51單片機(jī)diy雕刻機(jī)程序源碼
- /*z地址定義
- 50 1=x+,2=x-,3=y+,4=y-
- 51 前進(jìn)后退步數(shù)高
- 52 前進(jìn)后退步數(shù)低
- 53
- 54/55 字寬
- 56
- 57 弱光開關(guān)
- 58/59 激光強(qiáng)度
- 60 x軸速度
- 61 y軸速度
- 62 開始打印0,57
- 63 暫停
- 64 停止標(biāo)志
- 65
- 66 左右標(biāo)記
- 100開始時(shí)灰度圖數(shù)據(jù)
- #include <reg52.h>
- #define uint unsigned int
- #define uchar unsigned char
- #define N z[60] //X速度
- #define M z[61] //Y速度
- sbit a=P1^3;//步進(jìn)電機(jī)接線定義 移動(dòng)激光頭
- sbit a_=P1^2;
- sbit b=P1^1;
- sbit b_=P1^0;
- sbit xa=P1^4;
- sbit xa_=P1^5;
- sbit xb=P1^6;
- sbit xb_=P1^7;
- /*sbit a=P1^4;//步進(jìn)電機(jī)接線定義 移動(dòng)底板
- sbit a_=P1^5;
- sbit b=P1^6;
- sbit b_=P1^7;
- sbit xa=P1^3;
- sbit xa_=P1^2;
- sbit xb=P1^1;
- sbit xb_=P1^0; */
- sbit jg=P2^0;
- sbit led=P2^1;//指示燈
- uchar xdata z[500]={0};//緩存
- uchar buff[3];//串口緩存
- uchar x1,x0,y1,y0,cont2=0;
- uchar xfb=4,yfb=4;//走步標(biāo)志位
- unsigned char HighRH = 0; //高電平重載值的高字節(jié)
- unsigned char HighRL = 0; //高電平重載值的低字節(jié)
- unsigned char LowRH = 0; //低電平重載值的高字節(jié)
- unsigned char LowRL = 0; //低電平重載值的低字節(jié)
- void delayms(uint xms)
- uint i,j;
- for(i=xms;i>0;i--) //i=xms即延時(shí)約xms毫秒
- for(j=110;j>0;j--);
- /* 配置并啟動(dòng)PWM,fr-頻率,dc-占空比 */
- void ConfigPWM(unsigned int fr, unsigned char dc)
- unsigned int high, low;
- unsigned long tmp;
- tmp = (11059200/12) / fr; //計(jì)算一個(gè)周期所需的計(jì)數(shù)值
- high = (tmp*dc) / 100; //計(jì)算高電平所需的計(jì)數(shù)值
- low = tmp - high; //計(jì)算低電平所需的計(jì)數(shù)值
- high = 65536 - high + 12; //計(jì)算高電平的重載值并補(bǔ)償中斷延時(shí)
- low = 65536 - low + 12; //計(jì)算低電平的重載值并補(bǔ)償中斷延時(shí)
- HighRH = (unsigned char)(high>>8); //高電平重載值拆分為高低字節(jié)
- HighRL = (unsigned char)high;
- LowRH = (unsigned char)(low>>8); //低電平重載值拆分為高低字節(jié)
- LowRL = (unsigned char)low;
- TMOD &= 0xF0; //清零T0的控制位
- TMOD |= 0x01; //配置T0為模式1
- TH0 = HighRH; //加載T0重載值
- TL0 = HighRL;
- ET0 = 1; //使能T0中斷
- TR0 = 1; //啟動(dòng)T0
- jg = 1; //輸出低電平,關(guān)閉激光
- /* 關(guān)閉PWM */
- void ClosePWM()
- TR0 = 0; //停止定時(shí)器0
- ET0 = 0; //禁止定時(shí)器0中斷
- /* T0中斷服務(wù)函數(shù),產(chǎn)生PWM輸出 */
- void InterruptTimer0() interrupt 1
- if (jg == 1) //當(dāng)前輸出為低電平時(shí),裝載高電平值并輸出高電平
- TH0 = LowRH;
- TL0 = LowRL;
- jg = 0;
- else //當(dāng)前輸出為高電平時(shí),裝載低電平值并輸出低電平
- TH0 = HighRH;
- TL0 = HighRL;
- jg = 1;
- void xfor(uint i) //x軸前進(jìn)函數(shù),前進(jìn)多少步
- while(1)
- if(xfb==4)
- xa=xb=1;
- xb_=xa_=0;
- xfb=1;
- i--;
- delayms(N);
- if(i==0){xa=xb=0; break;}
- if(xfb==1)
- xb=xa_=1;
- xa=xb_=0;
- xfb=2;
- i--;
- delayms(N);
- if(i==0){xa_=xb=0; break;}
- if(xfb==2)
- xa_=xb_=1;
- xb=xa=0;
- xfb=3; //走步標(biāo)志位
- i--;
- delayms(N);
- if(i==0){xa_=xb_=0; break;}
- if(xfb==3)
- xa_=xb=0;
- xb_=xa=1;
- xfb=4;
- i--;
- delayms(N);
- if(i==0){xa=xb_=0; break;}
- void xbac(uint i) //xxx后退函數(shù)
- while(1)
- if(xfb==1)
- xa_=xb=0;
- xb_=xa=1;
- xfb=4;
- i--; //走步標(biāo)志位
- delayms(N);
- if(xfb==4)
- xa_=xb_=1;
- xb=xa=0;
- xfb=3;
- i--;
- delayms(N);
- if(xfb==3)
- xb=xa_=1;
- xa=xb_=0;
- xfb=2; //走步標(biāo)志位
- i--;
- delayms(N);
- if(xfb==2)
- xa=xb=1;
- xb_=xa_=0;
- xfb=1;
- i--;
- delayms(N);
- void yfor(uint i) //y軸前進(jìn)函數(shù)
- while(1)
- switch(yfb)
- case 4:{a=b=1; b_=a_=0; yfb=1; i--; delayms(M); if(i==0){a=b=0;break;}}
- case 1:{b=a_=1; a=b_=0; yfb=2; i--; delayms(M); if(i==0){a_=b=0;break;}}
- case 2:{a_=b_=1; b=a=0; yfb=3; i--; delayms(M); if(i==0){a_=b_=0;break;}}
- case 3:{b_=a=1; a_=b=0; yfb=4; i--; delayms(M); if(i==0){a=b_=0;break;}}
- if(i==0) break;
- void ybac(uint i) //yy后退函數(shù)
- while(1)
- switch(yfb)
- case 1:{a=b_=1; b=a_=0; yfb=4; i--; delayms(M); if(i==0){a=b_=0;break;}}
- case 4:{b_=a_=1; a=b=0; yfb=3; i--; delayms(M); if(i==0){a_=b_=0;break;}}
- case 3:{a_=b=1; b_=a=0; yfb=2; i--; delayms(M); if(i==0){a_=b=0;break;}}
- case 2:{b=a=1; a_=b_=0; yfb=1; i--; delayms(M); if(i==0){a=b=0;break;}}
- if(i==0) break;
- void dazi(uint zik)//打印函數(shù) ******打印函數(shù)已更改******
- uint x;
- jg=0;
- for(x=0;x<zik;x++)//執(zhí)行zik個(gè)循環(huán),x軸右移zik步
- while(z[63]); //暫停等待
- if(z[64]==1) break;//停止標(biāo)志 跳出循環(huán)
- SBUF=255; // 每開始打印一個(gè)點(diǎn),向上位機(jī)發(fā)送255,上位機(jī)進(jìn)度顯示用
- jg=0; //開激光
- delayms((z[99+x]*(z[58]*256+z[59]))/100);
- jg=1; //關(guān)閉激光
- if(z[66]==1)
- xbac(1);
- else
- xfor(1);
- if(z[64==1]) z[64]=0;
- else{yfor(1);} //y軸進(jìn)一行
- z[62]=0; //一行打印完成
- SBUF=1; //發(fā)送信息,表示打印一行完成
- /* 串口配置函數(shù),baud-通信波特率 */
- void ConfigUART(unsigned int baud)
- SCON = 0x50; //配置串口為模式1
- TMOD &= 0x0F; //清零T1的控制位
- TMOD |= 0x20; //配置T1為模式2
- TH1 = 256 - (11059200/12/32)/baud; //計(jì)算T1重載值
- TL1 = TH1; //初值等于重載值
- ET1 = 0; //禁止T1中斷
- ES = 1; //使能串口中斷
- TR1 = 1; //啟動(dòng)T1
- void chuanlo() interrupt 4
- if(RI)
- buff[cont2]=SBUF;//每次3字節(jié),地址高,地址低,數(shù)據(jù),,
- cont2++;
- if(cont2==3)//每收3個(gè)字節(jié),把數(shù)據(jù)寫入地址中
- z[(buff[0]*256)+buff[1]]=buff[2];
- cont2=0;
- SBUF=0; //*****************在這里加入這行代碼測(cè)試一下*******************************
- RI=0;
- if(TI)
- TI=0;
- main()
- EA=1;
- P0=0xff;
- ConfigUART(9600) ;
- z[60]=15;//默認(rèn)的參數(shù)
- z[61]=15;
- z[56]=1;
- z[62]=0;
- jg=0;
- cont2=0;
- while(1)
- // *****此處已更改******
- if(z[57]==100){ConfigPWM(100, 98);delayms(10);} //上位機(jī)指令處理,打開弱光定位,頻率100Hz,占空比98%
- else if(z[57]==1) jg=0; //打開強(qiáng)光
- else { ClosePWM(); delayms(10);}
- if(cont2!=0) led=0; else led=1;//指示通信是否可用
- if(z[50]==1){xfor(z[51]*256+z[52]);z[50]=0;}//x+
- if(z[50]==2){xbac(z[51]*256+z[52]);z[50]=0;}//x-
- if(z[50]==3){yfor(z[51]*256+z[52]);z[50]=0;}//y+
- if(z[50]==4){ybac(z[51]*256+z[52]);z[50]=0;}//y-
- if(z[62])//開始打印標(biāo)志
- dazi(z[54]*256+z[55]);
以上Keil代碼下載:
diaokeji.zip
(26.52 KB, 下載次數(shù): 69)
2018-5-5 09:05 上傳
點(diǎn)擊文件名下載附件
51雕刻機(jī)源碼
