查看: 2904|回復: 1
基于AT89S52單片機的兩位數碼管99秒計時器,帶矩陣鍵盤
ID:322996 發(fā)表于 2018-5-11 20:48 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
代碼簡單易懂,適合初學矩陣鍵盤和數碼管的同學
代碼:
C51 Code
C++ Code
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
#include <AT89X52.H>
#include "KEY44.H"
#include "7SEG.H"
bit Flag;
sbit LED = P3 ^ 0;
unsigned char time;
unsigned char NTime;
void timer_init(void)
    TMOD = 0x01;
    TH0 = (65536 - 10000) / 256;
    TL0 = (65536 - 10000) % 256;
    ET0 = 1;
    EA = 1;
    TR0 = 1;
void time_Stop(void)
    TMOD = 0x00;
    TH0 = 0;
    TL0 = 0;
    ET0 = 0;
    EA = 0;
    TR0 = 0;
void main(void)
    NTime = 0;
        unsigned char key = Matrix_keyboard();
        if(key == 1)
            timer_init();
            LED = 1;
        if(key == 2)
            time_Stop();
            Flag = 0;
            NTime = 0;
            LED = 0;
        if (Flag == 1)
            Flag = 0;
            Seg_Show(NTime);
            NTime += 1;
            if(NTime == 99 + 1)
                NTime = 0;
void t_0(void) interrupt 1 using 0
    TR0 = 0;
    time++;
    if(time == 100)
        time = 0;
        Flag = 1;
    TR0 = 1;
    File:   7SEG.h
    Date:Loser007       May 5, 2018 18:04
#ifndef __7SEG_H__
#define __7SEG_H__
#pragma SAVE
#pragma REGPARMS
extern void Seg_Show(unsigned char Time);
unsigned char code seg_cc[] =  //Common cathode digital tube segment code
    0x3F,   //0
    0x06,   //1
    0x5B,   //2
    0x4F,   //3
    0x66,   //4
    0x6D,   //5
    0x7D,   //6
    0x07,   //7
    0x7F,   //8
    0x6F,   //9
    0x77,   //A
    0x7C,   //B
    0x39,   //C
    0x5E,   //D
    0x79,   //E
    0x71,   //F
    Features:   Show time in 2 SEG
    Parameter: No
    Return: N0
    Instructions:SEG I/0 From P1^0 to P1^7 & P2^0 to P2^7
    Date:Loser007       May 5, 2018 10:40
    P0 = seg_cc[Time / 10];
    P2 = seg_cc[Time % 10];
#endif
    File:   key44.h
    Date:Loser007       May 5, 2018 12:59
#ifndef __KEY44_H__
#define __KEY44_H__
#pragma SAVE
#pragma REGPARMS
extern char Matrix_keyboard(void);
    Features:   Get a case from the 4*4 keyboard
    Parameter: No
    Return:Key code (char)
    Instructions:Keyboard I/0 From P1^0 to P1^7
    unsigned char Key = 0, X = 0, Y = 0;
    P1 = 0xF0;  //11110000
    X = P1 & 0xF0;  //Get row   (P1 XOR 11110000) Get Height
    if(X != 0xF0)
        X = P1 ^ 0xF0;
        P1 = 0x0F;  //00001111
        Y = P1 & 0x0F;
        if(Y != 0x0F)
            Y = P1 ^ 0x0F;  //Get Column    (P1 XOR 00001111) Get Low
            Key = X + Y;
    switch (Key)
    // 1
    case 0x81:
        return 0;   //1000 0001
    case 0x82:
        return 1;   //1000 0010
    case 0x84:
        return 2;   //1000 0100
    case 0x88:
        return 3;   //1000 1000
    // 2
    case 0x41:
        return 4;   //0100 0001
    case 0x42:
        return 5;   //0100 0010
    case 0x44:
        return 6;   //0100 0100
    case 0x48:
        return 7;   //0100 1000
    // 3
    case 0x21:
        return 8;   //0010 0001
    case 0x22:
        return 9;   //0010 0010
    case 0x24:
        return 10;  //0010 0100
    case 0x28:
        return 11;  //0010 1000
    //4
    case 0x11:
        return 12;  //0001 0001
    case 0x12:
        return 13;  //0001 0010
    case 0x14:
        return 14;  //0001 0100
    case 0x18:
        return 15;  //0001 1000
    default:
        return 255;
#endif
計時器.rar
20.18 KB, 下載次數: 26, 下載積分: 黑幣 -5
代碼,庫,仿真
參與人數 1黑幣 +50 收起 理由
admin + 50 共享資料的黑幣獎勵!
ID:450668 發(fā)表于 2019-1-3 09:40 | 只看該作者
為什么解壓之后仿真圖沒有啊
Powered by 單片機教程網
