此程序思路是,前提知道這三位數(shù)為X.XX,而且不能連續(xù)發(fā)送,寫的不好還請大神指教
- /*********************該程序可實現(xiàn)燈的亮滅**可以實現(xiàn)串口通信以及電腦控制單片機(jī)*********************************/
- /*該程序?qū)懙谋容^好*//*通過兩個不同的標(biāo)志位實現(xiàn),非常棒*/
- //只能發(fā)送一次,不能連續(xù)發(fā)送
- #include <STC15f2k60s2.h>
- #define u16 unsigned int
- #define u8 unsigned char
- u16 pwm_value;
- unsigned char UART_buff;//串口的接收和發(fā)送(只能是單個字符的使用)
- unsigned char receive[50];//用于接收所發(fā)出來的字符串
- unsigned char i;
- int xianshi;
- double shuju;
- bit New_rec = 0, Send_ed = 1, Money = 0; //定義的一些標(biāo)記位
- unsigned char code DSY_CODE[]=
- 0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90
- };//這是時鐘所用到的數(shù)
- /*******用于一毫秒的延時****************/
- void delayms(unsigned int xms)
- unsigned int i,j;
- for(i=xms;i>0;i--)
- for(j=110;j>0;j--);
- /*數(shù)碼管顯示程序2*/
- void display1(int h)
- P2=0xfe;
- P0=DSY_CODE[h/100];
- delayms(1);
- P2=0xff;
- P0=0xff;
- P2=0xfd;
- P0=DSY_CODE[h%100/10];
- delayms(1);
- P2=0xff;
- P0=0xff;
- P2=0xfb;
- P0=DSY_CODE[h%100%10];
- delayms(1);
- P2=0xff;
- P0=0xff;
- // 函數(shù): UpdatePwm(u8 PCA_id, u16 pwm_value)
- // 描述: 更新PWM值.
- // 參數(shù): PCA_id: PCA序號. 取值 PCA0,PCA1,PCA2,PCA_Counter
- // pwm_value: pwm值, 這個值是輸出高電平的時間.
- // 返回: none.
- // 版本: V1.0, 2012-11-22
- void UpdatePwm(u16 uart_date)
- pwm_value=uart_date/2;
- if(pwm_value == 0)
- CCAP0H =0xff;
- else
- CCAP0H = (u8)(256 - pwm_value);
- void main (void)
- AUXR |= 0x40; //設(shè)置1T
- AUXR &= 0xfe; //設(shè)置定時器1為串口1波特率發(fā)生器
- PCON &= 0x7f; //不加倍
- TMOD = 0x20; //定時器1工作方式2
- TH1 = 0xdc;
- TL1 = 0xdc;
- SM0 = 0;
- SM1 = 1;
- REN = 1;
- TR1 = 1;
- ES = 1;
- EA = 1;
- while(1)
- while(i>=2) //串口發(fā)送數(shù)字的位數(shù)如2.00
- shuju=(double)(receive[0])+(double)(receive[1])/10+(double)(receive[2])/100; //把輸入的每一個數(shù)轉(zhuǎn)化為輸入的數(shù)
- xianshi=shuju*100; //乘100為數(shù)碼管顯示方便
- display1(xianshi);
- // PCA0初始化
- AUXR1 &= ~0x30;
- AUXR1 |= 0x10; //切換IO口, 0x00: P1.2 P1.1 P1.0 P3.7, 0x10: P3.4 P3.5 P3.6 P3.7, 0x20: P2.4 P2.5 P2.6 P2.7
- CCAPM0 = 0x42; //工作模式 PWM
- PCA_PWM0 = (PCA_PWM0 & ~0xc0) | 0x00; //PWM寬度, 0x00: 8bit, 0x40: 7bit, 0x80: 6bit
- CMOD = (CMOD & ~0xe0) | 0x08; //選擇時鐘源, 0x00: 12T, 0x02: 2T, 0x04: Timer0溢出, 0x06: ECI, 0x08: 1T, 0x0A: 4T, 0x0C: 6T, 0x0E: 8T
- CR = 1;
- UpdatePwm(xianshi);
- if ((New_rec == 1) && (Send_ed == 1))
- { //如果收到新數(shù)據(jù)及發(fā)送完畢
- New_rec = 0;
- Send_ed = 0;
- void ser_int (void) interrupt 4
- if(RI == 1)
- { //如果收到.
- RI = 0; //清除標(biāo)志.
- New_rec = 1;//表明收到了信息了
- if((SBUF >= '0') && (SBUF <= '9'))
- receive[i]=SBUF-'0';//將字符串按字節(jié)放入到數(shù)組當(dāng)中,起到一定的緩存作用
- i++;
- UART_buff = SBUF; //接收.只支持字符,不支持字符串
- SBUF=UART_buff;//這個用于電腦串口的接收,也就是發(fā)送
- TI = 0; //清除標(biāo)志.
- Send_ed = 1;
- else { //如果送畢.
15電腦串口控制單片機(jī)電壓精美版.zip
(32.79 KB, 下載次數(shù): 24)
2018-4-29 08:41 上傳
點擊文件名下載附件
下載積分: 黑幣 -5
