來自學(xué)校圖書的光盤:單片機(jī)C語言實(shí)戰(zhàn)開發(fā)108例,可以參照作為溫度采集系統(tǒng)。包含c51源碼和proteus仿真
2018-5-6 17:55 上傳
2018-5-6 17:55 上傳
- #include <AT89X52.h>
- #include <Intrins.h>
- #define DATA P1 //1602驅(qū)動(dòng)端口
- //ROM操作命令
- #define READ_ROM 0x33 //讀ROM
- #define SKIP_ROM 0xCC //跳過ROM
- #define MATCH_ROM 0x55 //匹配ROM
- #define SEARCH_ROM 0xF0 //搜索ROM
- #define ALARM_SEARCH 0xEC //告警搜索
- //存儲器操作命令
- #define ANEW_MOVE 0xB8 //重新調(diào)出E^2數(shù)據(jù)
- #define READ_POWER 0xB4 //讀電源
- #define TEMP_SWITCH 0x44 //啟動(dòng)溫度變換
- #define READ_MEMORY 0xBE //讀暫存存儲器
- #define COPY_MEMORY 0x48 //復(fù)制暫存存儲器
- #define WRITE_MEMORY 0x4E //寫暫存存儲器
- //數(shù)據(jù)存儲結(jié)構(gòu)
- typedef struct tagTempData
- unsigned char btThird; //百位數(shù)據(jù)
- unsigned char btSecond; //十位數(shù)據(jù)
- unsigned char btFirst; //個(gè)位數(shù)據(jù)
- unsigned char btDecimal; //小數(shù)點(diǎn)后一位數(shù)據(jù)
- unsigned char btNegative; //是否為負(fù)數(shù)
- }TEMPDATA;
- TEMPDATA m_TempData;
- //引腳定義
- sbit DQ = P2^7; //數(shù)據(jù)線端口
- sbit RS= P2^0;
- sbit RW= P2^1;
- sbit E= P2^2;
- //DS18B20序列號,通過調(diào)用GetROMSequence()函數(shù)在P1口讀出(讀8次)
- const unsigned char code ROMData1[8] = {0x28, 0x33, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0xD7}; //U1
- const unsigned char code ROMData2[8] = {0x28, 0x30, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0x8E}; //U2
- const unsigned char code ROMData3[8] = {0x28, 0x31, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0xB9}; //U3
- const unsigned char code ROMData4[8] = {0x28, 0x32, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0xE0}; //U4
- const unsigned char code ROMData5[8] = {0x28, 0x34, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0x52}; //U5
- const unsigned char code ROMData6[8] = {0x28, 0x35, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0x65}; //U6
- const unsigned char code ROMData7[8] = {0x28, 0x36, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0x3C}; //U7
- const unsigned char code ROMData8[8] = {0x28, 0x37, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0x0B}; //U8
- //判斷忙指令
- void Busy()
- DATA = 0xff;
- RS = 0;
- RW = 1;
- while(DATA & 0x80)
- E = 0;
- E = 1;
- E = 0;
- //寫指令程序
- void WriteCommand(unsigned char btCommand)
- Busy();
- RS = 0;
- RW = 0;
- E = 1;
- DATA = btCommand;
- E = 0;
- //寫數(shù)據(jù)程序
- void WriteData(unsigned char btData)
- Busy();
- RS = 1;
- RW = 0;
- E = 1;
- DATA = btData;
- E = 0;
- //清屏顯示
- void Clear()
- WriteCommand(1);
- //初始化
- void Init()
- WriteCommand(0x0c); //開顯示,無光標(biāo)顯示
- WriteCommand(0x06); //文字不動(dòng),光標(biāo)自動(dòng)右移
- WriteCommand(0x38); //設(shè)置顯示模式:8位2行5x7點(diǎn)陣
- //顯示單個(gè)字符
- void DisplayOne(bit bRow, unsigned char btColumn, unsigned char btData, bit bIsNumber)
- if (bRow) WriteCommand(0xc0 + btColumn);
- else WriteCommand(0x80 + btColumn);
- if (bIsNumber) WriteData(btData + 0x30);
- else WriteData(btData);
- //顯示字符串函數(shù)
- void DisplayString(bit bRow, unsigned char btColumn, unsigned char *pData)
- while (*pData != '\0')
- if (bRow) WriteCommand(0xc0 + btColumn); //顯示在第1行
- else WriteCommand(0x80 + btColumn); //顯示在第0行
- WriteData(*(pData++)); //要顯示的數(shù)據(jù)
- btColumn++; //列數(shù)加一
- //延時(shí)16us子函數(shù)
- void Delay16us()
- unsigned char a;
- for (a = 0; a < 4; a++);
- //延時(shí)60us子函數(shù)
- void Delay60us()
- unsigned char a;
- for (a = 0; a < 18; a++);
- //延時(shí)480us子函數(shù)
- void Delay480us()
- unsigned char a;
- for (a = 0; a < 158; a++);
- //延時(shí)240us子函數(shù)
- void Delay240us()
- unsigned char a;
- for (a = 0; a < 78; a++);
- //延時(shí)500ms子函數(shù)
- void Delay500ms()
- unsigned char a, b, c;
- for (a = 0; a < 250; a++)
- for (b = 0; b < 3; b++)
- for (c = 0; c < 220; c++);
- //芯片初始化
- void Initialization()
- while(1)
- DQ = 0;
- Delay480us(); //延時(shí)480us
- DQ = 1;
- Delay60us(); //延時(shí)60us
- if(!DQ) //收到ds18b20的應(yīng)答信號
- DQ = 1;
- Delay240us(); //延時(shí)240us
- break;
- //寫一個(gè)字節(jié)(從低位開始寫)
- void WriteByte(unsigned char btData)
- unsigned char i, btBuffer;
- for (i = 0; i < 8; i++)
- btBuffer = btData >> i;
- if (btBuffer & 1)
- DQ = 0;
- _nop_();
- _nop_();
- DQ = 1;
- Delay60us();
- else
- DQ = 0;
- Delay60us();
- DQ = 1;
- //讀一個(gè)字節(jié)(從低位開始讀)
- unsigned char ReadByte()
- unsigned char i, btDest;
- btDest >>= 1;
- DQ = 0;
- _nop_();
- _nop_();
- DQ = 1;
- Delay16us();
- if (DQ) btDest |= 0x80;
- Delay60us();
- return btDest;
- //序列號匹配
- void MatchROM(const unsigned char *pMatchData)
- unsigned char i;
- Initialization();
- WriteByte(MATCH_ROM);
- for (i = 0; i < 8; i++) WriteByte(*(pMatchData + i));
- //得到64位ROM序列(在P1口顯示,必須與Proteus聯(lián)調(diào)且在單步調(diào)試下才能得到)
- /*void GetROMSequence()
- unsigned char i;
- Initialization();
- WriteByte(READ_ROM);
- P1 = ReadByte();
- //讀取溫度值
- TEMPDATA ReadTemperature()
- TEMPDATA TempData;
- unsigned int iTempDataH;
- unsigned char btDot, iTempDataL;
- static unsigned char i = 0;
- TempData.btNegative = 0; //為0溫度為正
- i++;
- if (i == 9) i = 1;
- Initialization();
- WriteByte(SKIP_ROM); //跳過ROM匹配
- WriteByte(TEMP_SWITCH); //啟動(dòng)轉(zhuǎn)換
- Delay500ms(); //調(diào)用一次就行
- Delay500ms();
- Initialization();
- //多個(gè)芯片的時(shí)候用MatchROM(ROMData)換掉WriteByte(SKIP_ROM)
- switch (i)
- case 1 : MatchROM(ROMData1); break; //匹配1
- case 2 : MatchROM(ROMData2); break; //匹配2
- case 3 : MatchROM(ROMData3); break; //匹配3
- case 4 : MatchROM(ROMData4); break; //匹配4
- case 5 : MatchROM(ROMData5); break; //匹配5
- case 6 : MatchROM(ROMData6); break; //匹配6
- case 7 : MatchROM(ROMData7); break; //匹配7
- case 8 : MatchROM(ROMData8); break; //匹配8
- //WriteByte(SKIP_ROM); //跳過ROM匹配(單個(gè)芯片時(shí)用這句換掉上面的switch)
- WriteByte(READ_MEMORY); //讀數(shù)據(jù)
- iTempDataL = ReadByte();
- iTempDataH = ReadByte();
- iTempDataH <<= 8;
- iTempDataH |= iTempDataL;
- if (iTempDataH & 0x8000)
- TempData.btNegative = 1;
- iTempDataH = ~iTempDataH + 1; //負(fù)數(shù)求補(bǔ)
- //為了省去浮點(diǎn)運(yùn)算帶來的開銷,而采用整數(shù)和小數(shù)部分分開處理的方法(沒有四舍五入)
- btDot = (unsigned char)(iTempDataH & 0x000F); //得到小數(shù)部分
- iTempDataH >>= 4; //得到整數(shù)部分
- btDot *= 5; //btDot*10/16得到轉(zhuǎn)換后的小數(shù)數(shù)據(jù)
- btDot >>= 3;
- //數(shù)據(jù)處理
- TempData.btThird = (unsigned char)iTempDataH / 100;
- TempData.btSecond = (unsigned char)iTempDataH % 100 / 10;
- TempData.btFirst = (unsigned char)iTempDataH % 10;
- TempData.btDecimal = btDot;
- return TempData;
- //數(shù)據(jù)處理子程序
- void DataProcess()
- m_TempData = ReadTemperature();
- if (m_TempData.btNegative) DisplayOne(1, 6, '-', 0);
- else DisplayOne(1, 6, m_TempData.btThird, 1);
多點(diǎn)溫度采集系統(tǒng).rar
(113.25 KB, 下載次數(shù): 115)
2018-5-6 11:01 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
