查看: 6589|回復(fù): 0
SM7012引腳圖電路圖與pdf資料下載 恒壓非隔離驅(qū)動(dòng)電源芯片
恒壓非隔離驅(qū)動(dòng)電源芯片SM7012技術(shù)文檔資料原理圖
Features
85v to 265v wide range AC voltage input
A 730v MOSFET on the same silicon chip
Auto start up with high voltage current source
PWM with current mode control
10v to 39v wide range VCC voltage
Fixed 55KHz switching frequency
Automatic skip cycle mode in low load condition.
Over temperature, over current and over voltage
protection
Auxiliary under voltage lockout with hysteresis
SM7012引腳圖:
SM7012應(yīng)用電路圖:
SM7012管腳功能定義:
完整的pdf格式文檔51黑下載地址:
AP8012技術(shù)資料.pdf (486.28 KB, 下載次數(shù): 12)
