查看: 1806|回復(fù): 0
單片機交通燈怎么把時間加到一起?
ID:305452 發(fā)表于 2018-5-8 20:34 | 顯示全部樓層 |閱讀模式
怎么把時間加到一起?
  1. #include<reg51.h>
  3. #define uint unsigned int
  4. sbit dula=P2^6;
  5. sbit wela=P2^7;
  6. sbit r1=P1^0;
  7. sbit g1=P1^2;
  8. sbit y1=P1^1;
  9. sbit r2=P1^4;
  10. sbit g2=P1^6;
  11. sbit y2=P1^5;
  12. uchar time,num,deng,deng1;
  13. uchar code wei[]={0xfe,0xfd,0xbf,0x7f};
  14. uchar code duan[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
  15. uchar dis[4]={0,0,0,0};
  16. void convert();
  17. void display();
  18. void close();
  19. void delay(unsigned int x)
  20. {
  21.         uchar m,k;
  22.   for(m=x;m>0;m--)
  23.     for(k=125;k>0;k--);
  24. }
  25. void close()
  26. {
  27.    uchar i;
  28.          for(i=0;i<4;i++)
  29.           {
  30.                         P0=wei[i];
  31.                         wela=1;wela=0;
  32.                         P0=0xff;
  33.                         P0=duan[dis[i]];
  34.                         dula=1;dula=0;
  35.                         delay(20);
  36.
  37.                 }
  38. }
  39. void main()
  40. {
  41.         TMOD=0x01;
  42.         TR0=1;
  43.         TH0=(65536-46080)/256;
  44.         TL0=(65536-46080)%256;
  45.         EA=1;
  46.         ET0=1;
  47.         while(1)
  48.         {
  49.                 close();
  50.                 convert();
  51.                 display();
  52.         }
  53. }
  54. void convert()
  55. {
  56.         dis[0]=time/10;
  57.         dis[1]=time%10;
  58.         dis[2]=time/10;
  59.         dis[3]=time%10;¡¤¡¤
  60. }
  61. void time0() interrupt 1
  62. {
  63.         TH0=(65536-46080)/256;
  64.         TL0=(65536-46080)%256;
  65.         num++;
  66.         if(num==20)
  67.                 {
  68.                         num=0;
  69.                         time--;
  70.
  71.                 }
  72. }
  73. void display()
  74. {
  75.                 if(time==0xff)
  76.                 {
  77.
  78.                         deng++;
  79.                         if(deng==4)
  80.                         deng=0;
  81.                         switch(deng)
  82.                         {
  83.                                 case 0: time=10;
  84.                                 r2=0;g2=1;y2=1;
  85.                                 r1=1;g1=0;y1=1;
  86.              break;
  87.                                 case 1: time=3;
  88.                                 r2=0;g2=1;y2=1;
  89.                                 r1=1;g1=1;y1=0;
  90.                                                 break;
  91.                                 case 2: time=10;
  92.                                 r2=1;g2=0;y2=1;
  93.                                 r1=0;g1=1;y1=1;
  94.                                                 break;
  95.                                 case 3: time=3;
  96.                                 r2=1;g2=1;y2=0;
  97.                                 r1=0;g1=1;y1=1;
  98.                                                 break;
  99.                         }
  100.                 }
  101.         }
仿真的時候看的好難受、
