硬件平臺:紅牛stm32F103ZE開發(fā)板,DDS模塊:AD9910
軟件版本:Keil 4
固件庫版本:v3.5
完成功能:
(1)產(chǎn)生頻率范圍:1Hz - 400MHz 的正弦波(按鍵觸發(fā)(F = 100KHz,Vpp:500mV):開發(fā)板上 WAKEUP 按鍵)
(2)產(chǎn)生幅度范圍:1mV - 650mV 的正弦波(初始化后:F = 100Hz,Vpp:100mV)
(3)產(chǎn)生上下限頻率、頻率步進(單位:Hz)、步進時間間隔(單位:us;輸入范圍:1-262us)可調(diào)的掃頻波(按鍵觸發(fā)(Fmin = 1KHz,F(xiàn)max = 100KHz,頻率步進:10Hz,步進時間間隔:240us,Vpp:500mV):開發(fā)板上 USER1 按鍵)
(Hardware platform: Red Bull stm32F103ZE development board, DDS module: AD9910. Software version: Keil 4 Firmware library version: v3.5 Complete function: (1) produce frequency range: 1Hz - 400MHz sine wave (keystroke trigger (F = 100KHz, Vpp:500mV): WAKEUP button on development board). (2) the amplitude range is 1mV - 650mV sine wave (initialization: F = 100Hz, Vpp:100mV). (3) generation of upper and lower frequency, frequency step (unit: Hz), step time interval (unit: US; input range: 1-262us) adjustable sweep wave (key trigger (Fmin = 1KHz, Fmax = 100KHz, frequency step: 10Hz, step time interval: 240us, Vpp:500mV): developing the USER1 button on board))
2018-5-14 18:58 上傳
單片機源碼:
- #include "pbdata.h"
- void RCC_Configuration(void);
- //void GPIO_Configuration(void);
- extern uchar cfr2[4]; //cfr2控制字
- int main(void)
- RCC_Configuration();//系統(tǒng)時鐘初始化
- // GPIO_Configuration();//端口時鐘初始化
- delay_init(72);
- Init_ad9910();
- //初始狀態(tài):100Hz,Vpp:100mV
- Freq_convert(300000000); //寫頻率,輸入范圍:1-400 000 000Hz
- Write_Amplitude(150); //寫幅度,輸入范圍:1-650 mV
- while(1)
- if(PAin(0) == 0)
- delay_ms(5);
- cfr2[1] = 0x00; //DRG 失能
- Init_ad9910();
- Write_Amplitude(100); //寫幅度,輸入范圍:1-650 mV
- // if(PAin(8) == 0)
- // delay_ms(5);
- // cfr2[1]=0x0e; //DRG 使能
- // Init_ad9910();
- // Write_Amplitude(500); //寫幅度,輸入范圍:1-650 mV
- // //掃頻波下限頻率,上限頻率,頻率步進(單位:Hz),步進時間間隔(單位:us)
- // SweepFre(1000, 100000, 10, 240); //步進時間范圍:1-262us
- SystemInit();
- // RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE); //使能APB2外設(shè)(GPIOB)時鐘
- void GPIO_Configuration(void)
- GPIO_InitTypeDef GPIO_InitStructure;
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_15;
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
- GPIO_Init(GPIOB, &GPIO_InitStructure);
全部資料51hei下載地址:
DDS v1.0.zip
(301.97 KB, 下載次數(shù): 215)
2018-5-14 11:34 上傳
點擊文件名下載附件
下載積分: 黑幣 -5
