這是主要程序: 按指定位置顯示一個(gè)字符,怎樣修改才能 顯示正常數(shù)字 - //寫數(shù)據(jù)
- void WriteDataLCD(unsigned char WDLCD)
- ReadStatusLCD(); //檢測忙
- LCD_RS = 1;
- LCD_RW = 0;
- LCD_Data = WDLCD;
- LCD_E = 1;
- LCD_E = 1;
- LCD_E = 1;
- LCD_E = 0;
- //寫指令
- void WriteCommandLCD(unsigned char WCLCD,BuysC) //BuysC為0時(shí)忽略忙檢測
- if (BuysC) ReadStatusLCD(); //根據(jù)需要檢測忙
- LCD_RS = 0;
- LCD_RW = 0;
- LCD_Data = WCLCD;
- LCD_E = 1;
- LCD_E = 1;
- LCD_E = 1;
- LCD_E = 0;
- //讀數(shù)據(jù)
- unsigned char ReadDataLCD(void)
- LCD_RS = 1;
- LCD_RW = 1;
- LCD_E = 0;
- LCD_E = 0;
- LCD_E = 1;
- return(LCD_Data);
- //讀狀態(tài)
- unsigned char ReadStatusLCD(void)
- LCD_Data = 0xFF;
- LCD_RS = 0;
- LCD_RW = 1;
- LCD_E = 1;
- while (LCD_Data & Busy); //檢測忙信號
- LCD_E = 0;
- return(LCD_Data);
- void LCDInit(void) //LCM初始化
- WriteCommandLCD(0x30,1); //顯示模式設(shè)置,開始要求每次檢測忙信號
- WriteCommandLCD(0x01,1); //顯示清屏
- WriteCommandLCD(0x06,1); // 顯示光標(biāo)移動(dòng)設(shè)置
- WriteCommandLCD(0x0C,1); // 顯示開及光標(biāo)設(shè)置
- void LCDClear(void) //清屏
- WriteCommandLCD(0x34,1); // 顯示光標(biāo)移動(dòng)設(shè)置
- WriteCommandLCD(0x30,1); // 顯示開及光標(biāo)設(shè)置
- //按指定位置顯示一個(gè)字符
- void DisplayOneChar(unsigned char X, unsigned char Y, unsigned char DData)
- if(Y<1)
- Y=1;
- if(Y>4)
- Y=4;
- X &= 0x0F; //限制X不能大于16,Y不能大于1
- switch(Y){
- case 1:X|=0X80;break;
- case 2:X|=0X90;break;
- case 3:X|=0X88;break;
- case 4:X|=0X98;break;
- WriteCommandLCD(X, 0); //這里不檢測忙信號,發(fā)送地址碼
- WriteDataLCD(DData);
