查看: 2497|回復(fù): 1
為什么我的主函數(shù)里邊if條件不滿足定時(shí)器就開始啟動(dòng)計(jì)時(shí)工作,是不是我傳遞的參數(shù)不對(duì)
ID:291819 發(fā)表于 2018-5-7 17:56 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
#include<reg51.h>
#include <math.h>
#include"intrins.h"
uchar hour,min,sec,count,hour1,hour2,
sec1,sec2,min1,min2,keystopc,temp;
sbit lcden=P2^7;
sbit lcdrw=P2^6;
sbit lcdrs=P2^5;
sbit SCL=P1^0;             //PCF8591T的 SCL 引腳接于單片機(jī)的P1^7引腳上
sbit SDA=P1^1;             //PCF8591T的 SDA 引腳接于單片機(jī)的P1^6引腳上
//HC-SR04相關(guān)I/O設(shè)置
sbit TIRG=P3^4;                   //定義IO口
sbit ECHO=P3^2;                   //定義IO口
bit      flag =0;
unsigned char k;
uchar code table[]={
'0','1','2','3','4','5','6','7','8','9',':','.'};
uint num=0;
float f_temp;
unsigned char ADbuf1,ADbuf2;//設(shè)置8位的寄存器用來暫存A/D轉(zhuǎn)換結(jié)果
void init()                     //定時(shí)器初始化
    count=0;
    hour=0;                   //時(shí)
    min=0;                   //分
    sec=0;                   //秒
    TMOD=0x01;
    TH0=(65536-50000)/256;                   //TH0=60
    TL0=(65536-50000)%256;                  //TL0=6
    TR0=0;
    EA=0;
        ET0=0;
void delay(uint z)                //延時(shí)程序
    uint x,y;
    for(x=z;x>0;x--)
     for(y=110;y>0;y--);
             LCD1602顯示函數(shù)
void write_com(uchar com)                                  //寫命令函數(shù)
    lcdrs=0;
    P0=com;
    delay(5);
    lcden=1;
    delay(5);
    lcden=0;
void write_data(uchar date)             //寫數(shù)據(jù)函數(shù)
    lcdrs=1;
    P0=date;
    delay(5);
    lcden=1;
    delay(5);
    lcden=0;
void init_1602()                //初始化1602
    lcden=0;
    lcdrw=0;
    write_com(0x38);
    write_com(0x0c);
    write_com(0x06);
    write_com(0x01);
    write_com(0x80);
void write_Char(unsigned char x,unsigned char y,unsigned char date)             //在1602上顯示數(shù)據(jù)位置
if (y == 0)
    write_com(0x80 + x);
    write_com(0xC0 + x);
write_data(date);
void display(uchar hour1,uchar hour2,uchar min1,uchar min2,uchar sec1,uchar sec2)    //顯示程序
    write_Char(4,1,table[hour1]);
    write_Char(5,1,table[hour2]);
    write_Char(6,1,table[0x0a]);
    write_Char(7,1,table[min1]);
    write_Char(8,1,table[min2]);
    write_Char(9,1,table[0x0a]);
    write_Char(10,1,table[sec1]);
    write_Char(11,1,table[sec2]);
// 計(jì)時(shí)器/定時(shí)器0
void count0()  interrupt 1
    count++;
    if(count==20)
            count=0;
            sec++;
            if(sec==60)
                sec=0;
                min++;
                if(min==60)
                    min=0;
                    hour++;
                    if(hour==12)
                        hour=0;
//名稱:生IIC啟動(dòng)信號(hào)函數(shù)
void IICstart(void)
     SDA=1;                //先將SDA=1,以準(zhǔn)備在SCL=1時(shí),將SDA=0
     SCL=1;                //時(shí)鐘總線拉高
     _nop_();                          //略做延時(shí)
     SDA=0;                //SCL=1時(shí),將SDA拉低即產(chǎn)生啟動(dòng)信號(hào)
     SCL=0;                //將SCL=0,完成啟動(dòng)信號(hào)操作
//名稱:IIC停止信號(hào)函數(shù)
void IICstop(void)
     SDA=0;                //先將SDA=0,以準(zhǔn)備在SCL=1時(shí),將SDA=1
     SDA=1;                //SCL=1時(shí),將SDA拉高即產(chǎn)生停止信號(hào)
//名稱:向IIC總線寫入1個(gè)字節(jié)函數(shù)
void Write1Byte(unsigned char Buf1)
     unsigned char k;      //1個(gè)字節(jié)要分8次寫入,需要定義一個(gè)寄存器用來計(jì)數(shù)
     for(k=0;k<8;k++)      //做一個(gè)8次的循環(huán),每次寫入1位,需要寫8次
         if(Buf1&0x80)     //從最高位開始寫
             SDA=1;        //如果欲寫入數(shù)據(jù)為1,就將數(shù)據(jù)線置1
             SDA=0;        //如果欲寫入數(shù)據(jù)為0,就將數(shù)據(jù)線寫0
         SCL=1;            //時(shí)鐘線做一個(gè)上升沿,將一位數(shù)據(jù)寫入
         Buf1=Buf1<<1;     //數(shù)據(jù)左移一位,將下次要寫入的位數(shù)據(jù)移到最高位
         SCL=0;            //將SCL=0,以準(zhǔn)備通過上升沿將數(shù)據(jù)寫入
     SDA=1;                //將SDA=1,準(zhǔn)備讀應(yīng)答信號(hào)
     SCL=1;                //將SCL=1,做個(gè)上升沿準(zhǔn)備讀應(yīng)答信號(hào)
     SCL=0;                //將SCL=0,結(jié)束應(yīng)答信號(hào)讀操作
//名稱:從IIC總線讀入1個(gè)字節(jié)函數(shù)
unsigned char Read1Byte(void)
     unsigned char k;      //1個(gè)字節(jié)要分8次讀出,需要定義一個(gè)寄存器用來計(jì)數(shù)
     unsigned char t=0;    //定義一個(gè)寄存器用保存讀出數(shù)據(jù)
     for(k=0;k<8;k++)      //做一個(gè)8次的循環(huán),每次讀入1位,需要讀8次
         t=t<<1;           //數(shù)據(jù)左移一位,空出最低位以準(zhǔn)備保存讀入的一位數(shù)據(jù)
         SDA=1;            //將SDA寫1準(zhǔn)備讀
         SCL=1;            //將SCL=1,做個(gè)上升沿準(zhǔn)備讀一位數(shù)據(jù)
         if(SDA==1)        //讀一位數(shù)據(jù),并判斷
             t=t|0x01;     //如果讀入數(shù)據(jù)為1,就將接收緩沖區(qū)最低一位置1
             t=t&0xfe;     //如果讀入數(shù)據(jù)為0,就將接收緩沖區(qū)最低一位寫0
         SCL=0;            //SCL恢復(fù)為0,結(jié)束一位數(shù)據(jù)讀操作
     return t;             //將讀入的一個(gè)字節(jié)返回
//名稱:軟件模擬IIC向PCF8591指定地址寫一個(gè)字節(jié)函數(shù)
void WritePCF8591(unsigned char Databuf)
{                          //直接調(diào)用本函數(shù)即可啟動(dòng)PCF8591的D/A轉(zhuǎn)換
    IICstart();            //IIC啟動(dòng)信號(hào)
    Write1Byte(0x90);      //發(fā)送PCF8591的器件地址和寫信號(hào)
    Write1Byte(0x40);      //發(fā)送器件子地址
    Write1Byte(Databuf);   //發(fā)送數(shù)據(jù)
    IICstop();             //產(chǎn)生IIC停止信號(hào)
//名稱:軟件模擬IIC從PCF8563指定地址讀一個(gè)字節(jié)函數(shù)
unsigned ReadPCF8591(unsigned char Ch)
{                          //直接調(diào)用本函數(shù)即可從PCF8591的Ch通道讀出數(shù)據(jù)返回
    unsigned char buf;     //定義一個(gè)寄存器用來暫存讀出的數(shù)據(jù)
    Write1Byte(0x40|Ch);   //發(fā)送器件通道參數(shù)Ch=0-3
    Write1Byte(0x91);      //發(fā)送PCF8591的器件地址和讀信號(hào)
    buf=Read1Byte();//讀一個(gè)字節(jié)數(shù)據(jù)
    return(buf);           //將讀出數(shù)據(jù)返回
/*********************************1602數(shù)據(jù)顯示函數(shù)88*********************************/
void dis_guangzhao(uchar t)
    uchar i;
    t=t*100/255;
    i=t/100;
          write_com(0x80+0x07);           //顯示光照百位
        write_data(table[i]);
    i=t%100/10;
    write_com(0x80+0x08);           //顯示光照十位
    i=t%100%10;
        write_com(0x80+0x09);           //顯示光照個(gè)位
             主函數(shù)
        unsigned char b=255;
    unsigned char a;
    init();
    init_1602();
        delay(1000);
        delay(1000);
                delay(1000);
                ADbuf1=ReadPCF8591(0);     //將AIN0通道A/D轉(zhuǎn)換結(jié)果暫存在ADbuf
                 dis_guangzhao(b-ADbuf1);
                delay(1000);
                delay(1000); //延時(shí)等待
                a=b-ADbuf1;
                 if(a>=80)
                //init();
                delay(1000);
                TR0=1;
        EA=1;
            ET0=1;
                hour1=hour/10;
        hour2=hour%10;
        min1=min/10;
        min2=min%10;
        sec1=sec/10;
        sec2=sec%10;
        display(hour1,hour2,min1,min2,sec1,sec2);  //一直顯示時(shí)鐘
ID:291819 發(fā)表于 2018-5-21 19:12 | 只看該作者
求大神幫忙看看
