協(xié)議棧單播_串口
2018-5-13 00:03 上傳
- Filename: OSAL_Nv.c
- Revised: $Date: 2008-08-06 17:17:11 -0700 (Wed, 06 Aug 2008) $
- Revision: $Revision: 17715 $
- Description: This module contains the OSAL non-volatile memory functions.
- Copyright 2006-2009 Texas Instruments Incorporated. All rights reserved.
- IMPORTANT: Your use of this Software is limited to those specific rights
- granted under the terms of a software license agreement between the user
- who downloaded the software, his/her employer (which must be your employer)
- and Texas Instruments Incorporated (the "License"). You may not use this
- Software unless you agree to abide by the terms of the License. The License
- limits your use, and you acknowledge, that the Software may not be modified,
- copied or distributed unless embedded on a Texas Instruments microcontroller
- or used solely and exclusively in conjunction with a Texas Instruments radio
- frequency transceiver, which is integrated into your product. Other than for
- the foregoing purpose, you may not use, reproduce, copy, prepare derivative
- works of, modify, distribute, perform, display or sell this Software and/or
- its documentation for any purpose.
- YOU FURTHER ACKNOWLEDGE AND AGREE THAT THE SOFTWARE AND DOCUMENTATION ARE
- PROVIDED 揂S IS?WITHOUT WARRANTY OF ANY KIND, EITHER EXPRESS OR IMPLIED,
- INCLUDING WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY, TITLE,
- NON-INFRINGEMENT AND FITNESS FOR A PARTICULAR PURPOSE. IN NO EVENT SHALL
- TEXAS INSTRUMENTS OR ITS LICENSORS BE LIABLE OR OBLIGATED UNDER CONTRACT,
- NEGLIGENCE, STRICT LIABILITY, CONTRIBUTION, BREACH OF WARRANTY, OR OTHER
- LEGAL EQUITABLE THEORY ANY DIRECT OR INDIRECT DAMAGES OR EXPENSES
- INCLUDING BUT NOT LIMITED TO ANY INCIDENTAL, SPECIAL, INDIRECT, PUNITIVE
- OR CONSEQUENTIAL DAMAGES, LOST PROFITS OR LOST DATA, COST OF PROCUREMENT
- OF SUBSTITUTE GOODS, TECHNOLOGY, SERVICES, OR ANY CLAIMS BY THIRD PARTIES
- (INCLUDING BUT NOT LIMITED TO ANY DEFENSE THEREOF), OR OTHER SIMILAR COSTS.
- Should you have any questions regarding your right to use this Software,
- contact Texas Instruments Incorporated at www.TI.com.
- Notes:
- - A trick buried deep in initPage() requires that the MSB of the NV Item Id is to
- be reserved for use by this module.
- * INCLUDES
- #include "hal_adc.h"
- #include "hal_flash.h"
- #include "hal_types.h"
- #include "ZComdef.h"
- #include "OSAL_Nv.h"
- * CONSTANTS
- #define OSAL_NV_PAGE_SIZE HAL_FLASH_PAGE_SIZE
- #define OSAL_NV_PAGES_USED HAL_NV_PAGE_CNT
- #define OSAL_NV_PAGE_BEG HAL_NV_PAGE_BEG
- #define OSAL_NV_PAGE_END (OSAL_NV_PAGE_BEG + OSAL_NV_PAGES_USED - 1)
- #define OSAL_NV_ACTIVE 0x00
- #define OSAL_NV_ERASED 0xFF
- #define OSAL_NV_ERASED_ID 0xFFFF
- #define OSAL_NV_ZEROED_ID 0x0000
- // Reserve MSB of Id to signal a search for the "old" source copy (new write interrupted/failed.)
- #define OSAL_NV_SOURCE_ID 0x8000
- #define OSAL_NV_PAGE_FREE HAL_FLASH_PAGE_SIZE
- // In case pages 0-1 are ever used, define a null page value.
- #define OSAL_NV_PAGE_NULL 0
- // In case item Id 0 is ever used, define a null item value.
- #define OSAL_NV_ITEM_NULL 0
- #define OSAL_NV_WORD_SIZE HAL_FLASH_WORD_SIZE
- #define OSAL_NV_PAGE_HDR_OFFSET 0
- * MACROS
- #define OSAL_NV_CHECK_BUS_VOLTAGE (HalAdcCheckVdd( HAL_ADC_VDD_LIMIT_4 ))
- #define OSAL_NV_DATA_SIZE( LEN ) \
- ((((LEN) + OSAL_NV_WORD_SIZE - 1) / OSAL_NV_WORD_SIZE) * OSAL_NV_WORD_SIZE)
- #define OSAL_NV_ITEM_SIZE( LEN ) \
- (((((LEN) + OSAL_NV_WORD_SIZE - 1) / OSAL_NV_WORD_SIZE) * OSAL_NV_WORD_SIZE) + OSAL_NV_HDR_SIZE)
- * TYPEDEFS
- typedef struct
- uint16 id;
- uint16 len; // Enforce Flash-WORD size on len.
- uint16 chk; // Byte-wise checksum of the 'len' data bytes of the item.
- uint16 stat; // Item status.
- } osalNvHdr_t;
- // Struct member offsets.
- #define OSAL_NV_HDR_ID 0
- #define OSAL_NV_HDR_LEN 2
- #define OSAL_NV_HDR_CHK 4
- #define OSAL_NV_HDR_STAT 6
- #define OSAL_NV_HDR_ITEM 2 // Length of any item of a header struct.
- #define OSAL_NV_HDR_SIZE 8
- #define OSAL_NV_HDR_HALF (OSAL_NV_HDR_SIZE / 2)
- typedef struct
- uint16 active;
- uint16 inUse;
- uint16 xfer;
- uint16 spare;
- } osalNvPgHdr_t;
- #define OSAL_NV_PG_ACTIVE 0
- #define OSAL_NV_PG_INUSE 2
- #define OSAL_NV_PG_XFER 4
- #define OSAL_NV_PG_SPARE 6
- #define OSAL_NV_PAGE_HDR_SIZE 8
- #define OSAL_NV_PAGE_HDR_HALF (OSAL_NV_PAGE_HDR_SIZE / 2)
- typedef enum
- eNvXfer,
- eNvZero
- } eNvHdrEnum;
- typedef enum
- ePgActive,
- ePgInUse,
- ePgXfer,
- ePgSpare
- } ePgHdrEnum;
- * EXTERNAL FUNCTIONS
- extern bool HalAdcCheckVdd(uint8 limit);
- * GLOBAL VARIABLES
- #ifndef OAD_KEEP_NV_PAGES
- // When NV pages are to remain intact during OAD download,
- // the image itself should not include NV pages.
- #pragma location="ZIGNV_ADDRESS_SPACE"
- __no_init uint8 _nvBuf[OSAL_NV_PAGES_USED * OSAL_NV_PAGE_SIZE];
- #pragma required=_nvBuf
- #pragma location="IEEE_ADDRESS_SPACE"
- __no_init uint8 _nvIEEE[Z_EXTADDR_LEN];
- #pragma required=_nvIEEE
- #endif // OAD_KEEP_NV_PAGES
- * LOCAL VARIABLES
- // Offset into the page of the first available erased space.
- static uint16 pgOff[OSAL_NV_PAGES_USED];
- // Count of the bytes lost for the zeroed-out items.
- static uint16 pgLost[OSAL_NV_PAGES_USED];
- static uint8 pgRes; // Page reserved for item compacting transfer.
- // Saving ~100 code bytes to move a uint8* parameter/return value from findItem() to a global.
- static uint8 findPg;
- /* Immediately before the voltage critical operations of a page erase or
- * a word write, check bus voltage. If less than min, set global flag & abort.
- * Since this is to be done at the lowest level, many void functions would have to be changed to
- * return a value and code added to check that value before proceeding, resulting in a very
- * expensive code size hit for implementing this properly. Therefore, use this global as follows:
- * at the start of osal_nv_item_init/osal_nv_write, set to FALSE, and at the end, before returning,
- * check the value. Thus, the global is an accumulator of any error that occurred in any of the
- * attempts to modify Flash with a low bus voltage during the complicated sequence of events that
- * may occur on any item init or write. This is much more expedient and code saving than adding
- * return values and checking return values to early out. No matter which method is used, an NV
- * data record may end up mangled due to the low VCC conditions. The strategy is that the headers
- * and checksums will detect and allow recovery from such a condition.
- * One unfortunate side-effect of using the global fail flag vice adding and checking return
- * values, is that when setting an item Id to zero has failed due to the low VCC check,
- * the page lost-bytes counter is still updated. Having an artificially high lost-byte
- * count makes it look like there are more bytes to recover from compacting a page than there may
- * actually be. The easy work-around implemented is it to invoke initNV() from osal_nv_item_init or
- * osal_nv_write anytime that the failF gets set - this will re-walk all of the pages and set the
- * page offset count and page lost bytes count to their actual values.
- static uint8 failF;
- * LOCAL FUNCTIONS
- static uint8 initNV( void );
- static void setPageUse( uint8 pg, uint8 inUse );
- static uint16 initPage( uint8 pg, uint16 id, uint8 findDups );
- static void erasePage( uint8 pg );
- static void compactPage( uint8 pg );
- static uint16 findItem( uint16 id );
- static uint8 initItem( uint8 flag, uint16 id, uint16 len, void *buf );
- static void setItem( uint8 pg, uint16 offset, eNvHdrEnum stat );
- static uint16 calcChkB( uint16 len, uint8 *buf );
- static uint16 calcChkF( byte pg, uint16 offset, uint16 len );
- static void writeWord( uint8 pg, uint16 offset, uint8 *buf );
- static void writeWordH( uint8 pg, uint16 offset, uint8 *buf );
- static void writeWordM( uint8 pg, uint16 offset, uint8 *buf, uint16 cnt );
- static void writeBuf( uint8 pg, uint16 offset, uint16 len, uint8 *buf );
- static void xferBuf( uint8 srcPg, uint16 srcOff, uint8 dstPg, uint16 dstOff, uint16 len );
- static uint8 writeItem( uint8 pg, uint16 id, uint16 len, void *buf, uint8 flag );
- * @fn initNV
- * @brief Initialize the NV flash pages.
- * @param none
- * @return TRUE
- osalNvPgHdr_t pgHdr;
- uint8 oldPg = OSAL_NV_PAGE_NULL;
- uint8 newPg = OSAL_NV_PAGE_NULL;
- uint8 findDups = FALSE;
- uint8 pg;
- pgRes = OSAL_NV_PAGE_NULL;
- for ( pg = OSAL_NV_PAGE_BEG; pg <= OSAL_NV_PAGE_END; pg++ )
- HalFlashRead(pg, OSAL_NV_PAGE_HDR_OFFSET, (uint8 *)(&pgHdr), OSAL_NV_HDR_SIZE);
- if ( pgHdr.active == OSAL_NV_ERASED_ID )
- if ( pgRes == OSAL_NV_PAGE_NULL )
- pgRes = pg;
- else
- setPageUse( pg, TRUE );
- else // Page is active.
- // If the page is not yet in use, it is the tgt of items from an xfer.
- if ( pgHdr.inUse == OSAL_NV_ERASED_ID )
- newPg = pg;
- // An Xfer from this page was in progress.
- else if ( pgHdr.xfer != OSAL_NV_ERASED_ID )
- oldPg = pg;
- // Calculate page offset and lost bytes - any "old" item triggers an N^2 re-scan from start.
- if ( initPage( pg, OSAL_NV_ITEM_NULL, findDups ) != OSAL_NV_ITEM_NULL )
- findDups = TRUE;
- pg = OSAL_NV_PAGE_BEG-1;
- continue;
- } // for ( pg = OSAL_NV_PAGE_BEG; pg <= OSAL_NV_PAGE_END; pg++ )
- /* First the old page is erased, and then the new page is put into use.
- * So if a transfer was in progress, the new page will always not yet be
- * marked as in use, since that is the last step to ending a transfer.
- if ( newPg != OSAL_NV_PAGE_NULL )
- /* If there is already a fallow page reserved, keep it and put the newPg in use.
- * An unfinished compaction will finish to the new reserve page and the old page
- * will be erased and reserved.
- if ( pgRes != OSAL_NV_PAGE_NULL )
- setPageUse( newPg, TRUE );
- else if ( oldPg != OSAL_NV_PAGE_NULL )
- pgRes = newPg;
- /* If a page compaction was interrupted and the page being compacted is not
- * yet erased, then there may be items remaining to xfer before erasing.
- if ( oldPg != OSAL_NV_PAGE_NULL )
- compactPage( oldPg );
- /* If no page met the criteria to be the reserve page:
- * - A compactPage() failed or board reset before doing so.
- * - Perhaps the user changed which Flash pages are dedicated to NV and downloaded the code
- * without erasing Flash?
- erasePage( pg );
- initNV();
- return TRUE;
- * @fn setPageUse
- * @brief Set page header active/inUse state according to 'inUse'.
- * @param pg - Valid NV page to verify and init.
- * @param inUse - Boolean TRUE if inUse, FALSE if only active.
- * @return none
- pgHdr.active = OSAL_NV_ZEROED_ID;
- if ( inUse )
- pgHdr.inUse = OSAL_NV_ZEROED_ID;
- else
- pgHdr.inUse = OSAL_NV_ERASED_ID;
- writeWord( pg, OSAL_NV_PAGE_HDR_OFFSET, (uint8*)(&pgHdr) );
- * @fn initPage
- * @brief Walk the page items; calculate checksums, lost bytes & page offset.
- * @param id - Valid NV item Id to use function as a "findItem".
- * If set to NULL then just perform the page initialization.
- * @return If 'id' is non-NULL and good checksums are found, return the offset
- * of the data corresponding to item Id; else OSAL_NV_ITEM_NULL.
- uint16 offset = OSAL_NV_PAGE_HDR_SIZE;
- uint16 sz, lost = 0;
- osalNvHdr_t hdr;
- do
- HalFlashRead(pg, offset, (uint8 *)(&hdr), OSAL_NV_HDR_SIZE);
- if ( hdr.id == OSAL_NV_ERASED_ID )
- break;
- offset += OSAL_NV_HDR_SIZE;
- sz = OSAL_NV_DATA_SIZE( hdr.len );
- // A bad 'len' write has blown away the rest of the page.
- if ( (offset + sz) > OSAL_NV_PAGE_FREE )
- lost += (OSAL_NV_PAGE_FREE - offset + OSAL_NV_HDR_SIZE);
- offset = OSAL_NV_PAGE_FREE;
- break;
- if ( hdr.id != OSAL_NV_ZEROED_ID )
- /* This trick allows function to do double duty for findItem() without
- * compromising its essential functionality at powerup initialization.
- if ( id != OSAL_NV_ITEM_NULL )
- /* This trick allows asking to find the old/transferred item in case
- * of a successful new item write that gets interrupted before the
- * old item can be zeroed out.
- if ( (id & 0x7fff) == hdr.id )
- if ( (((id & OSAL_NV_SOURCE_ID) == 0) && (hdr.stat == OSAL_NV_ERASED_ID)) ||
- (((id & OSAL_NV_SOURCE_ID) != 0) && (hdr.stat != OSAL_NV_ERASED_ID)) )
- return offset;
- // When invoked from the osal_nv_init(), verify checksums and find & zero any duplicates.
- else
- if ( hdr.chk == calcChkF( pg, offset, hdr.len ) )
- if ( findDups )
- if ( hdr.stat == OSAL_NV_ERASED_ID )
- /* The trick of setting the MSB of the item Id causes the logic
- * immediately above to return a valid page only if the header 'stat'
- * indicates that it was the older item being transferred.
- uint16 off = findItem( (hdr.id | OSAL_NV_SOURCE_ID) );
- if ( off != OSAL_NV_ITEM_NULL )
- setItem( findPg, off, eNvZero ); // Mark old duplicate as invalid.
- // Any "old" item immediately exits and triggers the N^2 exhaustive initialization.
- else if ( hdr.stat != OSAL_NV_ERASED_ID )
- return OSAL_NV_ERASED_ID;
- else
- setItem( pg, offset, eNvZero ); // Mark bad checksum as invalid.
- lost += (OSAL_NV_HDR_SIZE + sz);
- else
- offset += sz;
- } while ( TRUE );
- pgOff[pg - OSAL_NV_PAGE_BEG] = offset;
- pgLost[pg - OSAL_NV_PAGE_BEG] = lost;
- return OSAL_NV_ITEM_NULL;
- * @fn erasePage
- * @brief Erases a page in Flash.
- * @param pg - Valid NV page to erase.
- * @return none
- if ( !OSAL_NV_CHECK_BUS_VOLTAGE )
- failF = TRUE;
- return;
- HalFlashErase(pg);
- pgOff[pg - OSAL_NV_PAGE_BEG] = OSAL_NV_PAGE_HDR_SIZE;
- pgLost[pg - OSAL_NV_PAGE_BEG] = 0;
- * @fn compactPage
- * @brief Compacts the page specified.
- * @param srcPg - Valid NV page to erase.
- * @return none
- static void compactPage( uint8 srcPg )
- uint16 dstOff = pgOff[pgRes-OSAL_NV_PAGE_BEG];
- uint16 srcOff = OSAL_NV_ZEROED_ID;
- osalNvHdr_t hdr;
- // Mark page as being in process of compaction.
- writeWordH( srcPg, OSAL_NV_PG_XFER, (uint8*)(&srcOff) );
- srcOff = OSAL_NV_PAGE_HDR_SIZE;
- do
- uint16 sz;
- HalFlashRead(srcPg, srcOff, (uint8 *)(&hdr), OSAL_NV_HDR_SIZE);
- break;
- srcOff += OSAL_NV_HDR_SIZE;
- if ( (srcOff + hdr.len) > OSAL_NV_PAGE_FREE )
- break;
- if ( hdr.chk == calcChkF( srcPg, srcOff, hdr.len ) )
- setItem( srcPg, srcOff, eNvXfer );
- writeBuf( pgRes, dstOff, OSAL_NV_HDR_SIZE, (byte *)(&hdr) );
- dstOff += OSAL_NV_HDR_SIZE;
- xferBuf( srcPg, srcOff, pgRes, dstOff, sz );
- dstOff += sz;
- setItem( srcPg, srcOff, eNvZero ); // Mark old location as invalid.
- srcOff += sz;
- } while ( TRUE );
- pgOff[pgRes-OSAL_NV_PAGE_BEG] = dstOff;
- /* In order to recover from a page compaction that is interrupted,
- * the logic in osal_nv_init() depends upon the following order:
- * 1. Compacted page is erased.
- * 2. State of the target of compaction is changed ePgActive to ePgInUse.
- erasePage( srcPg );
- // Mark the reserve page as being in use.
- setPageUse( pgRes, TRUE );
- // Set the reserve page to be the newly erased page.
- pgRes = srcPg;
- * @fn findItem
- * @brief Find an item Id in NV and return the page and offset to its data.
- * @param id - Valid NV item Id.
- * @return Offset of data corresponding to item Id, if found;
- * otherwise OSAL_NV_ITEM_NULL.
- * The page containing the item, if found;
- * otherwise no valid assignment made - left equal to item Id.
- uint16 off;
- uint8 pg;
- if ( (off = initPage( pg, id, FALSE )) != OSAL_NV_ITEM_NULL )
- findPg = pg;
- return off;
- // Now attempt to find the item as the "old" item of a failed/interrupted NV write.
- if ( (id & OSAL_NV_SOURCE_ID) == 0 )
- return findItem( id | OSAL_NV_SOURCE_ID );
- else
- findPg = OSAL_NV_PAGE_NULL;
- * @fn initItem
- * @brief An NV item is created and initialized with the data passed to the function, if any.
- * @param len - Item data length.
- * @param *buf - Pointer to item initalization data. Set to NULL if none.
- * @return TRUE if item write and read back checksums ok; FALSE otherwise.
- uint16 sz = OSAL_NV_ITEM_SIZE( len );
- uint8 rtrn = FALSE;
- uint8 cnt = OSAL_NV_PAGES_USED;
- uint8 pg = pgRes+1; // Set to 1 after the reserve page to even wear across all available pages.
- uint8 idx = 0;
- do {
- if (pg >= OSAL_NV_PAGE_BEG+OSAL_NV_PAGES_USED)
- pg = OSAL_NV_PAGE_BEG;
- if ( pg != pgRes )
- idx = pg - OSAL_NV_PAGE_BEG;
- if ( (pgOff[idx] - pgLost[idx] + sz) <= OSAL_NV_PAGE_FREE )
- break;
- pg++;
- } while (--cnt);
- if (cnt)
- // Item fits if an old page is compacted.
- if ( (pgOff[idx] + sz) > OSAL_NV_PAGE_FREE )
- pg = pgRes;
- // New item is the first one written to the reserved page, then the old page is compacted.
- rtrn = writeItem( pg, id, len, buf, flag );
- if ( pg == pgRes )
- if ( flag )
- compactPage( OSAL_NV_PAGE_BEG+idx );
- else
- *(uint8 *)buf = OSAL_NV_PAGE_BEG+idx;
- return rtrn;
- * @fn setItem
- * @brief Set an item Id or status to mark its state.
- * @param pg - Valid NV page.
- * @param offset - Valid offset into the page of the item data - the header
- * offset is calculated from this.
- * @param stat - Valid enum value for the item status.
- * @return none
- osalNvHdr_t hdr;
- offset -= OSAL_NV_HDR_SIZE;
- if ( stat == eNvXfer )
- hdr.stat = OSAL_NV_ACTIVE;
- writeWord( pg, offset+OSAL_NV_HDR_CHK, (uint8*)(&(hdr.chk)) );
- else // if ( stat == eNvZero )
- uint16 sz = ((hdr.len + (OSAL_NV_WORD_SIZE-1)) / OSAL_NV_WORD_SIZE) * OSAL_NV_WORD_SIZE +
- OSAL_NV_HDR_SIZE;
- hdr.id = 0;
- writeWord( pg, offset, (uint8 *)(&hdr) );
- pgLost[pg-OSAL_NV_PAGE_BEG] += sz;
- * @fn calcChkB
- * @brief Calculates the data checksum over the 'buf' parameter.
- * @param pg - A valid NV Flash page.
- * @param offset - A valid offset into the page.
- * @param len - Byte count of the data to be checksummed.
- * @return Calculated checksum of the data bytes.
- uint8 fill = len % OSAL_NV_WORD_SIZE;
- uint16 chk;
- if ( !buf )
- chk = len * OSAL_NV_ERASED;
- else
- chk = 0;
- while ( len-- )
- chk += *buf++;
- // calcChkF() will calculate over OSAL_NV_WORD_SIZE alignment.
- if ( fill )
- chk += (OSAL_NV_WORD_SIZE - fill) * OSAL_NV_ERASED;
- return chk;
- * @fn calcChkF
- * @brief Calculates the data checksum by reading the data bytes from NV.
- uint16 chk = 0;
- len = (len + (OSAL_NV_WORD_SIZE-1)) / OSAL_NV_WORD_SIZE;
- while ( len-- )
- uint8 cnt, tmp[OSAL_NV_WORD_SIZE];
- HalFlashRead(pg, offset, tmp, OSAL_NV_WORD_SIZE);
- offset += OSAL_NV_WORD_SIZE;
- for ( cnt = 0; cnt < OSAL_NV_WORD_SIZE; cnt++ )
- chk += tmp[cnt];
- return chk;
- * @fn writeWord
- * @brief Writes a Flash-WORD to NV.
- * @param buf - Pointer to source buffer.
- * @return none
- offset = (offset >> 2) + ((uint16)pg << 9);
- if ( OSAL_NV_CHECK_BUS_VOLTAGE )
- HalFlashWrite(offset, buf, 1);
- else
- failF = TRUE;
- * @fn writeWordM
- * @brief Writes multiple Flash-WORDs to NV.
- * @param cnt - Number of 4-byte blocks to write.
- * @return none
- HalFlashWrite(offset, buf, cnt);
- else
- failF = TRUE;
- * @fn writeWordH
- * @brief Writes the 1st half of a Flash-WORD to NV (filling 2nd half with 0xffff).
- * @return none
- uint8 tmp[4];
- tmp[0] = buf[0];
- tmp[1] = buf[1];
- tmp[2] = OSAL_NV_ERASED;
- tmp[3] = OSAL_NV_ERASED;
- writeWord( pg, offset, tmp );
- * @fn writeBuf
- * @brief Writes a data buffer to NV.
- * @param dstPg - A valid NV Flash page.
- * @param len - Byte count of the data to write.
- * @param buf - The data to write.
- * @return TRUE if data buf checksum matches read back checksum, else FALSE.
- static void writeBuf( uint8 dstPg, uint16 dstOff, uint16 len, uint8 *buf )
- uint8 rem = dstOff % OSAL_NV_WORD_SIZE;
- uint8 tmp[OSAL_NV_WORD_SIZE];
- if ( rem )
- dstOff = (dstOff / OSAL_NV_WORD_SIZE) * OSAL_NV_WORD_SIZE;
- HalFlashRead(dstPg, dstOff, tmp, OSAL_NV_WORD_SIZE);
- while ( (rem < OSAL_NV_WORD_SIZE) && len )
- tmp[rem++] = *buf++;
- len--;
- writeWord( dstPg, dstOff, tmp );
- dstOff += OSAL_NV_WORD_SIZE;
- rem = len % OSAL_NV_WORD_SIZE;
- len /= OSAL_NV_WORD_SIZE;
- if ( len )
- writeWordM( dstPg, dstOff, buf, len );
- dstOff += OSAL_NV_WORD_SIZE * len;
- buf += OSAL_NV_WORD_SIZE * len;
- if ( rem )
- uint8 idx = 0;
- while ( rem-- )
- tmp[idx++] = *buf++;
- * @fn xferBuf
- * @brief Xfers an NV buffer from one location to another, enforcing OSAL_NV_WORD_SIZE writes.
- * @return none
- if ( rem )
- dstOff -= rem;
- HalFlashRead(srcPg, srcOff, tmp+rem, 1);
- srcOff++;
- rem++;
- len--;
- while ( len-- )
- HalFlashRead(srcPg, srcOff, tmp, OSAL_NV_WORD_SIZE);
- srcOff += OSAL_NV_WORD_SIZE;
- if ( rem )
- uint8 idx = 0;
- while ( rem-- )
- HalFlashRead(srcPg, srcOff, tmp+idx, 1);
- srcOff++;
- idx++;
- * @fn writeItem
- * @brief Writes an item header/data combo to the specified NV page.
- * @param pg - Valid NV Flash page.
- * @param buf - The data to write. If NULL, no data/checksum write.
- * @param flag - TRUE if the checksum should be written, FALSE otherwise.
- * @return TRUE if header/data to write matches header/data read back, else FALSE.
- uint16 offset = pgOff[pg-OSAL_NV_PAGE_BEG];
- osalNvHdr_t hdr;
- /* Mark reserve page as being active, in process of receiving items.
- * Invoking function must effect a page compaction.
- setPageUse( pg, FALSE );
- hdr.id = id;
- hdr.len = len;
- writeWord( pg, offset, (uint8 *)&hdr );
- if ( (hdr.id == id) && (hdr.len == len) )
- if ( flag )
- uint16 chk = calcChkB( len, buf );
- if ( buf != NULL )
- writeBuf( pg, offset, len, buf );
- if ( chk == calcChkF( pg, offset, len ) )
- writeWordH(pg, (offset-OSAL_NV_WORD_SIZE), (uint8 *)&chk);
- HalFlashRead(pg, (offset-OSAL_NV_HDR_SIZE), (uint8 *)(&hdr), OSAL_NV_HDR_SIZE);
- if ( chk == hdr.chk )
- rtrn = pg;
- else
- rtrn = pg;
- len = OSAL_NV_ITEM_SIZE( hdr.len );
- pgOff[pg-OSAL_NV_PAGE_BEG] += len;
- return rtrn;
Components.rar
(876.54 KB, 下載次數(shù): 8)
2018-5-12 12:47 上傳
點擊文件名下載附件
下載積分: 黑幣 -5
