查看: 2315|回復(fù): 0
Arduino ISP
ID:318096 發(fā)表于 2018-4-27 23:10 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
Tested OK
u can use ur arduino as a programmer for other avr family
  1. // ArduinoISP
  2. // Copyright (c) 2008-2011 Randall Bohn
  3. // If you require a license, see
  4. //
  5. // This sketch turns the Arduino into a AVRISP
  6. // using the following arduino pins:
  7. //
  8. // Pin 10 is used to reset the target microcontroller.
  9. //
  10. // By default, the hardware SPI pins MISO, MOSI and SCK pins are used
  11. // to communicate with the target. On all Arduinos, these pins can be found
  12. // on the ICSP/SPI header:
  13. //
  14. //               MISO °. . 5V (!) Avoid this pin on Due, Zero...
  15. //               SCK   . . MOSI
  16. //                     . . GND
  17. //
  18. // On some Arduinos (Uno,...), pins MOSI, MISO and SCK are the same pins
  19. // as digital pin 11, 12 and 13, respectively. That is why many tutorials
  20. // instruct you to hook up the target to these pins. If you find this wiring
  21. // more practical, have a define USE_OLD_STYLE_WIRING. This will work even
  22. // even when not using an Uno. (On an Uno this is not needed).
  23. //
  24. // Alternatively you can use any other digital pin by configuring software ('BitBanged')
  25. // SPI and having appropriate defines for PIN_MOSI, PIN_MISO and PIN_SCK.
  26. //
  27. // IMPORTANT: When using an Arduino that is not 5V tolerant (Due, Zero, ...)
  28. // as the programmer, make sure to not expose any of the programmer's pins to 5V.
  29. // A simple way to accomplish this is to power the complete system (programmer
  30. // and target) at 3V3.
  31. //
  32. // Put an LED (with resistor) on the following pins:
  33. // 9: Heartbeat   - shows the programmer is running
  34. // 8: Error       - Lights up if something goes wrong (use red if that makes sense)
  35. // 7: Programming - In communication with the slave
  36. //
  37. #include "Arduino.h"
  38. #undef SERIAL
  39. #define PROG_FLICKER true
  40. // Configure SPI clock (in Hz).
  41. // E.g. for an attiny @128 kHz: the datasheet states that both the high
  42. // and low spi clock pulse must be > 2 cpu cycles, so take 3 cycles i.e.
  43. // divide target f_cpu by 6:
  44. //     #define SPI_CLOCK            (128000/6)
  45. //
  46. // A clock slow enough for an attiny85 @ 1MHz, is a reasonable default:
  47. #define SPI_CLOCK                 (1000000/6)
  48. // Select hardware or software SPI, depending on SPI clock.
  49. // Currently only for AVR, for other archs (Due, Zero,...),
  50. // hardware SPI is probably too fast anyway.
  51. #if defined(ARDUINO_ARCH_AVR)
  52. #if SPI_CLOCK > (F_CPU / 128)
  53. #define USE_HARDWARE_SPI
  54. #endif
  55. #endif
  56. // Configure which pins to use:
  57. // The standard pin configuration.
  58. #ifndef ARDUINO_HOODLOADER2
  59. #define RESET     10 // Use pin 10 to reset the target rather than SS
  60. #define LED_HB    9
  61. #define LED_ERR   8
  62. #define LED_PMODE 7
  63. // Uncomment following line to use the old Uno style wiring
  64. // (using pin 11, 12 and 13 instead of the SPI header) on Leonardo, Due...
  65. // #define USE_OLD_STYLE_WIRING
  66. #ifdef USE_OLD_STYLE_WIRING
  67. #define PIN_MOSI        11
  68. #define PIN_MISO        12
  69. #define PIN_SCK                13
  70. #endif
  71. // HOODLOADER2 means running sketches on the atmega16u2
  72. // serial converter chips on Uno or Mega boards.
  73. // We must use pins that are broken out:
  74. #else
  75. #define RESET             4
  76. #define LED_HB            7
  77. #define LED_ERR           6
  78. #define LED_PMODE         5
  79. #endif
  80. // By default, use hardware SPI pins:
  81. #ifndef PIN_MOSI
  82. #define PIN_MOSI         MOSI
  83. #endif
  84. #ifndef PIN_MISO
  85. #define PIN_MISO         MISO
  86. #endif
  87. #ifndef PIN_SCK
  88. #define PIN_SCK         SCK
  89. #endif
  90. // Force bitbanged SPI if not using the hardware SPI pins:
  91. #if (PIN_MISO != MISO) ||  (PIN_MOSI != MOSI) || (PIN_SCK != SCK)
  92. #undef USE_HARDWARE_SPI
  93. #endif
  94. // Configure the serial port to use.
  95. //
  96. // Prefer the USB virtual serial port (aka. native USB port), if the Arduino has one:
  97. //   - it does not autoreset (except for the magic baud rate of 1200).
  98. //   - it is more reliable because of USB handshaking.
  99. //
  100. // Leonardo and similar have an USB virtual serial port: 'Serial'.
  101. // Due and Zero have an USB virtual serial port: 'SerialUSB'.
  102. //
  103. // On the Due and Zero, 'Serial' can be used too, provided you disable autoreset.
  104. // To use 'Serial': #define SERIAL Serial
  105. #ifdef SERIAL_PORT_USBVIRTUAL
  106. #define SERIAL SERIAL_PORT_USBVIRTUAL
  107. #else
  108. #define SERIAL Serial
  109. #endif
  110. // Configure the baud rate:
  111. //#define BAUDRATE        19200
  112. // #define BAUDRATE        115200
  113. #define BAUDRATE        500000
  114. #define HWVER 2
  115. #define SWMAJ 1
  116. #define SWMIN 18
  117. // STK Definitions
  118. #define STK_OK      0x10
  119. #define STK_FAILED  0x11
  120. #define STK_UNKNOWN 0x12
  121. #define STK_INSYNC  0x14
  122. #define STK_NOSYNC  0x15
  123. #define CRC_EOP     0x20 //ok it is a space...
  124. void pulse(int pin, int times);
  125. #ifdef USE_HARDWARE_SPI
  126. #include "SPI.h"
  127. #else
  128. #define SPI_MODE0 0x00
  129. class SPISettings {
  130. public:
  131.   // clock is in Hz
  132.   SPISettings(uint32_t clock, uint8_t bitOrder, uint8_t dataMode) : clock(clock){
  133.     (void) bitOrder;
  134.     (void) dataMode;
  135.   };
  136. private:
  137.   uint32_t clock;
  138. friend class BitBangedSPI;
  139. };
  140. class BitBangedSPI {
  141. public:
  142.   void begin() {
  143.     digitalWrite(PIN_SCK, LOW);
  144.     digitalWrite(PIN_MOSI, LOW);
  145.     pinMode(PIN_SCK, OUTPUT);
  146.     pinMode(PIN_MOSI, OUTPUT);
  147.     pinMode(PIN_MISO, INPUT);
  148.   }
  149.   void beginTransaction(SPISettings settings) {
  150.     pulseWidth = (500000 + settings.clock - 1) / settings.clock;
  151.     if (pulseWidth == 0)
  152.       pulseWidth = 1;
  153.   }
  154.   void end() {}
  155.   uint8_t transfer (uint8_t b) {
  156.     for (unsigned int i = 0; i < 8; ++i) {
  157.       digitalWrite(PIN_MOSI, (b & 0x80) ? HIGH : LOW);
  158.       digitalWrite(PIN_SCK, HIGH);
  159.       delayMicroseconds(pulseWidth);
  160.       b = (b << 1) | digitalRead(PIN_MISO);
  161.       digitalWrite(PIN_SCK, LOW); // slow pulse
  162.       delayMicroseconds(pulseWidth);
  163.     }
  164.     return b;
  165.   }
  166. private:
  167.   unsigned long pulseWidth; // in microseconds
  168. };
  169. static BitBangedSPI SPI;
  170. #endif
  171. void setup() {
  172.   SERIAL.begin(BAUDRATE);
  173.   pinMode(LED_PMODE, OUTPUT);
  174.   pulse(LED_PMODE, 2);
  175.   pinMode(LED_ERR, OUTPUT);
  176.   pulse(LED_ERR, 2);
  177.   pinMode(LED_HB, OUTPUT);
  178.   pulse(LED_HB, 2);
  179. }
  180. int error = 0;
  181. int pmode = 0;
  182. // address for reading and writing, set by 'U' command
  183. unsigned int here;
  184. uint8_t buff[256]; // global block storage
  185. #define beget16(addr) (*addr * 256 + *(addr+1) )
  186. typedef struct param {
  187.   uint8_t devicecode;
  188.   uint8_t revision;
  189.   uint8_t progtype;
  190.   uint8_t parmode;
  191.   uint8_t polling;
  192.   uint8_t selftimed;
  193.   uint8_t lockbytes;
  194.   uint8_t fusebytes;
  195.   uint8_t flashpoll;
  196.   uint16_t eeprompoll;
  197.   uint16_t pagesize;
  198.   uint16_t eepromsize;
  199.   uint32_t flashsize;
  200. }
  201. parameter;
  202. parameter param;
  203. // this provides a heartbeat on pin 9, so you can tell the software is running.
  204. uint8_t hbval = 128;
  205. int8_t hbdelta = 8;
  206. void heartbeat() {
  207.   static unsigned long last_time = 0;
  208.   unsigned long now = millis();
  209.   if ((now - last_time) < 40)
  210.     return;
  211.   last_time = now;
  212.   if (hbval > 192) hbdelta = -hbdelta;
  213.   if (hbval < 32) hbdelta = -hbdelta;
  214.   hbval += hbdelta;
  215.   analogWrite(LED_HB, hbval);
  216. }
  217. static bool rst_active_high;
  218. void reset_target(bool reset) {
  219.   digitalWrite(RESET, ((reset && rst_active_high) || (!reset && !rst_active_high)) ? HIGH : LOW);
  220. }
  221. void loop(void) {
  222.   // is pmode active?
  223.   if (pmode) {
  224.     digitalWrite(LED_PMODE, HIGH);
  225.   } else {
  226.     digitalWrite(LED_PMODE, LOW);
  227.   }
  228.   // is there an error?
  229.   if (error) {
  230.     digitalWrite(LED_ERR, HIGH);
  231.   } else {
  232.     digitalWrite(LED_ERR, LOW);
  233.   }
  234.   // light the heartbeat LED
  235.   heartbeat();
  236.   if (SERIAL.available()) {
  237.     avrisp();
  238.   }
  239. }
  240. uint8_t getch() {
  241.   while (!SERIAL.available());
  242.   return SERIAL.read();
  243. }
  244. void fill(int n) {
  245.   for (int x = 0; x < n; x++) {
  246.     buff[x] = getch();
  247.   }
  248. }
  249. #define PTIME 30
  250. void pulse(int pin, int times) {
  251.   do {
  252.     digitalWrite(pin, HIGH);
  253.     delay(PTIME);
  254.     digitalWrite(pin, LOW);
  255.     delay(PTIME);
  256.   } while (times--);
  257. }
  258. void prog_lamp(int state) {
  259.   if (PROG_FLICKER) {
  260.     digitalWrite(LED_PMODE, state);
  261.   }
  262. }
  263. uint8_t spi_transaction(uint8_t a, uint8_t b, uint8_t c, uint8_t d) {
  264.   SPI.transfer(a);
  265.   SPI.transfer(b);
  266.   SPI.transfer(c);
  267.   return SPI.transfer(d);
  268. }
  269. void empty_reply() {
  270.   if (CRC_EOP == getch()) {
  271.     SERIAL.print((char)STK_INSYNC);
  272.     SERIAL.print((char)STK_OK);
  273.   } else {
  274.     error++;
  275.     SERIAL.print((char)STK_NOSYNC);
  276.   }
  277. }
  278. void breply(uint8_t b) {
  279.   if (CRC_EOP == getch()) {
  280.     SERIAL.print((char)STK_INSYNC);
  281.     SERIAL.print((char)b);
  282.     SERIAL.print((char)STK_OK);
  283.   } else {
  284.     error++;
  285.     SERIAL.print((char)STK_NOSYNC);
  286.   }
  287. }
  288. void get_version(uint8_t c) {
  289.   switch (c) {
  290.     case 0x80:
  291.       breply(HWVER);
  292.       break;
  293.     case 0x81:
  294.       breply(SWMAJ);
  295.       break;
  296.     case 0x82:
  297.       breply(SWMIN);
  298.       break;
  299.     case 0x93:
  300.       breply('S'); // serial programmer
  301.       break;
  302.     default:
  303.       breply(0);
  304.   }
  305. }
  306. void set_parameters() {
  307.   // call this after reading paramter packet into buff[]
  308.   param.devicecode = buff[0];
  309.   param.revision   = buff[1];
  310.   param.progtype   = buff[2];
  311.   param.parmode    = buff[3];
  312.   param.polling    = buff[4];
  313.   param.selftimed  = buff[5];
  314.   param.lockbytes  = buff[6];
  315.   param.fusebytes  = buff[7];
  316.   param.flashpoll  = buff[8];
  317.   // ignore buff[9] (= buff[8])
  318.   // following are 16 bits (big endian)
  319.   param.eeprompoll = beget16(&buff[10]);
  320.   param.pagesize   = beget16(&buff[12]);
  321.   param.eepromsize = beget16(&buff[14]);
  322.   // 32 bits flashsize (big endian)
  323.   param.flashsize = buff[16] * 0x01000000
  324.                     + buff[17] * 0x00010000
  325.                     + buff[18] * 0x00000100
  326.                     + buff[19];
  327.   // avr devices have active low reset, at89sx are active high
  328.   rst_active_high = (param.devicecode >= 0xe0);
  329. }
  330. void start_pmode() {
  331.   // Reset target before driving PIN_SCK or PIN_MOSI
  332.   // SPI.begin() will configure SS as output,
  333.   // so SPI master mode is selected.
  334.   // We have defined RESET as pin 10,
  335.   // which for many arduino's is not the SS pin.
  336.   // So we have to configure RESET as output here,
  337.   // (reset_target() first sets the correct level)
  338.   reset_target(true);
  339.   pinMode(RESET, OUTPUT);
  340.   SPI.begin();
  341.   SPI.beginTransaction(SPISettings(SPI_CLOCK, MSBFIRST, SPI_MODE0));
  342.   // See avr datasheets, chapter "SERIAL_PRG Programming Algorithm":
  343.   // Pulse RESET after PIN_SCK is low:
  344.   digitalWrite(PIN_SCK, LOW);
  345.   delay(20); // discharge PIN_SCK, value arbitrally chosen
  346.   reset_target(false);
  347.   // Pulse must be minimum 2 target CPU clock cycles
  348.   // so 100 usec is ok for CPU speeds above 20KHz
  349.   delayMicroseconds(100);
  350.   reset_target(true);
  351.   // Send the enable programming command:
  352.   delay(50); // datasheet: must be > 20 msec
  353.   spi_transaction(0xAC, 0x53, 0x00, 0x00);
  354.   pmode = 1;
  355. }
  356. void end_pmode() {
  357.   SPI.end();
  358.   // We're about to take the target out of reset
  359.   // so configure SPI pins as input
  360.   pinMode(PIN_MOSI, INPUT);
  361.   pinMode(PIN_SCK, INPUT);
  362.   reset_target(false);
  363.   pinMode(RESET, INPUT);
  364.   pmode = 0;
  365. }
  366. void universal() {
  367.   uint8_t ch;
  368.   fill(4);
  369.   ch = spi_transaction(buff[0], buff[1], buff[2], buff[3]);
  370.   breply(ch);
  371. }
  372. void flash(uint8_t hilo, unsigned int addr, uint8_t data) {
  373.   spi_transaction(0x40 + 8 * hilo,
  374.                   addr >> 8 & 0xFF,
  375.                   addr & 0xFF,
  376.                   data);
  377. }
  378. void commit(unsigned int addr) {
  379.   if (PROG_FLICKER) {
  380.     prog_lamp(LOW);
  381.   }
  382.   spi_transaction(0x4C, (addr >> 8) & 0xFF, addr & 0xFF, 0);
  383.   if (PROG_FLICKER) {
  384.     delay(PTIME);
  385.     prog_lamp(HIGH);
  386.   }
  387. }
  388. unsigned int current_page() {
  389.   if (param.pagesize == 32) {
  390.     return here & 0xFFFFFFF0;
  391.   }
  392.   if (param.pagesize == 64) {
  393.     return here & 0xFFFFFFE0;
  394.   }
  395.   if (param.pagesize == 128) {
  396.     return here & 0xFFFFFFC0;
  397.   }
  398.   if (param.pagesize == 256) {
  399.     return here & 0xFFFFFF80;
  400.   }
  401.   return here;
  402. }
  403. void write_flash(int length) {
  404.   fill(length);
  405.   if (CRC_EOP == getch()) {
  406.     SERIAL.print((char) STK_INSYNC);
  407.     SERIAL.print((char) write_flash_pages(length));
  408.   } else {
  409.     error++;
  410.     SERIAL.print((char) STK_NOSYNC);
  411.   }
  412. }
  413. uint8_t write_flash_pages(int length) {
  414.   int x = 0;
  415.   unsigned int page = current_page();
  416.   while (x < length) {
  417.     if (page != current_page()) {
  418.       commit(page);
  419.       page = current_page();
  420.     }
  421.     flash(LOW, here, buff[x++]);
  422.     flash(HIGH, here, buff[x++]);
  423.     here++;
  424.   }
  425.   commit(page);
  426.   return STK_OK;
  427. }
  428. #define EECHUNK (32)
  429. uint8_t write_eeprom(unsigned int length) {
  430.   // here is a word address, get the byte address
  431.   unsigned int start = here * 2;
  432.   unsigned int remaining = length;
  433.   if (length > param.eepromsize) {
  434.     error++;
  435.     return STK_FAILED;
  436.   }
  437.   while (remaining > EECHUNK) {
  438.     write_eeprom_chunk(start, EECHUNK);
  439.     start += EECHUNK;
  440.     remaining -= EECHUNK;
  441.   }
  442.   write_eeprom_chunk(start, remaining);
  443.   return STK_OK;
  444. }
  445. // write (length) bytes, (start) is a byte address
  446. uint8_t write_eeprom_chunk(unsigned int start, unsigned int length) {
  447.   // this writes byte-by-byte,
  448.   // page writing may be faster (4 bytes at a time)
  449.   fill(length);
  450.   prog_lamp(LOW);
  451.   for (unsigned int x = 0; x < length; x++) {
  452.     unsigned int addr = start + x;
  453.     spi_transaction(0xC0, (addr >> 8) & 0xFF, addr & 0xFF, buff[x]);
  454.     delay(45);
  455.   }
  456.   prog_lamp(HIGH);
  457.   return STK_OK;
  458. }
  459. void program_page() {
  460.   char result = (char) STK_FAILED;
  461.   unsigned int length = 256 * getch();
  462.   length += getch();
  463.   char memtype = getch();
  464.   // flash memory @here, (length) bytes
  465.   if (memtype == 'F') {
  466.     write_flash(length);
  467.     return;
  468.   }
  469.   if (memtype == 'E') {
  470.     result = (char)write_eeprom(length);
  471.     if (CRC_EOP == getch()) {
  472.       SERIAL.print((char) STK_INSYNC);
  473.       SERIAL.print(result);
  474.     } else {
  475.       error++;
  476.       SERIAL.print((char) STK_NOSYNC);
  477.     }
  478.     return;
  479.   }
  480.   SERIAL.print((char)STK_FAILED);
  481.   return;
  482. }
  483. uint8_t flash_read(uint8_t hilo, unsigned int addr) {
  484.   return spi_transaction(0x20 + hilo * 8,
  485.                          (addr >> 8) & 0xFF,
  486.                          addr & 0xFF,
  487.                          0);
  488. }
  489. char flash_read_page(int length) {
  490.   for (int x = 0; x < length; x += 2) {
  491.     uint8_t low = flash_read(LOW, here);
  492.     SERIAL.print((char) low);
  493.     uint8_t high = flash_read(HIGH, here);
  494.     SERIAL.print((char) high);
  495.     here++;
  496.   }
  497.   return STK_OK;
  498. }
  499. char eeprom_read_page(int length) {
  500.   // here again we have a word address
  501.   int start = here * 2;
  502.   for (int x = 0; x < length; x++) {
  503.     int addr = start + x;
  504.     uint8_t ee = spi_transaction(0xA0, (addr >> 8) & 0xFF, addr & 0xFF, 0xFF);
  505.     SERIAL.print((char) ee);
  506.   }
  507.   return STK_OK;
  508. }
  509. void read_page() {
  510.   char result = (char)STK_FAILED;
  511.   int length = 256 * getch();
  512.   length += getch();
  513.   char memtype = getch();
  514.   if (CRC_EOP != getch()) {
  515.     error++;
  516.     SERIAL.print((char) STK_NOSYNC);
  517.     return;
  518.   }
  519.   SERIAL.print((char) STK_INSYNC);
  520.   if (memtype == 'F') result = flash_read_page(length);
  521.   if (memtype == 'E') result = eeprom_read_page(length);
  522.   SERIAL.print(result);
  523. }
  524. void read_signature() {
  525.   if (CRC_EOP != getch()) {
  526.     error++;
  527.     SERIAL.print((char) STK_NOSYNC);
  528.     return;
  529.   }
  530.   SERIAL.print((char) STK_INSYNC);
  531.   uint8_t high = spi_transaction(0x30, 0x00, 0x00, 0x00);
  532.   SERIAL.print((char) high);
  533.   uint8_t middle = spi_transaction(0x30, 0x00, 0x01, 0x00);
  534.   SERIAL.print((char) middle);
  535.   uint8_t low = spi_transaction(0x30, 0x00, 0x02, 0x00);
  536.   SERIAL.print((char) low);
  537.   SERIAL.print((char) STK_OK);
  538. }
  539. //////////////////////////////////////////
  540. //////////////////////////////////////////
  541. ////////////////////////////////////
  542. ////////////////////////////////////
  543. void avrisp() {
  544.   uint8_t ch = getch();
  545.   switch (ch) {
  546.     case '0': // signon
  547.       error = 0;
  548.       empty_reply();
  549.       break;
  550.     case '1':
  551.       if (getch() == CRC_EOP) {
  552.         SERIAL.print((char) STK_INSYNC);
  553.         SERIAL.print("AVR ISP");
  554.         SERIAL.print((char) STK_OK);
  555.       }
  556.       else {
  557.         error++;
  558.         SERIAL.print((char) STK_NOSYNC);
  559.       }
  560.       break;
  561.     case 'A':
  562.       get_version(getch());
  563.       break;
  564.     case 'B':
  565.       fill(20);
  566.       set_parameters();
  567.       empty_reply();
  568.       break;
  569.     case 'E': // extended parameters - ignore for now
  570.       fill(5);
  571.       empty_reply();
  572.       break;
  573.     case 'P':
  574.       if (!pmode)
  575.         start_pmode();
  576.       empty_reply();
  577.       break;
  578.     case 'U': // set address (word)
  579.       here = getch();
  580.       here += 256 * getch();
  581.       empty_reply();
  582.       break;
  583.     case 0x60: //STK_PROG_FLASH
  584.       getch(); // low addr
  585.       getch(); // high addr
  586.       empty_reply();
  587.       break;
  588.     case 0x61: //STK_PROG_DATA
  589.       getch(); // data
  590.       empty_reply();
  591.       break;
  592.     case 0x64: //STK_PROG_PAGE
  593.       program_page();
  594.       break;
  595.     case 0x74: //STK_READ_PAGE 't'
  596.       read_page();
  597.       break;
  598.     case 'V': //0x56
  599.       universal();
  600.       break;
  601.     case 'Q': //0x51
  602.       error = 0;
  603.       end_pmode();
  604.       empty_reply();
  605.       break;
  606.     case 0x75: //STK_READ_SIGN 'u'
  607.       read_signature();
  608.       break;
  609.     // expecting a command, not CRC_EOP
  610.     // this is how we can get back in sync
  611.     case CRC_EOP:
  612.       error++;
  613.       SERIAL.print((char) STK_NOSYNC);
  614.       break;
  615.     // anything else we will return STK_UNKNOWN
  616.     default:
  617.       error++;
  618.       if (CRC_EOP == getch())
  619.         SERIAL.print((char)STK_UNKNOWN);
  620.       else
  621.         SERIAL.print((char)STK_NOSYNC);
  622.   }
  623. }
ArduinoISP.rar (5.37 KB, 下載次數(shù): 9)
