2018-5-5 16:37 上傳
全部資料51hei下載地址:
uCOS-II.zip
(1.6 MB, 下載次數(shù): 14)
2018-5-5 10:36 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
uC/OS-II, The Real-Time Kernel
Companion CD
Version 2.52
READ ME FILE
****************************** TABLE OF CONTENTS *****************************
1) Reporting problems
2) Software Upgrades
3) Release Notes
/*$PAGE*/
***************************** REPORTING PROBLEMS *****************************
If you find a problem (i.e. bug) in uC/OS-II, do not hesitate to report
the problem to either:
1) Through the INTERNET:
My INTERNET address is:
2) By writing to me at:
Micrium, Inc.
949 Crestview Circle
Weston, FL 33327
U.S.A.
c/o: Jean J. Labrosse
3) By calling Micrium, Inc.:
(954) 217-2036
(954) 217-2037, FAX
Make sure that the problem you are reporting is in uC/OS-II and not your
application. If you in fact discover a bug in uC/OS-II, check the uC/OS-II
web site for a list of known bugs and their fixes:
www.uCOS-II.com
If you are using an older version, you should first get the lastest
version.
/*$PAGE*/
****************************** SOFTWARE UPGRADES *****************************
As you can see, I have been trying to support uC/OS (i.e. V1.xx) and now,
uC/OS-II. When bugs are found, I do my best to promptly correct them. It is
virtually impossible to notify everybody that purchased the code (i.e. the
diskette) to tell them that a new version is available. You should
occasionally check the uC/OS-II WEB site (www.ucos-ii.com) or the Micrium web
site to see what version is currently shipping.
I will not be upgrading the publisher everytime I add new features to
uC/OS-II.
I would highly suggest that you resist changing the STYLE of the code
unless you don't mind spending many hours doing so everytime you upgrade.
/*$PAGE*/
******************************** RELEASE NOTES *****************************
1) RELEASE NOTES:
The release notes are now provided in PDF format in the file:
\SOFTWARE\uCOS-II\DOC\RelV252.PDF
2) FEATURES SINCE V2.00:
All the features added since V2.00 are described in the PDF file:
\SOFTWARE\uCOS-II\DOC\NewV252.PDF
3) QUICK REFERENCE CHART:
A Quick Reference Chart for all the functions in V2.52 is provided in the
following .PDF files:
\SOFTWARE\uCOS-II\DOC\QuickRefChartV252-Color.PDF
Once printed, simply FOLD the page in half and if you have a LAMINATION
machine, you can protect the chart by laminating it.
