查看: 4036|回復(fù): 5
單片機(jī)串口通信的程序,memory model設(shè)置成small正常,改成large就出錯
ID:302865 發(fā)表于 2018-5-14 10:02 | 顯示全部樓層 |閱讀模式
想實現(xiàn)電腦發(fā)送數(shù)據(jù),單片機(jī)處理,返回電腦一個數(shù)據(jù)。用keil編譯的時候,memory model 設(shè)置成small,可以通信,但是改成large就不顯示數(shù)據(jù),是什么原因?
單片機(jī)源程序:
  1. #include "reg52.h"
  2. #include "string.h"
  3. #include "stdlib.h"
  4. #include "stdio.h"
  5. #define uchar unsigned char
  6. #define uint unsigned int
  7. unsigned char flag,c;
  8. uchar receivedata[12];
  9. double number1,number2,p;
  10. uint number4,number5,number6,number3;
  11. uchar number[2][4];
  12. uint length,count,i,point,j,k;
  13. uchar senddata[10];
  14. void UsartInit()
  15. {
  16. SCON=0x50;
  17. TMOD=0X20;
  18. PCON=0X80;
  19. TH1=0XF3;
  20. TL0=0XF3;
  21. ES=1;
  22. EA=1;
  23. TR1=1;
  24. }
  25. void Usart() interrupt 4
  26. {
  27. if(RI==1)
  28. {
  29. receivedata[count]=SBUF;
  30. if(receivedata[count]=='=')
  31. {
  32. flag=1;
  33. length=count;
  34. }
  35. count++;
  36. RI=0;
  37. }
  38. }
  39. void main()
  40. {
  41. UsartInit();
  42. while(1)
  43. {
  44. if(flag==1)
  45. {
  46. ES=0;
  47. while(receivedata[i])
  48. {
  49. if(receivedata[i]=='=')
  50. break;
  51. if((receivedata[i]>=48 && receivedata[i]<=57) || receivedata[i]=='.')
  52. {
  53. if(receivedata[i]=='.')
  54. point=1;
  55. number[j][i-k]=receivedata[i];
  56. i++;
  57. }
  58. else
  59. {
  60. i++;
  61. k=i;
  62. j++;
  63. }
  64. }
  65. if(point==1)
  66. {
  67. number1=atof(number[0]);
  68. number2=atof(number[1]);
  69. number3=atoi(number[2]);
  70. if(number3>=20 && number3<38)                //number2>=5  充電時長大于等于5小時
  71. {
  72.   p=number1*0.0365-number2*0.003+0.891;
  73. }
  74. if(number3>=38 && number3<=52)               //number2>=4  充電時長大于等于4小時
  75. {
  76.   p=number1*0.032-number2*0.07+1.226;
  77. }
  78. sprintf(senddata,"%.3f",p);
  79. }
  80. else
  81. {
  82. number4=atoi(number[0]);
  83. number5=atoi(number[1]);
  84. number6=atoi(number[2]);
  85. if(number6>=20 && number6<38)                //number2>=5 充電時長大于等于5小時
  86. {
  87.   p=number4*0.0365-number5*0.003+0.891;
  88. }
  89. if(number6>=38 && number6<=52)               //number2>=4  電時長大于等于4小時
  90. {
  91.   p=number4*0.032-number5*0.07+1.226;
  92. }
  93. sprintf(senddata,"%.3f",p);
  94. }
  95. for(c=0;c<10;c++)
  96. {
  97. SBUF=senddata[c];
  98. while(!TI);
  99. TI=0;
  100. }
  101. ES=1;
  102. flag=0;
  103. }
  104. if(p)
  105. break;
  106. }
  107. }
ID:47286 發(fā)表于 2018-5-14 12:17 | 顯示全部樓層
不是什么原因 是STC片子設(shè)計時的一些設(shè)定 有些片子開什么都行 有些開多一點就不干活了 這和你使用的片子研發(fā)時的定位和考慮有關(guān) 找個能用的方式用就是了 如果你特想了解 看STC給的89c頭文件 里邊有各種內(nèi)存的定義 再去查keil的內(nèi)存設(shè)定 總能找出原因
89c52這么初級的片子基本上就是最基礎(chǔ)的東西 我用11f04e的時候也是設(shè)定稍微超一點就不干活 有一陣用5608多 再用到11f04e的時候特別不習(xí)慣 這不行那不行的
admin + 50 回帖助人的獎勵!
ID:329625 發(fā)表于 2018-5-14 15:28 | 顯示全部樓層
不錯  很喜歡
ID:41347 發(fā)表于 2022-10-14 20:30 | 顯示全部樓層
我也遇到同樣的問題,有解決方案嗎?
ID:883242 發(fā)表于 2022-10-14 23:28 | 顯示全部樓層
small換成large可不是你在這里設(shè)置就能變大的,如果代碼不改,能用到的RAM還會變小。
把不常用的變量盡可能改成xdata屬性才能真正的節(jié)約內(nèi)存。
ID:1034262 發(fā)表于 2022-10-15 12:53 | 顯示全部樓層
如果修改為LARGE,編譯后要保證xdata不溢出。造成運行異常的,多方是因為按KEIL的默認(rèn)方式去訪問,可能會導(dǎo)致形參、實參、指針等等沒對齊所致,跟具體哪家的MCU沒啥關(guān)系。
