查看: 4880|回復(fù): 0
MSP430F6638單片機(jī)Demo源碼下載
msp4306638系列代碼
MSP430F6638_DemoV3.0.rar (13.2 MB, 下載次數(shù): 35)
源碼列表:
1.LED
10.PortMap
11.Timer_PWM
12.Timer_source
13.Timer_compare
14.Timer_capture
15.LCD_segment
16.MatrixKeyboard_DigitalTube
17.LCD_TFT_String
18.RTC
19.UART_RS232
2.Key_interrupt
20.UART_RS485
21.UART_IrDA
22.IIC_IrfraredThermopile&DigitalTemperature
23.TouchPad_CAP
25.UsbMessStorage
26.UsbMouse
27.SD_WriteRead
28.SD_FAT
29.LowPower
3.Key_debounce
30.ADC_Potentiometer
31.ADC_Record
32.DAC_Wave&Speaker
33.StepperMotor_DCMotor
  1. /**
  2.   ******************************************************************************
  3.   * @文件名 main.c
  4.   * @作者   DY
  5.   * @版本   V3.0
  6.   * @摘要   步進(jìn)電機(jī)測(cè)試程序
  7.   ******************************************************************************
  8.   * @All right reserved.
  9.   */
  10. /* Includes ------------------------------------------------------------------*/
  11. #include <msp430f6638.h>
  12. #include "cd4052.h"
  13. #include "DRV8833.H"
  14. #include "ADC.h"
  15. #include "step_motor.h"
  16. #include "Timer.h"
  17. #include "Segment_LCD.h"
  18. #include "HAL_PMM.H"
  19. #include "HAL_UCS.H"
  20. extern uint16_t results[4];
  21. uint8_t ADC_FLAG = 0;
  22. uint8_t Update = 0; //數(shù)碼管更新標(biāo)志位
  23. uint16_t Pot_ADC_Result = 0 ;
  24. /* Private function prototypes -----------------------------------------------*/
  25. void Up_ClockFor_20MHZ(void);
  26. /* Private functions ---------------------------------------------------------*/
  27. /*!
  28. *函數(shù)功能:主函數(shù)
  29. *輸入?yún)?shù):無(wú)
  30. *輸出參數(shù):無(wú)
  31. *返回值:  無(wú)
  32. */
  33. int main(void)
  34. {
  35.   uint8_t m = 0;
  36.   WDTCTL = WDTPW + WDTHOLD;    // Stop WDT
  37.   Up_ClockFor_20MHZ();         // 時(shí)鐘倍頻到20MHz
  38.   ADC_Init();                  // 初始化電位器
  39.   //LED初始化
  40.   P4DIR |= BIT4+BIT5+BIT6;
  41.   //段式LCD初始化
  42.   Init_TS3A5017DR();       // Configure TS3A5017DR  IN1 and IN2
  43.   Init_lcd();              // LCD初始化
  44.   Backlight_Enable();      // 打開(kāi)背光
  45.   LcdGo(1);                // 打開(kāi)液晶模塊
  46.   LCD_Clear();             // 清屏
  47.   CD4052_Configure();
  48.   Chanel_Configure(STEP_MOTOR);// 通道切換--->Step Motor
  49.   DRV8833_Init();
  50.   Step_nSleep_Enable();        // 步進(jìn)電機(jī)使能
  51.   Step_Timer_Init();           // 配置控制步進(jìn)電機(jī)的定時(shí)器
  52.   TIM_Capture_Config();        // 配置輸入捕獲通道
  53.   TIM_Update_Config();         // 配置定時(shí)器,定時(shí)更新捕獲的數(shù)據(jù)
  54.   __bis_SR_register(GIE);      // 使能中斷
  55.   while(1)
  56.   {
  57.          if(ADC_FLAG == 1)
  58.          {
  59.          for(m = 0 ; m < 4 ; m++)
  60.          {
  61.                  Pot_ADC_Result += results[m];
  62.          }
  63.          Pot_ADC_Result = Pot_ADC_Result >> 2;//0~~4096
  64.          //Set_TA0CCR0(Pot_ADC_Result);
  65.          //TA1CCR0 = Pot_ADC_Result;
  66.          ADC_FLAG = 0;
  67.          }
  68.   }//end while(1)
  69. }
  70. void Up_ClockFor_20MHZ(void)
  71. {
  72.         SetVCore(PMMCOREV_3);                                // Set Vcore to accomodate for max. allowed system speed
  73.         UCSCTL3 |= SELREF_2;                              // Set DCO FLL reference = REFO
  74.         UCSCTL4 |= SELA_2;                                // Set ACLK = REFO
  75.         Init_FLL_Settle(20000, 630);                        // Set system clock to max (20MHz)
  76. }
