查看: 4262|回復(fù): 0
eeprom程序有問題 高手指點(diǎn)
ID:30914 發(fā)表于 2011-9-20 10:02 | 顯示全部樓層 |閱讀模式
eeprom程序(寫0xaa到eeprom在讀出來給流水燈)為什么不論寫啥   只有一個(gè)燈亮  而且是在程序燒進(jìn)去很長時(shí)間
#include <reg52.h>
#include <intrins.h>
#define nop() _nop_()
sbit sclk=P2^0;
sbit sda=P2^1;
char temp;
void delay();
void delay1(uint z);
void init();
void start();
void stop();
void respond();
void write_byte(uchar byte);
uchar read_byte();
void write_eeprom(uchar add,uchar date);
uchar read_eeprom(uchar add);
        init();
        write_eeprom(1,0xaa);
        delay1(100);
        temp=read_eeprom(1);
        P0=temp;
        while(1);
void delay()
        nop();
        nop();
        nop();
        nop();
        nop();
void delay1(uint z)
        uint x,y;
        for(x=z;x>0;x--)
        for(y=123;y>0;y--);
void init()
        sclk=1;
        delay();
        sda=1;
        delay();
void start()
        sda=1;
        delay();
        sclk=1;
        delay();
        sda=0;
        delay();
void stop()
        sda=0;
        delay();
        sclk=1;
        delay();
        sda=1;
        delay();
void respond()
        uchar i;
        sclk=1;
        delay();
        while((sda==1)&&(i<250))i++;
        sclk=0;
        delay();
        uint i;
        uchar temp;
        temp=byte;
        for(i=0;i<8;i--)
                temp=temp<<1;
                sclk=0;
                delay();
                sda=CY;
                delay();
                sclk=1;
                delay();
        sclk=0;
        delay();
        sda=1;
        delay();
uchar read_byte()
        uint i;
        uchar temp;
        temp=0;
        sclk=0;
        delay();
        sda=1;
        delay();
        for(i=0;i<8;i--)
                sclk=1;
                if(sda==1)
                temp=temp|0x01;
                temp=temp<<1;
                sclk=0;
                delay();
        return temp;
        start();
        write_byte(0xa0);
        respond();
        write_byte(add);
        respond();
        write_byte(date);
        respond();
        stop();
        uchar date;
        start();
        write_byte(0xa0);
        respond();
        write_byte(add);
        respond();
        start();
        write_byte(0xa1);
        respond();
        date=read_byte();
        stop();
        return date;
