查看: 6583|回復(fù): 4
16X16的LED點陣屏可實現(xiàn)左移,右移、單片機(jī)源碼及仿真圖等資料
ID:326016 發(fā)表于 2018-5-9 16:58 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg51.h>//頭文件
sbit shcp=P1^2;//數(shù)據(jù)輸入時鐘線 59511
sbit stcp=P1^1;//輸出存儲器鎖存時鐘線 59512
sbit ds=P1^0;//數(shù)據(jù)線  59514
sbit s1=P3^1;//按下暫停再暫按繼續(xù)
sbit s2=P3^2;//按下方向取反
bit fx;//方向切換
unsigned char alt;//數(shù)據(jù)移動定時時間
unsigned int net;//控制顯示的字符
unsigned char zi=8;
unsigned int zong;//總字符  (所有的字?jǐn)?shù)+1*32   字?jǐn)?shù)指的是漢字,字母、數(shù)字兩個算一個數(shù)字
unsigned char code tab[]={
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
//(0) (1) (2) (3) (4) (5) (6) !(7)
0x04,0x08,0x04,0x10,0x24,0x20,0x24,0x40,0x24,0xFC,0x24,0xA2,0xFD,0x22,0x26,0x22,
0x24,0x42,0x2C,0x42,0x14,0x42,0x24,0x82,0x44,0x1E,0x04,0x00,0x04,0x00,0x00,0x00,/*"",0*/
0x00,0x00,0x3F,0xE1,0x00,0x02,0x00,0x0C,0xFF,0xF0,0x00,0x00,0x40,0x00,0x47,0xF8,
0x44,0x00,0x44,0x00,0x7F,0xFF,0x44,0x10,0x44,0x08,0x47,0xF0,0x40,0x00,0x00,0x00,/*"",1*/
0x00,0x00,0x00,0x00,0x00,0x1A,0x00,0x1C,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*",",2*/
0x04,0x02,0x08,0x0C,0x10,0x00,0x3F,0xEE,0xC4,0x01,0x08,0x81,0x11,0x11,0xE6,0x4D,
0x20,0x21,0x2F,0xC1,0x20,0x01,0x24,0x07,0x2A,0x00,0x31,0x88,0x00,0x06,0x00,0x00,/*"",3*/
0x02,0x00,0x02,0x20,0x22,0x20,0x22,0x20,0x2A,0x20,0x26,0x20,0xA2,0x20,0x63,0xFF,
0x22,0x20,0x26,0x20,0x2A,0x20,0x22,0x20,0x22,0x20,0x02,0x20,0x02,0x00,0x00,0x00,/*"",4*/
0x21,0x00,0x21,0x00,0x21,0x00,0x21,0x3F,0xF9,0x22,0x21,0x22,0x21,0x22,0x2F,0xE2,
0x21,0x22,0x21,0x22,0xF9,0x22,0x21,0x3F,0x21,0x00,0x21,0x00,0x21,0x00,0x00,0x00,/*"",5*/
0x00,0x00,0x40,0x00,0x40,0x00,0x40,0x00,0x40,0x00,0x40,0x02,0x40,0x01,0x47,0xFE,
0x44,0x00,0x48,0x00,0x50,0x00,0x60,0x00,0x40,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*"",6*/
0x00,0x00,0x00,0x00,0x00,0x00,0x7F,0xCC,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*"!",7*/
unsigned char code tab1[]={
//(0) (1) ,(2) (3) (4) (5) (6) (7)
void delay(unsigned int z)//延時子函數(shù)
   unsigned char x;
   for(;z>0;z--)
   for(x=110;x>0;x--);
void writedata(unsigned char dat1,unsigned char dat2)         //595顯示子函數(shù)
        unsigned char i;
        //CY存儲移位之后的數(shù)據(jù)  CY進(jìn)位標(biāo)志位,單片機(jī)內(nèi)部的寄存器   移位之后的數(shù)據(jù)就存在CY里面
        for(i=0;i<8;i++)//循環(huán)八次
                dat1=dat1<<1;//數(shù)據(jù)左移
                ds=CY;//數(shù)據(jù)發(fā)送
                shcp=1;//上升沿發(fā)生移位
                shcp=0;
                dat2=dat2<<1;//數(shù)據(jù)左移
                shcp=0;
        stcp=0;
        stcp=1;//上升沿將數(shù)據(jù)送到輸出鎖存器
        stcp=0;
void main()         //主函數(shù)
        char i,aa;
        TMOD=0x01;//定時器0  模式1  16位定時模式
        TH0=(65536-10000)/256;//定時10.000ms
        TL0=(65536-10000)%256;
        ET0=1;//使能定時器0
        EA=1;//開啟總中斷
        TR0=1;//開始計數(shù)
        zong=(zi+1)*32;
        while(1)         //無限循環(huán)
                if(s1==0)//檢測按鍵
                        delay(30);//延時消除按鍵抖動
                        if(s1==0)
                                TR0=~TR0;//按下暫停  暫按繼續(xù)
                                while(s1==0);//等待按鍵松手
                if(s2==0)//檢測按鍵
                        if(s2==0)
                                fx=~fx;//方向取反
                                aa=0;
                                if(fx==0)net=0;//正向移動
                                if(fx==1)net=zong;//反向移動
                                while(s2==0);//等待按鍵松手
                for(i=0;i<16;i++)//循環(huán)移位
                        //兩片138組成的4-16線譯碼器
                        P2=i;//列數(shù)據(jù)驅(qū)動,138的驅(qū)動端口
                        if(fx==0)writedata(tab[net+aa],tab[net+aa+1]);//顯示數(shù)據(jù)的數(shù)字位置
                        if(fx==1)writedata(tab1[net+aa],tab1[net+aa+1]);//顯示數(shù)據(jù)的數(shù)字位置
                        delay(3);//延時
                        writedata(0,0);//清屏
                        aa+=2;//數(shù)據(jù)加 實現(xiàn)掃描
                        if(aa>30)aa=0;//循環(huán)16次 清零
void timer0() interrupt 1
        TH0=(65536-10000)/256;//10.000ms   進(jìn)入一次中斷
        alt++;
        if(alt==10)//100.000ms時間加以實現(xiàn)移動
                alt=0;
                if(fx==0)//正向移動
                        net=net+2;        //每次送兩個編碼數(shù)據(jù)
                        if(net>zong)//達(dá)到總字符
                        net=0;//數(shù)據(jù)清零
                else//否則反向移動
                        net=net-2;//每次送兩個編碼數(shù)據(jù)
                        if(net<2)//數(shù)據(jù)完畢
                        net=zong;//回到總字符
1程序 老師 您辛苦了.zip
69.24 KB, 下載次數(shù): 109, 下載積分: 黑幣 -5
源碼
admin + 50 共享資料的黑幣獎勵!
收藏收藏4 分享淘帖 頂1 踩
ID:352628 發(fā)表于 2018-7-19 17:56 | 只看該作者
仿真呢?
ID:378732 發(fā)表于 2018-9-19 16:05 | 只看該作者
學(xué)習(xí)下下。。
ID:241596 發(fā)表于 2018-12-22 12:49 | 只看該作者
無仿真與電路原理圖
ID:443646 發(fā)表于 2019-1-4 16:09 | 只看該作者
仿真硬件圖有沒有
