這是花了幾天時間做的課程設計,里面包含原理圖,
代碼,
仿真圖,
程序,
大家請多多指教。
2018-5-7 00:48 上傳
2018-5-7 01:49 上傳
單片機源程序如下:
- #include<reg52.h>//包含52單片機頭文件
- #define uchar unsigned char
- #define uint unsigned int
- sbit rs=P2^0; //定義1602液晶RS端
- sbit lcden=P2^2;//定義1602液晶LCDEN端
- sbit rd=P2^1; //定義1602液晶rd端
- sbit s1=P3^0; //定義按鍵--功能鍵
- sbit s2=P3^1; //定義按鍵--增加鍵
- sbit s3=P3^2; //定義按鍵--減小鍵
- sbit beep=P2^3; //定義蜂鳴器端
- uchar count,s1num;
- char miao,shi,fen,nian,yue,ri,zhou,num,tian;
- char yizhou[8][4]={"MON","TUE","WEN","THU","FRI","SAT","SUN"};
- int pingnian[13]={0,31,28,31,30,31,30,31,31,30,31,30,31};
- int ruinian[13]={0,31,29,31,30,31,30,31,31,30,31,30,31};
- void delay(uint z) //延時函數(shù)
- uint x,y;
- for(x=z;x>0;x--)
- for(y=110;y>0;y--);
- void di()
- uchar i;
- for(i=0;i<100;i++)
- beep = ~beep;
- delay(1);
- beep = 0;
- void write_com(uchar com)//液晶寫命令函數(shù)
- rs=0;
- lcden=0;
- P0=com;
- delay(5);
- lcden=1;
- delay(5);
- lcden=0;
- void write_date(uchar date)//液晶寫數(shù)據(jù)函數(shù)
- rs=1;
- lcden=0;
- P0=date;
- delay(5);
- lcden=1;
- delay(5);
- lcden=0;
- void write_sfm(uchar add,uchar date)//寫時分秒函數(shù)
- uchar shi,ge;
- shi=date/10;//分解一個2位數(shù)的十位和個位
- ge=date%10;
- write_com(0x80+0x40+add);//設置顯示位置
- write_date(0x30+shi);//送去液晶顯示十位
- write_date(0x30+ge); //送去液晶顯示個位
- void write_nyr(uchar add,uchar date)//寫年月日函數(shù)
- uchar shi,ge;
- ge=date%10;
- write_com(0x80+add);//設置顯示位置
- void init()//初始化函數(shù)
- num=0;
- rd=0;
- lcden=0;
- fen=0; //初始化分變量值
- miao=0;
- shi=0;
- nian=1;
- yue=1;
- ri=1;
- zhou=0;
- count=0;
- s1num=0;
- write_com(0x38);//初始化1602液晶
- write_com(0x0c);
- write_com(0x06);
- write_com(0x01);
- write_com(0x80+1);//設置顯示初始坐標
- write_date('2');
- write_com(0x80+2 );
- write_date('0');
- write_com(0x80+0x40+6);//寫出時間顯示部分的兩個冒號
- write_date(':');
- delay(5);
- write_com(0x80+0x40+9);
- write_date(':');
- delay(5);
- write_com(0x80+5);//寫出時間顯示部分的兩個-
- write_date('-');
- delay(5);
- write_com(0x80+8);
- write_date('-');
- delay(5);
- write_com(0x80+12);
- for(num=0;num<3;num++)
- write_date(yizhou[zhou][num]);
- delay(5);
- write_nyr(3,nian);
- write_nyr(6,yue);
- write_nyr(9,ri);
- write_sfm(10,miao);
- write_sfm(7,fen);
- write_sfm(4,shi);
- TMOD=0x01;//設置定時器0工作模式1
- TH0=(65536-50000)/256;//定時器裝初值
- TL0=(65536-50000)%256;
- EA=1; //開總中斷
- ET0=1; //開定時器0中斷
- TR0=1; //啟動定時器0
- void keyscan()//按鍵掃描函數(shù)
- if(s1==0)
- delay(5);
- if(s1==0)//確認功能鍵被按下
- { s1num++;//功能鍵按下次數(shù)記錄
- while(!s1);//釋放確認
- di();//每當有按鍵釋放蜂鳴器發(fā)出滴聲
- if(s1num==1)//第一次被按下時
- TR0=0; //關閉定時器
- write_com(0x80+0x40+11);//光標定位到秒位置
- write_com(0x0f); //光標開始閃爍
- if(s1num==2)//第二次按下光標閃爍定位到分鐘位置
- write_com(0x80+0x40+8);
- if(s1num==3)//第三次按下光標閃爍定位到小時位置
- write_com(0x80+0x40+5);
- if(s1num==4)//第四次按下光標閃爍定位到周位置
- write_com(0x80+14);
- if(s1num==5)//第五次按下光標閃爍定位到日位置
- write_com(0x80+10);
- if(s1num==6)//第六次按下光標閃爍定位到月位置
- write_com(0x80+7);
- if(s1num==7)//第七次按下光標閃爍定位到年位置
- write_com(0x80+4);
- if(s1num==8)//第八次按下
- s1num=0;//記錄按鍵數(shù)清零
- write_com(0x0c);//取消光標閃爍
- TR0=1; //啟動定時器使時鐘開始走
- if(s1num!=0)//只有功能鍵被按下后,增加和減小鍵才有效
- if(s2==0)
- delay(5);
- if(s2==0)//增加鍵確認被按下
- while(!s2);//按鍵釋放
- if(s1num==1)//若功能鍵第一次按下
- miao++; //則調整秒加1
- if(miao>=60)//若滿60后將清零
- miao=0;
- write_sfm(10,miao);//每調節(jié)一次送液晶顯示一下
- write_com(0x80+0x40+11);//顯示位置重新回到調節(jié)處
- if(s1num==2)//若功能鍵第二次按下
- fen++;//則調整分鐘加1
- if(fen>=60)//若滿60后將清零
- fen=0;
- write_sfm(7,fen);//每調節(jié)一次送液晶顯示一下
- write_com(0x80+0x40+8);//顯示位置重新回到調節(jié)處
- if(s1num==3)//若功能鍵第三次按下
- shi++;//則調整小時加1
- if(shi>=24)//若滿24后將清零
- shi=0;
- write_sfm(4,shi);;//每調節(jié)一次送液晶顯示一下
- write_com(0x80+0x40+5);//顯示位置重新回到調節(jié)處
- if(s1num==4)//若功能鍵第四次按下
- zhou++;
- if(zhou>=7)//若滿7后將清零
- zhou=0;
- write_com(0x80+12);//設置顯示初始坐標
- delay(5);
- if(s1num==5)//若功能鍵第二次按下
- ri++;//則調整日加1
- if((2000+nian)%400==0||(2000+nian)%4==0&&(2000+nian)%100!=0)
- tian=ruinian[yue];
- else nian=pingnian[yue];
- if(ri>tian)
- ri=1;
- write_nyr(9,ri);//每調節(jié)一次送液晶顯示一下
- write_com(0x80+10);//顯示位置重新回到調節(jié)處
- if(s1num==6)//若功能鍵第二次按下
- yue++;//則調整月加1
- if(yue>12)//若滿12后將清零
- yue=1;
- write_nyr(6,yue);//每調節(jié)一次送液晶顯示一下
- write_com(0x80+7);//顯示位置重新回到調節(jié)處
- if(s1num==7)//若功能鍵第二次按下
- nian++;//則調整nian加1
- if(nian>50)//若滿50后將清零
- nian=0;
- write_nyr(3,nian);//每調節(jié)一次送液晶顯示一下
- write_com(0x80+4);//顯示位置重新回到調節(jié)處
- if(s3==0)
- delay(5);
- if(s3==0)//確認減小鍵被按下
- while(!s3);//按鍵釋放
- miao--; //則調整秒加1
- if(miao<0)//若滿60后將清零
- miao=59;
- fen--;//則調整分鐘加1
- if(fen<0)//若滿60后將清零
- fen=59;
- shi--;//則調整小時加1
- if(shi<0)//若滿24后將清零
- shi=23;
- zhou--;
- if(zhou<0)//若滿7后將清零
- zhou=6;
- delay(5);
- ri--;//則調整日加1
- if(ri<1)
- ri=tian;
- yue--;//則調整月加1
- if(yue<1)//若滿12后將清零
- yue=12;
- nian--;//則調整nian加1
- if(nian<0)//若滿50后將清零
- nian=50;
- void main()//主函數(shù)
- init();//首先初始化各數(shù)據(jù)
- while(1)//進入主程序大循環(huán)
- keyscan();//不停的檢測按鍵是否被按下
- void timer0() interrupt 1//定時器0中斷服務程序
- TH0=(65536-50000)/256;//再次裝定時器初值
- count++; //中斷次數(shù)累加
- if(count==20) //20次50毫秒為1秒
- count=0;
- miao++;
- if(miao>=60)//秒加到60則進位分鐘
- miao=0;//同時秒數(shù)清零
- fen++;
- if(fen>=60)//分鐘加到60則進位小時
- fen=0;//同時分鐘數(shù)清零
- shi++;
- if(shi>=24)//小時加到24則小時清零
- shi=0;
- ri++;
- zhou++;
- if(zhou>6)//若滿7后將清零
- zhou=0;
- delay(5);
復制代碼
DZZ.zip
(81.76 KB, 下載次數(shù): 236)
2018-5-7 00:49 上傳
點擊文件名下載附件
含程序,仿真圖 下載積分: 黑幣 -5
