查看: 1617|回復(fù): 2
如何添加串口發(fā)送
ID:329003 發(fā)表于 2018-5-14 22:28 | 顯示全部樓層 |閱讀模式
#include<reg52.h>
#include<intrins.h>
sbit sda=P2^0;
sbit scl=P2^1;
sbit dula=P2^6;
sbit wela=P2^7;
uchar code table[]={
                0x3F,  //"0"
                0x06,  //"1"
                0x5B,  //"2"
                0x4F,  //"3"
                0x66,  //"4"
                0x6D,  //"5"
                0x7D,  //"6"
                0x07,  //"7"
                0x7F,  //"8"
                0x6F,  //"9"
                0x77,  //"A"
                0x7C,  //"B"
                0x39,  //"C"
                0x5E,  //"D"
                0x79,  //"E"
                0x71,  //"F"
void delay()  //5us
void delay1(uint z)//1ms
        uint x,y;
        for(x=z;x>0;x--)
                for(y=120;y>0;y--);
void display(uchar value)
        uchar bai,shi,ge;
        bai=value/100;
        shi=value%100/10;
        ge=value%100%10;
        dula=1;
        P0=table[bai];
        dula=0;
        P0=0xff;
        wela=1;
        P0=0xfe;
        wela=0;
        delay1(1);
        dula=1;
        P0=table[shi];
        dula=0;
        P0=0xff;
        wela=1;
        P0=0xfd;
        wela=0;
        delay1(1);
        dula=1;
        P0=table[ge];
        dula=0;
        P0=0xff;
        wela=1;
        P0=0xfb;
        wela=0;
        delay1(1);
void start()
        scl=1;
        _nop_();
        sda=1;
        delay();
        sda=0;
        delay();
        scl=0;
        _nop_();
void stop()
        scl=1;
        _nop_();
        sda=0;
        delay();
        sda=1;
        delay();
void respons()
        scl=1;
        _nop_();
        sda=0;
        delay();
        scl=0;
        _nop_();
void norespons()
        scl=1;
        _nop_();
        sda=1;
        delay();
void init()
        scl=1;
        _nop_();
        sda=1;
        _nop_();
void write_byte(uchar dat)
        uchar i,temp;
        temp=dat;
        for(i=0;i<8;i++)
                scl=0;
                _nop_();
                if((temp&0x80)==0x80)
                        sda=1;          //д1
                        sda=0;          //д0
                scl=1;
                _nop_();
                temp<<=1;
        scl=0;
        _nop_();
uchar read_byte()
        uchar dat,i;
        sda=1;
        _nop_();
        scl=0;
        _nop_();
        for(i=0;i<8;i++)
                scl=1;
                _nop_();
                if(sda)
                        dat|=0x01;
                if(i<7)
                         dat<<=1;
                scl=0;
                _nop_();
        return dat;
void DAC_write(uchar dat)
        start();
        write_byte(0x90);
        respons();
        write_byte(0x40);
        respons();
        write_byte(dat);
        respons();
        stop();
uchar ADC_read(uchar com)
        uchar dat;
        dat=com;
        start();
        write_byte(0x90);
        respons();
        write_byte(com);
        respons();
        start();
        write_byte(0x91);
        respons();
        dat=read_byte();
        norespons();
        stop();
        return dat;
        uchar i=0,ad_value;
        init();
                ad_value=ADC_read(0x42);
                display(ad_value);
                /*DAC_write(i);
                i++;  */
                delay1(1);
參與人數(shù) 1黑幣 +10 收起 理由
cciejs12345 + 10 贊一個!
ID:213173 發(fā)表于 2018-5-15 07:32 | 顯示全部樓層
        uchar i=0,ad_value;
        init();
        TMOD=0x20;//定時器1方式2(8位重載)
        TH1=0xfd;//定時器1重載
        TL1=0xfd;//定時器1重載
        TR1=1;        //開定時器1
        REN=1;        //允許串行接收
        SM0=0;        //設(shè)置串口方式1(8位UART波特率可變)
        SM1=1;        //設(shè)置串口方式1(8位UART波特率可變)
                SBUF=ad_value;        //發(fā)送數(shù)據(jù)
                while(!TI);        //等待發(fā)送中斷請求標(biāo)志位為1(已發(fā)送)
                TI=0;                //發(fā)送中斷請求標(biāo)志位清0
                display(ad_value);
                /*DAC_write(i);
                i++;  */
                delay1(1);
ID:330198 發(fā)表于 2018-5-15 10:58 | 顯示全部樓層
#include<reg52.h>
#include"stdio.h"
typedef unsigned char uChar8;
typedef unsigned int uInt16;
void SendStr(uChar8  *s);
void InitUART  (void)
    SCON  = 0x50;                        // SCON: 模式 1, 8-bit UART, 使能接收
    TMOD |= 0x20;               // TMOD: timer 1, mode 2, 8-bit 重裝
    TH1   = 0xFD;               // TH1:  重裝值 9600 波特率 晶振 11.0592MHz
    TR1   = 1;                  // TR1:  timer 1 打開
    EA    = 1;                  //打開總中斷
void main (void)
        InitUART();
        while (1)
                SendStr(ad_value);
                delay1(1);
void SendByte(uChar8  dat)
SBUF = dat;
while(!TI);
      TI = 0;
        while(*s!='\0')// \0 表示字符串結(jié)束標(biāo)志,
        //通過檢測是否字符串末尾
                SendByte(*s);
                s++;
