#include "reg52.h"
#include "string.h"
#include "stdlib.h"
#include "stdio.h"
unsigned char flag,c;
uchar receivedata[12] ;
double number1,number2,result1;
uint number3,number4;
uchar number[1][4] ;
uint length,count,i,point,j,k,result2;
uchar yunsuanfu;
uchar senddata[10];
void UsartInit()
SCON=0x50;
TMOD=0X20;
PCON=0X80;
TH1=0XF3;
TL0=0XF3;
ES=1;
EA=1;
TR1=1;
void Usart() interrupt 4
if(RI==1)
receivedata[count]=SBUF;
if(receivedata[count]=='=')
flag=1;
length=count;
count++;
RI=0;
UsartInit();
if(flag==1)
ES=0;
while(receivedata[i])
if(receivedata[i]=='=')
break;
if((receivedata[i]>=48 && receivedata[i]<=57) || receivedata[i]=='.')
if(receivedata[i]=='.')
point=1;
number[j][i-k]=receivedata[i];
i++;
yunsuanfu=receivedata[i];
i++;
k=i;
j++;
if(point==1)
number1=atof(number[0]);
number2=atof(number[1]);
switch(yunsuanfu)
case '+':result1=number1+number2;break;
case '-':result1=number1-number2;break;
case '*':result1=number1*number2;break;
case '/':result1=number1/number2;break;
default: break;
sprintf(senddata,"%.3f",result1);
number3=atoi(number[0]);
number4=atoi(number[1]);
switch(yunsuanfu)
case '+':result2=number3+number4;break;
case '-':result2=number3-number4;break;
case '*':result2=number3*number4;break;
case '/':result2=number3/number4;break;
default: break;
sprintf(senddata,"%d",result2);
for(c=0;c<10;c++)
SBUF=senddata[c];
while(!TI);
TI=0;
ES=1;
flag=0;
你發(fā)送的字符,程序的操作對(duì)象其實(shí)是它的ASCII碼,你可以先用函數(shù)轉(zhuǎn)化成整型或者浮點(diǎn)型數(shù)
Atof()函數(shù):
其作用是把括號(hào)內(nèi)的一個(gè)字符串轉(zhuǎn)化為浮點(diǎn)數(shù):
Atoi()函數(shù):
其作用是把括號(hào)內(nèi)的一個(gè)字符串轉(zhuǎn)化為整數(shù);
Sprintf()函數(shù):
其作用是將一個(gè)數(shù)變成字符串存到一個(gè)數(shù)組中去;
sprintf(senddata,"%d",result2);例如這個(gè)的意思就是把數(shù)據(jù)result2變成字符串再存到senddata數(shù)組中去。
