查看: 2889|回復(fù): 1
幫我看看12864怎么實(shí)現(xiàn)向上滾動(dòng),菜鳥一只
  1. #include<reg51.h>
  2. #include<intrins.h>
  4. #define uint unsigned int
  5. //下面是"歡迎訪問伊人憔悴百度空間"點(diǎn)陣數(shù)據(jù),一個(gè)漢字有32字節(jié)數(shù)據(jù)組成
  6. unsigned char code he[]= // 賀
  7. {
  8. 0x80,0x44,0x34,0x8F,0xA4,0xC4,0xBC,0x80,0x80,0xBC,0xA4,0xA4,0x24,0x3C,0x00,0x00,
  9. 0x00,0x80,0x80,0x5F,0x40,0x20,0x10,0x0E,0x20,0x20,0x40,0x5F,0x80,0x00,0x00,0x00,
  10. };
  11. unsigned char code zhou[]= //州
  12. {
  13. 0x00,0xE0,0x00,0xFF,0x00,0x20,0xC0,0x00,0xFE,0x00,0x20,0xC0,0x00,0xFF,0x00,0x00,
  14. 0x81,0x40,0x30,0x0F,0x00,0x00,0x00,0x00,0x3F,0x00,0x00,0x00,0x00,0xFF,0x00,0x00,
  15. };
  16. unsigned char code xue[]= //學(xué)
  17. {
  18. 0x40,0x30,0x11,0x96,0x90,0x90,0x91,0x96,0x90,0x90,0x98,0x14,0x13,0x50,0x30,0x00,
  19. 0x04,0x04,0x04,0x04,0x04,0x44,0x84,0x7E,0x06,0x05,0x04,0x04,0x04,0x04,0x04,0x00,
  20. };
  21. unsigned char code yuan[]=  //院
  22. {
  23. 0x00,0xFE,0x22,0x5A,0x86,0x10,0x0C,0x24,0x24,0x25,0x26,0x24,0x24,0x14,0x0C,0x00,
  24. 0x00,0xFF,0x04,0x08,0x07,0x80,0x41,0x31,0x0F,0x01,0x01,0x3F,0x41,0x41,0x71,0x00,
  25. };
  26. unsigned char code huan[]=  //歡
  27. {
  28. 0x04,0x24,0x44,0x84,0x64,0x9C,0x40,0x30,0x0F,0xC8,0x08,0x08,0x28,0x18,0x00,0x00,
  29. 0x10,0x08,0x06,0x01,0x82,0x4C,0x20,0x18,0x06,0x01,0x06,0x18,0x20,0x40,0x80,0x00,
  30. };
  31. unsigned char code ying[]= //迎
  32. {
  33. 0x40,0x40,0x42,0xCC,0x00,0x00,0xFC,0x04,0x02,0x00,0xFC,0x04,0x04,0xFC,0x00,0x00,
  34. 0x00,0x40,0x20,0x1F,0x20,0x40,0x4F,0x44,0x42,0x40,0x7F,0x42,0x44,0x43,0x40,0x00,
  35. };
  36. unsigned char code nin[]= //您
  37. {
  38. 0x20,0x10,0x08,0xFC,0x23,0x10,0x88,0x67,0x04,0xF4,0x04,0x24,0x54,0x8C,0x00,0x00,
  39. 0x40,0x30,0x00,0x77,0x80,0x81,0x88,0xB2,0x84,0x83,0x80,0xE0,0x00,0x11,0x60,0x00,
  40. };
  41. unsigned char code m[]= //!
  42. {
  43. 0x00,0x00,0x00,0xFE,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  44. 0x00,0x00,0x00,0x33,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  45. } ;
  46. unsigned char code wo[]=
  47. {
  48. 0x20,0x24,0x24,0x24,0xFE,0x23,0x22,0x20,0x20,0xFF,0x20,0x22,0x2C,0xA0,0x20,0x00,
  49. 0x00,0x08,0x48,0x84,0x7F,0x02,0x41,0x40,0x20,0x13,0x0C,0x14,0x22,0x41,0xF8,0x00,
  50. };
  51. unsigned char code ai[]=
  52. {
  53. 0x80,0x64,0x2C,0x34,0x24,0x24,0xEC,0x32,0x22,0x22,0x32,0x2E,0x23,0xA2,0x60,0x00,
  54. 0x00,0x41,0x21,0x91,0x89,0x87,0x4D,0x55,0x25,0x25,0x55,0x4D,0x81,0x80,0x80,0x00,
  55. };
  56. sbit CS1=P2^0;//片選1,低電平有效,CS1=0開左屏幕,CS1=1關(guān)左屏幕
  57. sbit CS2=P2^1;//片選2,低電平有效,CS2=0開右屏幕,CS2=1關(guān)右屏幕
  58. sbit RS=P2^2;//數(shù)據(jù),指令選擇信號(hào),RS=1為數(shù)據(jù)操作,RS=0為寫指令或讀狀態(tài)(一般為讀忙標(biāo)志)
  59. sbit RW=P2^3;//讀寫選擇信號(hào),RW=1為讀選通,RW=0為寫選通
  60. sbit EN=P2^4;//讀寫使能信號(hào)
  61. void busy()//忙檢測(cè)函數(shù)
  62. {P0=0X00; //這句不能少
  63. RS=0;
  64. RW=1;
  65. EN=1;
  66. while(P0&0X80);//P0&0X80結(jié)果為真則一直執(zhí)行空操作,也就是說P0&0X80為0則結(jié)束循環(huán)
  67. EN=0;
  68. }
  69. void wcmd(uchar cmd)
  70. {busy(); //每次寫入指令或數(shù)據(jù)之前都進(jìn)行忙檢測(cè)
  71. RS=0;
  72. RW=0;
  73. P0=cmd;
  74. EN=1;_nop_();_nop_();//在EN下降沿寫入數(shù)據(jù)和指令
  75. EN=0;
  76. }
  77. void wdata(uchar dat) //寫命令和寫數(shù)據(jù)只在RS=0或RS=1上不同,其余都相同
  78. {busy();
  79. RS=1;
  80. RW=0;
  81. P0=dat;
  82. EN=1;_nop_();_nop_();//在EN下降沿寫入數(shù)據(jù)和指令
  83. EN=0;
  84. }
  85. void set_page(uchar page)//設(shè)置頁(yè),12864LCD共有8頁(yè),每頁(yè)有8行點(diǎn)陣點(diǎn)。
  86. {page=0xb8|page;  //首頁(yè)地址為0XB8
  87. wcmd(page);                  //page取值范圍為0~7,表示第1到8頁(yè)
  88. }
  89. void set_line(uchar line)//設(shè)置顯示的起始行,共有0--63行,一般從0行開始顯示
  90. {line=0xc0|line;  //起始行地址0XC0
  91. wcmd(line);        //line取值范圍為0~63,表示第1到64行
  92. }
  93. void set_column(uchar column)//設(shè)置顯示的列
  94. {//column=column&0x3f; //列的最大值為0X3F,即64
  95. column=0x40|column;         //列的首地址為0X40,
  96. wcmd(column);                 //column的取值范圍為0~63,共64列
  97. }
  98. void set_onoff(uchar onoff)//設(shè)置顯示開關(guān),onoff取值為0或1
  99. {onoff|=0x3e;//0X3E是關(guān)顯示,0X3F是開顯示
  100. wcmd(onoff);//所以若onoff為0,則表示關(guān)顯示,onoff為1,則表示開顯示
  101. }
  102. void select_screen(uchar screen)//選屏,screen取值范圍為0,1,2
  103. {switch(screen)
  104. {case 0:CS1=0;CS2=0;break; //全屏
  105. case 1:CS1=0;CS2=1;break;  //左半屏
  106. case 2:CS1=1;CS2=0;break;  //右半屏
  107. default:break;
  108. }
  109. }
  110. void clear_screen(uchar screen)//清屏
  111. {uchar i,j;
  112. select_screen(screen);//先選屏
  113. for(i=0;i<8;i++)//控制頁(yè)數(shù)0--7,共8頁(yè)
  114. {set_page(i);//設(shè)置頁(yè)
  115. set_column(0); //設(shè)置列,每頁(yè)都從第1列開始,共64列
  116. for(j=0;j<64;j++)//控制列數(shù)0--63,共64列
  117. wdata(0x00);//寫入0,列地址指針會(huì)自動(dòng)加1
  118. }
  119. }
  120. void init()        //LCD初始化
  121. {busy(); //忙檢測(cè)
  122. select_screen(0);//選屏,全屏
  123. set_onoff(0);        //關(guān)顯示
  124. select_screen(0); //選屏,全屏
  125. set_onoff(1);          //開顯示
  126. select_screen(0); //選屏,全屏
  127. clear_screen(0);  //清屏
  128. set_line(0);          //起始行:0
  129. }
  130. void show(uchar screen,uchar page,uchar column,uchar *p)//顯示一個(gè)漢字,一個(gè)漢字有32字節(jié)數(shù)據(jù)
  131. {uchar i;        //screen表示選擇屏幕,page表示頁(yè),column表示列,*p表示漢字的數(shù)組
  132. select_screen(screen); //選屏
  133. set_page(page);           //設(shè)置頁(yè),寫上半頁(yè)
  134. set_column(column);//設(shè)置列
  135. for(i=0;i<16;i++) //控制16列的數(shù)據(jù)輸出
  136. wdata(p[i]);   //漢字的上半部分
  137. set_page(page+1); //寫下半頁(yè)
  138. set_column(column);        //控制列
  139. for(i=0;i<16;i++) //控制16列的數(shù)據(jù)輸出
  140. wdata(p[i+16]);         //漢字的下半部分
  141. }
  142. void main()
  143. {
  144. {init();  //LCD初始化
  145. clear_screen(0); //清屏
  146. set_line(0);   //顯示開始行
  147. //1表示左屏顯示,0表示從0頁(yè)開始顯示。因?yàn)橐豁?yè)只有8行點(diǎn),
  148. //而顯示一個(gè)漢字需要16行點(diǎn)(整屏有64行點(diǎn)),所以顯示一個(gè)漢字需要2頁(yè)
  149. //第0頁(yè)顯示"歡"字的上半部分,第1頁(yè)顯示"歡"漢字的下半部分
  150. //2*16表示從第32列開始顯示,前面空出0~31列(即2個(gè)字的位置)
  151. show(1,2,2*16,he);//梧
  152. //1表示左屏顯示,0表示從0頁(yè)開始顯示
  153. //3*16表示從第48列開始顯示,前面空出0~47列(即3個(gè)漢字的位置)
  154. show(1,2,3*16,zhou);//州
  155. //2表示右屏顯示,0表示從0頁(yè)開始顯示
  156. //0*16表示從第0列開始顯示(即第一個(gè)漢字的位置)
  157. show(2,2,4*16,xue);//學(xué)
  158. //1*16表示從第16列開始顯示,前面空出0~15列(即一個(gè)漢字的位置)
  159. show(2,2,5*16,yuan);         //院
  160. //左屏開,從第3頁(yè)(共8頁(yè))第0列開始顯示,即第3,4頁(yè)顯示"伊人憔悴百度空間"幾個(gè)字
  161. show(1,4,2*16,huan);         //歡
  162. show(1,4,3*16,ying);         //迎
  163. show(2,4,4*16,nin); //您
  164. show(2,4,5*16,m); //!
  165. show(2,6,4*16,wo);
  166. show(2,8,4*16,ai);
  167. show(2,0,6*16,he);
  168. while(1);
  169. }
  170. }
ID:309039 發(fā)表于 2018-4-30 20:44 | 只看該作者
你好 在借鑒你的程序過程中 我無(wú)法選擇屏幕 即cs1 cs2始終為低電平是怎么回事呢
