2018-5-4 11:13 上傳
- #include <reg52.h> //調(diào)用單片機頭文件
- #define uchar unsigned char //無符號字符型 宏定義 變量范圍0~255
- #define uint unsigned int //無符號整型 宏定義 變量范圍0~65535
- #include <intrins.
- //數(shù)碼管段選定義 0 1 2 3 4 5 6 7 8 9
- uchar code smg_du[]={0x14,0x77,0x4c,0x45,0x27,0x85,0x84,0x57,0x04,0x05,A B C
- D E F 不顯示
- 0x06,0xa4,0x9c,0x64,0x8c,0x8e,0xff}; //斷碼
- //數(shù)碼管位選定義
- sbit smg_we1 = P2^0; //數(shù)碼管位選定義
- sbit smg_we2 = P2^2;
- sbit smg_we3 = P2^4;
- sbit smg_we4 = P2^6;
- uchar dis_smg[8] = {0x14,0x77,0x4c,0x45,0x27,0x85,0x84};
- sbit SCL=P1^2; //SCL定義為P1口的第3位腳,連接ADC0832SCL腳
- sbit DO=P1^3; //DO定義為P1口的第4位腳,連接ADC0832DO腳
- sbit CS=P1^0; //CS定義為P1口的第4位腳,連接ADC0832CS腳
- uchar shidu; //濕度等級
- uchar s_high = 70,s_low = 25; //濕度報警參數(shù)
- sbit dianji = P3^5; //電機IO定義
- /***********************1ms延時函數(shù)*****************************/
- void delay_1ms(uint q)
- uint i,j;
- for(i=0;i<q;i++)
- for(j=0;j<120;j++);
- /***********************數(shù)碼位選函數(shù)*****************************/
- void smg_we_switch(uchar i)
- switch(i)
- case 0: smg_we1 = 0; smg_we2 = 1; smg_we3 = 1; smg_we4 = 1; break;
- case 1: smg_we1 = 1; smg_we2 = 0; smg_we3 = 1; smg_we4 = 1; break;
- case 2: smg_we1 = 1; smg_we2 = 1; smg_we3 = 0; smg_we4 = 1; break;
- case 3: smg_we1 = 1; smg_we2 = 1; smg_we3 = 1; smg_we4 = 0; break;
- uchar flag_200ms ;
- uchar key_can; //按鍵值的變量
- uchar menu_1; //菜單設(shè)計的變量
- /***********************數(shù)碼顯示函數(shù)*****************************/
- void display()
- static uchar i;
- i++;
- if(i >= 4)
- i = 0;
- P0 = 0xff; //消隱
- smg_we_switch(i); //位選
- P0 = dis_smg[i]; //段選
- // delay_1ms(1);
- /***********讀數(shù)模轉(zhuǎn)換數(shù)據(jù)********************************************************/
- //請先了解ADC0832模數(shù)轉(zhuǎn)換的串行協(xié)議,再來讀本函數(shù),主要是對應(yīng)時序圖來理解,本函數(shù)是模擬0832
- 的串行協(xié)議進行的
- // 1 1 0 通道
- // 1 1 1 通道
- unsigned char ad0832read(bit SGL,bit ODD)
- unsigned char i=0,value=0,value1=0;
- SCL=0;
- DO=1;
- CS=0; //開始
- SCL=1; //第一個上升沿
- SCL=0;
- DO=SGL;
- SCL=1; //第二個上升沿
- SCL=0;
- DO=ODD;
- SCL=1; //第三個上升沿
- SCL=0; //第三個下降沿
- DO=1;
- for(i=0;i<8;i++)
- SCL=1;
- SCL=0; //開始從第四個下降沿接收數(shù)據(jù)
- value=value<<1;
- if(DO)
- value++;
- for(i=0;i<8;i++)
- { //接收校驗數(shù)據(jù)
- value1>>=1;
- if(DO)
- value1+=0x80;
- SCL=1;
- SCL=0;
- SCL=1;
- DO=1;
- CS=1;
- if(value==value1) //與校驗數(shù)據(jù)比較,正確就返
- 回數(shù)據(jù),否則返回0
- return value;
- return 0;
- /********************獨立按鍵程序*****************/
- void key() //獨立按鍵程序
- static uchar key_new;
- key_can = 20; //按鍵值還原
- P1 |= 0xf0;
- if((P1 & 0xf0) != 0xf0) //按鍵按下
- delay_1ms(1); //按鍵消抖動
- if(((P1 & 0xf0) != 0xf0) && (key_new == 1))
- { //確認是按鍵按下
- key_new = 0;
- switch(P1 & 0xf0)
- case 0x70: key_can = 1; break; //得到k2鍵值
- case 0xb0: key_can = 2; break; //得到k3鍵值
- case 0xd0: key_can = 3; break; //得到k4鍵值
- else
- key_new = 1;
- /****************按鍵處理顯示函數(shù)***************/
- void key_with()
- if(menu_1 == 0)
- if(key_can == 3) //手動打開電機
- dianji = 0; //打開電機
- if(key_can == 2)
- dianji = 1; //關(guān)閉電機
- if(key_can == 1) //設(shè)置鍵
- menu_1 ++;
- if(menu_1 >= 3)
- menu_1 = 0;
- if(menu_1 == 1) //設(shè)置濕度上限
- if(key_can == 2)
- s_high ++ ; //濕度上限值加1
- if(s_high > 99)
- s_high = 99;
- if(key_can == 3)
- s_high -- ; //濕度上限值減1
- if(s_high <= s_low)
- s_high = s_low + 1 ;
- dis_smg[0] = smg_du[s_high % 10]; //取個位顯示
- dis_smg[1] = smg_du[s_high / 10 % 10]; //取十位顯示
- dis_smg[2] = 0xef;
- dis_smg[3] = 0x26; //H 0010 0110
- if(menu_1 == 2) //設(shè)置濕度下限
- if(key_can == 2)
- s_low ++ ; //濕度下限值加1
- if(s_low >= s_high)
- s_low = s_high - 1;
- if(key_can == 3)
- s_low --; //濕度下限值減1
- if(s_low <= 1)
- s_low = 1;
- dis_smg[0] = smg_du[s_low % 10]; //取個位顯示
- dis_smg[1] = smg_du[s_low / 10 % 10]; //取十位顯示
- dis_smg[3] = 0xBC; //L
- /****************電機控制函數(shù)***************/
- void dianji_kongzi()
- static uchar value,value1;
- if(shidu <= s_low)
- value ++;
- if(value >= 2)
- value = 10;
- dianji = 0; //關(guān)機電機
- else
- value = 0;
- if(shidu >= s_high)
- value1 ++;
- if(value1 >= 2)
- value1 = 10;
- dianji = 1; //打開電機
- }else
- value1 = 0;
- /***************主函數(shù)*****************/
- void main()
- delay_1ms(100);
- P0 = P1 = P2 = P3 = 0xff; //初始化IO口
- while(1)
- key(); //獨立按鍵程序
- if(key_can < 10)
- key_with(); //按鍵按下要執(zhí)行的程序
- flag_200ms ++;
- if(flag_200ms >= 200)
- flag_200ms = 0;
- P0 = 0xff; //消隱
- if(menu_1 == 0)
- shidu = ad0832read(1,0); //讀出濕度
- shidu =100-shidu * 99 / 255;
- dis_smg[0] = 0xff; //
- dis_smg[1] = smg_du[shidu % 10]; //取濕度的個位顯示
- dis_smg[2] = smg_du[shidu / 10 % 10] ;//取濕度的十位顯示
- dis_smg[3] = 0XFF; //
- dianji_kongzi(); //電機控制函數(shù)
- display(); //數(shù)碼管顯示函數(shù)
- delay_1ms(1);
復(fù)制代碼 |
