查看: 1320|回復(fù): 0
1602接收信息滾動(dòng)顯示
ID:295783 發(fā)表于 2018-4-28 14:25 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
我這邊 寫了一個(gè)程序 是1602液晶顯示屏通過(guò)24l01無(wú)線模塊接收消息 并滾動(dòng)顯示在1602屏幕上
但是 我寫完驗(yàn)證時(shí)不是滾動(dòng)顯示 是閃爍顯示
各位大聲能幫我看看是什么原因嗎?
看看哪里出錯(cuò)了。。。
具體程序如下:
#include <reg51.h>
#include <string.h>
#include<intrins.h>
#define uint  unsigned int
#define ulong unsigned long
#define TX_ADR_WIDTH   5  // 5字節(jié)寬度的發(fā)送/接收地址
#define TX_PLOAD_WIDTH 4  // 數(shù)據(jù)通道有效數(shù)據(jù)寬度
sbit RS = P3^5;   //定義端口
sbit RW = P3^6;
sbit EN = P3^4;
#define RS_CLR RS=0
#define RS_SET RS=1
#define RW_CLR RW=0
#define RW_SET RW=1
#define EN_CLR EN=0
#define EN_SET EN=1
#define DataPort P0
sbit LED = P2^1;
uchar code TX_ADDRESS[TX_ADR_WIDTH] = {0x34,0x43,0x10,0x10,0x01};  // 定義一個(gè)靜態(tài)發(fā)送地址
uchar RX_BUF[TX_PLOAD_WIDTH];
uchar TX_BUF[TX_PLOAD_WIDTH];
uchar flag;
uchar DATA = 0x01;
uchar bdata sta;
sbit  RX_DR     = sta^6;
sbit  TX_DS     = sta^5;
sbit  MAX_RT = sta^4;
sbit CE =  P1^0;
sbit CSN=  P1^1;
sbit SCK=  P1^2;
sbit MOSI= P1^3;
sbit MISO= P1^4;
sbit IRQ = P1^5;
// SPI(nRF24L01) commands
#define READ_REG    0x00  // Define read command to register
#define WRITE_REG   0x20  // Define write command to register
#define RD_RX_PLOAD 0x61  // Define RX payload register address
#define WR_TX_PLOAD 0xA0  // Define TX payload register address
#define FLUSH_TX    0xE1  // Define flush TX register command
#define FLUSH_RX    0xE2  // Define flush RX register command
#define REUSE_TX_PL 0xE3  // Define reuse TX payload register command
#define NOP         0xFF  // Define No Operation, might be used to read status register
// SPI(nRF24L01) registers(addresses)
#define CONFIG      0x00  // 'Config' register address
#define EN_AA       0x01  // 'Enable Auto Acknowledgment' register address
#define EN_RXADDR   0x02  // 'Enabled RX addresses' register address
#define SETUP_AW    0x03  // 'Setup address width' register address
#define SETUP_RETR  0x04  // 'Setup Auto. Retrans' register address
#define RF_CH       0x05  // 'RF channel' register address
#define RF_SETUP    0x06  // 'RF setup' register address
#define STATUS      0x07  // 'Status' register address
#define OBSERVE_TX  0x08  // 'Observe TX' register address
#define CD          0x09  // 'Carrier Detect' register address
#define RX_ADDR_P0  0x0A  // 'RX address pipe0' register address
#define RX_ADDR_P1  0x0B  // 'RX address pipe1' register address
#define RX_ADDR_P2  0x0C  // 'RX address pipe2' register address
#define RX_ADDR_P3  0x0D  // 'RX address pipe3' register address
#define RX_ADDR_P4  0x0E  // 'RX address pipe4' register address
#define RX_ADDR_P5  0x0F  // 'RX address pipe5' register address
#define TX_ADDR     0x10  // 'TX address' register address
#define RX_PW_P0    0x11  // 'RX payload width, pipe0' register address
#define RX_PW_P1    0x12  // 'RX payload width, pipe1' register address
#define RX_PW_P2    0x13  // 'RX payload width, pipe2' register address
#define RX_PW_P3    0x14  // 'RX payload width, pipe3' register address
#define RX_PW_P4    0x15  // 'RX payload width, pipe4' register address
#define RX_PW_P5    0x16  // 'RX payload width, pipe5' register address
#define FIFO_STATUS 0x17  // 'FIFO Status Register' register address
//--定義SPI要使用的 IO--//
void blink(char i);
//--全局函數(shù)聲明--//
函數(shù): init_io()
描述:
    初始化IO
void init_io(void)
    CE  = 0;        // 待機(jī)
    CSN = 1;        // SPI禁止
    SCK = 0;        // SPI時(shí)鐘置低
    IRQ = 1;        // 中斷復(fù)位
    LED = 1;        // 關(guān)閉指示燈
函數(shù):delay_ms()
描述:
    延遲x毫秒
void delay_ms(uchar x)
    uchar i, j;
    i = 0;
    for(i=0; i<x; i++)
       j = 250;
       while(--j);
       j = 250;
       while(--j);
函數(shù):SPI_RW()
描述:
    根據(jù)SPI協(xié)議,寫一字節(jié)數(shù)據(jù)到nRF24L01,同時(shí)從nRF24L01
    讀出一字節(jié)
uchar SPI_RW(uchar byte)
    uchar i;
       for(i=0; i<8; i++)          // 循環(huán)8次
           MOSI = (byte & 0x80);   // byte最高位輸出到MOSI
           byte <<= 1;             // 低一位移位到最高位
           SCK = 1;                // 拉高SCK,nRF24L01從MOSI讀入1位數(shù)據(jù),同時(shí)從MISO輸出1位數(shù)據(jù)
           byte |= MISO;           // 讀MISO到byte最低位
           SCK = 0;                // SCK置低
    return(byte);               // 返回讀出的一字節(jié)
函數(shù):SPI_RW_Reg()
描述:
    寫數(shù)據(jù)value到reg寄存器
uchar SPI_RW_Reg(uchar reg, uchar value)
    uchar status;
      CSN = 0;                   // CSN置低,開始傳輸數(shù)據(jù)
      status = SPI_RW(reg);      // 選擇寄存器,同時(shí)返回狀態(tài)字
      SPI_RW(value);             // 然后寫數(shù)據(jù)到該寄存器
      CSN = 1;                   // CSN拉高,結(jié)束數(shù)據(jù)傳輸
      return(status);            // 返回狀態(tài)寄存器
函數(shù):SPI_Read()
描述:
    從reg寄存器讀一字節(jié)
uchar SPI_Read(uchar reg)
    uchar reg_val;
      //blink(4);
      reg_val = SPI_RW(0);        // 然后從該寄存器讀數(shù)據(jù)
    //delay_ms(200);
      return(reg_val);            // 返回寄存器數(shù)據(jù)
函數(shù):SPI_Read_Buf()
描述:
    從reg寄存器讀出bytes個(gè)字節(jié),通常用來(lái)讀取接收通道
    數(shù)據(jù)或接收/發(fā)送地址
uchar SPI_Read_Buf(uchar reg, uchar * pBuf, uchar bytes)
    uchar status, i;
      for(i=0; i<bytes; i++)
        pBuf[i] = SPI_RW(0);    // 逐個(gè)字節(jié)從nRF24L01讀出
函數(shù):SPI_Write_Buf()
描述:
    把pBuf緩存中的數(shù)據(jù)寫入到nRF24L01,通常用來(lái)寫入發(fā)
    射通道數(shù)據(jù)或接收/發(fā)送地址
uchar SPI_Write_Buf(uchar reg, uchar * pBuf, uchar bytes)
    uchar status, i;
        SPI_RW(pBuf[i]);        // 逐個(gè)字節(jié)寫入nRF24L01
函數(shù):RX_Mode()
描述:
    這個(gè)函數(shù)設(shè)置nRF24L01為接收模式,等待接收發(fā)送設(shè)備的數(shù)據(jù)包
void RX_Mode(void)
    CE = 0;
      SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, TX_ADDRESS, TX_ADR_WIDTH);  // 接收設(shè)備接收通道0使用和發(fā)送設(shè)備相同的發(fā)送地址
      SPI_RW_Reg(WRITE_REG + EN_AA, 0x01);               // 使能接收通道0自動(dòng)應(yīng)答
      SPI_RW_Reg(WRITE_REG + EN_RXADDR, 0x01);           // 使能接收通道0
      SPI_RW_Reg(WRITE_REG + RF_CH, 40);                 // 選擇射頻通道0x40
      SPI_RW_Reg(WRITE_REG + RX_PW_P0, TX_PLOAD_WIDTH);  // 接收通道0選擇和發(fā)送通道相同有效數(shù)據(jù)寬度
      SPI_RW_Reg(WRITE_REG + RF_SETUP, 0x07);            // 數(shù)據(jù)傳輸率1Mbps,發(fā)射功率0dBm,低噪聲放大器增益
      SPI_RW_Reg(WRITE_REG + CONFIG, 0x0f);              // CRC使能,16位CRC校驗(yàn),上電,接收模式
    delay_ms(150);
      CE = 1;                                            // 拉高CE啟動(dòng)接收設(shè)備
函數(shù):TX_Mode()
描述:
    這個(gè)函數(shù)設(shè)置nRF24L01為發(fā)送模式,(CE=1持續(xù)至少10us),
    130us后啟動(dòng)發(fā)射,數(shù)據(jù)發(fā)送結(jié)束后,發(fā)送模塊自動(dòng)轉(zhuǎn)入接收
    模式等待應(yīng)答信號(hào)。
void TX_Mode(uchar * BUF)
    CE = 0;
      SPI_Write_Buf(WRITE_REG + TX_ADDR, TX_ADDRESS, TX_ADR_WIDTH);     // 寫入發(fā)送地址
      SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, TX_ADDRESS, TX_ADR_WIDTH);  // 為了應(yīng)答接收設(shè)備,接收通道0地址和發(fā)送地址相同
      SPI_Write_Buf(WR_TX_PLOAD, BUF, TX_PLOAD_WIDTH);                  // 寫數(shù)據(jù)包到TX FIFO
      SPI_RW_Reg(WRITE_REG + SETUP_RETR, 0x0a);  // 自動(dòng)重發(fā)延時(shí)等待250us+86us,自動(dòng)重發(fā)10次
      SPI_RW_Reg(WRITE_REG + CONFIG, 0x0e);      // CRC使能,16位CRC校驗(yàn),上電
    delay_ms(150);
    CE = 1;
函數(shù):Check_ACK()
描述:
    檢查接收設(shè)備有無(wú)接收到數(shù)據(jù)包,設(shè)定沒(méi)有收到應(yīng)答信
    號(hào)是否重發(fā)
uchar Check_ACK(bit clear)
    while(IRQ);
    sta = SPI_RW(NOP);                    // 返回狀態(tài)寄存器
    if(TX_DS)
        //blink(3);
    //blink(5);
    if(MAX_RT)
        if(clear)                         // 是否清除TX FIFO,沒(méi)有清除在復(fù)位MAX_RT中斷標(biāo)志后重發(fā)
            SPI_RW(FLUSH_TX);
    SPI_RW_Reg(WRITE_REG + STATUS, sta);  // 清除TX_DS或MAX_RT中斷標(biāo)志
    IRQ = 1;
    if(TX_DS)
        return(0x00);
        return(0xff);
函數(shù):CheckButtons()
描述:
    檢查按鍵是否按下,按下則發(fā)送一字節(jié)數(shù)據(jù)
void CheckButtons()
    P3 |= 0x00;
    if(!(P3 & 0x01))                    // 讀取P3^0狀態(tài)
        delay_ms(20);
            TX_BUF[0] = ~DATA;          // 數(shù)據(jù)送到緩存
            //TX_BUF[0] = 0xff;          // 數(shù)據(jù)送到緩存
            TX_Mode(TX_BUF);            // 把nRF24L01設(shè)置為發(fā)送模式并發(fā)送數(shù)據(jù)
            //LED = ~DATA;                // 數(shù)據(jù)送到LED顯示
            Check_ACK(0);               // 等待發(fā)送完畢,清除TX FIFO
            delay_ms(250);
            delay_ms(250);
            LED = 1;                    // 關(guān)閉LED
            RX_Mode();                    // 設(shè)置為接收模式
            while(!(P3 & 0x01));
            DATA <<= 1;
            if(!DATA)
                DATA = 0x01;
void blink(char i)
    while(i--)
        LED = 1;
        delay_ms(500);
        LED = 0;
        delay_ms(500);
uS延時(shí)函數(shù),含有輸入?yún)?shù) unsigned char t,無(wú)返回值
unsigned char 是定義無(wú)符號(hào)字符變量,其值的范圍是
0~255 這里使用晶振12M,精確延時(shí)請(qǐng)使用匯編,大致延時(shí)
長(zhǎng)度如下 T=tx2+5 uS
void DelayUs2x(unsigned char t)
while(--t);
mS延時(shí)函數(shù),含有輸入?yún)?shù) unsigned char t,無(wú)返回值
void DelayMs(unsigned char t)
while(t--)
     //大致延時(shí)1mS
     DelayUs2x(245);
  DelayUs2x(245);
              判忙函數(shù)
bit LCD_Check_Busy(void)
DataPort= 0xFF;
RS_CLR;
RW_SET;
EN_CLR;
_nop_();
EN_SET;
return (bit)(DataPort & 0x80);
              寫入命令函數(shù)
void LCD_Write_Com(unsigned char com)
while(LCD_Check_Busy()); //忙則等待
RS_CLR;
RW_CLR;
EN_SET;
DataPort= com;
_nop_();
EN_CLR;
              寫入數(shù)據(jù)函數(shù)
void LCD_Write_Data(unsigned char Data)
RS_SET;
RW_CLR;
EN_SET;
DataPort= Data;
_nop_();
EN_CLR;
                清屏函數(shù)
void LCD_Clear(void)
LCD_Write_Com(0x01);
DelayMs(5);
              寫入字符串函數(shù)
void LCD_Write_String(unsigned char x,unsigned char y,unsigned char *s)
if (y == 0)
  LCD_Write_Com(0x80 + x);     //表示第一行
  LCD_Write_Com(0xC0 + x);      //表示第二行
while (*s)
LCD_Write_Data( *s);
s ++;
              寫入字符函數(shù)
void LCD_Write_Char(unsigned char x,unsigned char y,unsigned char Data)
if (y == 0)
LCD_Write_Data( Data);
              初始化函數(shù)
void LCD_Init(void)
   LCD_Write_Com(0x38);    /*顯示模式設(shè)置*/
   DelayMs(5);
   DelayMs(5);
   DelayMs(5);
   LCD_Write_Com(0x08);    /*顯示關(guān)閉*/
   LCD_Write_Com(0x01);    /*顯示清屏*/
   LCD_Write_Com(0x06);    /*顯示光標(biāo)移動(dòng)設(shè)置*/
   DelayMs(5);
   LCD_Write_Com(0x0C);    /*顯示開及光標(biāo)設(shè)置*/
函數(shù):main()
描述:
    主函數(shù)
void main(void)
    init_io();                      // 初始化IO
   LCD_Init();
     LCD_Clear();//清屏
//   LCD_Write_String(1,1,"A");
        sta = SPI_Read(STATUS);      // 讀狀態(tài)寄存器
        //delay_ms(200);
        if(RX_DR)                  // 判斷是否接受到數(shù)據(jù)
            SPI_Read_Buf(RD_RX_PLOAD, RX_BUF, TX_PLOAD_WIDTH);  // 從RX FIFO讀出數(shù)據(jù)
            flag = 1;
        SPI_RW_Reg(WRITE_REG + STATUS, sta);  // 清除RX_DS中斷標(biāo)志
        if(flag)                   // 接受完成
            if(RX_BUF[0] == 1)
      LCD_Write_Char(2,0,'A');
     LCD_Write_Char(3,0,'4');
     LCD_Write_Char(4,0,'1');
     LCD_Write_Com(0x18);//左平移畫面 0x1C 是右平移 ,0x18是左移。
                blink(2);
            if(RX_BUF[0] == 2)
        LCD_Write_Char(6,0,'A');
        LCD_Write_Char(7,0,'4');
     LCD_Write_Char(8,0,'2');
                blink(4);
        if(RX_BUF[0] == 3)
        LCD_Write_Char(2,1,'A');
        LCD_Write_Char(3,1,'4');
     LCD_Write_Char(4,1,'3');
                blink(4);
   flag = 0;               // 清標(biāo)志
            delay_ms(250);
            delay_ms(250);
          LED = 1;
         LCD_Init();
   DelayMs(200);
