查看: 2776|回復(fù): 8
剛買來的stc12c5a60s2單片機開發(fā)板+1602顯示dht11,1602上為什么不顯示數(shù)據(jù)呢
ID:291819 發(fā)表于 2018-4-25 22:23 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
  1. #include<reg52.h>
  2. #include<stdlib.h>
  3. #include <ctype.h>
  4. #define uint unsigned int
  5. #define uchar unsigned char
  6. uchar DHT11[5],RTflag=0;
  7. uchar FLAG; //超時標(biāo)志位
  8. uchar a;
  9. sbit dat=P1^0;         //DHT11數(shù)據(jù)引腳
  10. sbit RS=P2^5;         //1602引腳
  11. sbit RW=P2^6;         //1602引腳
  12. sbit EN=P2^7;          //1602引腳
  13. uchar table[5];
  14. uint wd,sd;
  15. void Delay_t(uint j)         //延時函數(shù)
  16. { uchar i;
  17. for(;j>0;j--)
  18. {
  19. for(i=0;i<27;i++);
  20. }
  21. }
  22. void Delay_10us(void) //10us延時函數(shù)
  23. {
  24. uchar i;
  25. i--;
  26. i--;
  27. i--;
  28. i--;
  29. i--;
  30. i--;
  31. }
  32. void delay(uint z)//1毫秒延時函數(shù)
  33. {
  34. uint x,y;
  35. for(x=z;x>0;x--)
  36. for(y=110;y>0;y--);
  37. }
  38. void lcd_write_com(uchar com) //1602寫指令
  39. {
  40. RS=0;
  41. //RW=0;
  42. delay(1);
  43. EN=1;
  44. P0=com;
  45. delay(1);
  46. EN=0;
  47. }
  48. void lcd_init()        //1602初始化
  49. {
  50. EN=0;
  51. RW=0;
  52. lcd_write_com(0x38);
  53. delay(1);
  54. lcd_write_com(0x08);
  55. delay(1);
  56. lcd_write_com(0x01);//1602清屏指令
  57. delay(1);
  58. lcd_write_com(0x06);
  59. delay(1);
  60. lcd_write_com(0x0C);
  61. delay(1);
  62. }
  63. void lcd_write_data(uchar date)//1602寫數(shù)據(jù)
  64. {
  65. RS=1;
  66. //RW=0;
  67. EN=1;
  68. P0=date;
  69. delay(1);
  70. EN=0;
  71. }
  72. void write_str(uchar x,uchar y,uchar *s)//在任意地址寫符號字母或數(shù)字
  73. {
  74. if(y==0)
  75. lcd_write_com(0x80+x);
  76. else
  77. lcd_write_com(0xc0+x);
  78. while(*s)
  79. {
  80. lcd_write_data(*s);
  81. s++;
  82. }
  83. }
  84. void write_shu(uchar x,uchar y,uchar num)//數(shù)據(jù)顯示函數(shù)
  85. {
  86. uchar s,g;
  87. if(y==0)
  88. lcd_write_com(0x80+x);
  89. else
  90. lcd_write_com(0xc0+x);
  91. s=num/10;// 數(shù)據(jù)分離顯示
  92. lcd_write_data(0x30+s);
  93. g=num%10;//數(shù)據(jù)分離顯示
  94. lcd_write_data(0x30+g);
  95. }
  96. uchar write_byte1() //讀一個字節(jié)
  97. {
  98. uchar i,comdata,temp1;
  99. for(i=0;i<8;i++)
  100. {
  101. FLAG=2;
  102. while((!dat)&&FLAG++);//判斷數(shù)據(jù)位是0還是1
  103. Delay_10us();
  104. Delay_10us();
  105. Delay_10us();
  106. temp1=0;
  107. if(dat)temp1=1;        // 如果高電平高過預(yù)定0高電平值則數(shù)據(jù)位為 1
  108. FLAG=2;
  109. while((dat)&&FLAG++);//flag先與后加1 如果dat一直為1 uchar型變量 flag 溢出變?yōu)? 再自加1
  110. if(FLAG==1)break;        //超時則跳出for循環(huán)
  111. comdata<<=1;//左移一位 高位在前 低位在后
  112. comdata|=temp1;
  113. }
  114. return (comdata);
  115. }
  116. void DHT11_5() //讀5個字節(jié)數(shù)據(jù) 兩個字節(jié)為溫度數(shù)據(jù) 兩個字節(jié)為濕度數(shù)據(jù) 最后一個字節(jié)為校驗
  117. {
  118.    int p;
  119.    char o;
  120. uchar i,temp;
  121. //主機拉低18ms
  122. dat=0;
  123. Delay_t(180);
  124. dat=1;
  125. //總線由上拉電阻拉高 主機延時20us
  126. Delay_10us();
  127. Delay_10us();
  128. Delay_10us();
  129. Delay_10us();
  130. //主機設(shè)為輸入 判斷從機響應(yīng)信號
  131. dat=1;
  132. //判斷從機是否有低電平響應(yīng)信號 如不響應(yīng)則跳出,響應(yīng)則向下運行
  133. if(!dat)        //T !
  134. {
  135. FLAG=2;        //超時標(biāo)志位
  136. while((!dat)&&FLAG++);//判斷從機是否發(fā)出 80us 的低電平響應(yīng)信號是否結(jié)束
  137. FLAG=2;
  138. while(
  139. (dat)&&FLAG++); //判斷從機拉高80us是否結(jié)束
  140. for(i=0;i<5;i++)//數(shù)據(jù)接收狀態(tài)
  141. {
  142. DHT11[i]=write_byte1();
  143. }
  144. dat=1;        //釋放數(shù)據(jù)總線 為下一次讀取做好準(zhǔn)備
  145. temp=(DHT11[0]+DHT11[1]+DHT11[2]+DHT11[3]);
  146. if(temp==DHT11[4])        //數(shù)據(jù)校驗
  147. {
  148. RTflag=1;
  149. }
  150.   p=DHT11[0];
  151.   o=toascii(p);
  152. if(RTflag==1) //如果RTflag=1 說明讀取到得數(shù)據(jù)正確
  153. {
  154. RTflag=0;
  155. //        tm[0]=DATARHT[0]/10;
  156. //        tm[1]=DATARHT[0]%10;
  157. //        tm[2]=DATARHT[1]/10; //濕度
  158. //        tm[3]=DATARHT[2]/10;
  159. //        tm[4]=DATARHT[2]%10;
  160. //        tm[5]=DATARHT[3]/10; //溫度
  161. write_str(0,0,"shidu: ");//第一行顯示濕度
  162. write_shu(12,0,o);
  163. write_str(14,0,"RH");
  164. write_str(0,1,"wendu: ");//第二行為顯示溫度
  165. write_shu(12,1,DHT11[2]);
  166. write_str(14,1,"^C");
  167. }
  168. }
  169. }
  170. void main()
  171. {
  172. lcd_init(); //1602初始化
  173. delay(1000); //等待DHT11溫濕度傳感器數(shù)據(jù)穩(wěn)定 開始激活DHT11
  174. while(1)//循環(huán)讀取 并更新數(shù)據(jù)顯示
  175. {
  176. delay(1000);//等待DHT11溫濕度傳感器數(shù)據(jù)穩(wěn)定 開始激活DHT11
  177. write_byte1();//讀一個字節(jié)
  178. DHT11_5(); //讀數(shù)據(jù)
  179. delay(1000); //延時等待
  180. }
  181. }
ID:291819 發(fā)表于 2018-4-25 22:25 | 只看該作者
程序是從51單片機移植過來的,把數(shù)據(jù)引腳改過了
ID:291819 發(fā)表于 2018-4-25 22:26 | 只看該作者
本帖最后由 電子勿擾 于 2018-4-25 22:29 編輯
剛買來的板子,還不太會用,請問51單片機與stc12c5a60s2單片機有什么區(qū)別嗎?倆者程序兼容嗎?
ID:213173 發(fā)表于 2018-4-26 12:14 | 只看該作者
電子勿擾 發(fā)表于 2018-4-25 22:26
51單片機與stc12c5a60s2單片機主要差別是后者是1T單片機并內(nèi)置了一些外圍設(shè)備,速度快許多,1602不顯示、dht11讀不了可能是你沒有把延時函數(shù)修改,從而導(dǎo)致驅(qū)動程序的時序錯誤。
ID:316332 發(fā)表于 2018-4-26 17:27 | 只看該作者
程序沒有問題,就調(diào)1602亮度
ID:291819 發(fā)表于 2018-4-26 19:30 | 只看該作者
wulin 發(fā)表于 2018-4-26 12:14
51單片機與stc12c5a60s2單片機主要差別是后者是1T單片機并內(nèi)置了一些外圍設(shè)備,速度快許多,1602不顯示、 ...
我把延時加長一點
ID:291819 發(fā)表于 2018-4-26 19:32 | 只看該作者
123456m 發(fā)表于 2018-4-26 17:27
我考慮到亮度,調(diào)過亮度還是不顯示數(shù)據(jù)
ID:291819 發(fā)表于 2018-4-26 19:33 | 只看該作者
我把延時加長一點試一試
ID:319953 發(fā)表于 2018-5-10 09:57 | 只看該作者
電子勿擾 發(fā)表于 2018-4-26 19:33
我把延時加長一點試一試
我也是這個問題,我想請教一下應(yīng)該怎么修改呢。
