一款以INTEL公司出品的80C51單片機(jī)為核心的自動(dòng)售貨。以80C51作為CPU處理單元連接各個(gè)功能模塊;以4*4矩陣鍵盤(pán)作為輸入控制模塊對(duì)貨物進(jìn)行種類(lèi)和數(shù)量的選擇以及模擬貨幣的投入功能;以LCD1602液晶作為顯示模塊來(lái)顯示當(dāng)前的購(gòu)物狀態(tài)以及貨幣狀態(tài);以LED的顯示來(lái)表示當(dāng)前選擇貨物以及出貨的狀態(tài)。通過(guò)Protues7.5單片機(jī)電路原理圖進(jìn)行連接布線連接各個(gè)模塊;再用Keil uVision3專(zhuān)業(yè)編譯軟件完成源程序編譯和調(diào)。
自動(dòng)售貨機(jī)的仿真原理圖如下(proteus仿真工程文件可到本帖附件中下載)
自動(dòng)售貨機(jī)的單片機(jī)源程序如下:
- #include<reg51.h>
- /*******************define*************************/
- #define WAIT_SALE 0 //定義1602顯示狀態(tài)
- #define NO_WATER 1
- #define INPUT_MONEY 2
- #define SALING 3
- #define CHANGE 4
- #define CANCLE 5
- #define NO_DATA 0
- #define water_change(x, y) ((x) & (~(0x01 << y))) //宏 控制水種類(lèi)的切換
- #define uint unsigned int
- #define uchar unsigned char
- unsigned char water_total[] = {10, 10, 10, 10, 10, 10, 10, 10};
- unsigned char water_price[] = {1, 2, 3, 4, 5, 6, 7, 8};
- uchar code wait_sale[]="for sale"; //定義所顯示的內(nèi)容
- uchar code no_water[] = "no water!";
- uchar code price[] = "price:";
- uchar code number[] = "num:";
- uchar code sum[] = "SUM:";
- uchar code input[] = "INPUT:";
- uchar code change[] = "change:";
- uchar code put_water[] = "put water...";
- uchar code cancle[] = "cancle...";
- unsigned char e=0x00;
- sbit P2_0=P2^0; //定義接端口
- sbit P2_1=P2^1;
- sbit P2_2=P2^2;
- sbit P2_3=P2^3;
- sbit lcd_en=P3^4;
- sbit rs=P3^2;
- sbit rw = P3^3;
- /***********************function**********************************/
- /************lcd 1602*************************/
- void lcd_1602_delay(uint z) //延時(shí)
- uint x,y;
- for(x=z;x>0;x--)
- for(y=110;y>0;y--);
- void lcd_1602_write_com(uchar com) //寫(xiě)命令
- rs=0;
- rw=0;
- P2=com;
- lcd_1602_delay(5);
- lcd_en=1;
- lcd_en=0;
- void lcd_1602_write_data(uchar date) //寫(xiě)數(shù)據(jù)
- rs=1;
- rw=0;
- P2=date;
- lcd_en=1;
- lcd_en=0;
- void lcd_1602_init() //LCD1602初始化函數(shù)
- lcd_en=0;
- lcd_1602_write_com(0x38);
- lcd_1602_write_com(0x0e);
- lcd_1602_write_com(0x06);
- lcd_1602_write_com(0x01);
- void lcd_1602_wait_sure() //顯示'OK'&'NO'界面
- lcd_1602_write_com(0x80+0x40);
- lcd_1602_write_data('O');
- lcd_1602_write_data('K');
- lcd_1602_write_com(0x80+0x4e);
- lcd_1602_write_data('N');
- void lcd_1602_show_num(uint num) // 1602顯示數(shù)字的函數(shù)
- if(num <= 9)
- lcd_1602_write_data('0'+num);
- lcd_1602_write_data(' ');
- }else if(num >= 10 )
- lcd_1602_write_data('0'+num/10);
- lcd_1602_write_data('0'+num%10);
- void lcd1602_info_display(uint choose, uint num_type, uint num_count) //1602顯示函數(shù)
- int num;
- switch(choose)
- case WAIT_SALE:
- lcd_1602_write_com(0x80+0x03); //
- for(num = 0; num < 8; num++)
- lcd_1602_write_data(wait_sale[num]);
- break;
- case NO_WATER:
- for(num = 0; num < 9; num++)
- lcd_1602_write_data(no_water[num]);
- break;
- case SALING:
- //price
- lcd_1602_write_com(0x80+0x00);
- for(num = 0; num < 6; num++)
- lcd_1602_write_data(price[num]);
- lcd_1602_write_data('0'+(num_type+1));
- //number
- for(num = 0; num < 4; num++)
- lcd_1602_write_data(number[num]);
- lcd_1602_show_num(num_count);
- break;
- case INPUT_MONEY:
- //need money
- lcd_1602_write_data(sum[num]);
- lcd_1602_show_num(num_type);
- //input
- lcd_1602_write_data(input[num]);
- break;
- case CHANGE:
- if(!num_count)
- //put water
- lcd_1602_write_com(0x80+0x02);
- for(num = 0; num < 13; num++)
- lcd_1602_write_data(put_water[num]);
- else
- //cancle water
- lcd_1602_write_com(0x80+0x02); //取消選擇時(shí)寫(xiě)命令退幣
- lcd_1602_write_data(cancle[num]);
- //change
- lcd_1602_write_com(0x80+0x43);
- for(num = 0; num < 7; num++)
- lcd_1602_write_data(change[num]);
- break;
- default:
- break;
- lcd_1602_write_com(0x0c);
- void lcd_1602_saling(uint type, uint num)
- lcd1602_info_display(SALING, type, num);
- lcd_1602_wait_sure();
- void lcd_1602_inputing(uint need, uint input)
- lcd1602_info_display(INPUT_MONEY, need, input);
- void delay1(unsigned int t) // 延時(shí)函數(shù)
- unsigned int i,j;
- for(i=0;i<t;i++)
- for(j=0;j<10;j++);
- void out_water() //推出水函數(shù)
- int i, j = 100;
- while(j--)
- for(i = 0; i < 8; i++)
- P0 = water_change(0xff, i);
- delay1(50);
- P0 = 0xff;
- unsigned char key(void) //按鍵響應(yīng)函數(shù)
- unsigned char key,key1,key2;
- P1=0XF0;
- if((P1&0XF0)!=0XF0) //ked down
- delay1(10); //延時(shí)去抖動(dòng)
- if((P1&0XF0)!=0XF0) //仍然有鍵按下
- key1=P1&0XF0; //讀入列線值
- P1=0X0F;
- key2=P1&0X0F;
- key=key1|key2;
- switch(key) //按鍵映射
- case 0xee: e=0x00;break;
- case 0xde: e=0x01;break;
- case 0xbe: e=0x02;break;
- case 0x7e: e=0x03; break;
- case 0xed: e=0x04;break;
- case 0xdd: e=0x05;break;
- case 0xbd: e=0x06;break;
- case 0x7d: e=0x07; break;
- case 0xeb: e=0x08;break;
- case 0xdb: e=0x09;break;
- case 0xbb: e=0x0a;break;
- case 0x7b: e=0x0b; break;
- case 0xe7: e=0x0c;break;
- case 0xd7: e=0x0d;break;
- case 0xb7: e=0x0e;break;
- case 0x77: e=0x0f; break;
- while((P1&0X0F)!=0X0F);
- delay1(10);
- return 1;
- return 0;
- /*****************main********************************/
- void main()
- unsigned char ok = 0, water_type = -1, water_is_choose = 0;
- char water_count = 0;
- unsigned int flag = 0, money = 0, need_money;
- lcd_1602_init();
- again:
- ok = 0; water_type = -1; water_count = 0; water_is_choose = 0;
- flag = 0; money = 0; need_money = 0;
- lcd1602_info_display(WAIT_SALE, 0, 0);
- while(!ok) //choose the water and count
- flag=key();
- if(flag)
- switch(e) //不同的按鍵進(jìn)行不同的操作
- case(0x00):
- water_type++;
- water_is_choose = 1;
- if(water_type == 8)
- water_type = 0;
- P0 = water_change(0xff, water_type);
- break;
- case(0x01):
- water_type--;
- if(water_type == -1 || water_type == -2)
- water_type = 7;
- break;
- case(0x02):
- if(water_is_choose == 1)
- water_count++;
- if(water_count > water_total[water_type])
- water_count = water_total[water_type];
- break;
- case(0x03):
- water_count--;
- if(water_count < 0)
- water_count = 0;
- break;
- case(0x0e): // 返回
- goto again;
- break;
- case(0x0f): // 確認(rèn)
- ok=1;
- break;
- default:
- break;
- lcd_1602_saling(water_type, water_count);
- //choose ok: calculate the money //計(jì)算錢(qián)的總數(shù)
- need_money = water_count * water_price[water_type];
- lcd_1602_inputing(need_money, money);
- ok = 0;
- while(!ok) //get money
- flag=key();
- if(flag)
- switch(e)
- case(0x04):
- money=money+1;
- break;
- case(0x05):
- money=money+5;
- break;
- case(0x06):
- money=money+10;
- break;
- case(0x07):
- money=money+20;
- break;
- case(0x08):
- money=money+50;
- break;
- case(0x09):
- money=money+100;
- break;
- case(0x0e): //back lcd1602_info_display(CHANGE, money, CANCLE);
- P0 = 0xff;
- delay1(50000);
所有資料51hei提供下載(論文+仿真+源碼):
售貨機(jī).zip
(809.39 KB, 下載次數(shù): 802)
2018-5-11 10:25 上傳
點(diǎn)擊文件名下載附件
