress-0X40;
         writecode(page+i);
                  for(j=64;j<128;j++)
        lineaddress+=1;
void lcdinti()
    writecode(0X3F);
    writecode(0XC0);
    writecode(0XB8);
    writecode(0X40);
void lcddelay(unsigned char c)           //LCD液晶延遲函數(shù)
   unsigned char a,b;
   for(;c>0;c--)
   for(b=142;b>0;b--)
   for(a=2;a>0;a--);
void int0() interrupt 0                        //LCD外部中斷1
  EX0=0;
  lcddelay(40);
  EX0=1;
  key=!key;
main()                                                //主函數(shù)
unsigned char k,i;
TMOD=1; //置CT0定時工作方式1
ET0=1;//IE=0x82 //CPU開中斷,CT0開中斷
   EA=1;
   EX0=1;
   IT0=1;
     if(key==0)
                 LCDDisplay(0Xb8,0X40,&ch2);
            i=0;
            while(i<100&&key==0)
               k=sszymmh[i]+7*sszymmh[i+1]-1;
           timer0h=FREQH[k];
           timer0l=FREQL[k];
           time=sszymmh[i+2];
           i=i+3;
               song();
          LCDDisplay(0Xb8,0X40,&ch1);
           i=0;
            while(i<100&&key==1)
               k=sszymmh1[i]+7*sszymmh1[i+1]-1;
           timer0h=FREQH[k];
           timer0l=FREQL[k];
           time=sszymmh1[i+2];
           i=i+3;
               song();
全部代碼在這
ID:303454 發(fā)表于 2018-4-25 11:21 | 只看該作者
error c202,求解。
ID:303454 發(fā)表于 2018-4-25 11:22 | 只看該作者
小白不太理解,幫忙代碼核對正確,謝謝大神們
ID:303454 發(fā)表于 2018-4-25 12:40 | 只看該作者
此貼終結(jié),謝謝51黑,已經(jīng)自己找到錯誤,打擾了
ID:452829 發(fā)表于 2019-3-18 08:48 | 只看該作者
我不會啊 發(fā)表于 2018-4-25 12:40
我做課程設(shè)計也遇到過同樣的錯誤,請問怎么解決?
