查看: 5142|回復: 1
AVR內部AD模塊的求助!各位大蝦們幫個忙吧……
ID:30377 發(fā)表于 2011-8-15 19:08 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
 各位大俠們,我想用ATmega128的內部AD的,我選用的編譯器是IAR AVR,程序如下:
#include <ioavr.h>
#include <intrinsics.h>
#define  unchar unsigned char
#define  unint  unsigned int
unchar vol;
#define    REFS1    7
#define    REFS0    6
#define    ADLAR    5
#define    MUX4     4
#define    MUX3     3
#define    MUX2     2
#define    MUX1     1
#define    MUX0     0
#define    ADEN     7
#define    ADSC     6
#define    ADFR     5
#define    ADIF     4
#define    ADIE     3
#define    ADPS2    2
#define    ADPS1    1
#define    ADPS0    0
#define rs_L()  (PORTD &= ~(1<<7))
#define rs_H()  (PORTD |= (1<<7))
#define rw_L()  (PORTD &= ~(1<<6))
#define rw_H()  (PORTD |= (1<<6))
#define en_L()  (PORTD &= ~(1<<5))
#define en_H()  (PORTD |= (1<<5))
void delay_ms(unint x)  //12M 1ms延時程序
  unint y;
  for(;x>0;x--)
    for(y=0;y<120;y++);
void w_com(unchar com)
  unint i;
 PORTC=com;
 rs_L();
 rw_L();
 en_L();
 i=10;
 while(i--);
 en_H();
 i=10;
 while(i--);
void w_data(unchar dataa)
  unint i;
 PORTC=dataa;
 rs_H();
 rw_L();
 en_L();
 i=10;
 while(i--);
 en_H();
 i=10;
 while(i--);
void L1602_init()
 w_com(0x01);
 w_com(0x38);
 w_com(0x0c);
 w_com(0x06);
 w_com(0xd0);
void L1602_char(unchar hang,unchar lie,char sign)
 unchar a;
 if(hang==1) a=0x80;
 if(hang==2) a=0xc0;
 a=a+lie-1;
 w_com(a);
 w_data(sign);
void L1602_string(unchar hang,unchar lie,unchar *p)
 unchar a;
 if(hang==1) a=0x80;
 if(hang==2) a=0xc0;
 a=a+lie-1;
 w_com(a);
  if(*p=='\0') break;
  w_data(*p);
  p++;
unchar BIT(unchar x)
  unchar temp;
  temp = (0x01<<x);
  return temp;
*函數(shù)功能:ADC模塊的初始化程序
*輸入?yún)?shù):無
*輸出參數(shù):無
*返 回 值:無
void init_adc()
  ADCSR=0X00;     //設置ADC前,禁止ADC
  ADMUX=BIT(REFS1)|BIT(REFS0);   //設置ADC內置參考電壓為2.56V的片內基準電源
  ADMUX|=BIT(ADLAR);     //ADC轉換結果左對齊,直接取ADCH的8位數(shù)據(jù)
  ADCSR=BIT(ADEN)|BIT(ADPS1)|BIT(ADPS0)|BIT(ADPS2);  //ADC使能,128分頻
unsigned char get_adcdata(void)
  unsigned char volt;
//  ADMUX=BIT(MUX0)|BIT(MUX1)|BIT(MUX2)|BIT(MUX3);           //選擇通道3,電池電壓通道
  ADMUX|=0;
  ADCSR|=BIT(ADSC);  //啟動單次ADC轉換
  while (!(ADCSR&BIT(ADIF)));  //等待轉換結束
  ADCSR&=~(BIT(ADIF));    //清楚ADIF位
  volt=ADCH;
  return volt;
void L1602_display1()
  L1602_char(1,9,vol/100%10+48);
  L1602_char(1,11,vol/10%10+48);
  L1602_char(1,12,vol%10+48);
  DDRC=0xff;
  PORTC=0xff;
  DDRD=0xff;
  PORTD=0xff;
  DDRF=0x00;
  PORTF=0x00;
  L1602_init();
  L1602_string(1,1,"   IN0: 0.00V   ");
  L1602_string(2,1,"   IN1: 0.00V   ");
  init_adc();
    vol = get_adcdata();
    vol=(vol/256)*500;
    L1602_display1();
    delay_ms(1000);
我用IAR模擬運行了一下,發(fā)現(xiàn)就是死在了 while (!(ADCSR&BIT(ADIF)));  這邊,這說明AD一直都在轉換,就是沒轉換好!這是為什么呢?勞煩各位大俠留步幫小弟解決下!有勞了各位了……
[此貼子已經被作者于2011-8-15 19:14:36編輯過]
ID:37273 發(fā)表于 2012-3-28 15:57 | 只看該作者
while (!(ADCSR&BIT(ADIF))); 這句話本身有問題吧。。。
Powered by 單片機教程網
