查看: 3135|回復(fù): 0
arduino_Uno_RevG-MU PCB板源文件
ID:326650 發(fā)表于 2018-5-10 11:09 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
arduino PCB板
DesignSpark PCB Reference Design
Arduino UNO SMD (RS Part Number: 769-7409)
This  is a  reference design of Arduino UNO SMD. The Arduino UNO SMD was
converted  into  DesignSpark  PCB  format.  Download  link  of  the  project  files
and introduction of Arduino UNO SMD could be found in this datasheet.
The Arduino Uno  is a microcontroller board based on  the ATmega328.  It
contains  everything  needed  to  support  the  microcontroller;  simply
connect  it  to a computer with a USB cable or power  it with a AC-to-DC
adapter  or  battery  to  get  started.  The  Uno  differs  from  all  preceding
boards in that it does not use the FTDI USB-to-serial driver chip. Instead,
it  features  the  Atmega8U2  programmed  as  a  USB-to-serial  converter.
Two versions are available differing only  in  the MCU package style: DIP
or SMD. The Rev3 part has some minor pin changes.
  ATmega328 16MHz, 32KB Flash memory, 2KB
  SPI and IC bus support
  USB connector
  ICSP header
  Reset button
全部資料51hei下載地址:
1412855329103049.zip (790.38 KB, 下載次數(shù): 11)
