- //函數(shù)名稱:ADC1_Mode_Config(void)
- //功能描述:配置ADC1的工作模式為MDA模式
- //輸入:無
- //輸出:無
- void ADC1_Mode_Config(void)
- DMA_InitTypeDef DMA_InitStructure;
- ADC_InitTypeDef ADC_InitStructure;
- /* DMA channel1 configuration */
- DMA_DeInit(DMA1_Channel1);
- DMA_InitStructure.DMA_PeripheralBaseAddr = ADC1_DR_Address; //ADC地址
- DMA_InitStructure.DMA_MemoryBaseAddr = (u32)&ADC_ConvertedValue; //內(nèi)存地址 ADC_ConvertedValue[15]一個數(shù)組
- DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
- DMA_InitStructure.DMA_BufferSize = 15;
- DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable; //外設(shè)地址固定
- DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable; //內(nèi)存地址自加
- DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord; //半字
- DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
- DMA_InitStructure.DMA_Mode = DMA_Mode_Circular; //循環(huán)傳輸
- DMA_InitStructure.DMA_Priority = DMA_Priority_High;
- DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
- DMA_Init(DMA1_Channel1, &DMA_InitStructure);
- /* Enable DMA channel1 */
- DMA_Cmd(DMA1_Channel1, ENABLE);
- DMA_ITConfig(DMA1_Channel1,DMA_IT_TC,ENABLE); //傳輸結(jié)束中斷
- /* ADC1 configuration */
- ADC_InitStructure.ADC_Mode = ADC_Mode_Independent; //獨(dú)立ADC模式
- ADC_InitStructure.ADC_ScanConvMode = DISABLE ; //禁止掃描模式,掃描模式用于多通道采集
- ADC_InitStructure.ADC_ContinuousConvMode = ENABLE; //開啟連續(xù)轉(zhuǎn)換模式,即不停地進(jìn)行ADC轉(zhuǎn)換
- ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None; //不使用外部觸發(fā)轉(zhuǎn)換
- ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right; //采集數(shù)據(jù)右對齊
- ADC_InitStructure.ADC_NbrOfChannel = 1; //要轉(zhuǎn)換的通道數(shù)目1
- ADC_Init(ADC1, &ADC_InitStructure);
- /*配置ADC時(shí)鐘,為PCLK2的8分頻,即9MHz*/
- RCC_ADCCLKConfig(RCC_PCLK2_Div8);
- /*配置ADC1的通道11為55. 5個采樣周期,序列為1 */
- ADC_RegularChannelConfig(ADC1, ADC_Channel_8, 1, ADC_SampleTime_55Cycles5);
- /* Enable ADC1 DMA */
- ADC_DMACmd(ADC1, ENABLE);
- /* Enable ADC1 */
- ADC_Cmd(ADC1, ENABLE);
- /*復(fù)位校準(zhǔn)寄存器 */
- ADC_ResetCalibration(ADC1);
- /*等待校準(zhǔn)寄存器復(fù)位完成 */
- while(ADC_GetResetCalibrationStatus(ADC1));
- /* ADC校準(zhǔn) */
- ADC_StartCalibration(ADC1);
- /* 等待校準(zhǔn)完成*/
- while(ADC_GetCalibrationStatus(ADC1));
- /* 由于沒有采用外部觸發(fā),所以使用軟件觸發(fā)ADC轉(zhuǎn)換 */
- ADC_SoftwareStartConvCmd(ADC1, ENABLE);
- //函數(shù)名稱:DMA1_Channel1_IRQHandler
- //功能描述:DMA中斷 對AD采集值平均濾波
- //輸入:無
- //輸出:無
- void DMA1_Channel1_IRQHandler(void)
- BYTE i;
- WORD ADC_ConvertedValue_TEMP=0;
- for(i=0;i<15;i++)
- ADC_ConvertedValue_TEMP += ADC_ConvertedValue; } ADC_ConvertedValue_average = ADC_ConvertedValue_TEMP/15; //全局變量ADC_ConvertedValue_average DMA_ClearITPendingBit(DMA1_IT_TC1); DMA_ClearFlag(DMA1_FLAG_TC1);}
- //============================================//函數(shù)名稱:void GPIO_Configuration(void)//功能描述:ADC引腳配置//輸入:無//輸出:無//============================================void GPIO_Configuration(void){ GPIO_InitTypeDef GPIO_InitStructure; //=======================ADC通道配置======================== GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN; GPIO_Init(GPIOB, &GPIO_InitStructure); // PB0,輸入時(shí)不用設(shè)置速率}
- //============================================//函數(shù)名稱:void NVIC_Configuration(void)//功能描述:中斷配置//輸入:無//輸出:無//============================================void NVIC_Configuration(void){ NVIC_InitTypeDef NVIC_InitStructure; /* Configure the NVIC Preemption Priority Bits */ NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0); NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0; NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
- NVIC_InitStructure.NVIC_IRQChannel = DMA1_Channel1_IRQn; NVIC_Init(&NVIC_InitStructure); }
