查看: 3147|回復(fù): 1
(原創(chuàng)設(shè)計(jì)程序)藍(lán)牙控制小車源程序
ID:317135 發(fā)表于 2018-4-27 14:26 | 只看該作者 回帖獎(jiǎng)勵(lì) |正序?yàn)g覽 |閱讀模式
************************************電機(jī)驅(qū)動(dòng)模塊為L298N*******************************************
************************************藍(lán)牙模塊為HC-06***********************************************
#include<reg52.h>
#include "drive.h"
typedef unsigned char u8;
typedef unsigned int u16;
u8 a;
uchar k;
sbit IN1=P1^1;
sbit IN2=P1^2;
sbit IN3=P1^3;
sbit IN4=P1^4;
sbit ENA=P1^0;
void com_init() //串口初始化函數(shù),波特率9600bps
TMOD = 0x20;
TH1 = 0xf9;
TL1 = 0xf9;
PCON=0X80;
TR1 = 1;
SCON=0X50;
ES = 1;
EA = 1;
void delay(unsigned int z)
    unsigned int x,y;
for(x=z;x>0;x--)
   for(y=100;y>0;y--);
void Stop()  //停止
unsigned int i;
IN1=0;
IN2=0;
IN3=0;
IN4=0; //停止
   for(i=0;i<100;i++)
      delay(20);
void Backward()  //后退
unsigned int i;
IN1=0;
IN2=1;
IN3=0;
IN4=1; //反轉(zhuǎn)
   for(i=0;i<100;i++)
      delay(20);
    IN1=0;
IN2=0;
IN3=0;
IN4=0;
void Forward() //前進(jìn)
unsigned int i;
IN1=1;
IN2=0;
IN3=1;
IN4=0; //正轉(zhuǎn)
   for(i=0;i<100;i++)
      delay(20);
    IN1=0;
IN2=0;
IN3=0;
IN4=0;
void Wleft()     //前左
unsigned int i;
IN1=0;
IN2=0;
IN3=1;
IN4=0; //左轉(zhuǎn)
   for(i=0;i<100;i++)
      delay(20);
    IN1=0;
IN2=0;
IN3=0;
IN4=0;
void Wright()     //前右
unsigned int i;
IN1=1;
IN2=0;
IN3=0;
IN4=0; //右轉(zhuǎn)
   for(i=0;i<100;i++)
      delay(20);
    IN1=0;
IN2=0;
IN3=0;
IN4=0;
void Bright()   //后右
unsigned int i;
IN1=0;
IN2=0;
IN3=0;
IN4=1; //后右
   for(i=0;i<100;i++)
      delay(20);
    IN1=0;
IN2=0;
IN3=0;
IN4=0;
void Bleft()    // 后左
unsigned int i;
IN1=0;
IN2=1;
IN3=0;
IN4=0; //后左
   for(i=0;i<100;i++)
      delay(20);
    IN1=0;
IN2=0;
IN3=0;
IN4=0;
void main() //主函數(shù)
com_init(); //串口初始化
while(1); //死循環(huán),等待藍(lán)牙傳命令過來
void Usart() interrupt 4
a=SBUF;
SBUF=a;//出去接收到的數(shù)據(jù)
switch(a) //判斷收到的命令是干嘛的
case 'A':Stop();break; //停止A
case 'B':Backward();break; //后退B
case 'C':Forward();break; //前進(jìn)C
case 'D':Wleft();break; //前左D
case 'E':Wright();break; //前右E
case 'F':Bright();break; //后右F
case 'G':Bleft();break; // 后左G
    REN=0;
    ES=1;
RI = 0;//清除接收中斷標(biāo)志位
while(!TI);    //等待發(fā)送數(shù)據(jù)完成
TI=0;       //清除發(fā)送完成標(biāo)志位
ID:1 發(fā)表于 2018-4-27 16:49 | 只看該作者
能分享下原理圖 與介紹嗎?
