之前我的程序能夠讀取AD值,但是會(huì)跳動(dòng),而且初始的電壓不是0V,現(xiàn)在我程序修改以后,它是穩(wěn)定了,讀不了AD了是怎么回事?只能讀到0.01V?
- #include "reg52.h"
- #include "intrins.h"
- typedef unsigned char uchar;
- typedef unsigned int uint;
- #define _Nop() _nop_()
- /*------------------------以下為L(zhǎng)CD1602顯示模塊定義-----------------------*/
- unsigned char data_char_table[]= {"0123456789ABCDEF"}; //LCD數(shù)據(jù)
- unsigned char Lcd_Dis1_table[] = {"Position:No. "}; //第一行顯示框架
- unsigned char pos_char_table[] = {" D "}; // 顯示位置
- unsigned char Lcd_Dis2_table[] = {"Voltage : V"}; //第二行顯示框架
- unsigned char num_char_table[] = {" 9A.CD V"}; // 顯示位置
- sbit lcd_rs_port = P2^4; //定義LCD控制端口,根據(jù)硬件調(diào)整
- sbit lcd_rw_port = P2^3;
- sbit lcd_en_port = P2^2;
- #define lcd_data_port P0
- void lcd_delay(uchar ms); //LCD1602 延時(shí)
- void lcd_busy_wait(); //LCD1602 忙等待
- void lcd_command_write(uint command); //LCD1602 命令字寫(xiě)入
- void lcd_system_reset(); //LCD1602 初始化
- void lcd_char_write(uint x_pos,y_pos,lcd_dat); //LCD1602 字符寫(xiě)入
- void lcd_bad_check(); //LCD1602 壞點(diǎn)檢查
- void Num_to_Disp(uchar i, uint Num); //顯示數(shù)據(jù)處理
- void LcdDisp(uchar j, uint num); //液晶顯示函數(shù)
- /*------------------------以下為ADC相應(yīng)寄存器初始化及端口定義-------------*/
- /***** 定義與ADC相關(guān)的特殊功能寄存器 *****/
- sfr ADC_CONTR = 0xBC; //ADC控制寄存器
- sfr ADC_RES = 0xBD; //ADC hight 8-bit result register
- sfr ADC_RESL = 0xBE; //ADC low 2-bit result register
- sfr P1ASF = 0x9D; //P1口功能控制寄存器P1ASF
- sfr P1M0 = 0x92; //I/O模式寄存器
- sfr P1M1 = 0x91; //I/O模式寄存器
- /************定義相應(yīng)操作位***************/
- #define ADC_POWER 0x80 //ADC電源控制位,0:關(guān)閉,1:打開(kāi)
- #define ADC_FLAG 0x10 //ADC結(jié)束標(biāo)志位
- #define ADC_START 0x08 //ADC啟動(dòng)控制位
- #define ADC_SPEEDLL 0x00 //540 clocks___________選擇轉(zhuǎn)換速度
- /*------------------------以下為相關(guān)函數(shù)聲明------------------------------*/
- void InitADC(); //ADC初始化
- uint GetADCResult(uchar ch);
- void Delay(uint n); //延時(shí)程序
- void delay_1ms(uchar x);
- /*-------------------------------- ADC 取值 ------------------------------*/
- uint GetADCResult(uchar channel)
- ADC_CONTR=0x88|channel; //開(kāi)啟AD轉(zhuǎn)換1000 1000 即POWER SPEED1 SPEED0 ADC_FLAG ADC_START CHS2 CHS1 CHS0
- _nop_(); _nop_(); _nop_(); _nop_();//要經(jīng)過(guò)4個(gè)CPU時(shí)鐘的延時(shí),其值才能夠保證被設(shè)置進(jìn)ADC_CONTR 寄存器
- // ADC_RES=0xdf;
- // ADC_RESL=0xef;
- while(!(ADC_CONTR&0x10)); //等待轉(zhuǎn)換完成
- ADC_CONTR&=0xe7; //關(guān)閉AD轉(zhuǎn)換,ADC_FLAG位由軟件清0
- return(ADC_RES*4+ADC_RESL); //返回AD轉(zhuǎn)換完成的10位數(shù)據(jù)(16進(jìn)制)
- /*---------------------------- 初始化ADC特殊功能寄存器 -------------------*/
- void InitADC( )
- P1ASF = P1 | 0x3f; //Set P1.0 - P1.5 as analog input port
- ADC_RES = 0; //Clear previous result
- ADC_RESL = 0;
- ADC_CONTR = ADC_POWER | ADC_SPEEDLL ;
- Delay(20); //ADC power-on delay and Start A/D conversion
- /*---------------------------- LCD1602相應(yīng)函數(shù) ---------------------------*/
- ///////////////以下為L(zhǎng)CD顯示數(shù)據(jù)處理/////////////////
- float NUM;
- int xx, yy, zz;
- NUM =(Num * 5/ 1024.0); //計(jì)算公式:10-bit A/D Conversion Result = 1024 x (Vin / Vcc)
- xx = (int)NUM;
- yy = (int)((NUM - (float)(xx)) * 10);
- zz = (int)((NUM - (float)(xx)) * 100)%10;
- num_char_table[9] = data_char_table[xx / 10]; //電壓值十位
- num_char_table[10]= data_char_table[xx % 10]; //電壓值個(gè)位
- num_char_table[12]= data_char_table[yy]; //電壓值小數(shù)點(diǎn)后一位
- num_char_table[13]= data_char_table[zz]; //電壓值小數(shù)點(diǎn)后兩位?
- pos_char_table[13]= data_char_table[i]; //當(dāng)前ADC接口
- //////////////////以下為L(zhǎng)CD顯示////////////////////
- uint i=0;
- for (i=0;i<16;i++)
- lcd_char_write(i,0,Lcd_Dis1_table[i]);
- lcd_char_write(i,1,Lcd_Dis2_table[i]); //顯示框架
- Num_to_Disp(j, num);
- lcd_char_write(13,0,pos_char_table[13]);
- for(i = 9; i < 14; i++)
- lcd_char_write(i,1,num_char_table[i]); //顯示電壓
- delay_1ms(100);
- //////////////以下是LCD1602驅(qū)動(dòng)程序////////////////
- void lcd_delay(uchar ms) /*LCD1602 延時(shí)*/
- uchar j;
- while(ms--){
- for(j=0;j<250;j++)
- void lcd_busy_wait() /*LCD1602 忙等待*/
- lcd_rs_port = 0;
- lcd_rw_port = 1;
- lcd_en_port = 1;
- lcd_data_port = 0xff;
- while (lcd_data_port&0x80);
- lcd_en_port = 0;
- void lcd_command_write(uint command) /*LCD1602 命令字寫(xiě)入*/
- lcd_busy_wait();
- lcd_rs_port = 0;
- lcd_rw_port = 0;
- lcd_en_port = 0;
- lcd_data_port = command;
- lcd_en_port = 1;
- lcd_en_port = 0;
- void lcd_system_reset() /*LCD1602 初始化*/
- lcd_delay(20);
- lcd_command_write(0x38);
- lcd_delay(100);
- lcd_delay(50);
- lcd_delay(10);
- lcd_command_write(0x08);
- lcd_command_write(0x01);
- lcd_command_write(0x06);
- lcd_command_write(0x0c);
- void lcd_char_write(uint x_pos,y_pos,lcd_dat) /*LCD1602 字符寫(xiě)入*/
- x_pos &= 0x0f; /* X位置范圍 0~15 */
- y_pos &= 0x01; /* Y位置范圍 0~ 1 */
- if(y_pos==1) x_pos += 0x40;
- x_pos += 0x80;
- lcd_command_write(x_pos);
- lcd_busy_wait();
- lcd_rs_port = 1;
- lcd_rw_port = 0;
- lcd_en_port = 0;
- lcd_data_port = lcd_dat;
- lcd_en_port = 1;
- lcd_en_port = 0;
- void lcd_bad_check() /*LCD1602 壞點(diǎn)檢查*/
- char i,j;
- for(i=0;i<2;i++){
- for(j=0;j<16;j++) {
- lcd_char_write(j,i,0xff);
- lcd_delay(200);
- lcd_delay(200);
- lcd_delay(200);
- lcd_delay(100);
- lcd_delay(200);
- lcd_command_write(0x01); /* clear lcd disp */
- //////////////////以上是LCD1602驅(qū)動(dòng)程序////////////////
- /*----------------------------- 延時(shí)程序 ---------------------------*/
- uint x;
- while (n--)
- x = 500;
- while (x--);
- /*1MS為單位的延時(shí)程序*/
- uchar j;
- while(x--)
- for(j=0;j<125;j++)
- 函數(shù): averageValueVolgate()
- 用途: 求多次采集電壓平均值
- 傳入?yún)?shù):chan是端口號(hào)
- 返回值:Val_Av是多次采樣的電壓值平均值
- float averageValueVolgate(uchar chan)
- float voltageValue=0;
- uchar num;
- for(num=100;num>0;num--)
- voltageValue+=GetADCResult(chan);
- voltageValue/=100.0;
- voltageValue=voltageValue*5.0/1024;
- return (voltageValue);
- /*-------------------------------- 主函數(shù) --------------------------------*/
- void main()
- uchar i;
- lcd_system_reset(); //LCD1602 初始化
- lcd_bad_check(); //LCD1602 壞點(diǎn)檢查
- InitADC(); //初始化ADC特殊功能寄存器
- // P1M1 = 0xFF; //P1.0/P1.5高阻 0011 1111
- // P1M0 = 0x00; //P1.0/P1.5高阻 0000 0000
- while (1)
- i = 0;
- LcdDisp(i,averageValueVolgate(0)); //液晶1602顯示第3通道電壓值
- Delay(1000);
